commit dce05aa6eec977f1472abed95ccd71276b9a3864 upstream.
Avoid global variables (namely sel_cons) by introducing vc_is_sel. It
checks whether the parameter is the current selection console. This will
help putting sel_cons to a struct later.
Link: https://lore.kernel.org/r/20200219073951.16151-1-jslaby@suse.cz
commit e8c75a30a23c6ba63f4ef6895cbf41fd42f21aa2 upstream.
sel_lock cannot nest in the console lock. Thanks to syzkaller, the
kernel states firmly:
> WARNING: possible circular locking dependency detected
> 5.6.0-rc3-syzkaller #0 Not tainted
> syz-executor.4/20336 is trying to acquire lock:
> ffff8880a2e952a0 (&tty->termios_rwsem){++++}, at: tty_unthrottle+0x22/0x100 drivers/tty/tty_ioctl.c:136
> but task is already holding lock:
> ffffffff89462e70 (sel_lock){+.+.}, at: paste_selection+0x118/0x470 drivers/tty/vt/selection.c:374
> which lock already depends on the new lock.
> the existing dependency chain (in reverse order) is:
> -> #2 (sel_lock){+.+.}:
> mutex_lock_nested+0x1b/0x30 kernel/locking/mutex.c:1118
> set_selection_kernel+0x3b8/0x18a0 drivers/tty/vt/selection.c:217
> set_selection_user+0x63/0x80 drivers/tty/vt/selection.c:181
> tioclinux+0x103/0x530 drivers/tty/vt/vt.c:3050
> vt_ioctl+0x3f1/0x3a30 drivers/tty/vt/vt_ioctl.c:364
This is ioctl(TIOCL_SETSEL).
Locks held on the path: console_lock -> sel_lock
> -> #1 (console_lock){+.+.}:
> console_lock+0x46/0x70 kernel/printk/printk.c:2289
> con_flush_chars+0x50/0x650 drivers/tty/vt/vt.c:3223
> n_tty_write+0xeae/0x1200 drivers/tty/n_tty.c:2350
> do_tty_write drivers/tty/tty_io.c:962 [inline]
> tty_write+0x5a1/0x950 drivers/tty/tty_io.c:1046
This is write().
Locks held on the path: termios_rwsem -> console_lock
> -> #0 (&tty->termios_rwsem){++++}:
> down_write+0x57/0x140 kernel/locking/rwsem.c:1534
> mkiss_receive_buf+0x12aa/0x1340 drivers/net/hamradio/mkiss.c:902
> tty_ldisc_receive_buf+0x12f/0x170 drivers/tty/tty_buffer.c:465
> paste_selection+0x346/0x470 drivers/tty/vt/selection.c:389
> tioclinux+0x121/0x530 drivers/tty/vt/vt.c:3055
This is ioctl(TIOCL_PASTESEL).
Locks held on the path: sel_lock -> termios_rwsem
> other info that might help us debug this:
> Chain exists of:
> &tty->termios_rwsem --> console_lock --> sel_lock
Clearly. From the above, we have:
Fix this by reversing the console_lock -> sel_lock dependency in
ioctl(TIOCL_SETSEL). First, lock sel_lock, then console_lock.
Reported-by: syzbot+26183d9746e62da329b8@syzkaller.appspotmail.com
Fixes: 07e6124a1a46 ("vt: selection, close sel_buffer race")
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200228115406.5735-2-jslaby@suse.cz
commit 4b70dd57a15d2f4685ac6e38056bad93e81e982f upstream.
We need to nest the console lock in sel_lock, so we have to push it down
a bit. Fortunately, the callers of set_selection_* just lock the console
lock around the function call. So moving it down is easy.
In the next patch, we switch the order.
Link: https://lore.kernel.org/r/20200228115406.5735-1-jslaby@suse.cz
commit 07e6124a1a46b4b5a9b3cacc0c306b50da87abf5 upstream.
syzkaller reported this UAF:
BUG: KASAN: use-after-free in n_tty_receive_buf_common+0x2481/0x2940 drivers/tty/n_tty.c:1741
Read of size 1 at addr ffff8880089e40e9 by task syz-executor.1/13184
CPU: 0 PID: 13184 Comm: syz-executor.1 Not tainted 5.4.7 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
Call Trace:
kasan_report+0xe/0x20 mm/kasan/common.c:634
tty_ldisc_receive_buf+0xac/0x190 drivers/tty/tty_buffer.c:461
paste_selection+0x297/0x400 drivers/tty/vt/selection.c:372
tioclinux+0x20d/0x4e0 drivers/tty/vt/vt.c:3044
vt_ioctl+0x1bcf/0x28d0 drivers/tty/vt/vt_ioctl.c:364
tty_ioctl+0x525/0x15a0 drivers/tty/tty_io.c:2657
vfs_ioctl fs/ioctl.c:47 [inline]
It is due to a race between parallel paste_selection (TIOCL_PASTESEL)
and set_selection_user (TIOCL_SETSEL) invocations. One uses sel_buffer,
while the other frees it and reallocates a new one for another
selection. Add a mutex to close this race.
