path: root/drivers/thermal
2015-10-01thermal: avoid division by zero in power allocatorAndrea Arcangeli
During boot I get a div by zero Oops regression starting in v4.3-rc3. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Javi Merino <javi.merino@arm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-20thermal: power_allocator: exit early if there are no cooling devicesJavi Merino
Don't waste cycles in the power allocator governor's throttle function if there are no cooling devices and exit early. This commit doesn't change any functionality, but should provide better performance for the odd case of a thermal zone with trip points but without cooling devices. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-14thermal: power_allocator: don't require tzp to be present for the thermal zoneJavi Merino
Thermal zones created using thermal_zone_device_create() may not have tzp. As the governor gets its parameters from there, allocate it while the governor is bound to the thermal zone so that it can operate in it. In this case, tzp is freed when the thermal zone switches to another governor. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-14thermal: power_allocator: relax the requirement of two passive trip pointsJavi Merino
The power allocator governor currently requires that the thermal zone has at least two passive trip points. If there aren't, the governor refuses to bind to the thermal zone. This commit relaxes that requirement. Now the governor will bind to all thermal zones regardless of how many trip points they have. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-14thermal: power_allocator: relax the requirement of a sustainable_power in tzpJavi Merino
The power allocator governor currently requires that a sustainable power is passed as part of the thermal zone's thermal zone parameters. If that parameter is not provided, it doesn't register with the thermal zone. While this parameter is strongly recommended for optimal performance, it doesn't need to be mandatory. Relax the requirement and allow the governor to bind to thermal zones that don't provide it by estimating it from the cooling devices' power model. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-14thermal: Add a function to get the minimum powerJavi Merino
The thermal core already has a function to get the maximum power of a cooling device: power_actor_get_max_power(). Add a function to get the minimum power of a cooling device. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: cpu_cooling: free power table on error or when unregisteringJavi Merino
The power table is not being freed on error from cpufreq_cooling register or when unregistering. Free it. Fixes: c36cf0717631 ("thermal: cpu_cooling: implement the power cooling device API") Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: cpu_cooling: don't call kcalloc() under rcu_read_lockJavi Merino
build_dyn_power_table() allocates the power table while holding rcu_read_lock. kcalloc using GFP_KERNEL may sleep, so it can't be called in an RCU read-side path. Move the rcu protection to the part of the function that really needs it: the part that handles the dev_pm_opp pointer received from dev_pm_opp_find_freq_ceil(). In the unlikely case that there is an OPP added to the cpu while this function is running, return -EAGAIN. Fixes: c36cf0717631 ("thermal: cpu_cooling: implement the power cooling device API") Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: db8500_cpufreq_cooling: Fix module autoload for OF platform driverLuis de Bethencourt
This platform driver has a OF device ID table but the OF module alias information is not created so module autoloading won't work. Signed-off-by: Luis de Bethencourt <luis@debethencourt.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: ti-soc: Kconfig fix to avoid menu showing wronglyEduardo Valentin
Move the dependencies to menu, so we avoid showing it wrongly. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: ti-soc: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to ti-soc driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: qcom_spmi: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to qcom_spmi driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: exynos: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to exynos driver to facilitate maintenance. Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: armada: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to armada driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: dove: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to dove driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: kirkwood: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to kirkwood driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: rockchip: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to rockchip driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: linux-pm@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-rockchip@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: spear: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to spear driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-13thermal: hisi: allow compile testEduardo Valentin
