path: root/drivers/tty/serial/serial-tegra.c
2015-10-17serial: tegra: Add helper function for handling RX bufferJon Hunter
In the tegra UART driver there are three places where the RX DMA buffer is handled and pushed up to the tty layer. In all three instances the same functions are called and so instead of duplicating the code in three places, move this code to a new helper function and use this new function. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17serial: tegra: Remove redundant code and check in tegra_uart_stop_rx()Jon Hunter
The serial-tegra driver always uses DMA and hence the driver always allocates DMA channels. Therefore, the test to see if the RX DMA channel is initialised in tegra_uart_stop_rx() is unnecessary and so remove the test and the code that corresponds to the case where the RX DMA channel is not initialised. Please note that the call to tegra_uart_stop_rx() should always be before the call to tegra_uart_shutdown() which will uninitialise the RX DMA channel. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17serial: tegra: Remove unnecessary return statementsJon Hunter
Some functions in the serial-tegra driver have unnecessary return statements at the end of a void function and so remove them. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17serial: tegra: Handle another RX race conditionJon Hunter
Commit 853a699739fe ("serial: tegra: handle race condition on uart rx side") attempted to fix a race condition between the RX end of transmission interrupt and RX DMA completion callback. Despite this fix there is still another case where these two paths can race and result in duplicated data. The race condition is as follows: 1. DMA completion interrupt occurs and schedules tasklet to call DMA callback. 2. DMA callback for the UART driver starts to execute. This will copy the data from the DMA buffer and restart the DMA. This is done under uart port spinlock. 3. During the callback, UART interrupt is raised for end of receive. The UART ISR runs and waits to acquire port spinlock held by the DMA callback. 4. DMA callback gives up spinlock after copying the data, but before restarting DMA. 5. UART ISR acquires the spin lock and reads the same DMA buffer because DMA has not been restarted yet. The release of the spinlock during the DMA callback was introduced by commit 9b88748b362c ("tty: serial: tegra: drop uart_port->lock before calling tty_flip_buffer_push()") to fix a spinlock lock-up issue when calling tty_flip_buffer_push(). However, since then commit a9c3f68f3cd8 ("tty: Fix low_latency BUG") migrated tty_flip_buffer_push() to always use a workqueue, allowing tty_flip_buffer_push() to be called from within atomic sections. Therefore, we can remove the unlocking of the spinlock from the DMA callback and UART ISR and this will ensure that the race condition no longer occurs. Reported-by: Christopher Freeman <cfreeman@nvidia.com> Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24serial: tegra: Fix memory leak on DMA setup failureJon Hunter
If the call to dmaengine_slave_config() fails, then the DMA buffer will not be freed/unmapped. Fix this by moving the code that stores the address of the buffer in the tegra_uart_port structure to before the call to dmaengine_slave_config(). Reported-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Correct error handling on DMA setupJon Hunter
Function tegra_uart_dma_channel_allocate() does not check that dma_map_single() mapped the DMA buffer correctly. Add a check for this and appropriate error handling. Furthermore, if dmaengine_slave_config() (called by tegra_uart_dma_channel_allocate()) fails, then memory allocated/mapped is not freed/unmapped. Therefore, call tegra_uart_dma_channel_free() instead of just dma_release_channel() if dmaengine_slave_config() fails. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Correct shutdown of UARTsJon Hunter
There are two issues in the shutdown path of the UARTs which are: 1. The function tegra_uart_shutdown() calls tegra_uart_flush_buffer() to stop DMA TX transfers. However, tegra_uart_flush_buffer() is called after the DMA channels have already been freed and so actually does nothing. 2. The function that frees the DMA channels (tegra_uart_dma_channel_free()), unmaps the dma buffer before freeing the DMA channel and does not ensure the DMA has been stopped. Resolve this by fixing the code in tegra_uart_dma_channel_free() to ensure the DMA is stopped, free the DMA channel and then unmap the DMA buffer. Finally, remove the unnecessary call to tegra_uart_flush_buffer(). Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Fix cookie used by TX channelJon Hunter
