commit 099506cbbc79c0bd52b19cb6b930f256dabc3950 upstream.
As noted in commit 84b40e3b57ee ("serial: 8250: omap: Disable DMA for
console UART"), UART console lines use low-level PIO only access functions
which will conflict with use of the line when DMA is enabled, e.g. when
the console line is also used for systemd messages. So disable DMA
support for UART console lines.
Reported-by: Michael Rodin <mrodin@de.adit-jv.com>
Link: https://patchwork.kernel.org/patch/10929511/
Tested-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: stable@vger.kernel.org
Signed-off-by: George G. Davis <george_davis@mentor.com>
commit 93bcefd4c6bad4c69dbc4edcd3fbf774b24d930d upstream.
We disable transmission interrupt (clear SCSCR_TIE) after all data has been transmitted
(if uart_circ_empty(xmit)). While transmitting, if the data is still in the tty buffer,
re-enable the SCSCR_TIE bit, which was done at sci_start_tx().
This is unnecessary processing, wasting CPU operation if the data transmission length is large.
And further, transmit end, FIFO empty bits disabling have also been performed in the step above.
Signed-off-by: Hoan Nguyen An <na-hoan@jinso.co.jp>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit c5a9262fa8bfed0dddc7466ef10fcd292e2af61b ]
The RX FIFO timer may be armed when the port is shut down, hence the
timer function may still be called afterwards.
Fix this race condition by deleting the timer during port shutdown.
Fixes: 039403765e5da3c6 ("serial: sh-sci: SCIFA/B RX FIFO software timeout")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit 8afb1d2c12163f77777f84616a8e9444d0050ebe upstream.
Commit 40f70c03e33a ("serial: sh-sci: add locking to console write
function to avoid SMP lockup") copied the strategy to avoid locking
problems in conjuncture with the console from the UART8250
driver. Instead using directly spin_{try}lock_irqsave(),
local_irq_save() followed by spin_{try}lock() was used. While this is
correct on mainline, for -rt it is a problem. spin_{try}lock() will
check if it is running in a valid context. Since the local_irq_save()
has already been executed, the context has changed and
spin_{try}lock() will complain. The reason why spin_{try}lock()
complains is that on -rt the spin locks are turned into mutexes and
therefore can sleep. Sleeping with interrupts disabled is not valid.
BUG: sleeping function called from invalid context at /home/wagi/work/rt/v4.4-cip-rt/kernel/locking/rtmutex.c:995
in_atomic(): 0, irqs_disabled(): 128, pid: 778, name: irq/76-eth0
CPU: 0 PID: 778 Comm: irq/76-eth0 Not tainted 4.4.126-test-cip22-rt14-00403-gcd03665c8318 #12
Hardware name: Generic RZ/G1 (Flattened Device Tree)
Backtrace:
[<c00140a0>] (dump_backtrace) from [<c001424c>] (show_stack+0x18/0x1c)
r7:c06b01f0 r6:60010193 r5:00000000 r4:c06b01f0
[<c0014234>] (show_stack) from [<c01d3c94>] (dump_stack+0x78/0x94)
[<c01d3c1c>] (dump_stack) from [<c004c134>] (___might_sleep+0x134/0x194)
r7:60010113 r6:c06d3559 r5:00000000 r4:ffffe000
[<c004c000>] (___might_sleep) from [<c04ded60>] (rt_spin_lock+0x20/0x74)
r5:c06f4d60 r4:c06f4d60
[<c04ded40>] (rt_spin_lock) from [<c02577e4>] (serial_console_write+0x100/0x118)
[<c02576e4>] (serial_console_write) from [<c0061060>] (call_console_drivers.constprop.15+0x10c/0x124)
r10:c06d2894 r9:c04e18b0 r8:00000028 r7:00000000 r6:c06d3559 r5:c06d2798
r4:c06b9914 r3:c02576e4
[<c0060f54>] (call_console_drivers.constprop.15) from [<c0062984>] (console_unlock+0x32c/0x430)