The mutex takes care properly of sel_buffer and sel_buffer_lth only. The
other selection global variables (like sel_start, sel_end, and sel_cons)
are protected only in set_selection_user. The other functions need quite
some more work to close the races of the variables there. This is going
to happen later.
This likely fixes (I am unsure as there is no reproducer provided) bug
206361 too. It was marked as CVE-2020-8648.
Reported-by: syzbot+59997e8d5cbdc486e6f6@syzkaller.appspotmail.com
References: https://bugzilla.kernel.org/show_bug.cgi?id=206361
Link: https://lore.kernel.org/r/20200210081131.23572-2-jslaby@suse.cz
Pasting text with gpm on a VC produced warning [1]. Reset task state
to TASK_RUNNING in the paste_selection() loop, if the loop did not
sleep.
[1]
WARNING: CPU: 6 PID: 1960 at /home/peter/src/kernels/mainline/kernel/sched/core.c:7286 __might_sleep+0x7f/0x90()
do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffff8151805e>] paste_selection+0x9e/0x1a0
Modules linked in: btrfs xor raid6_pq ufs qnx4 hfsplus hfs minix ntfs msdos jfs xfs libcrc32c .....
CPU: 6 PID: 1960 Comm: gpm Not tainted 4.1.0-rc7+tty-xeon+debug #rc7+tty
Hardware name: Dell Inc. Precision WorkStation T5400 /0RW203, BIOS A11 04/30/2012
ffffffff81c9c0a0 ffff8802b0fd3ac8 ffffffff8185778a 0000000000000001
ffff8802b0fd3b18 ffff8802b0fd3b08 ffffffff8108039a ffffffff82ae8510
ffffffff81c9ce00 0000000000000015 0000000000000000 0000000000000000
Call Trace:
[<ffffffff8185778a>] dump_stack+0x4f/0x7b
[<ffffffff8108039a>] warn_slowpath_common+0x8a/0xc0
[<ffffffff81080416>] warn_slowpath_fmt+0x46/0x50
[<ffffffff810ddced>] ? __lock_acquire+0xe2d/0x13a0
[<ffffffff8151805e>] ? paste_selection+0x9e/0x1a0
[<ffffffff810ad4ff>] __might_sleep+0x7f/0x90
[<ffffffff8185f76a>] down_read+0x2a/0xa0
[<ffffffff810bb1d8>] ? sched_clock_cpu+0xb8/0xe0
[<ffffffff8150d1dc>] n_tty_receive_buf_common+0x4c/0xba0
[<ffffffff810dc875>] ? mark_held_locks+0x75/0xa0
[<ffffffff81861c95>] ? _raw_spin_unlock_irqrestore+0x65/0x80
[<ffffffff810b49a1>] ? get_parent_ip+0x11/0x50
[<ffffffff8150dd44>] n_tty_receive_buf2+0x14/0x20
[<ffffffff81518117>] paste_selection+0x157/0x1a0
[<ffffffff810b77b0>] ? wake_up_state+0x20/0x20
[<ffffffff815203f8>] tioclinux+0xb8/0x2c0
[<ffffffff81515bfe>] vt_ioctl+0xaee/0x11a0
[<ffffffff810baf75>] ? sched_clock_local+0x25/0x90
[<ffffffff810bbe11>] ? vtime_account_user+0x91/0xa0
[<ffffffff8150810c>] tty_ioctl+0x20c/0xe20
[<ffffffff810b4a69>] ? preempt_count_sub+0x49/0x50
[<ffffffff811ab71c>] ? context_tracking_exit+0x5c/0x290
[<ffffffff81248b98>] do_vfs_ioctl+0x318/0x570
[<ffffffff810dca8d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff810dc9b5>] ? trace_hardirqs_on_caller+0x115/0x1e0
[<ffffffff81254acc>] ? __fget_light+0x6c/0xa0
[<ffffffff81248e71>] SyS_ioctl+0x81/0xa0
[<ffffffff81862832>] system_call_fastpath+0x16/0x7a
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Convert the tty_buffer_flush() exclusion mechanism to a
public interface - tty_buffer_lock/unlock_exclusive() - and use
the interface to safely write the paste selection to the line
discipline.