The DMA cookie for the RX channel is being used by the TX channel. Therefore, fix driver to use the correct DMA cookie for the TX channel. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Use unsigned types for RX and TX byte countsJon Hunter
The function tty_insert_flip_string() takes an argument "size" which is of type size_t. This is an unsigned type. Update the count, rx_bytes_requested and tx_bytes_requested in the tegra serial driver to be unsigned integers so that an unsigned type is passed to tty_insert_flip_string(). Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: handle race condition on uart rx sideShardar Shariff Md
The tegra serial driver has two paths through which receive data is copied up to the tty layer. These are: 1. DMA completion callback 2. UART RX interrupt A UART RX interrupt occurs for either RX_TIMEOUT (data has been sitting in the Rx FIFO for more than 4 character times without being read because there is not enough data to reach the trigger level), End of Receive Data event (receiver detects that data stops coming in for more than 4 character times) or a receive error. In the RX interrupt path, the following happens ... - All RX DMA transfers are stopped - Any data in the DMA buffer and RX FIFO are copied up to the tty layer. - DMA is restarted/primed for the RX path In the DMA completion callback, the DMA buffer is copied up to the tty layer but there is no check to see if the RX interrupt could have occurred between the DMA interrupt firing the the DMA callback running. Hence, if a RX interrupt was to occur shortly after the DMA completion interrupt, it is possible that the RX interrupt path has already copied the DMA buffer before the DMA callback has been called. Therefore, when the DMA callback is called, if the DMA is already in-progress, then this indicates that the UART RX interrupt has already occurred and there is nothing to do in the DMA callback. This race condition can cause duplicated data to be received. Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com> [jonathanh@nvidia.com: Moved async_tx_ack() call to after check to see if DMA has completed because if the DMA is in progress we do not need to ACK yet. Changed the print from dev_info to dev_debug. Updated changelog to add more commentary on the race condition based upon feedback from author.] Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: check the count and read if any from dmaShardar Shariff Md
It is only necessary to read data from the dma buffer when the count value is non-zero and hence, tegra_uart_copy_rx_to_tty() so only be called when this is the case. Although, this was being tested for in two places, there is a third place where this was not tested. However, instead of adding another if-statement prior to calling tegra_uart_copy_rx_to_tty(), move the test inside the function. Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com> [jonathanh@nvidia.com: Re-worked patch to move the check for the count value inside the function tegra_uart_copy_rx_to_tty(). Updated changelog with more commentary.] Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Add delay after enabling FIFO modeJon Hunter
For all tegra devices (up to t210), there is a hardware issue that requires software to wait for 3 UART clock periods after enabling the TX fifo, otherwise data could be lost. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10serial: tegra: Correct delay after TX flushJon Hunter
For all tegra devices (up to t210), there is a hardware issue that requires software to wait for 32 UART clock periods for the flush to propagate otherwise TX data could be post. Add a helper function to wait for N UART clock periods and update delay following FIFO flush to be 32 UART clock cycles. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26tty: constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Peter Korsgaard <peter@korsgaard.com> Acked-by: Timur Tabi <timur@tabi.org> Acked-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-25serial: tegra: clean up tty-flag assignmentsJohan Hovold
