Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
commit 4291086b1f081b869c6d79e5b7441633dc3ace00 upstream.
The tty atomic_write_lock does not provide an exclusion guarantee for
the tty driver if the termios settings are LECHO & !OPOST. And since
it is unexpected and not allowed to call TTY buffer helpers like
tty_insert_flip_string concurrently, this may lead to crashes when
concurrect writers call pty_write. In that case the following two
writers:
* the ECHOing from a workqueue and
* pty_write from the process
race and can overflow the corresponding TTY buffer like follows.
If we look into tty_insert_flip_string_fixed_flag, there is:
int space = __tty_buffer_request_room(port, goal, flags);
struct tty_buffer *tb = port->buf.tail;
memcpy(char_buf_ptr(tb, tb->used), chars, space);
tb->used += space;
so the race of the two can result in something like this:
A B
memcpy(buf(tb->used), ...)
tb->used += space;
memcpy(buf(tb->used), ...) ->BOOM
B's memcpy is past the tty_buffer due to the previous A's tb->used
increment.
Since the N_TTY line discipline input processing can output
concurrently with a tty write, obtain the N_TTY ldisc output_lock to
serialize echo output with normal tty writes. This ensures the tty
buffer helper tty_insert_flip_string is not called concurrently and
everything is fine.
Note that this is nicely reproducible by an ordinary user using
forkpty and some setup around that (raw termios + ECHO). And it is
present in kernels at least after commit
d945cb9cce20ac7143c2de8d88b187f62db99bdc (pty: Rework the pty layer to
use the normal buffering logic) in 2.6.31-rc3.
js: add more info to the commit log
js: switch to bool
js: lock unconditionally
js: lock only the tty->ops->write call
References: CVE-2014-0196
Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cherry-picked from
git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
branch: stable/linux-3.10.y
commit: abb5100737bba3f82b5514350fea89ca361ac66c
Change-Id: I81e79fe209f5c7b25cac35189a44286e5a9ddac0
Signed-off-by: JP Abgrall <jpa@google.com>
On tegra,after a break is issued, uart status register
generates FIFOE error rather than the next character
ready status. For that quirk is already present. Hook is added
for the quirk so that sysrq key combination works. This helps
in debugging soft hangs
Bug 1401397
Change-Id: I0131cfc986aba694ddc21d859685748843534611
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/401535
(cherry picked from commit c72b366e010b5cfbac6541eb339a0324b863ff17)
Reviewed-on: http://git-master/r/406402
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
writers:
tb->used += space;
A B
tb->used += space;
increment.
everything is fine.
js: switch to bool
commit b790f210fe8423eff881b2a8a93ba5dbc45534d0 upstream.
The sleep function was updated to put the serial port to sleep only when necessary.
This appears to resolve the errant behavior of the driver as described in
Kernel Bug 61961 – "My Exar Corp. XR17C/D152 Dual PCI UART modem does not
work with 3.8.0".
Signed-off-by: Michael Welling <mwelling@ieee.org>
commit 501fed45b7e8836ee9373f4d31e2d85e3db6103a upstream.
When 'console=hvc0' is specified to the kernel parameter in x86 KVM guest,
hvc console is setup within a kthread. However, that will cause SEGV
and the boot will fail when the driver is builtin to the kernel,
because currently hvc_console_setup() is annotated with '__init'. This
patch removes '__init' to boot the guest successfully with 'console=hvc0'.
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com>
commit f76a1cbed18c86e2d192455f0daebb48458965f3 upstream.
Commit 3e6c6f630a5282df8f3393a59f10eb9c56536d23 ("Delay creation of
khcvd thread") moved the call of hvc_init from being a device_initcall
into hvc_alloc, and used a non-null hvc_driver as indication of whether
hvc_init had already been called.
The problem with this is that hvc_driver is only assigned a value
at the bottom of hvc_init, and so there is a window where multiple
hvc_alloc calls can be in progress at the same time and hence try
and call hvc_init multiple times. Previously the use of device_init
guaranteed that hvc_init was only called once.
This manifests itself as sporadic instances of two hvc_init calls
racing each other, and with the loser of the race getting -EBUSY
from tty_register_driver() and hence that virtual console fails:
Couldn't register hvc console driver
virtio-ports vport0p1: error -16 allocating hvc for port
Here we add an atomic_t to guarantee we'll never run hvc_init twice.
