git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Use container_of instead of casting first structure member.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
If IGNBRK is set without either BRKINT or PARMRK set, some uart
drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the
line discipline, when it should send either nothing or the TTYBREAK flag
set. This happens because the read_status_mask masks out the BI
condition, which uart_insert_char() then interprets as a normal 0x00 byte.
SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General
Terminal Interface - Input Modes, states:
"If IGNBRK is set, a break condition detected on input shall be ignored;
that is, not put on the input queue and therefore not read by any
process."
Fix read_status_mask to include the BI bit if IGNBRK is set; the
lsr status retains the BI bit if a BREAK is recv'd, which is
subsequently ignored in uart_insert_char() when masked with the
ignore_status_mask.
Affected drivers:
8250 - all
serial_txx9
mfd
amba-pl010
amba-pl011
atmel_serial
bfin_uart
dz
ip22zilog
max310x
mxs-auart
netx-serial
pnx8xxx_uart
pxa
sb1250-duart
sccnxp
serial_ks8695
sirfsoc_uart
st-asc
vr41xx_siu
zs
sunzilog
fsl_lpuart
sunsab
ucc_uart
bcm63xx_uart
sunsu
efm32-uart
pmac_zilog
mpsc
msm_serial
m32r_sio
Unaffected drivers:
omap-serial
rp2
sa1100
imx
icom
Annotated for fixes:
altera_uart
mcf
Drivers without break detection:
21285
xilinx-uartps
altera_jtaguart
apbuart
arc-uart
clps711x
max3100
uartlite
msm_serial_hs
nwpserial
lantiq
vt8500_serial
Unknown:
samsung
mpc52xx_uart
bfin_sport_uart
cpm_uart/core
Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag'
Reported-by: Ivan <athlon_@mail.ru>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Tested-by: Allen Pais <allen.pais@oracle.com>
These aren't necessary after switch and while blocks.
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Also, unnecessary dev_set_drvdata() is removed, because the driver core
clears the driver data to NULL after device_release or on probe failure.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
We have registered platform driver when module init, and
need unregister it when module exit.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
If a machine has X (X < 4) sunsu ports and cmdline
option "console=ttySY" is passed, where X < Y <= 4,
than the following panic happens:
Unable to handle kernel NULL pointer dereference
TPC: <sunsu_console_setup+0x78/0xe0>
RPC: <sunsu_console_setup+0x74/0xe0>
I7: <register_console+0x378/0x3e0>
Call Trace:
[0000000000453a38] register_console+0x378/0x3e0
[0000000000576fa0] uart_add_one_port+0x2e0/0x340
[000000000057af40] su_probe+0x160/0x2e0
[00000000005b8a4c] platform_drv_probe+0xc/0x20
[00000000005b6c2c] driver_probe_device+0x12c/0x220
[00000000005b6da8] __driver_attach+0x88/0xa0
[00000000005b4df4] bus_for_each_dev+0x54/0xa0
[00000000005b5a54] bus_add_driver+0x154/0x260
[00000000005b7190] driver_register+0x50/0x180
[00000000006d250c] sunsu_init+0x18c/0x1e0
[00000000006c2668] do_one_initcall+0xe8/0x160
[00000000006c282c] kernel_init_freeable+0x12c/0x1e0
[0000000000603764] kernel_init+0x4/0x100
[0000000000405f64] ret_from_syscall+0x1c/0x2c
[0000000000000000] (null)
1)Fix the panic;
2)Increment registered port number every successful
probe.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
CC: David Miller <davem@davemloft.net>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_char is the next one to proceed. This one is used all
over the code, so the patch is huge.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
Acked-by: Tobias Klauser <tklauser@distanz.ch>
Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Tony Prisk <linux@prisktech.co.nz>
Acked-by: David Brown <davidb@codeaurora.org>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
This structure might have made sense many years ago, but at this
point it is only used in one specific driver, and referenced in
stale comments elsewhere. Rather than change the sunsu.c driver,
simply move the struct to be within the exclusive domain of that
driver, so it won't get inadvertently picked up and used by other
serial drivers going forward. The comments referencing the now
driver specific struct are updated accordingly.
Note that 8250.c has a struct that is similar in usage, with the
name serial8250_config; but is 100% independent and untouched here.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
The addition of 8250-like entities continues to grow, while this
driver has a snapshot of a select few common 8250 UARTs. So it
has no need to grow with the new additions, since it calls out
its own (largely historic) static list which does not grow.
Disintegrate asm/system.h for Sparc.
cc: sparclinux@vger.kernel.org
There are multiple users of this file from different source
paths now, and rather than have ../ paths in include statements,
just move the file to the linux header dir.
Suggested-by: David S. Miller <davem@davemloft.net>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Get rid of users of of_platform_driver in drivers/serial. The
of_platform_{,un}register_driver functions are going away, so the
users need to be converted to using the platform_bus_type directly.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
