path: root/drivers/target
2012-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull target updates from Nicholas Bellinger: "It has been a very busy development cycle this time around in target land, with the highlights including: - Kill struct se_subsystem_dev, in favor of direct se_device usage (hch) - Simplify reservations code by combining SPC-3 + SCSI-2 support for virtual backends only (hch) - Simplify ALUA code for virtual only backends, and remove left over abstractions (hch) - Pass sense_reason_t as return value for I/O submission path (hch) - Refactor MODE_SENSE emulation to allow for easier addition of new mode pages. (roland) - Add emulation of MODE_SELECT (roland) - Fix bug in handling of ExpStatSN wrap-around (steve) - Fix bug in TMR ABORT_TASK lookup in qla2xxx target (steve) - Add WRITE_SAME w/ UNMAP=0 support for IBLOCK backends (nab) - Convert ib_srpt to use modern target_submit_cmd caller + drop legacy ioctx->kref usage (nab) - Convert ib_srpt to use modern target_submit_tmr caller (nab) - Add link_magic for fabric allow_link destination target_items for symlinks within target_core_fabric_configfs.c code (nab) - Allocate pointers in instead of full structs for config_group->default_groups (sebastian) - Fix 32-bit highmem breakage for FILEIO (sebastian) All told, hch was able to shave off another ~1K LOC by killing the se_subsystem_dev abstraction, along with a number of PR + ALUA simplifications. Also, a nice patch by Roland is the refactoring of MODE_SENSE handling, along with the addition of initial MODE_SELECT emulation support for virtual backends. Sebastian found a long-standing issue wrt to allocation of full config_group instead of pointers for config_group->default_group[] setup in a number of areas, which ends up saving memory with big configurations. He also managed to fix another long-standing BUG wrt to broken 32-bit highmem support within the FILEIO backend driver. Thank you again to everyone who contributed this round!" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (50 commits) target/iscsi_target: Add NodeACL tags for initiator group support target/tcm_fc: fix the lockdep warning due to inconsistent lock state sbp-target: fix error path in sbp_make_tpg() sbp-target: use simple assignment in tgt_agent_rw_agent_state() iscsi-target: use kstrdup() for iscsi_param target/file: merge fd_do_readv() and fd_do_writev() target/file: Fix 32-bit highmem breakage for SGL -> iovec mapping target: Add link_magic for fabric allow_link destination target_items ib_srpt: Convert TMR path to target_submit_tmr ib_srpt: Convert I/O path to target_submit_cmd + drop legacy ioctx->kref target: Make spc_get_write_same_sectors return sector_t target/configfs: use kmalloc() instead of kzalloc() for default groups target/configfs: allocate only 6 slots for dev_cg->default_groups target/configfs: allocate pointers instead of full struct for default_groups target: update error handling for sbc_setup_write_same() iscsit: use GFP_ATOMIC under spin lock iscsi_target: Remove redundant null check before kfree target/iblock: Forward declare bio helpers target: Clean up flow in transport_check_aborted_status() target: Clean up logic in transport_put_cmd() ...
