The function meson_uart_release_port() inappropriately try to
iounmap() a resource managed by devm_ioremap_nocache().
The function meson_uart_release_port() maybe called by uart_ioctl()
that means meson_uart_release_port() is not called from within a
probe or remove function, for safety, I convert iounmap() to
devm_iounmap().
Signed-off-by: Firo Yang <firogm@gmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The SoC has four fully functional UARTs which use the same programming
model. They are named UART_A, UART_B, UART_C and UART_AO (Always-On)
which cannot be powered off.
Signed-off-by: Carlo Caione <carlo@caione.org>