Although line discipline receiving is single-producer/single-consumer,
using tty->receive_room to manage flow control creates unnecessary
critical regions requiring additional lock use.
Instead, introduce the optional .receive_buf2() ldisc method which
returns the # of bytes actually received. Serialization is guaranteed
by the caller.
In turn, the line discipline should schedule the buffer work item
whenever space becomes available; ie., when there is room to receive
data and receive_room() previously returned 0 (the buffer work
item stops processing if receive_buf2() returns 0). Note the
'no room' state need not be atomic despite concurrent use by two
threads because only the buffer work thread can set the state and
only the read() thread can clear the state.
Add n_tty_receive_buf2() as the receive_buf2() method for N_TTY.
Provide a public helper function, tty_ldisc_receive_buf(), to use
when directly accessing the receive_buf() methods.
Line disciplines not using input flow control can continue to set
tty->receive_room to a fixed value and only provide the receive_buf()
method.
There used to be a single tty_ldisc_ref_wait. But then, when a
big-tty-mutex (BTM) was introduced, it has to be tty_ldisc_ref +
tty_unlock + tty_ldisc_ref_wait + tty_lock. Later, BTM was removed
from that path and tty_ldisc_ref + tty_ldisc_ref_wait remained there.
But it makes no sense now. So leave there only tty_ldisc_ref_wait.
And when we have a reference to an ldisc, actually use it in the loop.
Otherwise it may be racy.
Acked-by: Alan Cox <alan@linux.intel.com>
We leave the existing paste mess alone and just fix up the vt side of
things.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Some of this ventures into selection which is still a complete lost cause. We
are not making it any worse. It's completely busted anyway.
Keyboard struct lifetime is easy, but the locking is not and is completely
ignored by the existing code. Tackle this one head on
- Make the kbd_table private so we can run down all direct users
- Hoick the relevant ioctl handlers into the keyboard layer
- Lock them with the keyboard lock so they don't change mid keypress
- Add helpers for things like console stop/start so we isolate the poking
around properly
- Tweak the braille console so it still builds
There are a couple of FIXME locking cases left for ioctls that are so hideous
they should be addressed in a later patch. After this patch the kbd_table is
private and all the keyboard jiggery pokery is in one place.
This update fixes speakup and also a memory leak in the original.
We used it really only serial and ami_serial. The rest of the
callsites were BUG/WARN_ONs to check if BTM is held. Now that we
pruned tty_locked from both of the real users, we can get rid of
tty_lock along with __big_tty_mutex_owner.
Cc: Alan Cox <alan@linux.intel.com>
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c.
It was broken in so many ways, and results in random odd pty issues.
It re-introduced the buggy schedule_work() in flush_to_ldisc() that can
cause endless work-loops (see commit a5660b41af6a: "tty: fix endless
work loop when the buffer fills up").
It also used an "unsigned int" return value fo the ->receive_buf()
function, but then made multiple functions return a negative error code,
and didn't actually check for the error in the caller.
And it didn't actually work at all. BenH bisected down odd tty behavior
to it:
"It looks like the patch is causing some major malfunctions of the X
server for me, possibly related to PTYs. For example, cat'ing a
large file in a gnome terminal hangs the kernel for -minutes- in a
loop of what looks like flush_to_ldisc/workqueue code, (some ftrace
data in the quoted bits further down).
Some more data: It -looks- like what happens is that the
flush_to_ldisc work queue entry constantly re-queues itself (because
the PTY is full ?) and the workqueue thread will basically loop
forver calling it without ever scheduling, thus starving the consumer
process that could have emptied the PTY."
which is pretty much exactly the problem we fixed in a5660b41af6a.
Milton Miller pointed out the 'unsigned int' issue.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: Milton Miller <miltonm@bga.com>
Cc: Stefan Bigler <stefan.bigler@keymile.com>
Cc: Toby Gray <toby.gray@realvnc.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
it makes it simpler to keep track of the amount of
bytes received and simplifies how flush_to_ldisc counts
the remaining bytes. It also fixes a bug of lost bytes
on n_tty when flushing too many bytes via the USB
serial gadget driver.
Tested-by: Stefan Bigler <stefan.bigler@keymile.com>
Tested-by: Toby Gray <toby.gray@realvnc.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
remove invalid location line in each file header after location
moved from driver/char to driver/tty
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
These were missed the last time I cleaned this up
globally, because of code moving around or new code
getting merged.
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
Cc: Greg KH <gregkh@suse.de>
The vt and other related code is moved into the drivers/tty/vt directory.
Cc: Jiri Slaby <jslaby@suse.cz>