2012-12-13target/iscsi_target: Add NodeACL tags for initiator group supportAndy Grover
Thanks for reviews, looking a lot better. ---- 8< ---- Initiator access config could be easier. The way other storage vendors have addressed this is to support initiator groups: the admin adds initiator WWNs to the group, and then LUN permissions can be granted for the entire group at once. Instead of changing ktarget's configfs interface, this patch keeps the configfs interface per-initiator-wwn and just adds a 'tag' field for each. This should be enough for user tools like targetcli to group initiator ACLs and sync their configurations. acl_tag is not used internally, but needs to be kept in configfs so that all user tools can avoid dependencies on each other. Code tested to work, although userspace pieces still to be implemented. Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12target/tcm_fc: fix the lockdep warning due to inconsistent lock stateYi Zou
The lockdep warning below is in theory correct but it will be in really weird rare situation that ends up that deadlock since the tcm fc session is hashed based the rport id. Nonetheless, the complaining below is about rcu callback that does the transport_deregister_session() is happening in softirq, where transport_register_session() that happens earlier is not. This triggers the lockdep warning below. So, just fix this to make lockdep happy by disabling the soft irq before calling transport_register_session() in ft_prli. BTW, this was found in FCoE VN2VN over two VMs, couple of create and destroy would get this triggered. v1: was enforcing register to be in softirq context which was not righ. See, http://www.spinics.net/lists/target-devel/msg03614.html v2: following comments from Roland&Nick (thanks), it seems we don't have to do transport_deregister_session() in rcu callback, so move it into ft_sess_free() but still do kfree() of the corresponding ft_sess struct in rcu callback to make sure the ft_sess is not freed till the rcu callback. ... [ 1328.370592] scsi2 : FCoE Driver [ 1328.383429] fcoe: No FDMI support. [ 1328.384509] host2: libfc: Link up on port (000000) [ 1328.934229] host2: Assigned Port ID 00a292 [ 1357.232132] host2: rport 00a393: Remove port [ 1357.232568] host2: rport 00a393: Port sending LOGO from Ready state [ 1357.233692] host2: rport 00a393: Delete port [ 1357.234472] host2: rport 00a393: work event 3 [ 1357.234969] host2: rport 00a393: callback ev 3 [ 1357.235979] host2: rport 00a393: Received a LOGO response closed [ 1357.236706] host2: rport 00a393: work delete [ 1357.237481] [ 1357.237631] ================================= [ 1357.238064] [ INFO: inconsistent lock state ] [ 1357.238450] 3.7.0-rc7-yikvm+ #3 Tainted: G O [ 1357.238450] --------------------------------- [ 1357.238450] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. [ 1357.238450] ksoftirqd/0/3 [HC0[0]:SC1[1]:HE0:SE0] takes: [ 1357.238450] (&(&se_tpg->session_lock)->rlock){+.?...}, at: [<ffffffffa01eacd4>] transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] {SOFTIRQ-ON-W} state was registered at: [ 1357.238450] [<ffffffff810834f5>] mark_held_locks+0x6d/0x95 [ 1357.238450] [<ffffffff8108364a>] trace_hardirqs_on_caller+0x12d/0x197 [ 1357.238450] [<ffffffff810836c1>] trace_hardirqs_on+0xd/0xf [ 1357.238450] [<ffffffff8149caba>] _raw_spin_unlock_irq+0x2d/0x45 [ 1357.238450] [<ffffffffa01e8d10>] __transport_register_session+0xb8/0x122 [target_core_mod] [ 1357.238450] [<ffffffffa01e8dbe>] transport_register_session+0x44/0x5a [target_core_mod] [ 1357.238450] [<ffffffffa018e32c>] ft_prli+0x1e3/0x275 [tcm_fc] [ 1357.238450] [<ffffffffa0160e8d>] fc_rport_recv_req+0x95e/0xdc5 [libfc] [ 1357.238450] [<ffffffffa015be88>] fc_lport_recv_els_req+0xc4/0xd5 [libfc] [ 1357.238450] [<ffffffffa015c778>] fc_lport_recv_req+0x12f/0x18f [libfc] [ 1357.238450] [<ffffffffa015a6d7>] fc_exch_recv+0x8ba/0x981 [libfc] [ 1357.238450] [<ffffffffa0176d7a>] fcoe_percpu_receive_thread+0x47a/0x4e2 [fcoe] [ 1357.238450] [<ffffffff810549f1>] kthread+0xb1/0xb9 [ 1357.238450] [<ffffffff814a40ec>] ret_from_fork+0x7c/0xb0 [ 1357.238450] irq event stamp: 275411 [ 1357.238450] hardirqs last enabled at (275410): [<ffffffff810bb6a0>] rcu_process_callbacks+0x229/0x42a [ 1357.238450] hardirqs last disabled at (275411): [<ffffffff8149c2f7>] _raw_spin_lock_irqsave+0x22/0x8e [ 1357.238450] softirqs last enabled at (275394): [<ffffffff8103d669>] __do_softirq+0x246/0x26f [ 1357.238450] softirqs last disabled at (275399): [<ffffffff8103d6bb>] run_ksoftirqd+0x29/0x62 [ 1357.238450] [ 1357.238450] other info that might help us debug this: [ 1357.238450] Possible unsafe locking scenario: [ 1357.238450] [ 1357.238450] CPU0 [ 1357.238450] ---- [ 1357.238450] lock(&(&se_tpg->session_lock)->rlock); [ 1357.238450] <Interrupt> [ 1357.238450] lock(&(&se_tpg->session_lock)->rlock); [ 1357.238450] [ 1357.238450] *** DEADLOCK *** [ 1357.238450] [ 1357.238450] no locks held by ksoftirqd/0/3. [ 1357.238450] [ 1357.238450] stack backtrace: [ 1357.238450] Pid: 3, comm: ksoftirqd/0 Tainted: G O 3.7.0-rc7-yikvm+ #3 [ 1357.238450] Call Trace: [ 1357.238450] [<ffffffff8149399a>] print_usage_bug+0x1f5/0x206 [ 1357.238450] [<ffffffff8100da59>] ? save_stack_trace+0x2c/0x49 [ 1357.238450] [<ffffffff81082aae>] ? print_irq_inversion_bug.part.14+0x1ae/0x1ae [ 1357.238450] [<ffffffff81083336>] mark_lock+0x106/0x258 [ 1357.238450] [<ffffffff81084e34>] __lock_acquire+0x2e7/0xe53 [ 1357.238450] [<ffffffff8102903d>] ? pvclock_clocksource_read+0x48/0xb4 [ 1357.238450] [<ffffffff810ba6a3>] ? rcu_process_gp_end+0xc0/0xc9 [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff81085ef1>] lock_acquire+0x119/0x143 [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff8149c329>] _raw_spin_lock_irqsave+0x54/0x8e [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffffa01eacd4>] transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff810bb6a0>] ? rcu_process_callbacks+0x229/0x42a [ 1357.238450] [<ffffffffa018ddc5>] ft_sess_rcu_free+0x17/0x24 [tcm_fc] [ 1357.238450] [<ffffffffa018ddae>] ? ft_sess_free+0x1b/0x1b [tcm_fc] [ 1357.238450] [<ffffffff810bb6d7>] rcu_process_callbacks+0x260/0x42a [ 1357.238450] [<ffffffff8103d55d>] __do_softirq+0x13a/0x26f [ 1357.238450] [<ffffffff8149b34e>] ? __schedule+0x65f/0x68e [ 1357.238450] [<ffffffff8103d6bb>] run_ksoftirqd+0x29/0x62 [ 1357.238450] [<ffffffff8105c83c>] smpboot_thread_fn+0x1a5/0x1aa [ 1357.238450] [<ffffffff8105c697>] ? smpboot_unregister_percpu_thread+0x47/0x47 [ 1357.238450] [<ffffffff810549f1>] kthread+0xb1/0xb9 [ 1357.238450] [<ffffffff8149b49d>] ? wait_for_common+0xbb/0x10a [ 1357.238450] [<ffffffff81054940>] ? __init_kthread_worker+0x59/0x59 [ 1357.238450] [<ffffffff814a40ec>] ret_from_fork+0x7c/0xb0 [ 1357.238450] [<ffffffff81054940>] ? __init_kthread_worker+0x59/0x59 [ 1417.440099] rport-2:0-0: blocked FC remote port time out: removing rport Signed-off-by: Yi Zou <yi.zou@intel.com> Cc: Open-FCoE <devel@open-fcoe.org> Cc: Nicholas A. Bellinger <nab@risingtidesystems.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-12sbp-target: fix error path in sbp_make_tpg()Chris Boot
If the TPG memory is allocated successfully, but we fail further along in the function, a dangling pointer to freed memory is left in the TPort structure. This is mostly harmless, but does prevent re-trying the operation without first removing the TPort altogether. Reported-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Chris Boot <bootc@bootc.net> Cc: Andy Grover <agrover@redhat.com> Cc: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-12sbp-target: use simple assignment in tgt_agent_rw_agent_state()Chris Boot
There is no need to memcpy() a 32-bit integer. The data pointer is guaranteed to be quadlet aligned by the FireWire stack so we can replace the memcpy() with an assignment. Thanks to Stefan Richter. Signed-off-by: Chris Boot <bootc@bootc.net> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Andy Grover <agrover@redhat.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-07iscsi-target: use kstrdup() for iscsi_paramSebastian Andrzej Siewior
The kmalloc() + strlen() + memcpy() block is what kstrdup() does as well. While here I also removed the "to NULL assignment" of pointers which are fed to kfree or thrown away anyway. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-05target/file: merge fd_do_readv() and fd_do_writev()Sebastian Andrzej Siewior