Adding COMPILE_TEST flag to hisi driver to facilitate maintenance. Cc: Zhang Rui <rui.zhang@intel.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-09-11thermal: fix intel PCH thermal driver mismergeLinus Torvalds
I didn't notice this when merging the thermal code from Zhang, but his merge (commit 5a924a07f882: "Merge branches 'thermal-core' and 'thermal-intel' of .git into next") of the thermal-core and thermal-intel branches was wrong. In thermal-core, commit 17e8351a7739 ("thermal: consistently use int for temperatures") converted the thermal layer to use "int" for temperatures. But in parallel, in the thermal-intel branch commit d0a12625d2ff ("thermal: Add Intel PCH thermal driver") added support for the intel PCH thermal sensor using the old interfaces that used "unsigned long" pointers. This resulted in warnings like this: drivers/thermal/intel_pch_thermal.c:184:14: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] .get_temp = pch_thermal_get_temp, ^ drivers/thermal/intel_pch_thermal.c:184:14: note: (near initialization for ‘tzd_ops.get_temp’) drivers/thermal/intel_pch_thermal.c:186:19: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] .get_trip_temp = pch_get_trip_temp, ^ drivers/thermal/intel_pch_thermal.c:186:19: note: (near initialization for ‘tzd_ops.get_trip_temp’) This fixes it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal updates from Zhang Rui: - use int instead of unsigned long to represent temperature to avoid bogus overheat detection when negative temperature reported. From Sascha Hauer. - export available thermal governors information to user space via sysfs. From Wei Ni. - introduce new thermal driver for Wildcat Point platform controller hub, which uses PCH thermal sensor and associated critical and hot trip points. From Tushar Dave. - add suuport for Intel Skylake and Denlow platforms in powerclamp driver. - some small cleanups in thermal core. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: thermal: Add Intel PCH thermal driver thermal: Add comment explaining test for critical temperature thermal: Use IS_ENABLED instead of #ifdef thermal: remove unnecessary call to thermal_zone_device_set_polling thermal: trivial: fix typo in comment thermal: consistently use int for temperatures thermal: add available policies sysfs attribute thermal/powerclamp: add cpu id for denlow platform thermal/powerclamp: add cpu id for Skylake u/y thermal/powerclamp: add cpu id for skylake h/s
2015-09-08Merge tag 'regmap-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "This has been a busy release for regmap. By far the biggest set of changes here are those from Markus Pargmann which implement support for block transfers in smbus devices. This required quite a bit of refactoring but leaves us better able to handle odd restrictions that controllers may have and with better performance on smbus. Other new features include: - Fix interactions with lockdep for nested regmaps (eg, when a device using regmap is connected to a bus where the bus controller has a separate regmap). Lockdep's default class identification is too crude to work without help. - Support for must write bitfield operations, useful for operations which require writing a bit to trigger them from Kuniori Morimoto. - Support for delaying during register patch application from Nariman Poushin. - Support for overriding cache state via the debugfs implementation from Richard Fitzgerald" * tag 'regmap-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (25 commits) regmap: fix a NULL pointer dereference in __regmap_init regmap: Support bulk reads for devices without raw formatting regmap-i2c: Add smbus i2c block support regmap: Add raw_write/read checks for max_raw_write/read sizes regmap: regmap max_raw_read/write getter functions regmap: Introduce max_raw_read/write for regmap_bulk_read/write regmap: Add missing comments about struct regmap_bus regmap: No multi_write support if bus->write does not exist regmap: Split use_single_rw internally into use_single_read/write regmap: Fix regmap_bulk_write for bus writes regmap: regmap_raw_read return error on !bus->read regulator: core: Print at debug level on debugfs creation failure regmap: Fix regmap_can_raw_write check regmap: fix typos in regmap.c regmap: Fix integertypes for register address and value regmap: Move documentation to regmap.h regmap: Use different lockdep class for each regmap init call thermal: sti: Add parentheses around bridge->ops->regmap_init call mfd: vexpress: Add parentheses around bridge->ops->regmap_init call regmap: debugfs: Fix misuse of IS_ENABLED ...
