path: root/drivers/tty/serial/altera_jtaguart.c
2015-05-06drivers/tty/serial: altera: fix typos in #endif commentsValentin Rothberg
Correct reference on CONFIG_SERIAL_ALTERA_{JTAG}UART_CONSOLE in C-comment after #endif. Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09serial: altera-juart: fix NULL device in log messageLey Foon Tan
Add device pointer to port->dev. Before: "(NULL device *): ttyJ0 at MMIO 0x1008 (irq = 2, base_baud = 0) is a Altera JTAG UART" After: "altera_jtaguart 1008.serial: ttyJ0 at MMIO 0x1008 (irq = 2, base_baud = 0) is a Altera JTAG UART" Signed-off-by: Ley Foon Tan <lftan@altera.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20tty: serial: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-08serial: altera: Make of_device_id arrays constTobias Klauser
Make the of_device_id arrays const, as it is handled as const by all OF functions. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-22serial: altera_jtaguart: Fix putchar function passed to uart_console_write()Tobias Klauser
Commit 3d1c90d48cbe335a ("serial: altera_jtaguart: Adpot uart_console_write()") introduced the usage of uart_console_write() but didn't change the signature of altera_jtaguart_console_putc() to take a pointer to struct uart_port instead of struct console, breaking the driver's console support and leading to the following warning: > drivers/tty/serial/altera_jtaguart.c: In function 'altera_jtaguart_console_write': > >> drivers/tty/serial/altera_jtaguart.c:350:2: warning: passing argument 4 of 'uart_console_write' from incompatible pointer type [enabled by default] > uart_console_write(port, s, count, altera_jtaguart_console_putc); > ^ > In file included from drivers/tty/serial/altera_jtaguart.c:25:0: > include/linux/serial_core.h:317:6: note: expected 'void (*)(struct uart_port *, int)' but argument is of type 'void (*)(struct console *, int)' > void uart_console_write(struct uart_port *port, const char *s, Fix this by adjusting the signature of altera_jtaguart_console_putc() accordingly. Reported-by: kbuild test robot <fengguang.wu@intel.com> Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17serial: altera_jtaguart: Adpot uart_console_write()Tobias Klauser
Follow commit 2970b7f5ea3c ("serial: altera: Adopt uart_console_write()") and don't open code the LF to LFCR conversion in altera_jtaguart either. Use uart_console_write() instead. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09serial: treewide: Remove empty implementations of enable_ms()Alexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-08-29dts: Deprecate ALTR as a vendor prefixDinh Nguyen
Because most of the vendor prefixes are lower case, deprecate the vendor prefix "ALTR" in place of "altr" for Altera Corp.. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: devicetree@vger.kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-27tty: serial: altera_jtag: drop uart_port->lock before calling ↵Viresh Kumar
tty_flip_buffer_push() The current driver triggers a lockdep warning for if tty_flip_buffer_push() is called with uart_port->lock locked. This never shows up on UP kernels and comes up only on SMP kernels. Crash looks like this (produced with samsung.c driver): ----- [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0) [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0) [<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+) [<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x) [<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c) [<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30) [<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94) [<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68) [<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70) Exception stack(0xc04cdf70 to 0xc04cdfb8) df60: 00000000 00000000 0000166e 00000000 df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000 dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff [<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30) [<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148) [<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c) BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360 lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1 CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2 Workqueue: events flush_to_ldisc [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34) [<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738) [<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348) [<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c) [<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0) [<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c) ----- Release the port lock before calling tty_flip_buffer_push() and reacquire it after the call. Similar stuff was already done for few other drivers in the past, like: commit 2389b272168ceec056ca1d8a870a97fa9c26e11a Author: Thomas Gleixner <tglx@linutronix.de> Date: Tue May 29 21:53:50 2007 +0100 [ARM] 4417/1: Serial: Fix AMBA drivers locking Cc: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-31serial: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-05tty: serial: altera_jtaguart: Simplify altera_jtaguart_init()Tobias Klauser
No need for two separate return statements, consolidate them. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: serial: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-10-27Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: of_mdio: Don't phy_scan_fixups() twice Devicetree: Expand on ARM Primecell binding documentation dt: Add empty of_match_node() macro dt: add empty dt helpers for non-dt build devicetree: fix build error on drivers/tty/serial/altera_jtaguart.c devicetree: Add ARM pl022 spi controller binding doc devicetree: Add ARM pl061 gpio controller binding doc of/irq: of_irq_find_parent: check for parent equal to child MAINTAINERS: update devicetree maintainers dt: add helper to read 64-bit integers tty: use of_match_ptr() for of_match_table entry OF: Add of_match_ptr() macro dt: add empty for_each_child_of_node, of_find_property devicetree: Document Qualcomm and Atmel prefixes serial/imx: add of_alias_get_id() reference back dt: add of_alias_scan and of_alias_get_id devicetree: Add a registry of vendor prefixes
2011-10-05devicetree: fix build error on drivers/tty/serial/altera_jtaguart.cGrant Likely
This patch fixes the following build error caused by commit 85888069cf5d ("tty: use of_match_ptr() for of_match_table entry"). The problem was a missing #include <linux/of.h> which is where of_match_ptr() is defined. drivers/tty/serial/altera_jtaguart.c:483:3: error: implicit declaration of function 'of_match_ptr' [-Werror=implicit-function-declaration] drivers/tty/serial/altera_jtaguart.c:483:34: error: 'altera_jtaguart_match' undeclared here (not in a function) Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Tobias Klauser <tklauser@distanz.ch> (maintainer:ALTERA UART/JTAG...) Cc: Alan Cox <alan@linux.intel.com> (maintainer:SERIAL DRIVERS)
2011-09-29tty: use of_match_ptr() for of_match_table entryBen Dooks
Use the new of_match_ptr() macro for the of_match_table pointer entry to avoid having to #dfine match NULL Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-22TTY: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-01tty: serial: altera_jtaguart: Add device tree supportTobias Klauser
Advertise the possibility to use this driver with device tree if CONFIG_OF is set. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-22tty: serial: altera_jtaguart: Fixup type usage of port flagsTobias Klauser
port->flags is of type upf_t, which corresponds to UPF_* flags. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22tty: serial: altera_jtaguart: Support getting mapbase and IRQ from resourcesTobias Klauser
This will make it easier to get the driver to support device tree. The old platform data method is still supported though. Also change the driver to use only one platform device per port. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22tty: serial: altera_jtaguart: Remove unused function early_altera_jtaguart_setupTobias Klauser
This is not even used in nios2 arch code anymore. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22tty: serial: altera_jtaguart: Don't use plain integer as NULL pointerTobias Klauser
This fixes a sparse warning. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