Those two functions are almost identical so merge them. Noticed this while fixing the highmem in both cases. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-05target/file: Fix 32-bit highmem breakage for SGL -> iovec mappingSebastian Andrzej Siewior
This patch changes vectored file I/O to use kmap + kunmap when mapping incoming SGL memory -> struct iovec in order to properly support 32-bit highmem configurations. This is because an extra bounce buffer may be required when processing scatterlist pages allocated with GFP_KERNEL. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-12-05target: Add link_magic for fabric allow_link destination target_itemsNicholas Bellinger
This patch adds [dev,lun]_link_magic value assignment + checks within generic target_fabric_port_link() and target_fabric_mappedlun_link() code to ensure destination config_item *target_item sent from configfs_symlink() -> config_item_operations->allow_link() is the underlying se_device->dev_group and se_lun->lun_group that we expect to symlink. Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target: Make spc_get_write_same_sectors return sector_tNicholas Bellinger
We already expect TFO->get_blocks() to return sector_t for zero value case when doing WRITE_SAME to the end of the backend device, so go ahead and return sector_t from spc_get_write_same_sectors() to handle this case properly. Also, update the single iblock_execute_write_same() caller of this code. Cc: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target/configfs: use kmalloc() instead of kzalloc() for default groupsSebastian Andrzej Siewior
All elements are assigned even the NULL member at the end so there is no reason to allocate zeroed memory. (nab: Fix up minor apply breakage in for-next) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target/configfs: allocate only 6 slots for dev_cg->default_groupsSebastian Andrzej Siewior
Only slots 0-5 are used so 6 slots should be enough. I don't see anyone writting anything else than NULL into ->default_groups[5] so a "late" initialisation should not happen here. (nab: Fix up minor apply breakage in for-next) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target/configfs: allocate pointers instead of full struct for default_groupsSebastian Andrzej Siewior
default_groups is defined as struct config_group **default_groups so we don't need to allocate a whole struct but only enough space for a pointer that points there. (nab: Fix up minor apply breakage in for-next) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target: update error handling for sbc_setup_write_same()Dan Carpenter
We recently changed this to return positive subsystem error codes so the error handling needs to be updated. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27iscsit: use GFP_ATOMIC under spin lockWei Yongjun
The function iscsit_build_conn_drop_async_message() is called from iscsit_close_connection() with spin lock 'sess->conn_lock' held, so we should use GFP_ATOMIC instead of GFP_KERNEL. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27iscsi_target: Remove redundant null check before kfreeSachin Kamat
kfree on null pointer is a no-op. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target/iblock: Forward declare bio helpersNicholas Bellinger
Go ahead and forward declare the handful of helper functions required for bio submission code in order to avoid the extra function prototypes. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-27target: Clean up flow in transport_check_aborted_status()Roland Dreier
Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
2012-11-27target: Clean up logic in transport_put_cmd()Roland Dreier
No need to have a goto where a return is clearer. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
2012-11-27target: Update copyright information to 2012Nicholas Bellinger
v2: Use correct target_core_stat.c 2006 copyright year v3: Drop extra unnessary legal verbage from header (hch) Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-19target: iscsi: fix comment typos in target/iscsi driversMasanari Iida