r10:c06d30d8 r9:00000028 r8:c06dd518 r7:00000005 r6:00000000 r5:c06d2798
r4:c06d2798 r3:00000028
[<c0062658>] (console_unlock) from [<c0062e1c>] (vprintk_emit+0x394/0x4f0)
r10:c06d2798 r9:c06d30ee r8:00000006 r7:00000005 r6:c06a78fc r5:00000027
r4:00000003
[<c0062a88>] (vprintk_emit) from [<c0062fa0>] (vprintk+0x28/0x30)
r10:c060bd46 r9:00001000 r8:c06b9a90 r7:c06b9a90 r6:c06b994c r5:c06b9a3c
r4:c0062fa8
[<c0062f78>] (vprintk) from [<c0062fb8>] (vprintk_default+0x10/0x14)
[<c0062fa8>] (vprintk_default) from [<c009cd30>] (printk+0x78/0x84)
[<c009ccbc>] (printk) from [<c025afdc>] (credit_entropy_bits+0x17c/0x2cc)
r3:00000001 r2:decade60 r1:c061a5ee r0:c061a523
r4:00000006
[<c025ae60>] (credit_entropy_bits) from [<c025bf74>] (add_interrupt_randomness+0x160/0x178)
r10:466e7196 r9:1f536000 r8:fffeef74 r7:00000000 r6:c06b9a60 r5:c06b9a3c
r4:dfbcf680
[<c025be14>] (add_interrupt_randomness) from [<c006536c>] (irq_thread+0x1e8/0x248)
r10:c006537c r9:c06cdf21 r8:c0064fcc r7:df791c24 r6:df791c00 r5:ffffe000
r4:df525180
[<c0065184>] (irq_thread) from [<c003fba4>] (kthread+0x108/0x11c)
r10:00000000 r9:00000000 r8:c0065184 r7:df791c00 r6:00000000 r5:df791d00
r4:decac000
[<c003fa9c>] (kthread) from [<c00101b8>] (ret_from_fork+0x14/0x3c)
r8:00000000 r7:00000000 r6:00000000 r5:c003fa9c r4:df791d00
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Daniel Wagner <daniel.wagner@siemens.com>
commit d63c16f8e1ab761775275adcf54f4bef7c330295 upstream.
Printk format "%pCr" will be removed soon, as clk_get_rate() must not be
called in atomic context.
Replace it by open-coding the operation. This is safe here, as the code
runs in task context.
Link: http://lkml.kernel.org/r/1527845302-12159-4-git-send-email-geert+renesas@glider.be
To: Jia-Ju Bai <baijiaju1990@gmail.com>
To: Jonathan Corbet <corbet@lwn.net>
To: Michael Turquette <mturquette@baylibre.com>
To: Stephen Boyd <sboyd@kernel.org>
To: Zhang Rui <rui.zhang@intel.com>
To: Eduardo Valentin <edubezval@gmail.com>
To: Eric Anholt <eric@anholt.net>
To: Stefan Wahren <stefan.wahren@i2se.com>
To: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: linux-doc@vger.kernel.org
Cc: linux-clk@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: linux-serial@vger.kernel.org
Cc: linux-renesas-soc@vger.kernel.org
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: stable@vger.kernel.org # 4.5+
Signed-off-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit 090fa4b0dccfa3d04e1c5ab0fe4eba16e6713895 ]
The sci_ports[] array is indexed using a value derived from the
"serialN" alias in DT, which may lead to an out-of-bounds access.
Fix this by adding a range check.
Note that the array size is defined by a Kconfig symbol
(CONFIG_SERIAL_SH_SCI_NR_UARTS), so this can even be triggered using a
legitimate DTB.
Fixes: 97ed9790c514066b ("serial: sh-sci: Remove unused platform data capabilities field")
commit 7842055bfce4bf0170d0f61df8b2add8399697be upstream.
When the TTY buffers fill up to the configured maximum, a system lockup
occurs:
[ 598.820128] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 598.825796] 0-...!: (1 GPs behind) idle=5a6/2/0 softirq=1974/1974 fqs=1
[ 598.832577] (detected by 3, t=62517 jiffies, g=296, c=295, q=126)
[ 598.838755] Task dump for CPU 0:
[ 598.841977] swapper/0 R running task 0 0 0 0x00000022
[ 598.849023] Call trace:
[ 598.851476] __switch_to+0x98/0xb0
[ 598.854870] (null)
This can be prevented by doing a dummy read of the RX data register.
