commit 7cf64b18b0b96e751178b8d0505d8466ff5a448f upstream.
vt_in_use() dereferences console_driver->ttys[i] without proper locking.
This is broken because the tty can be closed and freed concurrently.
We could fix this by using 'READ_ONCE(console_driver->ttys[i]) != NULL'
and skipping the check of tty_struct::count. But, looking at
console_driver->ttys[i] isn't really appropriate anyway because even if
it is NULL the tty can still be in the process of being closed.
Instead, fix it by making vt_in_use() require console_lock() and check
whether the vt is allocated and has port refcount > 1. This works since
following the patch "vt: vt_ioctl: fix VT_DISALLOCATE freeing in-use
virtual console" the port refcount is incremented while the vt is open.
Reproducer (very unreliable, but it worked for me after a few minutes):
#include <fcntl.h>
#include <linux/vt.h>
int main()
int fd, nproc;
struct vt_stat state;
char ttyname[16];
fd = open("/dev/tty10", O_RDONLY);
for (nproc = 1; nproc < 8; nproc *= 2)
fork();
for (;;) {
sprintf(ttyname, "/dev/tty%d", rand() % 8);
close(open(ttyname, O_RDONLY));
ioctl(fd, VT_GETSTATE, &state);
KASAN report:
BUG: KASAN: use-after-free in vt_in_use drivers/tty/vt/vt_ioctl.c:48 [inline]
BUG: KASAN: use-after-free in vt_ioctl+0x1ad3/0x1d70 drivers/tty/vt/vt_ioctl.c:657
Read of size 4 at addr ffff888065722468 by task syz-vt2/132
CPU: 0 PID: 132 Comm: syz-vt2 Not tainted 5.6.0-rc5-00130-g089b6d3654916 #13
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS ?-20191223_100556-anatol 04/01/2014
Call Trace:
tty_ioctl+0x9db/0x11b0 drivers/tty/tty_io.c:2660
Allocated by task 136:
kzalloc include/linux/slab.h:669 [inline]
alloc_tty_struct+0x96/0x8a0 drivers/tty/tty_io.c:2982
tty_init_dev+0x23/0x350 drivers/tty/tty_io.c:1334
tty_open_by_driver drivers/tty/tty_io.c:1987 [inline]
tty_open+0x3ca/0xb30 drivers/tty/tty_io.c:2035
Freed by task 41:
kfree+0xbf/0x200 mm/slab.c:3757
free_tty_struct+0x8d/0xb0 drivers/tty/tty_io.c:177
release_one_tty+0x22d/0x2f0 drivers/tty/tty_io.c:1468
process_one_work+0x7f1/0x14b0 kernel/workqueue.c:2264
worker_thread+0x8b/0xc80 kernel/workqueue.c:2410
Fixes: 4001d7b7fc27 ("vt: push down the tty lock so we can see what is left to tackle")
Cc: <stable@vger.kernel.org> # v3.4+
Acked-by: Jiri Slaby <jslaby@suse.cz>
Link: https://lore.kernel.org/r/20200322034305.210082-3-ebiggers@kernel.org
commit ca4463bf8438b403596edd0ec961ca0d4fbe0220 upstream.
The VT_DISALLOCATE ioctl can free a virtual console while tty_release()
is still running, causing a use-after-free in con_shutdown(). This
occurs because VT_DISALLOCATE considers a virtual console's
'struct vc_data' to be unused as soon as the corresponding tty's
refcount hits 0. But actually it may be still being closed.
Fix this by making vc_data be reference-counted via the embedded
'struct tty_port'. A newly allocated virtual console has refcount 1.
Opening it for the first time increments the refcount to 2. Closing it
for the last time decrements the refcount (in tty_operations::cleanup()
so that it happens late enough), as does VT_DISALLOCATE.
Reproducer:
#include <fcntl.h>
#include <sys/ioctl.h>
#include <unistd.h>
int main()
if (fork()) {
for (;;)
close(open("/dev/tty5", O_RDWR));
} else {
int fd = open("/dev/tty10", O_RDWR);
for (;;)
ioctl(fd, VT_DISALLOCATE, 5);
KASAN report:
BUG: KASAN: use-after-free in con_shutdown+0x76/0x80 drivers/tty/vt/vt.c:3278
Write of size 8 at addr ffff88806a4ec108 by task syz_vt/129
CPU: 0 PID: 129 Comm: syz_vt Not tainted 5.6.0-rc2 #11
Call Trace:
release_tty+0xa8/0x410 drivers/tty/tty_io.c:1514
tty_release_struct+0x34/0x50 drivers/tty/tty_io.c:1629
tty_release+0x984/0xed0 drivers/tty/tty_io.c:1789
Allocated by task 129:
vc_allocate drivers/tty/vt/vt.c:1085 [inline]
vc_allocate+0x1ac/0x680 drivers/tty/vt/vt.c:1066
con_install+0x4d/0x3f0 drivers/tty/vt/vt.c:3229
tty_driver_install_tty drivers/tty/tty_io.c:1228 [inline]
tty_init_dev+0x94/0x350 drivers/tty/tty_io.c:1341
Freed by task 130:
kfree+0xbf/0x1e0 mm/slab.c:3757
vt_disallocate drivers/tty/vt/vt_ioctl.c:300 [inline]
vt_ioctl+0x16dc/0x1e30 drivers/tty/vt/vt_ioctl.c:818
Reported-by: syzbot+522643ab5729b0421998@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20200322034305.210082-2-ebiggers@kernel.org
commit 1aa6e058dd6cd04471b1f21298270014daf48ac9 upstream.
The vc_cons_allocated() checks in vt_ioctl() and vt_compat_ioctl() are
unnecessary because they can only be reached by calling ioctl() on an
open tty, which implies the corresponding virtual console is allocated.
And even if the virtual console *could* be freed concurrently, then
these checks would be broken since they aren't done under console_lock,
and the vc_data is dereferenced before them anyway.
So, remove these unneeded checks to avoid confusion.
Link: https://lore.kernel.org/r/20200224080326.295046-1-ebiggers@kernel.org
commit f400991bf872debffb01c46da882dc97d7e3248e upstream.
vt_dont_switch is pure boolean, no need for whole char.
Link: https://lore.kernel.org/r/20200219073951.16151-6-jslaby@suse.cz
commit e587e8f17433ddb26954f0edf5b2f95c42155ae9 upstream.
These two were macros. Switch them to static inlines, so that it's more
understandable what they are doing.
Link: https://lore.kernel.org/r/20200219073951.16151-2-jslaby@suse.cz
commit dce05aa6eec977f1472abed95ccd71276b9a3864 upstream.
Avoid global variables (namely sel_cons) by introducing vc_is_sel. It
checks whether the parameter is the current selection console. This will
help putting sel_cons to a struct later.
Link: https://lore.kernel.org/r/20200219073951.16151-1-jslaby@suse.cz
commit e8c75a30a23c6ba63f4ef6895cbf41fd42f21aa2 upstream.
sel_lock cannot nest in the console lock. Thanks to syzkaller, the
kernel states firmly:
> WARNING: possible circular locking dependency detected
> 5.6.0-rc3-syzkaller #0 Not tainted
> syz-executor.4/20336 is trying to acquire lock:
> ffff8880a2e952a0 (&tty->termios_rwsem){++++}, at: tty_unthrottle+0x22/0x100 drivers/tty/tty_ioctl.c:136
> but task is already holding lock:
> ffffffff89462e70 (sel_lock){+.+.}, at: paste_selection+0x118/0x470 drivers/tty/vt/selection.c:374
> which lock already depends on the new lock.