Correct spelling typo in printk and comment within target/iscsi drivers Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-17target: Fix handling of aborted commandsRoland Dreier
- If we stop processing an already-aborted command in target_execute_cmd(), then we need to complete t_transport_stop_comp to wake up the the TMR handling thread, or else it will end up waiting forever. - If we've a already sent an "aborted" status for a command in transport_check_aborted_status() then we should bail out of transport_send_task_abort() to avoid freeing the command twice. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
2012-11-15target/iblock: Add WRITE_SAME w/ UNMAP=0 emulation supportNicholas Bellinger
This patch adds support for emulation of WRITE_SAME w/ UNMAP=0 within iblock_execute_write_same() backend code. The emulation uses a bio_add_page() call for each sector, and by default enforces a limit of max_write_same_len=0xFFFF (65536) sectors following what scsi_debug reports per default for MAXIMUM WRITE SAME LENGTH. It also sets max_write_same_len to the operational default at setup -> iblock_configure_device() time. (hch: Move unmap logic into iblock_execute_write_same_unmap + add check for single sector SGLs in iblock_execute_write_same) (mkp: Update comment for 0xFFFF magic constant) (nab: drop left-over max_write_same_len check in iblock_execute_write_same) Cc: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-15target: Add/check max_write_same_len device attribute + update block limits VPDNicholas Bellinger
This patch adds a new max_write_same_len device attribute for use with WRITE_SAME w/ UNMAP=0 backend emulation. This can be useful for lowering the default backend value (IBLOCK uses 0xFFFF). Also, update block limits VPD emulation code in spc_emulate_evpd_b0() to report MAXIMUM WRITE SAME LENGTH, and enforce max_write_same_len during sbc_parse() -> sbc_setup_write_same() CDB sanity checking for all emulated WRITE_SAME w/ UNMAP=0 cases. (Robert: Move max_write_same_len check in sbc_setup_write_same() to check both WRITE_SAME w/ UNMAP=1 and w/ UNMAP=0 cases) Cc: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Robert Elliott <Elliott@hp.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-15target/sbc: Seperate WRITE_SAME based on UNMAP flag in sbc_opsNicholas Bellinger
This patch adds a new sbc_ops->execute_write_same_unmap() caller for use with WRITE_SAME w/ UNMAP=1, and performs the ->execute_cmd() setup based this bit within sbc_setup_write_same() code. Also, makes the changes in sbc_parse_cdb() to handle a sense_reason_t return from sbc_setup_write_same() on error. Reported-by: Christoph Hellwig <hch@lst.de> Cc: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07target: Change sbc_emulate_noop to return sense_reason_tNicholas Bellinger
As reported by Fengguang Wu + 0 day build team, the sense_reason_t conversion in for-next did not catch the recent sbc_emulate_noop() addition in mainline, producing the following build warning in auto-next: drivers/target/target_core_sbc.c: In function ‘sbc_parse_cdb’: drivers/target/target_core_sbc.c:555: warning: assignment from incompatible pointer type Go ahead and remove duplicate sbc_emulate_verify(), and change VERIFY to use sbc_emulate_noop() as well. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07sbp-target: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Chris Boot <bootc@bootc.net> CC: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07iscsi-target: Always send a response before terminating iSCSI connectionRoland Dreier
There are some cases, for example when the initiator sends an out-of-bounds ErrorRecoveryLevel value, where the iSCSI target terminates the connection without sending back any error. Audit the login path and add appropriate iscsit_tx_login_rsp() calls to make sure this doesn't happen. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07iscsi-target: Fix bug in handling of ExpStatSN ACK during u32 wrap-aroundSteve Hodgson
