path: root/drivers/tty/serial/st-asc.c
2015-10-04tty/serial: st-asc: drop the use of IRQF_NO_SUSPENDSudeep Holla
These drivers doesn't claim the serial device to be wakeup source. Even if it is, it needs to use enable_irq_wake or other related PM wakeup APIs to enable it. This patch removes yet another misuse of IRQF_NO_SUSPEND. Cc: Srinivas Kandagatla <srinivas.kandagatla@gmail.com> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-arm-kernel@lists.infradead.org Cc: kernel@stlinux.com Cc: linux-serial@vger.kernel.org Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-26tty: constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Peter Korsgaard <peter@korsgaard.com> Acked-by: Timur Tabi <timur@tabi.org> Acked-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20tty: serial: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-28serial: asc: Conditionally use readl_relaxed (COMPILE_TEST)Daniel Thompson
Commit 08177ece596c ("serial: asc: Adopt readl_/writel_relaxed()) is regressing the m68k allmodconfig build. This is due to the unconditional use of readl_relaxed() which, although documented, does not currently exist for m68k. This is trivially fixable for st-asc because we can just update the asc_in() accessor to make this conditional. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Cc: Srinivas Kandagatla <srinivas.kandagatla@gmail.com> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Patrice Chotard <patrice.chotard@st.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-10serial: asc: Adopt readl_/writel_relaxed()Daniel Thompson
The architectures supported by this driver, arm and sh, have expensive implementations of writel(), reliant on spin locks and explicit L2 cache management. These architectures provide a cheaper writel_relaxed() which is much better suited to peripherals that do not perform DMA. The situation with readl()/readl_relaxed()is similar although less acute. This driver does not use DMA and will be more power efficient and more robust (due to absence of spin locks during console I/O) if it uses the relaxed variants. The driver supports COMPILE_TEST and therefore falls back to writel() when writel_relaxed() does not exist. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@gmail.com> Cc: Maxime Coquelin <maxime.coquelin@st.com> Cc: Patrice Chotard <patrice.chotard@st.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: kernel@stlinux.com Cc: linux-serial@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-27serial: st-asc: Fix overflow in baudrate calculationMaxime COQUELIN
In the current calculation, if the required baud rate is above 262143, we get an overflow. This patch uses a 64bits variable to do the maths. Also, we remove the '+1' to avoid a divide by zero if the input clock rate is something unexpected. Indeed, if the input clock rate is zero, it is preferable to be notified, since the UART won't work anyway. Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-27serial: st-asc: Don't call BUG in asc_console_setup()Maxime COQUELIN
In order to prevent an asc instance to be used as early console, BUG_ON is used on either mapbase or membase being NULL. Problem is that this condition is also true when we set console to be a ttyASx different to the first asc instance being probed. Instead of calling BUG_ON, it now returns -ENXIO when either mapbase or membase is NULL. Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09serial: treewide: Remove empty implementations of enable_ms()Alexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19serial: Fix IGNBRK handlingPeter Hurley
If IGNBRK is set without either BRKINT or PARMRK set, some uart drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the line discipline, when it should send either nothing or the TTYBREAK flag set. This happens because the read_status_mask masks out the BI condition, which uart_insert_char() then interprets as a normal 0x00 byte. SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General Terminal Interface - Input Modes, states: "If IGNBRK is set, a break condition detected on input shall be ignored; that is, not put on the input queue and therefore not read by any process." Fix read_status_mask to include the BI bit if IGNBRK is set; the lsr status retains the BI bit if a BREAK is recv'd, which is subsequently ignored in uart_insert_char() when masked with the ignore_status_mask. Affected drivers: 8250 - all serial_txx9 mfd amba-pl010 amba-pl011 atmel_serial bfin_uart dz ip22zilog max310x mxs-auart netx-serial pnx8xxx_uart pxa sb1250-duart sccnxp serial_ks8695 sirfsoc_uart st-asc vr41xx_siu zs sunzilog fsl_lpuart sunsab ucc_uart bcm63xx_uart sunsu efm32-uart pmac_zilog mpsc msm_serial m32r_sio Unaffected drivers: omap-serial rp2 sa1100 imx icom Annotated for fixes: altera_uart mcf Drivers without break detection: 21285 xilinx-uartps altera_jtaguart apbuart arc-uart clps711x max3100 uartlite msm_serial_hs nwpserial lantiq vt8500_serial Unknown: samsung mpc52xx_uart bfin_sport_uart cpm_uart/core Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag' Reported-by: Ivan <athlon_@mail.ru> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-28serial: st-asc: Fix data corruption during long console burstsDaniel Thompson
On my test platform (B2020/STiH416) the serial port issues bad characters during the initial message avalanche as the console comes up. The problem also occurs when dense(ish) I/O is done using the polled I/O interface. The problem is fixed for me by using the FIFO half-empty bit rather than FIFO full bit. Note that using the half-empty bit causes the FIFO to be managed in a similar way to interrupt based I/O (i.e. where the hardware gets best test coverage). Running the FIFO half full will have no impact (good or bad) on console performance. The UART will still remain fully saturated and the busy-wait until the FIFO is empty in asc_console_write() will complete at the same time. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16serial: st-asc: Fix SysRq char handlingDaniel Thompson
This driver, like several others, uses the upper bits of the character to track both real and dummy state. Unfortunately it neglects to mask these bits properly when passing the character data around. This means neither break detection nor sysrq character handling work correctly. This patch adds the requires masking and has been tested to confirm that it correctly handles magic sysrq sequences on ST's B2020 board. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27serial: st-asc: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-19serial: st-asc: replace devm_request_and_ioremap by devm_ioremap_resourceJulia Lawall
Use devm_ioremap_resource instead of devm_request_and_ioremap. This was done using the semantic patch scripts/coccinelle/api/devm_ioremap_resource.cocci and various manual modifications to move associated calls to platform_get_resource closer to the resulting call to devm_ioremap_resource and to remove the associated error handling code. The initialization of port->mapbase is also moved lower, to take advantage of the NULL test on res performed by devm_ioremap_resource. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-03serial: st-asc: Fix unused variable warning for non DT.Srinivas Kandagatla
This patch fixes a below warning reported by kbuild test robot. drivers/tty/serial/st-asc.c:727:28: warning: 'asc_match' defined but not used [-Wunused-variable] The code used in DT case is now ifdefed under CONFIG_OF to fix this warning. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Reported-by: Kbuild Test Robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-26serial:st-asc: Add ST ASC driver.Srinivas Kandagatla
This patch adds support to ASC (asynchronous serial controller) driver, which is basically a standard serial driver. This IP is common across all the ST parts for settop box platforms. ASC is embedded in ST COMMS IP block. It supports Rx & Tx functionality. It support all industry standard baud rates. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> CC: Stephen Gallimore <stephen.gallimore@st.com> CC: Stuart Menefy <stuart.menefy@st.com> CC: Arnd Bergmann <arnd@arndb.de> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