The tty break and error flags are not bit masks so do not to use bitwise OR when assigning them. Note that there is no functional change due to the if-else construct and flag having been initialised to zero (TTY_NORMAL). Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: Refactor uart_flush_buffer() from uart_close()Peter Hurley
In the context of the final tty & port close, flushing the tx ring buffer after the hardware has already been shutdown and the ring buffer freed is neither required nor desirable. uart_flush_buffer() performs 3 operations: 1. Resets tx ring buffer indices, but the tx ring buffer has already been freed and the indices are reset if the port is re-opened. 2. Calls uart driver's flush_buffer() method 5 in-tree uart drivers define flush_buffer() methods: amba-pl011, atmel-serial, imx, serial-tegra, timbuart These have been refactored into the shutdown() method, if required. 3. Kicks the ldisc for more writing, but this is undesirable. The file handle is being released; any waiting writer will will be kicked out by tty_release() with a warning. Further, the N_TTY ldisc may generate SIGIO for a file handle which is no longer valid. Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-10serial: tegra: ack the rx dma desc after transfer terminatedPradeep Goudagunta
The Rx dma descriptor allocated without the DMA_ACK flags so that once after tarnsfer done or terminated, client can ack the descriptor to free it for later use. If the Rx DMA is terminated for some reason then rx-dma descriptor is not getting acked which causes the memory leak and list of usage desc to grow continuously. Hence, acknowledge the rx-dma descriptor once transfer is terminated to avoid memory leak and desc list to grow. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-10serial: tegra: update tx_circular buffer only when TX_DMA is in progressPradeep Goudagunta
When channel is require to stop transmit then update the Tx circular buffer only when DMA based transfer is in progress. If there is no DMA based transfer then no need to update the Tx buffer. Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11serial: tegra: convert to standard DMA DT bindingsStephen Warren
By using dma_request_slave_channel_or_err(), the DMA slave ID can be looked up from standard DT properties, and squirrelled away during channel allocation. Hence, there's no need to use a custom DT property to store the slave ID. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com>
2013-12-11serial: tegra: use reset frameworkStephen Warren
Tegra's clock driver now provides an implementation of the common reset API (include/linux/reset.h). Use this instead of the old Tegra- specific API; that will soon be removed. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Thierry Reding <treding@nvidia.com>
2013-10-07serial: tegra: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch proposes to remove the use of the IRQF_DISABLED flag It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17serial: tegra: fix tty-kref leakJohan Hovold
Fix potential tty-kref leak in stop_rx path. Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <jhovold@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27tty: serial: tegra: drop uart_port->lock before calling tty_flip_buffer_push()Viresh Kumar
The current driver triggers a lockdep warning for if tty_flip_buffer_push() is called with uart_port->lock locked. This never shows up on UP kernels and comes up only on SMP kernels. Crash looks like this (produced with samsung.c driver): ----- [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) [<c01b59ac>] (do_raw_spin_unlock+0xc4/0xd8) from [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0) [<c03627e4>] (_raw_spin_unlock_irqrestore+0xc/0x38) from [<c020a1a8>] (s3c24xx_serial_rx_chars+0) [<c020a1a8>] (s3c24xx_serial_rx_chars+0x12c/0x260) from [<c020aae8>] (s3c64xx_serial_handle_irq+) [<c020aae8>] (s3c64xx_serial_handle_irq+0x48/0x60) from [<c006aaa0>] (handle_irq_event_percpu+0x) [<c006aaa0>] (handle_irq_event_percpu+0x50/0x194) from [<c006ac20>] (handle_irq_event+0x3c/0x5c) [<c006ac20>] (handle_irq_event+0x3c/0x5c) from [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) [<c006d864>] (handle_fasteoi_irq+0x80/0x13c) from [<c006a4a4>] (generic_handle_irq+0x20/0x30) [<c006a4a4>] (generic_handle_irq+0x20/0x30) from [<c000f454>] (handle_IRQ+0x38/0x94) [<c000f454>] (handle_IRQ+0x38/0x94) from [<c0008538>] (gic_handle_irq+0x34/0x68) [<c0008538>] (gic_handle_irq+0x34/0x68) from [<c00123c0>] (__irq_svc+0x40/0x70) Exception stack(0xc04cdf70 to 0xc04cdfb8) df60: 00000000 00000000 0000166e 00000000 df80: c04cc000 c050278f c050278f 00000001 c04d444c 410fc0f4 c03649b0 00000000 dfa0: 00000001 c04cdfb8 c000f758 c000f75c 60070013 ffffffff [<c00123c0>] (__irq_svc+0x40/0x70) from [<c000f75c>] (arch_cpu_idle+0x28/0x30) [<c000f75c>] (arch_cpu_idle+0x28/0x30) from [<c0054888>] (cpu_startup_entry+0x5c/0x148) [<c0054888>] (cpu_startup_entry+0x5c/0x148) from [<c0497aa4>] (start_kernel+0x334/0x38c) BUG: spinlock lockup suspected on CPU#0, kworker/0:1/360 lock: s3c24xx_serial_ports+0x1d8/0x370, .