2015-09-04Merge remote-tracking branches 'regmap/topic/lockdep' and ↵Mark Brown
'regmap/topic/seq-delay' into regmap-next
2015-09-02Merge branches 'thermal-core' and 'thermal-intel' of .git into nextZhang Rui
2015-09-01Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm changes from Ingo Molnar: "The biggest changes in this cycle were: - Revamp, simplify (and in some cases fix) Time Stamp Counter (TSC) primitives. (Andy Lutomirski) - Add new, comprehensible entry and exit handlers written in C. (Andy Lutomirski) - vm86 mode cleanups and fixes. (Brian Gerst) - 32-bit compat code cleanups. (Brian Gerst) The amount of simplification in low level assembly code is already palpable: arch/x86/entry/entry_32.S | 130 +---- arch/x86/entry/entry_64.S | 197 ++----- but more simplifications are planned. There's also the usual laudry mix of low level changes - see the changelog for details" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (83 commits) x86/asm: Drop repeated macro of X86_EFLAGS_AC definition x86/asm/msr: Make wrmsrl() a function x86/asm/delay: Introduce an MWAITX-based delay with a configurable timer x86/asm: Add MONITORX/MWAITX instruction support x86/traps: Weaken context tracking entry assertions x86/asm/tsc: Add rdtscll() merge helper selftests/x86: Add syscall_nt selftest selftests/x86: Disable sigreturn_64 x86/vdso: Emit a GNU hash x86/entry: Remove do_notify_resume(), syscall_trace_leave(), and their TIF masks x86/entry/32: Migrate to C exit path x86/entry/32: Remove 32-bit syscall audit optimizations x86/vm86: Rename vm86->v86flags and v86mask x86/vm86: Rename vm86->vm86_info to user_vm86 x86/vm86: Clean up vm86.h includes x86/vm86: Move the vm86 IRQ definitions to vm86.h x86/vm86: Use the normal pt_regs area for vm86 x86/vm86: Eliminate 'struct kernel_vm86_struct' x86/vm86: Move fields from 'struct kernel_vm86_struct' to 'struct vm86' x86/vm86: Move vm86 fields out of 'thread_struct' ...
2015-08-29thermal: power_allocator: allocate with kcalloc what you free with kfreeJavi Merino
Commit cf736ea6f902 ("thermal: power_allocator: do not use devm* interfaces") forgot to change a devm_kcalloc() to just kcalloc(), but it's corresponding devm_kfree() was changed to kfree(). Allocate with kcalloc() to match the kfree(). Fixes: cf736ea6f902 ("thermal: power_allocator: do not use devm* interfaces") Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-18Merge branch 'x86/urgent' into x86/asm to fix up conflicts and to pick up fixesIngo Molnar
Conflicts: arch/x86/entry/entry_64_compat.S arch/x86/math-emu/get_address.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-14thermal/cpu_cooling: update policy limits if clipped_freq < policy->maxViresh Kumar
policy->max is the maximum allowed frequency defined by user and clipped_freq is the maximum that thermal constraints allow. If clipped_freq is lower than policy->max, then we need to readjust policy->max. But, if clipped_freq is greater than policy->max, we don't need to do anything. We used to call cpufreq_verify_within_limits() in this case, but it doesn't change anything in this case. Lets skip this unnecessary call and write a comment that explains this. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-14thermal/cpu_cooling: rename max_freq as clipped_freq in notifierViresh Kumar
That's what it is for, lets name it properly. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-14thermal/cpu_cooling: rename cpufreq_val as clipped_freqViresh Kumar
2015-08-14thermal/cpu_cooling: convert 'switch' block to 'if' block in notifierViresh Kumar
We just need to take care of single event here and there is no need to increase indentation level of most of the code (which causes lines longer that 80 columns to break). Kill the switch block. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-14thermal/cpu_cooling: quit early after updating policyViresh Kumar
If a valid cpufreq_dev is found for policy->cpu, we should update the policy and quit the for loop. There is no need to keep traversing the list of cpufreq_dev's. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-14thermal/cpu_cooling: No need to initialize max_freq to 0Viresh Kumar
