2011-05-19 | tty/serial: Add explicit PORT_TEGRA type | Stephen Warren | |
Tegra's UART is currently auto-detected as PORT_XSCALE due to register bit UART_IER.UUE being writable. However, the Tegra documentation states that this register bit is reserved. Hence, we should not program it. Instead, the documentation specifies that the UART is 16550 compatible. However, Tegra does need register bit UART_IER.RTOIE set, which is not enabled by any 16550 port type. This was not noticed before, since PORT_XSCALE enables CAP_UUE, which conflates both UUE and RTOIE bit programming. This change defines PORT_TEGRA that doesn't set UART_CAP_UUE, but does set UART_CAP_RTOIE, which is a new capability indicating that the RTOIE bit needs to be enabled. Based-on-code-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> | |||
2011-04-19 | tty: remove invalid location line in file header | Jovi Zhang | |
remove invalid location line in each file header after location moved from driver/char to driver/tty Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> | |||
2011-01-13 | tty: move drivers/serial/ to drivers/tty/serial/ | Greg Kroah-Hartman | |
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> |