> the existing dependency chain (in reverse order) is:
> -> #2 (sel_lock){+.+.}:
> mutex_lock_nested+0x1b/0x30 kernel/locking/mutex.c:1118
> set_selection_kernel+0x3b8/0x18a0 drivers/tty/vt/selection.c:217
> set_selection_user+0x63/0x80 drivers/tty/vt/selection.c:181
> tioclinux+0x103/0x530 drivers/tty/vt/vt.c:3050
> vt_ioctl+0x3f1/0x3a30 drivers/tty/vt/vt_ioctl.c:364
This is ioctl(TIOCL_SETSEL).
Locks held on the path: console_lock -> sel_lock
> -> #1 (console_lock){+.+.}:
> console_lock+0x46/0x70 kernel/printk/printk.c:2289
> con_flush_chars+0x50/0x650 drivers/tty/vt/vt.c:3223
> n_tty_write+0xeae/0x1200 drivers/tty/n_tty.c:2350
> do_tty_write drivers/tty/tty_io.c:962 [inline]
> tty_write+0x5a1/0x950 drivers/tty/tty_io.c:1046
This is write().
Locks held on the path: termios_rwsem -> console_lock
> -> #0 (&tty->termios_rwsem){++++}:
> down_write+0x57/0x140 kernel/locking/rwsem.c:1534
> mkiss_receive_buf+0x12aa/0x1340 drivers/net/hamradio/mkiss.c:902
> tty_ldisc_receive_buf+0x12f/0x170 drivers/tty/tty_buffer.c:465
> paste_selection+0x346/0x470 drivers/tty/vt/selection.c:389
> tioclinux+0x121/0x530 drivers/tty/vt/vt.c:3055
This is ioctl(TIOCL_PASTESEL).
Locks held on the path: sel_lock -> termios_rwsem
> other info that might help us debug this:
> Chain exists of:
> &tty->termios_rwsem --> console_lock --> sel_lock
Clearly. From the above, we have:
Fix this by reversing the console_lock -> sel_lock dependency in
ioctl(TIOCL_SETSEL). First, lock sel_lock, then console_lock.
Reported-by: syzbot+26183d9746e62da329b8@syzkaller.appspotmail.com
Fixes: 07e6124a1a46 ("vt: selection, close sel_buffer race")
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200228115406.5735-2-jslaby@suse.cz
commit 4b70dd57a15d2f4685ac6e38056bad93e81e982f upstream.
We need to nest the console lock in sel_lock, so we have to push it down
a bit. Fortunately, the callers of set_selection_* just lock the console
lock around the function call. So moving it down is easy.
In the next patch, we switch the order.
Link: https://lore.kernel.org/r/20200228115406.5735-1-jslaby@suse.cz
commit 07e6124a1a46b4b5a9b3cacc0c306b50da87abf5 upstream.
syzkaller reported this UAF:
BUG: KASAN: use-after-free in n_tty_receive_buf_common+0x2481/0x2940 drivers/tty/n_tty.c:1741
Read of size 1 at addr ffff8880089e40e9 by task syz-executor.1/13184
CPU: 0 PID: 13184 Comm: syz-executor.1 Not tainted 5.4.7 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
Call Trace:
kasan_report+0xe/0x20 mm/kasan/common.c:634
tty_ldisc_receive_buf+0xac/0x190 drivers/tty/tty_buffer.c:461
paste_selection+0x297/0x400 drivers/tty/vt/selection.c:372
tioclinux+0x20d/0x4e0 drivers/tty/vt/vt.c:3044
vt_ioctl+0x1bcf/0x28d0 drivers/tty/vt/vt_ioctl.c:364
tty_ioctl+0x525/0x15a0 drivers/tty/tty_io.c:2657
vfs_ioctl fs/ioctl.c:47 [inline]
It is due to a race between parallel paste_selection (TIOCL_PASTESEL)
and set_selection_user (TIOCL_SETSEL) invocations. One uses sel_buffer,
while the other frees it and reallocates a new one for another
selection. Add a mutex to close this race.
The mutex takes care properly of sel_buffer and sel_buffer_lth only. The
other selection global variables (like sel_start, sel_end, and sel_cons)
are protected only in set_selection_user. The other functions need quite
some more work to close the races of the variables there. This is going
to happen later.
This likely fixes (I am unsure as there is no reproducer provided) bug
206361 too. It was marked as CVE-2020-8648.
Reported-by: syzbot+59997e8d5cbdc486e6f6@syzkaller.appspotmail.com
References: https://bugzilla.kernel.org/show_bug.cgi?id=206361
Link: https://lore.kernel.org/r/20200210081131.23572-2-jslaby@suse.cz
commit 4a3e208474204e879d22a310b244cb2f39e5b1f8 upstream.
in this place, the function should return a
negative value and the PTR_ERR already returns
a negative,so return -PTR_ERR() is wrong.
Signed-off-by: tangbin <tangbin@cmss.chinamobile.com>
Link: https://lore.kernel.org/r/20200305013823.20976-1-tangbin@cmss.chinamobile.com
[ Upstream commit 87c5cbf71ecbb9e289d60a2df22eb686c70bf196 ]
On AR934x this UART is usually not initialized by the bootloader
as it is only used as a secondary serial port while the primary
UART is a newly introduced NS16550-compatible.
In order to make use of the ar933x-uart on AR934x without RTS/CTS
hardware flow control, one needs to set the
UART_CS_{RX,TX}_READY_ORIDE bits as other than on AR933x where this
UART is used as primary/console, the bootloader on AR934x typically
doesn't set those bits.
Setting them explicitely on AR933x should not do any harm, so just
set them unconditionally.
Tested-by: Chuanhong Guo <gch981213@gmail.com>
Signed-off-by: Daniel Golle <daniel@makrotopia.org>
Link: https://lore.kernel.org/r/20200207095335.GA179836@makrotopia.org
commit 7febbcbc48fc92e3f33863b32ed715ba4aff18c4 upstream.
The commit 54e53b2e8081
("tty: serial: 8250: pass IRQ shared flag to UART ports")
nicely explained the problem:
---8<---8<---
On some systems IRQ lines between multiple UARTs might be shared. If so, the
irqflags have to be configured accordingly. The reason is: The 8250 port startup
code performs IRQ tests *before* the IRQ handler for that particular port is
registered. This is performed in serial8250_do_startup(). This function checks
whether IRQF_SHARED is configured and only then disables the IRQ line while
testing.
This test is performed upon each open() of the UART device. Imagine two UARTs
share the same IRQ line: On is already opened and the IRQ is active. When the
second UART is opened, the IRQ line has to be disabled while performing IRQ
tests. Otherwise an IRQ might handler might be invoked, but the IRQ itself
cannot be handled, because the corresponding handler isn't registered,
yet. That's because the 8250 code uses a chain-handler and invokes the
corresponding port's IRQ handling routines himself.
