path: root/drivers/tc
2018-11-13TC: Set DMA masks for devicesMaciej W. Rozycki
commit 3f2aa244ee1a0d17ed5b6c86564d2c1b24d1c96b upstream. Fix a TURBOchannel support regression with commit 205e1b7f51e4 ("dma-mapping: warn when there is no coherent_dma_mask") that caused coherent DMA allocations to produce a warning such as: defxx: v1.11 2014/07/01 Lawrence V. Stefani and others tc1: DEFTA at MMIO addr = 0x1e900000, IRQ = 20, Hardware addr = 08-00-2b-a3-a3-29 ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at ./include/linux/dma-mapping.h:516 dfx_dev_register+0x670/0x678 Modules linked in: CPU: 0 PID: 1 Comm: swapper Not tainted 4.19.0-rc6 #2 Stack : ffffffff8009ffc0 fffffffffffffec0 0000000000000000 ffffffff80647650 0000000000000000 0000000000000000 ffffffff806f5f80 ffffffffffffffff 0000000000000000 0000000000000000 0000000000000001 ffffffff8065d4e8 98000000031b6300 ffffffff80563478 ffffffff805685b0 ffffffffffffffff 0000000000000000 ffffffff805d6720 0000000000000204 ffffffff80388df8 0000000000000000 0000000000000009 ffffffff8053efd0 ffffffff806657d0 0000000000000000 ffffffff803177f8 0000000000000000 ffffffff806d0000 9800000003078000 980000000307b9e0 000000001e900000 ffffffff80067940 0000000000000000 ffffffff805d6720 0000000000000204 ffffffff80388df8 ffffffff805176c0 ffffffff8004dc78 0000000000000000 ffffffff80067940 ... Call Trace: [<ffffffff8004dc78>] show_stack+0xa0/0x130 [<ffffffff80067940>] __warn+0x128/0x170 ---[ end trace b1d1e094f67f3bb2 ]--- This is because the TURBOchannel bus driver fails to set the coherent DMA mask for devices enumerated. Set the regular and coherent DMA masks for TURBOchannel devices then, observing that the bus protocol supports a 34-bit (16GiB) DMA address space, by interpreting the value presented in the address cycle across the 32 `ad' lines as a 32-bit word rather than byte address[1]. The architectural size of the TURBOchannel DMA address space exceeds the maximum amount of RAM any actual TURBOchannel system in existence may have, hence both masks are the same. This removes the warning shown above. References: [1] "TURBOchannel Hardware Specification", EK-369AA-OD-007B, Digital Equipment Corporation, January 1993, Section "DMA", pp. 1-15 -- 1-17 Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Paul Burton <paul.burton@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/20835/ Fixes: 205e1b7f51e4 ("dma-mapping: warn when there is no coherent_dma_mask") Cc: stable@vger.kernel.org # 4.16+ Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-24TC: Error handling clean-upsMaciej W. Rozycki
Rewrite TURBOchannel error handling to use a common failure path, making sure put_device is called for devices that failed initialization. While at it update printk calls to use pr_err rather than KERN_ERR. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6701/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26TC: Handle device_register() errors.Levente Kurusa
Make the TURBOchannel driver bail out if the call to device_register() failed. Signed-off-by: Levente Kurusa <levex@linux.com> Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: LKML <linux-kernel@vger.kernel.org> Cc: Linux MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/6673/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-24tc: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: macro@linux-mips.org Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2007-10-17lk201: remove obsolete driverMaciej W. Rozycki
Remove the old-fashioned lk201 driver under drivers/tc/ that used to be used by the old dz.c and zs.c drivers, which is now orphan code referred to from nowhere and does not build anymore. A modern replacement is available as drivers/input/keyboard/lkkbd.c. There are no plans to do anything about this piece of code and it does not fit anywhere anymore, so it is not just a matter of maintenance or the lack of. There are still some bits that might be added to the new lkkbd.c driver based on the old code, and the embedded hardware documentation which is otherwise quite hard to get hold of might be useful to keep too. Both of these can be done separately though. RIP. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17unicode diacritics supportSamuel Thibault