This issue affects both HSCIF and SCIF ports. Reported for R-Car H3 ES2.0;
reproduced and fixed on H3 ES1.1. Probably affects other R-Car platforms
as well.
Reported-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Tested-by: Nguyen Viet Dung <dung.nguyen.aj@renesas.com>
[ Upstream commit 7464779fa8551b90d5797d4020b0bdb7e6422eb9 ]
If a port has no dma channel defined in the device tree, then
don't attempt to allocate a dma channel for the port.
Also suppress the warning message concerning the failure to allocate
a dma channel. Continue to emit the warning message if a dma
channel is defined but cannot be allocated.
Signed-off-by: Andy Lowe <andy_lowe@mentor.com>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Use more compact of_property_read_bool() call for a boolean property
instead of of_find_property() call in sci_parse_dt().
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
The kstrtol() function returns -ERANGE as well as -EINVAL so these tests
are not enough. It's not a super serious bug, but my static checker
correctly complains that the "r" variable might be used uninitialized.
Fixes: 5d23188a473d ("serial: sh-sci: make RX FIFO parameters tunable via sysfs")
The commit below changed a function call from
dma_request_slave_channel_compat() to dma_request_slave_channel(), but
forgot to update the printed failure message.
Fixes: 219fb0c1436e4893 ("serial: sh-sci: Remove the platform data dma slave rx/tx channel IDs")
uart_register_driver call binds the driver to a specific device
node through tty_register_driver call. This should typically
happen during device probe call.
In a multiplatform scenario, it is possible that multiple serial
drivers are part of the kernel. Currently the driver registration fails
if multiple serial drivers with overlapping major/minor numbers are
included.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
If DMA is enabled and used, a burst of old data may be seen on the
serial console during "poweroff" or "reboot". uart_flush_buffer()
clears the circular buffer, but sci_port.tx_dma_len is not reset.
This leads to a circular buffer overflow, dumping (UART_XMIT_SIZE -
sci_port.tx_dma_len) bytes.
To fix this, add a .flush_buffer() callback that resets
sci_port.tx_dma_len.
Inspired by commit 31ca2c63fdc0aee7 ("tty/serial: atmel: fix race
condition (TX+DMA)").
If a UART has dedicated RTS/CTS pins, and hardware control flow is
disabled (or AUTORTS is not yet effective), changing any serial port
configuration deasserts RTS, as .set_termios() calls sci_init_pins().
To fix this, consider the current (AUTO)RTS state when (re)initializing
the pins. Note that for SCIFA/SCIFB, AUTORTS needs explicit
configuration of the RTS# pin function, while (H)SCIF handles this
automatically.
Fixes: d2b9775d795ec05f ("serial: sh-sci: Correct pin initialization on (H)SCIF")
Fixes: e9d7a45a03991349 ("serial: sh-sci: Add pin initialization for SCIFA/SCIFB")
When changing hardware control flow for a UART with dedicated RTS/CTS
pins, the new AUTORTS state is not immediately reflected in the
hardware, but only when RTS is raised. However, the serial core does
not call .set_mctrl() after .set_termios(), hence AUTORTS may only
become effective when the port is closed, and reopened later.
Note that this problem does not happen when manually using stty to
change CRTSCTS, as AUTORTS will work fine on next open.
To fix this, call .set_mctrl() from .set_termios() when dedicated
RTS/CTS pins are present, to refresh the AUTORTS or RTS state.
This is similar to what other drivers supporting AUTORTS do (e.g.
omap-serial).
Reported-by: Baumann, Christoph (C.) <cbaumann@visteon.com>
Fixes: 33f50ffc253854cf ("serial: sh-sci: Fix support for hardware-assisted RTS/CTS")
When the .set_termios() callback resets the UART, it first waits (busy
loops) until all characters in the transmit FIFO have been transmitted,
to prevent a port configuration change from impacting these characters.
However, if the UART has dedicated RTS/CTS hardware flow control
enabled, these characters may have been stuck in the FIFO due to CTS not
being asserted by the remote side.
- When a new user opens the port, .set_termios() is called while
transmission is still disabled, leading to an infinite loop:
NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s!
- When an active user changes port configuration without waiting for
the draining of the transmit FIFO, this may also block indefinitely,
until CTS is asserted by the remote side.