Unfortunately this IRQF_SHARED flag isn't configured for UARTs probed via device
tree even if the IRQs are shared. This way, the actual and shared IRQ line isn't
disabled while performing tests and the kernel correctly detects a spurious
IRQ. So, adding this flag to the DT probe solves the issue.
Note: The UPF_SHARE_IRQ flag is configured unconditionally. Therefore, the
IRQF_SHARED flag can be set unconditionally as well.
Example stack trace by performing `echo 1 > /dev/ttyS2` on a non-patched system:
|irq 85: nobody cared (try booting with the "irqpoll" option)
|handlers:
|[<ffff0000080fc628>] irq_default_primary_handler threaded [<ffff00000855fbb8>] serial8250_interrupt
|Disabling IRQ #85
---8<---8<---
But unfortunately didn't fix the root cause. Let's try again here by moving
IRQ flag assignment from serial_link_irq_chain() to serial8250_do_startup().
This should fix the similar issue reported for 8250_pnp case.
Since this change we don't need to have custom solutions in 8250_aspeed_vuart
and 8250_of drivers, thus, drop them.
Fixes: 1c2f04937b3e ("serial: 8250: add IRQ trigger support")
Reported-by: Li RongQing <lirongqing@baidu.com>
Cc: Kurt Kanzenbach <kurt@linutronix.de>
Cc: Vikram Pandita <vikram.pandita@ti.com>
Acked-by: Kurt Kanzenbach <kurt@linutronix.de>
Link: https://lore.kernel.org/r/20200211135559.85960-1-andriy.shevchenko@linux.intel.com
[Kurt: Backport to v4.9]
Signed-off-by: Kurt Kanzenbach <kurt@linutronix.de>
commit c3fee60908db4a8594f2e4a2131998384b8fa006 upstream.
The commit 97f5f0cd8cd0a0544 ("Input: implement SysRq as a separate input
handler") added pr_fmt() definition. It caused a duplicated message
prefix in the sysrq header messages, for example:
[ 177.053931] sysrq: SysRq : Show backtrace of all active CPUs
[ 742.864776] sysrq: SysRq : HELP : loglevel(0-9) reboot(b) crash(c)
Fixes: 97f5f0cd8cd0a05 ("Input: implement SysRq as a separate input handler")
Signed-off-by: Petr Mladek <pmladek@suse.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Tommi Rantala <tommi.t.rantala@nokia.com>
commit 075e1a0c50f59ea210561d0d0fedbd945615df78 upstream.
The sysrq header line is printed with an increased loglevel
to provide users some positive feedback.
The original loglevel is not restored when the sysrq operation
is disabled. This bug was introduced in 2.6.12 (pre-git-history)
by the commit ("Allow admin to enable only some of the Magic-Sysrq
functions").
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 6cd1ed50efd88261298577cd92a14f2768eddeeb ]
We need to make sure vc_cons[i].d is not NULL after grabbing
console_lock(), or risk a crash.
general protection fault, probably for non-canonical address 0xdffffc0000000068: 0000 [#1] PREEMPT SMP KASAN
KASAN: null-ptr-deref in range [0x0000000000000340-0x0000000000000347]
CPU: 1 PID: 19462 Comm: syz-executor.5 Not tainted 5.5.0-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:vt_ioctl+0x1f96/0x26d0 drivers/tty/vt/vt_ioctl.c:883
Code: 74 41 e8 bd a6 84 fd 48 89 d8 48 c1 e8 03 42 80 3c 28 00 0f 85 e4 04 00 00 48 8b 03 48 8d b8 40 03 00 00 48 89 fa 48 c1 ea 03 <42> 0f b6 14 2a 84 d2 74 09 80 fa 03 0f 8e b1 05 00 00 44 89 b8 40
RSP: 0018:ffffc900086d7bb0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: ffffffff8c34ee88 RCX: ffffc9001415c000
RDX: 0000000000000068 RSI: ffffffff83f0e6e3 RDI: 0000000000000340
RBP: ffffc900086d7cd0 R08: ffff888054ce0100 R09: fffffbfff16a2f6d
R10: ffff888054ce0998 R11: ffff888054ce0100 R12: 000000000000001d
R13: dffffc0000000000 R14: 1ffff920010daf79 R15: 000000000000ff7f
FS: 00007f7d13c12700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007ffd477e3c38 CR3: 0000000095d0a000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
tty_ioctl+0xa37/0x14f0 drivers/tty/tty_io.c:2660
ksys_ioctl+0x123/0x180 fs/ioctl.c:763
__do_sys_ioctl fs/ioctl.c:772 [inline]
__se_sys_ioctl fs/ioctl.c:770 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:770
do_syscall_64+0xfa/0x790 arch/x86/entry/common.c:294
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x45b399
Code: ad b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f7d13c11c78 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00007f7d13c126d4 RCX: 000000000045b399
RDX: 0000000020000080 RSI: 000000000000560a RDI: 0000000000000003
RBP: 000000000075bf20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000666 R14: 00000000004c7f04 R15: 000000000075bf2c
Modules linked in:
---[ end trace 80970faf7a67eb77 ]---
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: syzbot <syzkaller@googlegroups.com>
Link: https://lore.kernel.org/r/20200210190721.200418-1-edumazet@google.com
[ Upstream commit 1b3bce4d6bf839304a90951b4b25a5863533bf2a ]
commit f76707831829530ffdd3888bebc108aecefccaa0 upstream.
There has oops as below happen on i.MX8MP EVK platform that has
6G bytes DDR memory.
when (xmit->tail < xmit->head) && (xmit->head == 0),
it setups one sg entry with sg->length is zero:
sg_set_buf(sgl + 1, xmit->buf, xmit->head);
if xmit->buf is allocated from >4G address space, and SDMA only
support <4G address space, then dma_map_sg() will call swiotlb_map()
to do bounce buffer copying and mapping.
But swiotlb_map() don't allow sg entry's length is zero, otherwise
report BUG_ON().
So the patch is to correct the tx DMA scatter list.
Oops:
[ 287.675715] kernel BUG at kernel/dma/swiotlb.c:497!
