1.Avoiding system wrong reboot caused by error temperature without
cancel_delayed_work before entering into suspend,so to cancel
thermal_zone_device temperature polling temperature delayed_work
before entering into suspend, reenable polling temperature delayed_work
after entering into resume.
2.In anatop_thermal_suspend, turn off alarm firstly
Signed-off-by: Rong Dian <b38775@freescale.com>
1.Common code of thermal_sys has some bug,could
not set the mode via sysfs using echo enable/disabled
command;
2.Since the anatop thermal formula still not accurate,
in order to help test and adjust the trip point of
anatop thermal zone, we add the set trip point temp
value into the sysfs interface.
Signed-off-by: Anson Huang <b20788@freescale.com>
This patch fixes two minor bugs in thermal_sys:
(a) The flow of goto's in thermal_hwmon_add_sysfs.
(b) Remove the temp*_crit only if there is a get_crit_temp defined, in
thermal_remove_hwmon_sysfs.
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Several ACPI drivers fail to build if CONFIG_NET is unset, because
they refer to things depending on CONFIG_THERMAL that in turn depends
on CONFIG_NET. However, CONFIG_THERMAL doesn't really need to depend
on CONFIG_NET, because the only part of it requiring CONFIG_NET is
the netlink interface in thermal_sys.c.
Put the netlink interface in thermal_sys.c under #ifdef CONFIG_NET
and remove the dependency of CONFIG_THERMAL on CONFIG_NET from
drivers/thermal/Kconfig.
Cc: Len Brown <lenb@kernel.org>
Cc: Luming Yu <luming.yu@intel.com>
This patch adds event notification support to the generic
thermal sysfs framework in the kernel. The notification is in the
form of a netlink event.
Signed-off-by: R.Durgadoss <durgadoss.r@intel.com>
And while touching that function definition do something about the disaster
of formatting there.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Initialize sysfs attributes before device_create_file call.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15548
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <len.brown@intel.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
state is unsigned long so the test did not work.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Otherwise polling will continue for the thermal zone even when
it is no longer needed, for example because forced passive cooling
was disabled.
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Matthew Garrett <mjg@redhat.com>
Setting polling_delay is useless as passive_delay has priority,
so the value shown in proc isn't the actual polling delay. It
also gives the impression to the user that he can change the
polling interval through proc, while in fact he can't.
Also, unset passive_delay when the forced passive trip point is
unbound to allow polling to be disabled.
Values below 1000 milli-celsius don't make sense and can cause the
system to go into a thermal heart attack: the actual temperature
will always be lower and thus the system will be throttled down to
its lowest setting.
An additional problem is that values below 1000 will show as 0 in
/proc/acpi/thermal/TZx/trip_points:passive.
cat passive
0
echo -n 90 >passive
bash: echo: write error: Invalid argument
echo -n 90000 >passive
cat passive
90000
Make the trip_point_N_type sysfs files return a string ending in EOL for
consistency with other sysfs files.
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
Otherwise THERMAL_HWMON can be selected when HWMON=n and THERMAL=n, which
fails to build.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Matthew Garrett <mjg@redhat.com>
The return value of the get_temp function is not checked when doing a
thermal zone update. This may lead to a critical shutdown if get_temp
fails and the content of the temp variable is incorrectly set higher than
the critical trip point.
This has been observed on a system with incorrect ACPI implementation
where the corresponding methods were not serialized and therefore
sometimes triggered ACPI errors (AE_ALREADY_EXISTS). The following
critical shutdowns indicated a temperature of 2097 C, which was obviously
wrong.
The patch adds a return value check that jumps over all trip point
evaluations printing a warning if get_temp fails. The trip points are
evaluated again on the next polling interval with successful get_temp
execution.
Signed-off-by: Michael Brunner <mibru@gmx.de>
In the near future, the driver core is going to not allow direct access
to the driver_data pointer in struct device. Instead, the functions
dev_get_drvdata() and dev_set_drvdata() should be used. These functions
have been around since the beginning, so are backwards compatible with
all older kernel versions.
This patch fixes a regression caused by commit
b1569e99c795bf83b4ddf41c4f1c42761ab7f75e
"ACPI: move thermal trip handling to generic thermal layer"
which accidentally changed trip point trigger condition to
temp > trip_temp
This patch changes the trigger condition back to
temp >= trip_temp
Signed-off-by: Vladimir Zajac <eightgraph@gmail.com>
Due to poor thermal design or Linux driving hardware outside its thermal
envelope, some systems will reach critical temperature and shut down
under high load. This patch adds support for forcing a polling-based
passive trip point if the firmware doesn't provide one. The assumption
is made that the processor is the most practical means to reduce the
dynamic heat generation, so hitting the passive thermal limit will cause
the CPU to be throttled until the temperature stabalises around the
defined value.
UI is provided via a "passive" sysfs entry in the thermal zone
directory. It accepts a decimal value in millidegrees celsius, or "0" to
disable the functionality. Default behaviour is for this functionality
to be disabled.
The ACPI code currently carries its own thermal trip handling, meaning that
any other thermal implementation will need to reimplement it. Move the code
to the generic thermal layer.
The thermal API currently uses strings to pass values to userspace. This
makes it difficult to use from within the kernel. Change the interface
to use integers and fix up the consumers.
Acked-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
A bug in libsensors <= 2.10.6 is exposed
when this new hwmon I/F is enabled.
Create CONFIG_THERMAL_HWMON=n
until some time after libsensors 2.10.7 ships
so those users can run the latest kernel.
libsensors 3.x is already fixed -- those users
can use CONFIG_THERMAL_HWMON=y now.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Acked-by: Mark M. Hoffman <mhoffman@lightlink.com>
thermal_sys was already the name of the resulting module,
and it is built from this one source file.
Add hwmon sys I/F for generic thermal driver.
Note: we have one hwmon class device for EACH TYPE of the thermal zone device.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Build the generic thermal driver as module "thermal_sys".
Make ACPI thermal, video, processor and fan SELECT the generic
thermal driver, as these drivers rely on it to build the sysfs I/F.
The THERMAL_MAX_TRIPS value is set to 10. It is too few for the Compaq AP550
machine which has 12 trip points.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
The generic thermal I/F gets selected by ACPI_THERMAL --
its only current customer.
it doesn't need to clutter other configs by default.
This reverts commit 3152fb9f11cdd2fd8688c2c5cb805e5c09b53dd9.
This broke libsensors.
Need to return using ERR_PTR instead of NULL
in case of errors.
Signed-off-by: Thomas Sujith <sujith.thomas@intel.com>
Added sanity check to make sure that thermal zone
and cooling device exists.
Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
The Generic Thermal sysfs driver for thermal management.