This has been observed with SCIFA (on r8a7740/armadillo), and SCIFB and
HSCIF (on r8a7791/koelsch).
To fix this, remove the code that waits for the draining of the transmit
FIFO.
This patch fixes an issue that kernel panic happens when DMA is enabled
and we press enter key while the kernel booting on the serial console.
* An interrupt may occur after sci_request_irq().
* DMA transfer area is initialized by setup_timer() in sci_request_dma()
and used in interrupt.
If an interrupt occurred between sci_request_irq() and setup_timer() in
sci_request_dma(), DMA transfer area has not been initialized yet.
So, this patch changes the order of sci_request_irq() and
sci_request_dma().
Fixes: 73a19e4c0301 ("serial: sh-sci: Add DMA support.")
Signed-off-by: Takatoshi Akiyama <takatoshi.akiyama.kj@ps.hitachi-solutions.com>
[Shimoda changes the commit log]
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
1. Do not set the RX trigger level for software timeout devices on reset;
there is no timeout by default, and data will rot.
2. Do set the RX trigger level for hardware timeout devices when set
via sysfs attribute.
Fixes SCIFA-type serial consoles.
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Allows tuning of the RX FIFO fill threshold and timeout. (The latter is
only applicable to SCIFA and SCIFB).
Implements support for FIFO fill thresholds greater than one with software
timeout.
This mechanism is not possible (or at least not useful) on SCIF family
hardware other than SCIFA and SCIFB because they do not support turning off
the DR hardware timeout interrupt separately from the RI interrupt.
Sets reasonable trigger defaults for the various SCIF variants.
Also corrects the FIFO size for SH7705-style ports.
Sets the closest match for a desired RX trigger level.
Defines the bits controlling FIFO thresholds, adds the additional
HSCIF registers to the register map.
As the function header of sci_parse_dt() is split in an unusual way,
"git diff" gets confused when changes to the body of the function are
made, and attributes them to the wrong function.
Reformat the function header to fix this.
SCI instances found in SH SoCs have different spacing between registers
depending on the SoC. The platform data contains a regshift field that
tells the driver by how many bits to shift the register offset to
compute its address. We can compute the regshift value automatically
based on the memory resource size, there's no need to pass the value
through platform data.
Fix the sh7750 SCI and sh7760 SIM port memory resources length to ensure
proper computation of the regshift value.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
The field isn't set by any platform but is only used internally in the
driver to hold data parsed from DT. Move it to the sci_port structure.
The sh-sci driver implements manual break debouncing for a few SH
platforms by reading the value of the RX pin port register. This feature
is optional and the driver considers all negative or zero values of the
platform data port_reg field as invalid. As the four platforms that set
the field to a register address all use an address higher than
0x7fffffff, the driver will always consider the value as invalid and
never perform debouncing. The feature is unused, remove it.
Debouncing could be implemented properly in the future using the pinctrl
and GPIO APIs if desired.
Only SH platforms still use platform data for the sh-sci, and none of
them declare DMA channels connected to the SCI. Remove the corresponding
platform data fields and simplify the driver accordingly.
The fifo size, overrun register and mask, sampling rate mask and error
mask all depend on the port type only and don't need to be computed at
runtime. Add them to the sci_port_parameters structure.
The driver modifies platform data for internal purpose only. Fix that
and make the platform data structure const.
Turn the regmap two-dimensional array to an array of port parameters and
store a pointer to the port parameters in the sci_port structure. This
will allow handling additional port type dependent parameters.
The compiler zeros uninitialized fields, don't zero them manually.
Even though most of its registers are 8-bit wide, the IRDA has two
16-bit registers that make it a 16-bit peripheral and not a 8-bit
peripheral with addresses shifted by one. Fix the registers offset in
the driver and the platform data regshift value.
The UPF_BOOT_AUTOCONF platform data flag is set by all platforms,
hardcode it.
The UPF_IOREMAP flag is set by a single SH platform and thus needs to be
kept. However, for ARM platforms, we can base the decision on whether an
OF node is present and bypass the platform data flags completely.
The Transmit Enable and Receive Enable bits are set in the scscr field
of all instances of the sh-sci platform data. Set them in the driver
directly to prepare for their removal from platform data.