[ 287.680592] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 287.686075] Modules linked in:
[ 287.689133] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.3-00016-g3fdc4e0-dirty #10
[ 287.696872] Hardware name: FSL i.MX8MP EVK (DT)
[ 287.701402] pstate: 80000085 (Nzcv daIf -PAN -UAO)
[ 287.706199] pc : swiotlb_tbl_map_single+0x1fc/0x310
[ 287.711076] lr : swiotlb_map+0x60/0x148
[ 287.714909] sp : ffff800010003c00
[ 287.718221] x29: ffff800010003c00 x28: 0000000000000000
[ 287.723533] x27: 0000000000000040 x26: ffff800011ae0000
[ 287.728844] x25: ffff800011ae09f8 x24: 0000000000000000
[ 287.734155] x23: 00000001b7af9000 x22: 0000000000000000
[ 287.739465] x21: ffff000176409c10 x20: 00000000001f7ffe
[ 287.744776] x19: ffff000176409c10 x18: 000000000000002e
[ 287.750087] x17: 0000000000000000 x16: 0000000000000000
[ 287.755397] x15: 0000000000000000 x14: 0000000000000000
[ 287.760707] x13: ffff00017f334000 x12: 0000000000000001
[ 287.766018] x11: 00000000001fffff x10: 0000000000000000
[ 287.771328] x9 : 0000000000000003 x8 : 0000000000000000
[ 287.776638] x7 : 0000000000000000 x6 : 0000000000000000
[ 287.781949] x5 : 0000000000200000 x4 : 0000000000000000
[ 287.787259] x3 : 0000000000000001 x2 : 00000001b7af9000
[ 287.792570] x1 : 00000000fbfff000 x0 : 0000000000000000
[ 287.797881] Call trace:
[ 287.800328] swiotlb_tbl_map_single+0x1fc/0x310
[ 287.804859] swiotlb_map+0x60/0x148
[ 287.808347] dma_direct_map_page+0xf0/0x130
[ 287.812530] dma_direct_map_sg+0x78/0xe0
[ 287.816453] imx_uart_dma_tx+0x134/0x2f8
[ 287.820374] imx_uart_dma_tx_callback+0xd8/0x168
[ 287.824992] vchan_complete+0x194/0x200
[ 287.828828] tasklet_action_common.isra.0+0x154/0x1a0
[ 287.833879] tasklet_action+0x24/0x30
[ 287.837540] __do_softirq+0x120/0x23c
[ 287.841202] irq_exit+0xb8/0xd8
[ 287.844343] __handle_domain_irq+0x64/0xb8
[ 287.848438] gic_handle_irq+0x5c/0x148
[ 287.852185] el1_irq+0xb8/0x180
[ 287.855327] cpuidle_enter_state+0x84/0x360
[ 287.859508] cpuidle_enter+0x34/0x48
[ 287.863083] call_cpuidle+0x18/0x38
[ 287.866571] do_idle+0x1e0/0x280
[ 287.869798] cpu_startup_entry+0x20/0x40
[ 287.873721] rest_init+0xd4/0xe0
[ 287.876949] arch_call_rest_init+0xc/0x14
[ 287.880958] start_kernel+0x420/0x44c
[ 287.884622] Code: 9124c021 9417aff8 a94363f7 17ffffd5 (d4210000)
[ 287.890718] ---[ end trace 5bc44c4ab6b009ce ]---
[ 287.895334] Kernel panic - not syncing: Fatal exception in interrupt
[ 287.901686] SMP: stopping secondary CPUs
[ 288.905607] SMP: failed to stop secondary CPUs 0-1
[ 288.910395] Kernel Offset: disabled
[ 288.913882] CPU features: 0x0002,2000200c
[ 288.917888] Memory Limit: none
[ 288.920944] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Reported-by: Eagle Zhou <eagle.zhou@nxp.com>
Tested-by: Eagle Zhou <eagle.zhou@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Fixes: 7942f8577f2a ("serial: imx: TX DMA: clean up sg initialization")
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Link: https://lore.kernel.org/r/1581401761-6378-1-git-send-email-fugang.duan@nxp.com
commit 04b5bfe3dc94e64d0590c54045815cb5183fb095 upstream.
In atmel_shutdown() we call atmel_stop_rx() and atmel_stop_tx() functions.
Prevent the rx restart that is implemented in RS485 or ISO7816 modes when
calling atmel_stop_tx() by using the atomic information tasklet_shutdown
that is already in place for this purpose.
Fixes: 98f2082c3ac4 ("tty/serial: atmel: enforce tasklet init and termination sequences")
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Link: https://lore.kernel.org/r/20200210152053.8289-1-nicolas.ferre@microchip.com
commit 687bff0cd08f790d540cfb7b2349f0d876cdddec upstream.
When pasting a selection to a vt, the task is set as INTERRUPTIBLE while
waiting for a tty to unthrottle. But signals are not handled at all.
Normally, this is not a problem as tty_ldisc_receive_buf receives all
the goods and a user has no reason to interrupt the task.
There are two scenarios where this matters:
1) when the tty is throttled and a signal is sent to the process, it
spins on a CPU until the tty is unthrottled. schedule() does not
really echedule, but returns immediately, of course.
2) when the sel_buffer becomes invalid, KASAN prevents any reads from it
and the loop simply does not proceed and spins forever (causing the
tty to throttle, but the code never sleeps, the same as above). This
sometimes happens as there is a race in the sel_buffer handling code.
So add signal handling to this ioctl (TIOCL_PASTESEL) and return -EINTR
in case a signal is pending.
Link: https://lore.kernel.org/r/20200210081131.23572-1-jslaby@suse.cz
[ Upstream commit 446e76873b5e4e70bdee5db2f2a894d5b4a7d081 ]
Clang warns:
../drivers/tty/synclink_gt.c:1337:3: warning: misleading indentation;
statement is not part of the previous 'if' [-Wmisleading-indentation]
if (C_CRTSCTS(tty)) {
../drivers/tty/synclink_gt.c:1335:2: note: previous statement is here
if (I_IXOFF(tty))
../drivers/tty/synclink_gt.c:2563:3: warning: misleading indentation;
if (I_BRKINT(info->port.tty) || I_PARMRK(info->port.tty))
../drivers/tty/synclink_gt.c:2561:2: note: previous statement is here
if (I_INPCK(info->port.tty))
../drivers/tty/synclink_gt.c:3221:3: warning: misleading indentation;
statement is not part of the previous 'else' [-Wmisleading-indentation]
set_signals(info);
../drivers/tty/synclink_gt.c:3219:2: note: previous statement is here
else
3 warnings generated.
The indentation on these lines is not at all consistent, tabs and spaces
are mixed together. Convert to just using tabs to be consistent with the
Linux kernel coding style and eliminate these warnings from clang.
Link: https://github.com/ClangBuiltLinux/linux/issues/822
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Link: https://lore.kernel.org/r/20191218023912.13827-1-natechancellor@gmail.com
[ Upstream commit 1feedf61e7265128244f6993f23421f33dd93dbc ]
Clang warns:
../drivers/tty/synclinkmp.c:1456:3: warning: misleading indentation;
../drivers/tty/synclinkmp.c:1453:2: note: previous statement is here
if (I_IXOFF(tty))
../drivers/tty/synclinkmp.c:2473:8: warning: misleading indentation;
info->port.tty->hw_stopped = 0;
../drivers/tty/synclinkmp.c:2471:7: note: previous statement is here
if ( debug_level >= DEBUG_LEVEL_ISR )
../drivers/tty/synclinkmp.c:2482:8: warning: misleading indentation;
info->port.tty->hw_stopped = 1;
../drivers/tty/synclinkmp.c:2480:7: note: previous statement is here
../drivers/tty/synclinkmp.c:2809:3: warning: misleading indentation;
../drivers/tty/synclinkmp.c:2807:2: note: previous statement is here
../drivers/tty/synclinkmp.c:3246:3: warning: misleading indentation;
set_signals(info);
../drivers/tty/synclinkmp.c:3244:2: note: previous statement is here
else
5 warnings generated.
Link: https://github.com/ClangBuiltLinux/linux/issues/823
Link: https://lore.kernel.org/r/20191218024720.3528-1-natechancellor@gmail.com
commit dc76697d7e933d5e299116f219c890568785ea15 upstream.
