commit 016002848c82eeb5d460489ce392d91fe18c475c upstream.
In 'rp2_probe', the driver registers 'rp2_uart_interrupt' then calls
'rp2_fw_cb' through 'request_firmware_nowait'. In 'rp2_fw_cb', if the
firmware don't exists, function just return without initializing ports
of 'rp2_card'. But now the interrupt handler function has been
registered, and when an interrupt comes, 'rp2_uart_interrupt' may access
those ports then causing NULL pointer dereference or other bugs.
Because the driver does some initialization work in 'rp2_fw_cb', in
order to make the driver ready to handle interrupts, 'request_firmware'
should be used instead of asynchronous 'request_firmware_nowait'.
This report reveals it:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.19.177-gdba4159c14ef-dirty #45
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.0-59-
gc9ba5276e321-prebuilt.qemu.org 04/01/2014
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xec/0x156 lib/dump_stack.c:118
assign_lock_key kernel/locking/lockdep.c:727 [inline]
register_lock_class+0x14e5/0x1ba0 kernel/locking/lockdep.c:753
__lock_acquire+0x187/0x3750 kernel/locking/lockdep.c:3303
lock_acquire+0x124/0x340 kernel/locking/lockdep.c:3907
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x32/0x50 kernel/locking/spinlock.c:144
spin_lock include/linux/spinlock.h:329 [inline]
rp2_ch_interrupt drivers/tty/serial/rp2.c:466 [inline]
rp2_asic_interrupt.isra.9+0x15d/0x990 drivers/tty/serial/rp2.c:493
rp2_uart_interrupt+0x49/0xe0 drivers/tty/serial/rp2.c:504
__handle_irq_event_percpu+0xfb/0x770 kernel/irq/handle.c:149
handle_irq_event_percpu+0x79/0x150 kernel/irq/handle.c:189
handle_irq_event+0xac/0x140 kernel/irq/handle.c:206
handle_fasteoi_irq+0x232/0x5c0 kernel/irq/chip.c:725
generic_handle_irq_desc include/linux/irqdesc.h:155 [inline]
handle_irq+0x230/0x3a0 arch/x86/kernel/irq_64.c:87
do_IRQ+0xa7/0x1e0 arch/x86/kernel/irq.c:247
common_interrupt+0xf/0xf arch/x86/entry/entry_64.S:670
</IRQ>
RIP: 0010:native_safe_halt+0x28/0x30 arch/x86/include/asm/irqflags.h:61
Code: 00 00 55 be 04 00 00 00 48 c7 c7 00 c2 2f 8c 48 89 e5 e8 fb 31 e7 f8
8b 05 75 af 8d 03 85 c0 7e 07 0f 00 2d 8a 61 65 00 fb f4 <5d> c3 90 90 90
90 90 90 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 41
RSP: 0018:ffff88806b71fcc8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffffde
RAX: 0000000000000000 RBX: ffffffff8bde7e48 RCX: ffffffff88a21285
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff8c2fc200
RBP: ffff88806b71fcc8 R08: fffffbfff185f840 R09: fffffbfff185f840
R10: 0000000000000001 R11: fffffbfff185f840 R12: 0000000000000002
R13: ffffffff8bea18a0 R14: 0000000000000000 R15: 0000000000000000
arch_safe_halt arch/x86/include/asm/paravirt.h:94 [inline]
default_idle+0x6f/0x360 arch/x86/kernel/process.c:557
arch_cpu_idle+0xf/0x20 arch/x86/kernel/process.c:548
default_idle_call+0x3b/0x60 kernel/sched/idle.c:93
cpuidle_idle_call kernel/sched/idle.c:153 [inline]
do_idle+0x2ab/0x3c0 kernel/sched/idle.c:263
cpu_startup_entry+0xcb/0xe0 kernel/sched/idle.c:369
start_secondary+0x3b8/0x4e0 arch/x86/kernel/smpboot.c:271
secondary_startup_64+0xa4/0xb0 arch/x86/kernel/head_64.S:243
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
PGD 8000000056d27067 P4D 8000000056d27067 PUD 56d28067 PMD 0
Oops: 0000 [#1] PREEMPT SMP KASAN PTI
RIP: 0010:readl arch/x86/include/asm/io.h:59 [inline]
RIP: 0010:rp2_ch_interrupt drivers/tty/serial/rp2.c:472 [inline]
RIP: 0010:rp2_asic_interrupt.isra.9+0x181/0x990 drivers/tty/serial/rp2.c:
493
Code: df e8 43 5d c2 05 48 8d 83 e8 01 00 00 48 89 85 60 ff ff ff 48 c1 e8
03 42 80 3c 30 00 0f 85 aa 07 00 00 48 8b 83 e8 01 00 00 <8b> 40 10 89 c1
89 85 68 ff ff ff 48 8b 83 e8 01 00 00 89 48 10 83
RSP: 0018:ffff88806c287cd0 EFLAGS: 00010046
RAX: 0000000000000000 RBX: ffff88806ade6820 RCX: ffffffff814300b1
RDX: 1ffff1100d5bcd06 RSI: 0000000000000004 RDI: ffff88806ade6820
RBP: ffff88806c287db8 R08: ffffed100d5bcd05 R09: ffffed100d5bcd05
R10: 0000000000000001 R11: ffffed100d5bcd04 R12: ffffc90001e00000