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1 CPU: 0 PID: 360 Comm: kworker/0:1 Not tainted 3.11.0-rc6-next-20130819-00003-g75485f1 #2 Workqueue: events flush_to_ldisc [<c0014d58>] (unwind_backtrace+0x0/0xf8) from [<c0011908>] (show_stack+0x10/0x14) [<c0011908>] (show_stack+0x10/0x14) from [<c035da34>] (dump_stack+0x6c/0xac) [<c035da34>] (dump_stack+0x6c/0xac) from [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) [<c01b581c>] (do_raw_spin_lock+0x100/0x17c) from [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) [<c03628a0>] (_raw_spin_lock_irqsave+0x20/0x28) from [<c0203224>] (uart_start+0x18/0x34) [<c0203224>] (uart_start+0x18/0x34) from [<c01ef890>] (__receive_buf+0x4b4/0x738) [<c01ef890>] (__receive_buf+0x4b4/0x738) from [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) [<c01efb44>] (n_tty_receive_buf2+0x30/0x98) from [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) [<c01f2ba8>] (flush_to_ldisc+0xec/0x138) from [<c0031af0>] (process_one_work+0xfc/0x348) [<c0031af0>] (process_one_work+0xfc/0x348) from [<c0032138>] (worker_thread+0x138/0x37c) [<c0032138>] (worker_thread+0x138/0x37c) from [<c0037a7c>] (kthread+0xa4/0xb0) [<c0037a7c>] (kthread+0xa4/0xb0) from [<c000e5f8>] (ret_from_fork+0x14/0x3c) ----- Release the port lock before calling tty_flip_buffer_push() and reacquire it after the call. Similar stuff was already done for few other drivers in the past, like: commit 2389b272168ceec056ca1d8a870a97fa9c26e11a Author: Thomas Gleixner <tglx@linutronix.de> Date: Tue May 29 21:53:50 2007 +0100 [ARM] 4417/1: Serial: Fix AMBA drivers locking Cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12serial: tegra: use NULL instead of 0Jingoo Han
'cons' is a pointer; thus NULL should be used instead of 0. Also, local symbols are staticized. Fix the following sparse warnings: drivers/tty/serial/serial-tegra.c:1209:27: warning: Using plain integer as NULL pointer drivers/tty/serial/serial-tegra.c:1240:29: warning: symbol 'tegra20_uart_chip_data' was not declared. Should it be static? drivers/tty/serial/serial-tegra.c:1246:29: warning: symbol 'tegra30_uart_chip_data' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-28treewide: Fix typo in printkMasanari Iida
Correct spelling typo in various part of drivers Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-15serial: tegra: Convert to devm_ioremap_resource()Sachin Kamat
Use the newly introduced devm_ioremap_resource() instead of devm_request_and_ioremap() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages; so all explicit error messages can be removed from the failure code paths. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-15serial: tegra: assume CONFIG_OFStephen Warren
Tegra only supports, and always enables, device tree. Remove all ifdefs for DT support from the driver. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-25serial: tegra: Fix compilation errorVenu Byravarasu
Fix compilation error, by adding the correct header file for Tegra clocks. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17serial: tegra: Switch to using struct tty_portThierry Reding
Many of the tty functions were converted to use a struct tty_port instead of a struct tty_struct. Update the Tegra driver accordingly to avoid build breakage. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15serial: tegra: add serial driverLaxman Dewangan
NVIDIA's Tegra has multiple UART controller which supports: - APB DMA based controller fifo read/write. - End Of Data interrupt in incoming data to know whether end of frame achieve or not. - HW controlled RTS and CTS flow control to reduce SW overhead. Add serial driver to use all above feature. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Alan Cox <alan@linux.intel.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
