path: root/drivers/tty/serial/bcm63xx_uart.c
2015-11-20bcm63xx_uart: Use the device name when registering an interruptSimon Arlott
Use the device name when registering an interrupt so that multiple ports don't all have the same interrupt name. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-07tty: serial/bcm63xx_uart: fix sparse warningLad, Prabhakar
this patch fixes following sparse warnings: bcm63xx_uart.c:857:43: warning: Using plain integer as NULL pointer bcm63xx_uart.c:871:35: warning: Using plain integer as NULL pointer Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-06tty: serial: bcm63xx: Eliminate unnecessary request/release functionsKevin Cernekee
We don't really need to perform the ioremap "on demand" so it's simpler just to do it from the probe function. This also lets us eliminate the UART_REG_SIZE constant and rely on the resource information passed in from the DT or platform code. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06tty: serial: bcm63xx: Enable DT earlycon supportKevin Cernekee
This enables early console output if there is a chosen/stdout-path property referencing a UART node with the "brcm,bcm6345-uart" compatible string. The bootloader sets up the pinmux and baud/parity/etc. Tested on bcm3384 (MIPS, DT). Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06tty: serial: bcm63xx: Fix typo in MODULE_DESCRIPTIONKevin Cernekee
Remove the extra '<' character. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06tty: serial: bcm63xx: Add support for unnamed clock outputs from DTKevin Cernekee
The original non-DT bcm63xx clk code ignores the struct device argument and looks up a global clock name. DT platforms, by contrast, often just use a phandle to reference a clock node with no "clock-output-names" property. Modify the UART driver to support both schemes. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20tty: serial: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-19serial: Fix IGNBRK handlingPeter Hurley
If IGNBRK is set without either BRKINT or PARMRK set, some uart drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the line discipline, when it should send either nothing or the TTYBREAK flag set. This happens because the read_status_mask masks out the BI condition, which uart_insert_char() then interprets as a normal 0x00 byte. SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General Terminal Interface - Input Modes, states: "If IGNBRK is set, a break condition detected on input shall be ignored; that is, not put on the input queue and therefore not read by any process." Fix read_status_mask to include the BI bit if IGNBRK is set; the lsr status retains the BI bit if a BREAK is recv'd, which is subsequently ignored in uart_insert_char() when masked with the ignore_status_mask. Affected drivers: 8250 - all serial_txx9 mfd amba-pl010 amba-pl011 atmel_serial bfin_uart dz ip22zilog max310x mxs-auart netx-serial pnx8xxx_uart pxa sb1250-duart sccnxp serial_ks8695 sirfsoc_uart st-asc vr41xx_siu zs sunzilog fsl_lpuart sunsab ucc_uart bcm63xx_uart sunsu efm32-uart pmac_zilog mpsc msm_serial m32r_sio Unaffected drivers: omap-serial rp2 sa1100 imx icom Annotated for fixes: altera_uart mcf Drivers without break detection: 21285 xilinx-uartps altera_jtaguart apbuart arc-uart clps711x max3100 uartlite msm_serial_hs nwpserial lantiq vt8500_serial Unknown: samsung mpc52xx_uart bfin_sport_uart cpm_uart/core Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag' Reported-by: Ivan <athlon_@mail.ru> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28tty: serial: bcm63xx_uart: add support for DT probingFlorian Fainelli
Add a matching table for the the bcm63xx_uart driver on the compatible string "brcm,bcm6345-uart" which covers all BCM63xx implementations and reflects the fact that this block was first introduced with the BCM6345 SoC. Also make sure that we convert the id based on the uart aliases provided by the relevant Device Tree. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28tty: serial: bcm63xx_uart: define UART_REG_SIZE constantFlorian Fainelli
The bcm63xx_uart driver uses RSET_UART_SIZE which is a constant defined for MIPS-based BCM63xx platforms, pull this constant value from the MIPS-specific header and put it in include/linux/serial_bcm63xx.h to make the driver platform agnostic. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28tty: serial: bcm63xx_uart: include linux/io.hFlorian Fainelli
Include linux/io.h which provides the definition for __raw_{readl,writel}, this is not necessary on MIPS since there is an implicit inclusion, but it is on ARM for instance. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-23tty: serial: bcm63xx_uart: use linux/serial_bcm63xx.hFlorian Fainelli
Now that the UART block defines have been moved to a separate file, include that one and do not longer rely on the MIPS-specific bcm63xx_regs.h header file. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6204/
2014-01-23tty: serial: bcm63xx_uart: drop bcm_{readl,writel} macrosFlorian Fainelli
bcm_{readl,writel} macros expand to __raw_{readl,writel}, use these directly such that we do not rely on the platform to provide these for us. As a result, we no longer use bcm63xx_io.h, so remove that inclusion too. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6201/
2014-01-23tty: serial: bcm63xx_uart: remove unused inclusionFlorian Fainelli
bcm63xx_irqs.h is included but we are not using anything from it, drop that include. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6205/
2013-08-27tty: serial: bcm63xx: drop uart_port->lock before calling tty_flip_buffer_push()Viresh Kumar
The current driver triggers a lockdep warning for if tty_flip_buffer_push() is called with uart_port->lock locked. This never shows up on UP kernels and comes up only on SMP kernels. Crash looks like this (produced with samsung.c driver): ----- [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0) [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0) [<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+) [<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x) [<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c) [<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30) [<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94) [<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68) [<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70) Exception stack(0xc04cdf70 to 0xc04cdfb8) df60: 00000000 00000000 0000166e 00000000 df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000 dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff [<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30) [<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148) [<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c) BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360 lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1 CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2 Workqueue: events flush_to_ldisc [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34) [<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738) [<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348) [<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c) [<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0) [<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c) ----- Release the port lock before calling tty_flip_buffer_push() and reacquire it after the call. Similar stuff was already done for few other drivers in the past, like: commit 2389b272168ceec056ca1d8a870a97fa9c26e11a Author: Thomas Gleixner <tglx@linutronix.de> Date: Tue May 29 21:53:50 2007 +0100 [ARM] 4417/1: Serial: Fix AMBA drivers locking Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-26serial: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Barry Song <baohua.song@csr.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-08MIPS: BCM63XX: merge bcm63xx_clk.h into bcm63xx/clk.cJonas Gorski
All the header file does is provide the internal structure of clk, which shouldn't be used by anyone except clk.c itself anyway. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Patchwork: http://patchwork.linux-mips.org/patch/5055/ Acked-by: John Crispin <blogic@openwrt.org>
2013-03-12serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char"Jonas Gorski
92a19f9cec9a80ad93c06e115822deb729e2c6ad introduced a local variable with the same name as the argument to bcm_uart_do_rx, breaking compilation. Fix this by renaming the new variable and its uses where expected. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_charJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_char is the next one to proceed. This one is used all over the code, so the patch is huge. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: serial: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-16serial: bcm63xx_uart: fix irq storm after rx fifo overrun.Maxime Bizon
RX fifo reset is required to clear irq. Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