This patch fixes a bug in the hanlding of initiator provided ExpStatSN and individual iscsi_cmd->stat_sn comparision during iscsi_conn->stat_sn wrap-around within iscsit_ack_from_expstatsn() code. This bug would manifest itself as iscsi_cmd descriptors not being Acked by a lower ExpStatSn, causing them to be leaked until an iSCSI connection or session reinstatement event occurs to release all commands. Also fix up two other uses of incorrect CmdSN SNA comparison to use wrapper usage from include/scsi/iscsi_proto.h. Signed-off-by: Steve Hodgson <steve@purestorage.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07iscsi-target: Fix potential deadlock on lock taken in timerRoland Dreier
We need to disable BHs when taking sess_idr_lock because the iscsit_handle_time2retain_timeout() timer function takes se_tpg->session_lock, and iscsit_close_session() nests sess_idr_lock inside se_tpg->session_lock. So if the timer can run inside sess_idr_lock, we have a potential AB-BA deadlock. Fix this by disabling BHs when taking sess_idr_lock. This was found because of a lockdep warning, but it looks like a real (if highly theoretical) deadlock. In any case avoiding lockdep spew so that we can find other issues is a worthy cause. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07target: Fix exception path pr_reg put regression for PR RELEASENicholas Bellinger
Fix a regression bug in core_scsi3_emulate_pro_release() where should still be getting released via core_scsi3_put_pr_reg() during No persistent reservation, with returing GOOD status. Use goto statement here to follow converted code from hch. Cc: Christoph Hellwig <hch@lst.de> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-07target: Fix possible TFO->write_pending() sense_reason_t silent WRITE corruptionNicholas Bellinger
This patch fixes a possible case in transport_generic_new_cmd() where a failure from TFO->write_pending() from a fabric module return something other than -EAGAIN or -ENOMEM would cause a failed WRITE to silently succeed. Go ahead and return TCM_LOGICAL_UNIT_COMMUNICATION_FAILURE for this special case instead of only just making noise with WARN_ON(). (v2: Fix incorrect exception return for all cases) Cc: Christoph Hellwig <hch@lst.de> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: Fix incorrect inversion of TPGS_EXPLICT_ALUA checkNicholas Bellinger
Fix a bug introduced with patch "target: pass sense_reason as a return value" in for-3.8 code where only target port groups with TPGS_EXPLICT_ALUA set need to be allowed to perform explictly ALUA. Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: pass sense_reason as a return valueChristoph Hellwig
Pass the sense reason as an explicit return value from the I/O submission path instead of storing it in struct se_cmd and using negative return values. This cleans up a lot of the code pathes, and with the sparse annotations for the new sense_reason_t type allows for much better error checking. (nab: Convert spc_emulate_modesense + spc_emulate_modeselect to use sense_reason_t with Roland's MODE SELECT changes) Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: Fix incorrect starting offset after MODE_SENSE refactoringNicholas Bellinger
This patch fixes a new off-by-one bug in the hardcoded starting offset of spc_emulate_modesense() code that causes BLOCK DESCRIPTOR to be incorrectly written within the MEDIUM TYPE buffer area of the mode parameter header. According to spc4r30, Section 7.5.4, BLOCK DESCRIPTOR for MODE_SENSE_10 starts at byte 3, and BLOCK_DESCRIPTOR for MODE_SENSE (6) starts at byte 2. (roland: add MODE DATA LENGTH + MEDIUM TYPE offset comment) Cc: Roland Dreier <roland@purestorage.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: Add emulation for MODE SELECTRoland Dreier
This is another thing that compliance tests try, and it's easy to implement on top of the MODE SENSE refactoring; since we don't claim to support any changeable values, all we need to do is check that the page contents sent by the initiator match what we would return. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: Implement mode page 0x1c, "Informational Exceptions"Roland Dreier
The Windows SCSI compliance test asks for this mode page, and it's easy to implement: we can just return all 0s to show we don't support any of these features. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: Refactor MODE SENSE emulationRoland Dreier