Unbinding the bcm2835aux UART driver raises the following error if the
maximum number of 8250 UARTs is set to 1 (via the 8250.nr_uarts module
parameter or CONFIG_SERIAL_8250_RUNTIME_UARTS):
(NULL device *): Removing wrong port: a6f80333 != fa20408b
That's because bcm2835aux_serial_probe() retrieves UART line number 1
from the devicetree and stores it in data->uart.port.line, while
serial8250_register_8250_port() instead uses UART line number 0,
which is stored in data->line.
On driver unbind, bcm2835aux_serial_remove() uses data->uart.port.line,
which contains the wrong number. Fix it.
The issue does not occur if the maximum number of 8250 UARTs is >= 2.
Fixes: bdc5f3009580 ("serial: bcm2835: add driver for bcm2835-aux-uart")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: stable@vger.kernel.org # v4.6+
Cc: Martin Sperl <kernel@martin.sperl.org>
Reviewed-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de>
Tested-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de>
Link: https://lore.kernel.org/r/912ccf553c5258135c6d7e8f404a101ef320f0f4.1579175223.git.lukas@wunner.de
[ Upstream commit b83b957c91f68e53f0dc596e129e8305761f2a32 ]
Disables the tx irq when the transmission is ended and updates stop_tx
conditions for code cleanup.
Fixes: 48a6092fb41f ("serial: stm32-usart: Add STM32 USART Driver")
Signed-off-by: Erwan Le Ray <erwan.leray@st.com>
[ Upstream commit 7dd50e205b3348dc7784efbdf85723551de64a25 ]
There is a potential NULL pointer dereference in case
alloc_ctrl_packet() fails and returns NULL.
Fixes: 099dc4fb6265 ("ipwireless: driver for PC Card 3G/UMTS modem")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit 74887542fdcc92ad06a48c0cca17cdf09fc8aa00 upstream.
Per Documentation/DMA-API-HOWTO.txt,
To unmap a scatterlist, just call:
dma_unmap_sg(dev, sglist, nents, direction);
.. note::
The 'nents' argument to the dma_unmap_sg call must be
the _same_ one you passed into the dma_map_sg call,
it should _NOT_ be the 'count' value _returned_ from the
dma_map_sg call.
However in the driver, priv->nent is directly assigned with value
returned from dma_map_sg, and dma_unmap_sg use priv->nent for unmap,
this breaks the API usage.
So introduce a new entry orig_nent to remember 'nents'.
Fixes: da3564ee027e ("pch_uart: add multi-scatter processing")
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Link: https://lore.kernel.org/r/1573623259-6339-1-git-send-email-peng.fan@nxp.com
commit 596fd8dffb745afcebc0ec6968e17fe29f02044c upstream.
The dmaengine_prep_slave_sg needs to use sg count returned
by dma_map_sg, not use sport->dma_tx_nents, because the return
value of dma_map_sg is not always same with "nents".
Fixes: b4cdc8f61beb ("serial: imx: add DMA support for imx6q")
Link: https://lore.kernel.org/r/1573108875-26530-1-git-send-email-peng.fan@nxp.com
commit 273f632912f1b24b642ba5b7eb5022e43a72f3b5 upstream.
If the serial device is disconnected and reconnected, it re-enumerates
properly but does not link it. fwiw, linking means just saving the port
index, so allow it always as there is no harm in saving the same value
again even if it tries to relink with the same port.
Fixes: fb2b90014d78 ("tty: link tty and port before configuring it as console")
Reported-by: Kenneth R. Crudup <kenny@panix.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Link: https://lore.kernel.org/r/20191227174434.12057-1-sudipm.mukherjee@gmail.com
commit fb2b90014d782d80d7ebf663e50f96d8c507a73c upstream.
There seems to be a race condition in tty drivers and I could see on
many boot cycles a NULL pointer dereference as tty_init_dev() tries to
do 'tty->port->itty = tty' even though tty->port is NULL.
'tty->port' will be set by the driver and if the driver has not yet done
it before we open the tty device we can get to this situation. By adding
some extra debug prints, I noticed that:
6.650130: uart_add_one_port
6.663849: register_console
6.664846: tty_open
6.674391: tty_init_dev
6.675456: tty_port_link_device
uart_add_one_port() registers the console, as soon as it registers, the
userspace tries to use it and that leads to tty_open() but
uart_add_one_port() has not yet done tty_port_link_device() and so
tty->port is not yet configured when control reaches tty_init_dev().
Further look into the code and tty_port_link_device() is done by
uart_add_one_port(). After registering the console uart_add_one_port()
will call tty_port_register_device_attr_serdev() and
tty_port_link_device() is called from this.
Call add tty_port_link_device() before uart_configure_port() is done and
add a check in tty_port_link_device() so that it only links the port if
it has not been done yet.
Suggested-by: Jiri Slaby <jslaby@suse.com>
Link: https://lore.kernel.org/r/20191212131602.29504-1-sudipm.mukherjee@gmail.com
[ Upstream commit 934bda59f286d0221f1a3ebab7f5156a996cc37d ]
While developing KASAN for 64-bit book3s, I hit the following stack
over-read.
It occurs because the hypercall to put characters onto the terminal
takes 2 longs (128 bits/16 bytes) of characters at a time, and so
hvc_put_chars() would unconditionally copy 16 bytes from the argument
buffer, regardless of supplied length. However, udbg_hvc_putc() can
call hvc_put_chars() with a single-byte buffer, leading to the error.
BUG: KASAN: stack-out-of-bounds in hvc_put_chars+0xdc/0x110
Read of size 8 at addr c0000000023e7a90 by task swapper/0
CPU: 0 PID: 0 Comm: swapper Not tainted 5.2.0-rc2-next-20190528-02824-g048a6ab4835b #113
Call Trace:
dump_stack+0x104/0x154 (unreliable)
print_address_description+0xa0/0x30c
__kasan_report+0x20c/0x224
kasan_report+0x18/0x30
__asan_report_load8_noabort+0x24/0x40
hvterm_raw_put_chars+0x9c/0x110
udbg_hvc_putc+0x154/0x200
udbg_write+0xf0/0x240
console_unlock+0x868/0xd30
register_console+0x970/0xe90
register_early_udbg_console+0xf8/0x114
setup_arch+0x108/0x790
start_kernel+0x104/0x784
start_here_common+0x1c/0x534
Memory state around the buggy address:
c0000000023e7980: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0000000023e7a00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f1 f1
>c0000000023e7a80: f1 f1 01 f2 f2 f2 00 00 00 00 00 00 00 00 00 00
c0000000023e7b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0000000023e7b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Document that a 16-byte buffer is requred, and provide it in udbg.
Signed-off-by: Daniel Axtens <dja@axtens.net>
commit 0e4f7f920a5c6bfe5e851e989f27b35a0cc7fb7e upstream.
As the commit 677fe555cbfb ("serial: imx: Fix recursive locking bug")
has mentioned the uart driver might cause recursive locking between
normal printing and the kernel debugging facilities (e.g. sysrq and
oops). In the commit it gave out suggestion for fixing recursive
locking issue: "The solution is to avoid locking in the sysrq case
and trylock in the oops_in_progress case."
This patch follows the suggestion (also used the exactly same code with
other serial drivers, e.g. amba-pl011.c) to fix the recursive locking
issue, this can avoid stuck caused by deadlock and print out log for
sysrq and oops.