Its always set before getting used, don't initialize it. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-14thermal: cpu_cooling: fix lockdep problems in cpu_coolingRussell King
A recent change to the cpu_cooling code introduced a AB-BA deadlock scenario between the cpufreq_policy_notifier_list rwsem and the cooling_cpufreq_lock. This is caused by cooling_cpufreq_lock being held before the registration/removal of the notifier block (an operation which takes the rwsem), and the notifier code itself which takes the locks in the reverse order: ====================================================== [ INFO: possible circular locking dependency detected ] 3.18.0+ #1453 Not tainted ------------------------------------------------------- rc.local/770 is trying to acquire lock: (cooling_cpufreq_lock){+.+.+.}, at: [<c04abfc4>] cpufreq_thermal_notifier+0x34/0xfc but task is already holding lock: ((cpufreq_policy_notifier_list).rwsem){++++.+}, at: [<c0042f04>] __blocking_notifier_call_chain+0x34/0x68 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 ((cpufreq_policy_notifier_list).rwsem){++++.+}: [<c06bc3b0>] down_write+0x44/0x9c [<c0043444>] blocking_notifier_chain_register+0x28/0xd8 [<c04ad610>] cpufreq_register_notifier+0x68/0x90 [<c04abe4c>] __cpufreq_cooling_register.part.1+0x120/0x180 [<c04abf44>] __cpufreq_cooling_register+0x98/0xa4 [<c04abf8c>] cpufreq_cooling_register+0x18/0x1c [<bf0046f8>] imx_thermal_probe+0x1c0/0x470 [imx_thermal] [<c037cef8>] platform_drv_probe+0x50/0xac [<c037b710>] driver_probe_device+0x114/0x234 [<c037b8cc>] __driver_attach+0x9c/0xa0 [<c0379d68>] bus_for_each_dev+0x5c/0x90 [<c037b204>] driver_attach+0x24/0x28 [<c037ae7c>] bus_add_driver+0xe0/0x1d8 [<c037c0cc>] driver_register+0x80/0xfc [<c037cd80>] __platform_driver_register+0x50/0x64 [<bf007018>] 0xbf007018 [<c0008a5c>] do_one_initcall+0x88/0x1d8 [<c0095da4>] load_module+0x1768/0x1ef8 [<c0096614>] SyS_init_module+0xe0/0xf4 [<c000ec00>] ret_fast_syscall+0x0/0x48 -> #0 (cooling_cpufreq_lock){+.+.+.}: [<c00619f8>] lock_acquire+0xb0/0x124 [<c06ba3b4>] mutex_lock_nested+0x5c/0x3d8 [<c04abfc4>] cpufreq_thermal_notifier+0x34/0xfc [<c0042bf4>] notifier_call_chain+0x4c/0x8c [<c0042f20>] __blocking_notifier_call_chain+0x50/0x68 [<c0042f58>] blocking_notifier_call_chain+0x20/0x28 [<c04ae62c>] cpufreq_set_policy+0x7c/0x1d0 [<c04af3cc>] store_scaling_governor+0x74/0x9c [<c04ad418>] store+0x90/0xc0 [<c0175384>] sysfs_kf_write+0x54/0x58 [<c01746b4>] kernfs_fop_write+0xdc/0x190 [<c010dcc0>] vfs_write+0xac/0x1b4 [<c010dfec>] SyS_write+0x44/0x90 [<c000ec00>] ret_fast_syscall+0x0/0x48 other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock((cpufreq_policy_notifier_list).rwsem); lock(cooling_cpufreq_lock); lock((cpufreq_policy_notifier_list).rwsem); lock(cooling_cpufreq_lock); *** DEADLOCK *** 7 locks held by rc.local/770: #0: (sb_writers#6){.+.+.+}, at: [<c010dda0>] vfs_write+0x18c/0x1b4 #1: (&of->mutex){+.+.+.}, at: [<c0174678>] kernfs_fop_write+0xa0/0x190 #2: (s_active#52){.+.+.+}, at: [<c0174680>] kernfs_fop_write+0xa8/0x190 #3: (cpu_hotplug.lock){++++++}, at: [<c0026a60>] get_online_cpus+0x34/0x90 #4: (cpufreq_rwsem){.+.+.+}, at: [<c04ad3e0>] store+0x58/0xc0 #5: (&policy->rwsem){+.+.+.}, at: [<c04ad3f8>] store+0x70/0xc0 #6: ((cpufreq_policy_notifier_list).rwsem){++++.+}, at: [<c0042f04>] __blocking_notifier_call_chain+0x34/0x68 stack backtrace: CPU: 0 PID: 770 Comm: rc.local Not tainted 3.18.0+ #1453 Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree) Backtrace: [<c00121c8>] (dump_backtrace) from [<c0012360>] (show_stack+0x18/0x1c) r6:c0b85a80 r5:c0b75630 r4:00000000 r3:00000000 [<c0012348>] (show_stack) from [<c06b6c48>] (dump_stack+0x7c/0x98) [<c06b6bcc>] (dump_stack) from [<c06b42a4>] (print_circular_bug+0x28c/0x2d8) r4:c0b85a80 r3:d0071d40 [<c06b4018>] (print_circular_bug) from [<c00613b0>] (__lock_acquire+0x1acc/0x1bb0) r10:c0b50660 r8:c09e6d80 r7:d0071d40 r6:c11d0f0c r5:00000007 r4:d0072240 [<c005f8e4>] (__lock_acquire) from [<c00619f8>] (lock_acquire+0xb0/0x124) r10:00000000 r9:c04abfc4 r8:00000000 r7:00000000 r6:00000000 