When the call to kasprintf() returns a NULL pointer, function
sci_request_irq() frees the preallocated memory and returns 0 is
returned. Because 0 means no error, the caller of sci_request_irq()
will keep going, and the freed memory may be used or freed again. To
avoid the above issue, this patch assigns "-ENOMEM" to the return
variable ret.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188691
Signed-off-by: Pan Bian <bianpan2016@163.com>
While spin is already locked, serial output request causes the deadlock,
because serial output process also tries to lock the spin.
This patch removes serial output with spin locked.
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Check for uart_ops structures that are only stored in the ops field of a
uart_port structure. This field is declared const, so uart_ops structures
that have this property can be declared as const also.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct uart_ops i@p = { ... };
@ok@
identifier r.i;
struct uart_port e;
position p;
e.ops = &i@p;
@bad@
position p != {r.p,ok.p};
identifier r.i;
struct uart_ops e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct uart_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Make sure the transmitter and receiver are stopped when shutting down
the port, and related interrupts are disabled.
Without this:
- New input data may be received into the RX FIFO, possibly
triggering a new RX DMA completion,
- Transfers will still be enabled on a subsequent startup of the UART,
before the UART's FIFOs have been reset, causing reading of stale
data.
Inspired by a patch in the BSP by Koji Matsuoka
<koji.matsuoka.xm@renesas.com>.
Add the missing timeout bit definition for (H)SCIF.
Clear the timeout and overrun flag bits during UART reset, cfr. the
initialization flowchart in the datasheet.
Setting the FIFO reset bits is not sufficient to reset the RX FIFO.
After this the status register's RDF flag bit may still be set, causing
the reception of one stale byte of data.
To fix this, clear all status flag bits related to reception, error, and
break handling, cfr. the initialization flowchart in the datasheet.
FIFO reset is done in sci_reset(), called from sci_set_termios(), while
sci_start_tx() and sci_start_rx() are called before, from sci_startup().
However, starting transfers before the UART's FIFOs have been reset may
cause reading of stale data.
Remove the calls to sci_start_tx() and sci_start_rx() from sci_startup()
to fix this.
Transfers are still started when needed:
- sci_start_rx() is called from sci_set_termios() after FIFO reset, if
the CREAD flag is set,
- sci_start_tx() is called from uart_change_speed() immediately
thereafter, if transmission is enabled.
Add support for indicating the availability of dedicated lines for
RTS/CTS hardware flow control, using the standard "uart-has-rtscts" DT
property.
The existing support for hardware-assisted RTS/CTS is rudimentary and
doesn't work.
Add support for hardware-assisted RTS/CTS hardware flow control for the
(H)SCIF, SCIFA, and SCIFB variants.
Before, the driver relied on initialization by the boot loader, or by
implicit reset state.
Note that unlike on (H)SCIF, the RTS/CTS bits exist only if dedicated
RTS/CTS pins are available, which depends on the SoC and UART instance.
Correct pin initialization on (H)SCIF:
- RTS must be deasserted (it's active low),
- SCK must be an input, as it may be used as the optional external
clock input.
Initial pin configuration must always be done:
- Regardless of the presence of dedicated RTS and CTS pins: if the
register exists, the RTS/CTS bits exist, too,
- Regardless of hardware flow control being enabled or not: RTS must
be deasserted.
Replace open-coded variants of sci_getreg() by function calls, and drop
intermediate variables where appropriate.
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Enhance the Renesas SCI UART driver to add support for GPIO-controlled
modem lines (CTS, DSR, DCD, RNG, RTS, DTR), using the serial_mctrl_gpio
helpers.
GPIO-controlled modem lines can be used when dedicated modem lines are
not available. Invalid configurations specifying both GPIO RTS/CTS and
dedicated RTS/CTS are rejected.
Documentation/serial/driver clearly states:
If the port does not support CTS, DCD or DSR, the driver should
indicate that the signal is permanently active.
Hence always set TIOCM_CTS, as we currently don't look at the CTS
hardware line state at all.
FWIW, this fixes the transmit path when hardware-assisted flow control
is enabled, and userspace enables CRTSCTS.
The receive path is still broken, as RTS is never asserted.
As of commit 2eaa790989e03900 ("earlycon: Use common framework for
earlycon declarations") it is no longer needer to specify both
EARLYCON_DECLARE() and OF_EARLYCON_DECLARE().