Fixes: 04896a77a97b ("msm_serial: serial driver for MSM7K onboard serial peripheral.")
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Reviewed-by: Jeffrey Hugo <jeffrey.l.hugo@gmail.com>
Link: https://lore.kernel.org/r/20191127141544.4277-2-leo.yan@linaro.org
[ Upstream commit cb47b9f8630ae3fa3f5fbd0c7003faba7abdf711 ]
Use MCK_DIV8 when the clock divider is > 65535. Unfortunately the mode
register was already written thus the clock selection is ignored.
Fix by doing the baud rate calulation before setting the mode.
Fixes: 5bf5635ac170 ("tty/serial: atmel: add fractional baud rate support")
Signed-off-by: David Engraf <david.engraf@sysgo.com>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Acked-by: Richard Genoud <richard.genoud@gmail.com>
Link: https://lore.kernel.org/r/20191216085403.17050-1-david.engraf@sysgo.com
commit b2b2dd71e0859436d4e05b2f61f86140250ed3f8 upstream.
Do not try to handle keycodes that are too big, otherwise we risk doing
out-of-bounds writes:
BUG: KASAN: global-out-of-bounds in clear_bit include/asm-generic/bitops-instrumented.h:56 [inline]
BUG: KASAN: global-out-of-bounds in kbd_keycode drivers/tty/vt/keyboard.c:1411 [inline]
BUG: KASAN: global-out-of-bounds in kbd_event+0xe6b/0x3790 drivers/tty/vt/keyboard.c:1495
Write of size 8 at addr ffffffff89a1b2d8 by task syz-executor108/1722
input_to_handler+0x3b6/0x4c0 drivers/input/input.c:118
input_pass_values.part.0+0x2e3/0x720 drivers/input/input.c:145
input_pass_values drivers/input/input.c:949 [inline]
input_set_keycode+0x290/0x320 drivers/input/input.c:954
evdev_handle_set_keycode_v2+0xc4/0x120 drivers/input/evdev.c:882
evdev_do_ioctl drivers/input/evdev.c:1150 [inline]
In this case we were dealing with a fuzzed HID device that declared over
12K buttons, and while HID layer should not be reporting to us such big
keycodes, we should also be defensive and reject invalid data ourselves as
well.
Reported-by: syzbot+19340dff067c2d3835c0@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191122204220.GA129459@dtor-ws
[ Upstream commit c96cf923a98d1b094df9f0cf97a83e118817e31b ]
There might be situations where tty_ldisc_lock() has blocked, but there
is already IO on tty and it prevents line discipline changes.
It might theoretically turn into dead-lock.
Basically, provide more priority to pending tty_ldisc_lock() than to
servicing reads/writes over tty.
User-visible issue was reported by Mikulas where on pa-risc with
Debian 5 reboot took either 80 seconds, 3 minutes or 3:25 after proper
locking in tty_reopen().
Cc: Jiri Slaby <jslaby@suse.com>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Dmitry Safonov <dima@arista.com>
[ Upstream commit 63fd4b94b948c14eeb27a3bbf50ea0f7f0593bad ]
The ipg clock only needs to be unprepared in case preparing
per clock fails. The ipg clock has already disabled at the point.
Fixes: 1cf93e0d5488 ("serial: imx: remove the uart_console() check")
Signed-off-by: Stefan Agner <stefan@agner.ch>
commit 50b2b571c5f3df721fc81bf9a12c521dfbe019ba upstream.
The driver forgets to call pm_runtime_disable in remove.
Add the missed calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Link: https://lore.kernel.org/r/20191118024833.21587-1-hslester96@gmail.com
commit 7d73170e1c282576419f8b50a771f1fcd2b81a94 upstream.
Doing fuzz test on sbsa uart device, causes a kernel crash
due to NULL pointer dereference:
Unable to handle kernel paging request at virtual address fffffffffffffffc
pgd = ffffffe331723000
[fffffffffffffffc] *pgd=0000002333595003, *pud=0000002333595003, *pmd=00000
Internal error: Oops: 96000005 [#1] PREEMPT SMP
Modules linked in: ping(O) jffs2 rtos_snapshot(O) pramdisk(O) hisi_sfc(O)
Drv_Nandc_K(O) Drv_SysCtl_K(O) Drv_SysClk_K(O) bsp_reg(O) hns3(O)
hns3_uio_enet(O) hclgevf(O) hclge(O) hnae3(O) mdio_factory(O)
mdio_registry(O) mdio_dev(O) mdio(O) hns3_info(O) rtos_kbox_panic(O)
uart_suspend(O) rsm(O) stp llc tunnel4 xt_tcpudp ipt_REJECT nf_reject_ipv4
iptable_filter ip_tables x_tables sd_mod xhci_plat_hcd xhci_pci xhci_hcd
usbmon usbhid usb_storage ohci_platform ohci_pci ohci_hcd hid_generic hid
ehci_platform ehci_pci ehci_hcd vfat fat usbcore usb_common scsi_mod
yaffs2multi(O) ext4 jbd2 ext2 mbcache ofpart i2c_dev i2c_core uio ubi nand
nand_ecc nand_ids cfi_cmdset_0002 cfi_cmdset_0001 cfi_probe gen_probe
cmdlinepart chipreg mtdblock mtd_blkdevs mtd nfsd auth_rpcgss oid_registry
nfsv3 nfs nfs_acl lockd sunrpc grace autofs4
CPU: 2 PID: 2385 Comm: tty_fuzz_test Tainted: G O 4.4.193 #1
task: ffffffe32b23f110 task.stack: ffffffe32bda4000
PC is at uart_break_ctl+0x44/0x84
LR is at uart_break_ctl+0x34/0x84
pc : [<ffffff8393196098>] lr : [<ffffff8393196088>] pstate: 80000005
sp : ffffffe32bda7cc0
x29: ffffffe32bda7cc0 x28: ffffffe32b23f110
x27: ffffff8393402000 x26: 0000000000000000
x25: ffffffe32b233f40 x24: ffffffc07a8ec680
x23: 0000000000005425 x22: 00000000ffffffff
x21: ffffffe33ed73c98 x20: 0000000000000000
x19: ffffffe33ed94168 x18: 0000000000000004
x17: 0000007f92ae9d30 x16: ffffff8392fa6064
x15: 0000000000000010 x14: 0000000000000000
x13: 0000000000000000 x12: 0000000000000000
x11: 0000000000000020 x10: 0000007ffdac1708
x9 : 0000000000000078 x8 : 000000000000001d
x7 : 0000000052a64887 x6 : ffffffe32bda7e08
x5 : ffffffe32b23c000 x4 : 0000005fbc5b0000
x3 : ffffff83938d5018 x2 : 0000000000000080
x1 : ffffffe32b23c040 x0 : ffffff83934428f8
virtual start addr offset is 38ac00000
module base offset is 2cd4cf1000
linear region base offset is : 0
Process tty_fuzz_test (pid: 2385, stack limit = 0xffffffe32bda4000)
Stack: (0xffffffe32bda7cc0 to 0xffffffe32bda8000)
7cc0: ffffffe32bda7cf0 ffffff8393177718 ffffffc07a8ec680 ffffff8393196054
7ce0: 000000001739f2e0 0000007ffdac1978 ffffffe32bda7d20 ffffff8393179a1c
7d00: 0000000000000000 ffffff8393c0a000 ffffffc07a8ec680 cb88537fdc8ba600
7d20: ffffffe32bda7df0 ffffff8392fa5a40 ffffff8393c0a000 0000000000005425
7d40: 0000007ffdac1978 ffffffe32b233f40 ffffff8393178dcc 0000000000000003