R13: ffff888069654e10 R14: dffffc0000000000 R15: ffff888069654df0
FS: 0000000000000000(0000) GS:ffff88806c280000(0000) knlGS:
0000000000000000
CR2: 0000000000000010 CR3: 000000006892c000 CR4: 00000000000006e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<IRQ>
</IRQ>
f8 8b 05 75 af 8d 03 85 c0 7e 07 0f 00 2d 8a 61 65 00 fb f4 <5d> c3 90
90 90 90 90 90 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 41
Modules linked in:
Dumping ftrace buffer:
(ftrace buffer empty)
---[ end trace 11804dbb55cb1a64 ]---
493
e8 03 42 80 3c 30 00 0f 85 aa 07 00 00 48 8b 83 e8 01 00 00 <8b> 40 10 89
c1 89 85 68 ff ff ff 48 8b 83 e8 01 00 00 89 48 10 83
0000000000000000
Reported-by: Zheyu Ma <zheyuma97@gmail.com>
Signed-off-by: Zheyu Ma <zheyuma97@gmail.com>
Link: https://lore.kernel.org/r/1621577323-1541-1-git-send-email-zheyuma97@gmail.com
Cc: stable <stable@vger.kernel.org>
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro
is not preferred.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The current driver triggers a lockdep warning for if tty_flip_buffer_push() is
called with uart_port->lock locked. This never shows up on UP kernels and comes
up only on SMP kernels.
Crash looks like this (produced with samsung.c driver):
[<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14)
[<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac)
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8)
[<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0)
[<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0)
[<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+)
[<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x)
[<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c)
[<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c)
[<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30)
[<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94)
[<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68)
[<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70)
Exception stack(0xc04cdf70 to 0xc04cdfb8)
df60: 00000000 00000000 0000166e 00000000
df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000
dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff
[<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30)
[<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148)
[<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c)
BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360
lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1
CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2
Workqueue: events flush_to_ldisc
[<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c)
[<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28)
[<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34)
[<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738)
[<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98)
[<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138)
[<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348)
[<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c)
[<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0)
[<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c)
Release the port lock before calling tty_flip_buffer_push() and reacquire it
after the call.
Similar stuff was already done for few other drivers in the past, like:
commit 2389b272168ceec056ca1d8a870a97fa9c26e11a
Author: Thomas Gleixner <tglx@linutronix.de>
Date: Tue May 29 21:53:50 2007 +0100
[ARM] 4417/1: Serial: Fix AMBA drivers locking
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
This driver supports the RocketPort EXPRESS and RocketPort INFINITY
families of PCI/PCIe multiport serial adapters. These adapters use a
"RocketPort 2" ASIC that is not compatible with the original RocketPort
driver (CONFIG_ROCKETPORT).
Tested with the RocketPort EXPRESS Octa DB9 and Quad DB9. Also added an
old RocketPort 8J PCI card to the same system to verify that rocket.c and
rp2.c coexist peacefully.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