There have been issues with non-latin1 diacritics and unicode. http://bugzilla.kernel.org/show_bug.cgi?id=7746 Git 759448f459234bfcf34b82471f0dba77a9aca498 `Kernel utf-8 handling' partly resolved it by adding conversion between diacritics and unicode. The patch below goes further by just turning diacritics into unicode, hence providing better future support. The kbd support can be fetched from http://bugzilla.kernel.org/attachment.cgi?id=12313 This was tested in all of latin1, latin9, latin2 and unicode with french and czech dead keys. Turn the kernel accent_table into unicode, and extend ioctls KDGKBDIACR and KDSKBDIACR into their equivalents KDGKBDIACRUC and KDSKBDIACR. New function int conv_uni_to_8bit(u32 uni) for converting unicode into 8bit _input_. No, we don't want to store the translation, as it is potentially sparse and large. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jan Engelhardt <jengelh@gmx.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18zs: move to the serial subsystemMaciej W. Rozycki
This is a reimplementation of the zs driver for the serial subsystem. Any resemblance to the old driver is purely coincidential. ;-) I do hope I got the handling of modem lines right -- better do not tackle me about the issue unless you feel too good... Any users of the old driver: please note the numbers of the serial lines have now been swapped, i.e. ttyS0 <-> ttyS1 and ttyS2 <-> ttyS3. It has to do with the modem lines mentioned above; basically the port A in a given chip has to be initialised before the port B if you want to use the latter as the serial console (which is usually the case), as operations on modem lines of the serial line associated with the port B access both ports (see the comment at the top of the driver for the details of wiring used). Please update your scripts. This is also the reason each SCC now requests an IRQ once only (as seen in "/proc/interrupts") -- the handler takes care of both ports at once as the line associated with the port B has to take status update interrupts from both ports (and yet the line of the port A takes its own for itself too). The old driver never got it right... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12[MIPS] DEC: Fix modpost warning.Ralf Baechle
LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map MODPOST vmlinux WARNING: drivers/built-in.o(.data+0x2480): Section mismatch: reference to .init.text: (between 'sercons' and 'ds_parms') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12Revert "[MIPS] DEC: Fix modpost warning."Ralf Baechle
This reverts commit 8713762acf341edea9d25d6a4817f235c67bc004.
2007-07-10[MIPS] DEC: Fix modpost warning.Ralf Baechle
2007-06-08potential parse error in ifdef part 3Yoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-04[PATCH] Fix build error on zs serial driverYoichi Yuasa
drivers/tc/zs.c:73:24: error: asm/dec/tc.h: No such file or directory Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[TC] MIPS: TURBOchannel resources off-by-one fixMaciej W. Rozycki
Fix resource reservation of TURBOchannel areas, where the end is one byte too far. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-09[TC] MIPS: TURBOchannel update to the driver modelMaciej W. Rozycki
This is a set of changes to convert support for the TURBOchannel bus to the driver model. It implements the usual set of calls similar to what other bus drivers have: tc_register_driver(), tc_unregister_driver(), etc. All the platform-specific bits have been removed and headers from asm-mips/dec/ have been merged into linux/tc.h, which should be included by drivers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08[MIPS] Fix DECserial build error by IRQ hander changeYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] kill _INLINE_Adrian Bunk
This patch removes all occurances of _INLINE_ in the kernel. With the exception of tty_flip.h, I've simply removed the inline's since gcc should know best which functions to be inlined. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2005-11-17[MIPS] zs.c: Resurrect the deceased zs.c for now.Maciej W. Rozycki
Not that it's meant to be sustained for long, but from time to time it's useful to have some console... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Add .gitignore files for TurbochannelRalf Baechle
2005-10-29Use physical addresses at the interface level, letting drivers remapMaciej W. Rozycki
them as appropriate. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Remove left-over unused bits.Maciej W. Rozycki
2005-10-29Fix function types to ones appropriate for initcalls.Maciej W. Rozycki
2005-10-29Deal with the bloody KSEG vs CKSEG horror...Maciej W. Rozycki
2005-09-13[PATCH] Remove unnecessary check_region references in commentsPeter Osterlund
Remove check_region references from comments and printk statements so that searching for real users of this deprecated function gets easier. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
