path: root/drivers/tty/serial/msm_serial_hs.c
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-07serial: msm_serial_hs: Add MSM high speed UART driverMayank Rana
This driver supports UART-DM HW on MSM platforms. It uses the on chip DMA to drive data transfers and has optional support for UART power management independent of Linux suspend/resume and wakeup from Rx. The driver was originally developed by Google. It is functionally equivalent to the version available at: http://android.git.kernel.org/?p=kernel/experimental.git the differences being: 1) Remove wakelocks and change unsupported DMA API. 2) Replace clock selection register codes by macros. 3) Fix checkpatch errors and add inline documentation. 4) Add runtime PM hooks for active power state transitions. 5) Handle error path and cleanup resources if required. CC: Nick Pelly <npelly@google.com> Signed-off-by: Sankalp Bose <sankalpb@codeaurora.org> Signed-off-by: Mayank Rana <mrana@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