r5:c0a06f0c r4:00000000 [<c0061948>] (lock_acquire) from [<c06ba3b4>] (mutex_lock_nested+0x5c/0x3d8) r10:ec853800 r9:c0a06ed4 r8:d0071d40 r7:c0a06ed4 r6:c11d0f0c r5:00000000 r4:c04abfc4 [<c06ba358>] (mutex_lock_nested) from [<c04abfc4>] (cpufreq_thermal_notifier+0x34/0xfc) r10:ec853800 r9:ec85380c r8:d00d7d3c r7:c0a06ed4 r6:d00d7d3c r5:00000000 r4:fffffffe [<c04abf90>] (cpufreq_thermal_notifier) from [<c0042bf4>] (notifier_call_chain+0x4c/0x8c) r7:00000000 r6:00000000 r5:00000000 r4:fffffffe [<c0042ba8>] (notifier_call_chain) from [<c0042f20>] (__blocking_notifier_call_chain+0x50/0x68) r8:c0a072a4 r7:00000000 r6:d00d7d3c r5:ffffffff r4:c0a06fc8 r3:ffffffff [<c0042ed0>] (__blocking_notifier_call_chain) from [<c0042f58>] (blocking_notifier_call_chain+0x20/0x28) r7:ec98b540 r6:c13ebc80 r5:ed76e600 r4:d00d7d3c [<c0042f38>] (blocking_notifier_call_chain) from [<c04ae62c>] (cpufreq_set_policy+0x7c/0x1d0) [<c04ae5b0>] (cpufreq_set_policy) from [<c04af3cc>] (store_scaling_governor+0x74/0x9c) r7:ec98b540 r6:0000000c r5:ec98b540 r4:ed76e600 [<c04af358>] (store_scaling_governor) from [<c04ad418>] (store+0x90/0xc0) r6:0000000c r5:ed76e6d4 r4:ed76e600 [<c04ad388>] (store) from [<c0175384>] (sysfs_kf_write+0x54/0x58) r8:0000000c r7:d00d7f78 r6:ec98b540 r5:0000000c r4:ec853800 r3:0000000c [<c0175330>] (sysfs_kf_write) from [<c01746b4>] (kernfs_fop_write+0xdc/0x190) r6:ec98b540 r5:00000000 r4:00000000 r3:c0175330 [<c01745d8>] (kernfs_fop_write) from [<c010dcc0>] (vfs_write+0xac/0x1b4) r10:0162aa70 r9:d00d6000 r8:0000000c r7:d00d7f78 r6:0162aa70 r5:0000000c r4:eccde500 [<c010dc14>] (vfs_write) from [<c010dfec>] (SyS_write+0x44/0x90) r10:0162aa70 r8:0000000c r7:eccde500 r6:eccde500 r5:00000000 r4:00000000 [<c010dfa8>] (SyS_write) from [<c000ec00>] (ret_fast_syscall+0x0/0x48) r10:00000000 r8:c000edc4 r7:00000004 r6:000216cc r5:0000000c r4:0162aa70 Solve this by moving to finer grained locking - use one mutex to protect the cpufreq_dev_list as a whole, and a separate lock to ensure correct ordering of cpufreq notifier registration and removal. cooling_list_lock is taken within cooling_cpufreq_lock on (un)registration to preserve the behavior of the code, i.e. to atomically add/remove to the list and (un)register the notifier. Fixes: 2dcd851fe4b4 ("thermal: cpu_cooling: Update always cpufreq policy with Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-13thermal: power_allocator: do not use devm* interfacesDmitry Torokhov
The code in question is called outside of standard driver probe()/remove() callbacks and thus will not benefit from use of devm* infrastructure. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-07thermal: sti: Add parentheses around bridge->ops->regmap_init callNicolas Boichat
regmap_init(...) is a macro since commit "regmap: Use different lockdep class for each regmap init call". That same name is used as a function pointer: prevent its expansion by adding parentheses around the function pointer. Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-04thermal: Add Intel PCH thermal driverTushar Dave
This change adds a thermal driver for Wildcat Point platform controller hub. This driver register PCH thermal sensor as a thermal zone and associate critical and hot trips if present. Signed-off-by: Tushar Dave <tushar.n.dave@intel.com> Reviewed-by: Pandruvada, Srinivas <srinivas.pandruvada@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal: Add comment explaining test for critical temperatureSascha Hauer
The code testing if a temperature should be emulated or not is not obvious. Add a comment explaining why this test is done. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Mikko Perttunen <mperttunen@nvidia.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal: Use IS_ENABLED instead of #ifdefSascha Hauer
Use IS_ENABLED(CONFIG_THERMAL_EMULATION) to make the code more readable and to get rid of the addtional #ifdef around the variable definitions in thermal_zone_get_temp(). Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal: remove unnecessary call to thermal_zone_device_set_pollingSascha Hauer