Convert spc_emulate_modesense() to use a table of mode pages, rather than a switch statement. This makes it possible to add more pages sanely -- in particular we no longer need to make sure we keep the 0x3f (return all mode pages) case in sync. While we're touching this code, make our MODE SENSE emulation a bit better in a couple of ways: - When the initiator passes PC == 1 asking for changeable values, return all 0s to show we don't support setting anything. - Return a block descriptor for disk devices. (nab: fix up device attribute references to use dev->dev_attrib in for-next code) Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06iscsi-target: Use list_first_entry() where appropriateRoland Dreier
Instead of using the obfuscated pattern of list_for_each_entry(var, list, ...) break; to set var to the first entry of a list, use the straightforward var = list_first_entry(list, ...); Reported-by: Joern Engel <joern@logfs.org> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: remove ->get_device_revChristoph Hellwig
Now that the reservations and ALUA code have been cleaned up there is no need for the get_device_rev method, as we only need the standards revision in the inquiry data, where we can hardcode it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: simplify alua supportChristoph Hellwig
We always support ALUA for virtual backends, and never for physical ones. Simplify the code to just deal with these two cases and remove the superflous abstractions. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: simplify reservations codeChristoph Hellwig
We do not support host-level reservations for the pscsi backend, and all virtual backends are newere than SCSI-2, so just make the combined SPC-3 + SCSI-2 support the only supported variant and kill the switches for the different implementations, given that this code handles the no-op version just fine. (hch: Update DRF_SPC2_RESERVATIONS lock usage) Signed-off-by: Christoph Hellwig <hch@lst.de>
2012-11-06target: kill dev->dev_task_attr_typeChristoph Hellwig
We can just key off ordered tag emulation of the transport_type field. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06pscsi: fix REPORT LUNS handlingChristoph Hellwig
We need to assign spc_emulate_report_luns to the execute_cmd callback and not execute it directly. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target/pscsi: Make pscsi_configure_device + target_release_session staticFengguang Wu
drivers/target/target_core_pscsi.c:464:5: sparse: symbol 'pscsi_configure_device' was not declared. Should it be static? FYI, there are new sparse warnings show up in tree: git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending.git queue head: 738b86ac5e56c645aa5b7bf49cb38e2a04c665f8 commit: 410aeee637c47bcf7e8dd7893347fe0811e07ab1 [47/51] target: kill struct se_subsystem_dev vim +464 drivers/target/target_core_pscsi.c 410aeee6 Christoph Hellwig 2012-10-08 @464 int pscsi_configure_device(struct se_device *dev) c66ac9db Nicholas Bellinger 2010-12-17 465 { 410aeee6 Christoph Hellwig 2012-10-08 466 struct se_hba *hba = dev->se_hba; 410aeee6 Christoph Hellwig 2012-10-08 467 struct pscsi_dev_virt *pdv = PSCSI_DEV(dev); c66ac9db Nicholas Bellinger 2010-12-17 468 struct scsi_device *sd; 410aeee6 Christoph Hellwig 2012-10-08 469 struct pscsi_hba_virt *phv = dev->se_hba->hba_ptr; c66ac9db Nicholas Bellinger 2010-12-17 470 struct Scsi_Host *sh = phv->phv_lld_host; c66ac9db Nicholas Bellinger 2010-12-17 471 int legacy_mode_enable = 0; 410aeee6 Christoph Hellwig 2012-10-08 472 int ret; Please consider folding the attached diff :-) Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: provide generic sbc device type/revision helpersChristoph Hellwig
2012-11-06target/pscsi: call spc_emulate_report_luns directlyChristoph Hellwig
No need to indirect through spc_parse_cdb if we only ever call it for REPORT LUNS emulation. (nab: Add missing EXPORT_SYMBOL for spc_emulate_report_luns) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-06target: move REPORT LUNS emulation to target_core_spc.cChristoph Hellwig
2012-11-06target: rename spc_opsChristoph Hellwig
These really are sbc_ops, so name them correctly. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