7d60: 000000000000011d 000000000000001d ffffffe32b23f110 000000000000029e
7d80: ffffffe34fe8d5d0 0000000000000000 ffffffe32bda7e14 cb88537fdc8ba600
7da0: ffffffe32bda7e30 ffffff8393042cfc ffffff8393c41720 ffffff8393c46410
7dc0: ffffff839304fa68 ffffffe32b233f40 0000000000005425 0000007ffdac1978
7de0: 000000000000011d cb88537fdc8ba600 ffffffe32bda7e70 ffffff8392fa60cc
7e00: 0000000000000000 ffffffe32b233f40 ffffffe32b233f40 0000000000000003
7e20: 0000000000005425 0000007ffdac1978 ffffffe32bda7e70 ffffff8392fa60b0
7e40: 0000000000000280 ffffffe32b233f40 ffffffe32b233f40 0000000000000003
7e60: 0000000000005425 cb88537fdc8ba600 0000000000000000 ffffff8392e02e78
7e80: 0000000000000280 0000005fbc5b0000 ffffffffffffffff 0000007f92ae9d3c
7ea0: 0000000060000000 0000000000000015 0000000000000003 0000000000005425
7ec0: 0000007ffdac1978 0000000000000000 00000000a54c910e 0000007f92b95014
7ee0: 0000007f92b95090 0000000052a64887 000000000000001d 0000000000000078
7f00: 0000007ffdac1708 0000000000000020 0000000000000000 0000000000000000
7f20: 0000000000000000 0000000000000010 000000556acf0090 0000007f92ae9d30
7f40: 0000000000000004 000000556acdef10 0000000000000000 000000556acdebd0
7f60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
7f80: 0000000000000000 0000000000000000 0000000000000000 0000007ffdac1840
7fa0: 000000556acdedcc 0000007ffdac1840 0000007f92ae9d3c 0000000060000000
7fc0: 0000000000000000 0000000000000000 0000000000000003 000000000000001d
7fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
Call trace:
Exception stack(0xffffffe32bda7ab0 to 0xffffffe32bda7bf0)
7aa0: 0000000000001000 0000007fffffffff
7ac0: ffffffe32bda7cc0 ffffff8393196098 0000000080000005 0000000000000025
7ae0: ffffffe32b233f40 ffffff83930d777c ffffffe32bda7b30 ffffff83930d777c
7b00: ffffffe32bda7be0 ffffff83938d5000 ffffffe32bda7be0 ffffffe32bda7c20
7b20: ffffffe32bda7b60 ffffff83930d777c ffffffe32bda7c10 ffffff83938d5000
7b40: ffffffe32bda7c10 ffffffe32bda7c50 ffffff8393c0a000 ffffffe32b23f110
7b60: ffffffe32bda7b70 ffffff8392e09df4 ffffffe32bda7bb0 cb88537fdc8ba600
7b80: ffffff83934428f8 ffffffe32b23c040 0000000000000080 ffffff83938d5018
7ba0: 0000005fbc5b0000 ffffffe32b23c000 ffffffe32bda7e08 0000000052a64887
7bc0: 000000000000001d 0000000000000078 0000007ffdac1708 0000000000000020
7be0: 0000000000000000 0000000000000000
[<ffffff8393196098>] uart_break_ctl+0x44/0x84
[<ffffff8393177718>] send_break+0xa0/0x114
[<ffffff8393179a1c>] tty_ioctl+0xc50/0xe84
[<ffffff8392fa5a40>] do_vfs_ioctl+0xc4/0x6e8
[<ffffff8392fa60cc>] SyS_ioctl+0x68/0x9c
[<ffffff8392e02e78>] __sys_trace_return+0x0/0x4
Code: b9410ea0 34000160 f9408aa0 f9402814 (b85fc280)
---[ end trace 8606094f1960c5e0 ]---
Fix this problem by adding NULL checks prior to calling break_ctl ops.
Signed-off-by: Jiangfeng Xiao <xiaojiangfeng@huawei.com>
Link: https://lore.kernel.org/r/1574263133-28259-1-git-send-email-xiaojiangfeng@huawei.com
commit f6a196477184b99a31d16366a8e826558aa11f6d upstream.
PL011's ->flush_buffer() implementation releases and reacquires the port
lock. Due to a race condition here, data can end up being added to the
circular buffer but neither being discarded nor being sent out. This
leads to, for example, tcdrain(2) waiting indefinitely.
Process A Process B
uart_flush_buffer()
- acquire lock
- circ_clear
- pl011_flush_buffer()
-- release lock
-- dmaengine_terminate_all()
uart_write()
- acquire lock
- add chars to circ buffer
- start_tx()
-- start DMA
- release lock
-- acquire lock
-- turn off DMA
-- release lock
// Data in circ buffer but DMA is off
According to the comment in the code, the releasing of the lock around
dmaengine_terminate_all() is to avoid a deadlock with the DMA engine
callback. However, since the time this code was written, the DMA engine
API documentation seems to have been clarified to say that
dmaengine_terminate_all() (in the identically implemented but
differently named dmaengine_terminate_async() variant) does not wait for
any running complete callback to be completed and can even be called
from a complete callback. So there is no possibility of deadlock if the
DMA engine driver implements this API correctly.
So we should be able to just remove this release and reacquire of the
lock to prevent the aforementioned race condition.
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Link: https://lore.kernel.org/r/20191118092547.32135-1-vincent.whitchurch@axis.com
commit b027ce258369cbfa88401a691c23dad01deb9f9b upstream.
hci_qca interfaces to the wcn3990 via a uart_dm on the msm8998 mtp and
Lenovo Miix 630 laptop. As part of initializing the wcn3990, hci_qca
disables flow, configures the uart baudrate, and then reenables flow - at
which point an event is expected to be received over the uart from the
wcn3990. It is observed that this event comes after the baudrate change
but before hci_qca re-enables flow. This is unexpected, and is a result of
msm_reset() being broken.
According to the uart_dm hardware documentation, it is recommended that
automatic hardware flow control be enabled by setting RX_RDY_CTL. Auto
hw flow control will manage RFR based on the configured watermark. When
there is space to receive data, the hw will assert RFR. When the watermark
is hit, the hw will de-assert RFR.
The hardware documentation indicates that RFR can me manually managed via
CR when RX_RDY_CTL is not set. SET_RFR asserts RFR, and RESET_RFR
de-asserts RFR.
msm_reset() is broken because after resetting the hardware, it
unconditionally asserts RFR via SET_RFR. This enables flow regardless of
the current configuration, and would undo a previous flow disable
operation. It should instead de-assert RFR via RESET_RFR to block flow
until the hardware is reconfigured. msm_serial should rely on the client
to specify that flow should be enabled, either via mctrl() or the termios
structure, and only assert RFR in response to those triggers.
