path: root/drivers/telephony/Kconfig
2007-10-12kconfig: syntax cleanup - drop support for "depends/requires/def_boolean"Adrian Bunk
Remove the following redundant and never or rarely used kconfig syntax: - "def_boolean" (same as "def_bool") - "requires" (same as "depends on") - "depends" (same as "depends on") This patch contains the code changes and Kconfig updates. The shipped files are in next patch to let actual codechange stand out. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17mark a bunch of ISA|EISA|PCI drivers as suchAl Viro
2007-07-16Use menuconfig objects II - TelephonyJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