When the thermal zone has no get_temp callback then thermal_zone_device_register() calls thermal_zone_device_set_polling() with a polling delay of 0. This only cancels the poll_queue. Since the poll_queue hasn't been scheduled this is a no-op. Remove it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal: trivial: fix typo in commentSascha Hauer
2015-08-03thermal: consistently use int for temperaturesSascha Hauer
The thermal code uses int, long and unsigned long for temperatures in different places. Using an unsigned type limits the thermal framework to positive temperatures without need. Also several drivers currently will report temperatures near UINT_MAX for temperatures below 0°C. This will probably immediately shut the machine down due to overtemperature if started below 0°C. 'long' is 64bit on several architectures. This is not needed since INT_MAX °mC is above the melting point of all known materials. Consistently use a plain 'int' for temperatures throughout the thermal code and the drivers. This only changes the places in the drivers where the temperature is passed around as pointer, when drivers internally use another type this is not changed. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Peter Feuerer <peter@piie.net> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Jean Delvare <jdelvare@suse.de> Cc: Peter Feuerer <peter@piie.net> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-acpi@vger.kernel.org Cc: platform-driver-x86@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: Guenter Roeck <linux@roeck-us.net> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Darren Hart <dvhart@infradead.org> Cc: lm-sensors@lm-sensors.org Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal: add available policies sysfs attributeNi Wade
The Linux thermal framework support to change thermal governor policy in userspace, but it can't show what available policies supported. This patch adds available_policies attribute to the thermal framework, it can list the thermal governors which can be used for a particular zone. This attribute is read only. Signed-off-by: Wei Ni <wni@nvidia.com> Reviewed-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal/powerclamp: add cpu id for denlow platformJacob Pan
Add support for Intel Denlow UP server platform. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal/powerclamp: add cpu id for Skylake u/yRadivoje Jovanovic
Add support for Intel Skylake u/y Signed-off-by: Radivoje Jovanovic <radivoje.jovanovic@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03thermal/powerclamp: add cpu id for skylake h/sRadivoje Jovanovic
Add support for Intel Skylake H/S Signed-off-by: Radivoje Jovanovic <radivoje.jovanovic@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-03Merge branch 'fixes' of ↵Zhang Rui
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal into for-rc
2015-08-03thermal: Drop owner assignment from platform_driverKrzysztof Kozlowski
platform_driver does not need to set an owner because platform_driver_register() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-08-02thermal: exynos: Remove unused code related to platform_data on probe()Chanwoo Choi
This patch removes the unused code related to struct exynos_tmu_platform_data because exynos_tmu_probe() don't handle the struct exynos_tmu_platform_data *pdata. Test HW: Exynos4412 - Trats2 board Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2015-08-02thermal: exynos: Add the dependency of CONFIG_THERMAL_OF instead of CONFIG_OFChanwoo Choi
The exynos thermal driver use the of_thermal_*() API to parse the basic data for thermal management from devicetree file. So, if CONFIG_EXYNOS_THERMAL is selected without CONFIG_THERMAL_OF, kernel can build it without any problem. But, exynos thermal driver is not working with following error log. This patch add the dependency of CONFIG_THERMAL_OF instead of CONFIG_OF. [ 1.458644] get_th_reg: Cannot get trip points from of-thermal.c! [ 1.459096] get_th_reg: Cannot get trip points from of-thermal.c! [ 1.465211] exynos4412_tmu_initialize: No CRITICAL trip point defined at of-thermal.c! Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