Signed-off-by: Jeffrey Hugo <jeffrey.l.hugo@gmail.com>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Reviewed-by: Andy Gross <agross@kernel.org>
Link: https://lore.kernel.org/r/20191021154616.25457-1-jeffrey.l.hugo@gmail.com
commit 487ee861de176090b055eba5b252b56a3b9973d6 upstream.
When enabling iommu for lpuart + edma, iommu framework may concatenate
two sgs into one.
Fixes: 6250cc30c4c4e ("tty: serial: fsl_lpuart: Use scatter/gather DMA for Tx")
Link: https://lore.kernel.org/r/1572932977-17866-1-git-send-email-peng.fan@nxp.com
[ Upstream commit a8da3c7873ea57acb8f9cea58c0af477522965aa ]
Function max310x_tx_empty() accesses the IRQSTS register, which is
cleared by IC when reading, so if there is an interrupt status, we
will lose it. This patch implement the transmitter check only by
the current FIFO level.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
[ Upstream commit 27230e51349fde075598c1b59d15e1ff802f3f6e ]
compat_ptr() for pointer-taking ones...
[ Upstream commit 5963e8a3122471cadfe0eba41c4ceaeaa5c8bb4d ]
On the error path of mxs_auart_request_gpio_irq() is performed
backward iterating with index i of enum type. Underline enum type
may be unsigned char. In this case check (--i >= 0) will be always
true and error handling goes into infinite loop.
The patch changes the check so that it is valid for signed and unsigned
types.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Anton Vasilyev <vasilyev@ispras.ru>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
[ Upstream commit 37e3ab00e4734acc15d96b2926aab55c894f4d9c ]
When using mctrl_gpio_to_gpiod, it dereferences gpios into a single
requested GPIO. This dereferencing can break if gpios is NULL,
so this patch adds a NULL check before dereferencing it. If
gpios is NULL, this function will also return NULL.
Reviewed-by: Yegor Yefremov <yegorslists@googlemail.com>
Link: https://lore.kernel.org/r/20191006163314.23191-1-aford173@gmail.com
[ Upstream commit 30ec514d440cf2c472c8e4b0079af2c731f71a3e ]
The SC16IS752 has an Enhanced Feature Register which is aliased at the
same address as the Interrupt Identification Register; accessing it
requires that a magic value is written to the Line Configuration
Register. If an interrupt is raised while the EFR is mapped in then
the ISR won't be able to access the IIR, leading to the "Unexpected
interrupt" error messages.
Avoid the problem by claiming a mutex around accesses to the EFR
register, also claiming the mutex in the interrupt handler work
item (this is equivalent to disabling interrupts to interlock against
a non-threaded interrupt handler).
See: https://github.com/raspberrypi/linux/issues/2529
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
commit a553add0846f355a28ed4e81134012e4a1e280c2 upstream.
Call uart_unregister_driver() conditionally instead of
unconditionally, only if it has been previously registered.
This uses driver.state, just as the sh-sci.c driver does.
Fixes this null pointer dereference in tty_unregister_driver(),
since the 'driver' argument is null:
general protection fault: 0000 [#1] PREEMPT SMP KASAN PTI
RIP: 0010:tty_unregister_driver+0x25/0x1d0
Fixes: 238b8721a554 ("[PATCH] serial uartlite driver")
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Link: https://lore.kernel.org/r/9c8e6581-6fcc-a595-0897-4d90f5d710df@infradead.org
commit d2ace81bf902a9f11d52e59e5d232d2255a0e353 upstream.
When half-duplex RS485 communication is used, after RX is started, TX
tasklet still needs to be scheduled tasklet. This avoids console freezing
when more data is to be transmitted, if the serial communication is not
closed.
Fixes: 69646d7a3689 ("tty/serial: atmel: RS485 HD w/DMA: enable RX after TX is stopped")
Signed-off-by: Razvan Stefanescu <razvan.stefanescu@microchip.com>
Link: https://lore.kernel.org/r/20190813074025.16218-1-razvan.stefanescu@microchip.com
commit 9c801e313195addaf11c16e155f50789d6ebfd19 upstream.
The sequence of arguments which was passed to handle_lsr_errors() didn't
match the parameters defined in that function, &lsr was passed to flag
and &flag was passed to lsr, this patch fixed that.
Fixes: b7396a38fb28 ("tty/serial: Add Spreadtrum sc9836-uart driver support")
Signed-off-by: Chunyan Zhang <chunyan.zhang@unisoc.com>
Signed-off-by: Chunyan Zhang <zhang.lyra@gmail.com>
Link: https://lore.kernel.org/r/20190905074151.5268-1-zhang.lyra@gmail.com
[ Upstream commit 952041a8639a7a3a73a2b6573cb8aa8518bc39f8 ]
While reviewing rwsem down_slowpath, Will noticed ldsem had a copy of
a bug we just found for rwsem.
X = 0;
CPU0 CPU1
rwsem_down_read()
for (;;) {
set_current_state(TASK_UNINTERRUPTIBLE);
X = 1;
rwsem_up_write();
rwsem_mark_wake()
atomic_long_add(adjustment, &sem->count);
smp_store_release(&waiter->task, NULL);
if (!waiter.task)
break;
r = X;
Allows 'r == 0'.
Reported-by: Will Deacon <will@kernel.org>
Acked-by: Will Deacon <will@kernel.org>
Cc: Peter Hurley <peter@hurleysoftware.com>
Fixes: 4898e640caf0 ("tty: Add timed, writer-prioritized rw semaphore")
[ Upstream commit 8493eab02608b0e82f67b892aa72882e510c31d0 ]
When uart_flush_buffer() is called, the .flush_buffer() callback zeroes
the tx_dma_len field. This may race with the work queue function
handling transmit DMA requests:
1. If the buffer is flushed before the first DMA API call,
dmaengine_prep_slave_single() may be called with a zero length,
causing the DMA request to never complete, leading to messages
like:
rcar-dmac e7300000.dma-controller: Channel Address Error happen
and, with debug enabled:
sh-sci e6e88000.serial: sci_dma_tx_work_fn: ffff800639b55000: 0...0, cookie 126
and DMA timeouts.
2. If the buffer is flushed after the first DMA API call, but before
the second, dma_sync_single_for_device() may be called with a zero
length, causing the transmit data not to be flushed to RAM, and
leading to stale data being output.
Fix this by:
1. Letting sci_dma_tx_work_fn() return immediately if the transmit
buffer is empty,
2. Extending the critical section to cover all DMA preparational work,
so tx_dma_len stays consistent for all of it,
3. Using local copies of circ_buf.head and circ_buf.tail, to make sure
they match the actual operation above.
Reported-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Suggested-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Tested-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Link: https://lore.kernel.org/r/20190624123540.20629-2-geert+renesas@glider.be
[ Upstream commit 775b7ffd7d6d5db320d99b0a485c51e04dfcf9f1 ]
While the .flush_buffer() callback clears sci_port.tx_dma_len since
commit 1cf4a7efdc71cab8 ("serial: sh-sci: Fix race condition causing
garbage during shutdown"), it does not terminate a transmit DMA
operation that may be in progress.
Fix this by terminating any pending DMA operations, and resetting the
corresponding cookie.
Link: https://lore.kernel.org/r/20190624123540.20629-3-geert+renesas@glider.be