Fixes: 3e6c6f630a52 ("Delay creation of khcvd thread")
Reported-by: Jim Somerville <Jim.Somerville@windriver.com>
Tested-by: Jim Somerville <Jim.Somerville@windriver.com>
commit 723abd87f6e536f1353c8f64f621520bc29523a3 upstream.
The 'active' sysfs attribute should refer to the currently active tty
devices the console is running on, not the currently active console. The
console structure doesn't refer to any device in sysfs, only the tty the
console is running on has. So we need to print out the tty names in
'active', not the console names.
There is one special-case, which is tty0. If the console is directed to
it, we want 'tty0' to show up in the file, so user-space knows that the
messages get forwarded to the active VT. The ->device() callback would
resolve tty0, though. Hence, treat it special and don't call into the VT
layer to resolve it (plymouth is known to depend on it).
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Werner Fink <werner@suse.de>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
dma_request_slave_channel_reason would only work in case
the device nodes are registered from DT. Added support
for DMA channel request for non-DT instances as well.
Bug 1497862
Change-Id: I1f8c1a1902cf3615a85061901348840213251fe3
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
By using dma_request_slave_channel_or_err(), the DMA slave ID can be
looked up from standard DT properties, and squirrelled away during
channel allocation. Hence, there's no need to use a custom DT property
to store the slave ID.
Change-Id: I56c2233d390ba185329a6e77e6bd6b0dfcdfe802
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Reviewed-on: http://git-master/r/389696
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 0930b0950a8996aa88b0d2ba4bb2bab27cc36bc7 upstream.
\E[3J console code (secure clear screen) needs to update_screen(vc)
in order to write-through blanks into off-screen video memory.
This has been removed accidentally in 3.6 by:
commit 81732c3b2fede049a692e58a7ceabb6d18ffb18c
Author: Jean-François Moine <moinejf@free.fr>
Date: Thu Sep 6 19:24:13 2012 +0200
tty vt: Fix line garbage in virtual console on command line edition
Signed-off-by: Petr Písař <petr.pisar@atlas.cz>
commit 3ac06b905655b3ef2fd2196bab36e4587e1e4e4f upstream.
3GPP TS 07.10 states in section 5.4.6.3.7:
"The length byte contains the value 2 or 3 ... depending on the break
signal." The break byte is optional and if it is sent, the length is
3. In fact the driver was not able to work with modems that send this
break byte in their modem status control message. If the modem just
sends the break byte if it is really set, then weird things might
happen.
The code for deconding the modem status to the internal linux
presentation in gsm_process_modem has already a big comment about
this 2 or 3 byte length thing and it is already able to decode the
brk, but the code calling the gsm_process_modem function in
gsm_control_modem does not encode it and hand it over the right way.
This patch fixes this.
Without this fix if the modem sends the brk byte in it's modem status
control message the driver will hang when opening a muxed channel.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
commit 3685f19e07802ec4207b52465c408f185b66490e upstream.
Tegra chips have 4 or 5 identical UART modules embedded. UARTs C..E have
their MODEM-control signals tied off to a static state. However UARTs A
and B can optionally route those signals to/from package pins, depending
on the exact pinmux configuration.
When these signals are not routed to package pins, false interrupts may
trigger either temporarily, or permanently, all while not showing up in
the IIR; it will read as NO_INT. This will eventually lead to the UART
IRQ being disabled due to unhandled interrupts. When this happens, the
kernel may print e.g.:
irq 68: nobody cared (try booting with the "irqpoll" option)
In order to prevent this, enable UART_BUG_NOMSR. This prevents
UART_IER_MSI from being enabled, which prevents the false interrupts
from triggering.
In practice, this is not needed under any of the following conditions:
* On Tegra chips after Tegra30, since the HW bug has apparently been
fixed.
* On UARTs C..E since their MODEM control signals are tied to the correct
static state which doesn't trigger the issue.
* On UARTs A..B if the MODEM control signals are routed out to package
pins, since they will then carry valid signals.
However, we ignore these exceptions for now, since they are only relevant
if a board actually hooks up more than a 4-wire UART, and no currently
supported board does this. If we ever support a board that does, we can
refine the algorithm that enables UART_BUG_NOMSR to take those exceptions
into account, and/or read a flag from DT/... that indicates that the
board has hooked up and pinmux'd more than a 4-wire UART.
Reported-by: Olof Johansson <olof@lixom.net> # autotester
commit 9c5320f8d7d9a2cf623e65d50e1113f34d9b9eb1 upstream.
Fix the initialisation of older Quatech serial cards which are fitted with
the AMCC PCI Matchmaker interface chip.
Signed-off-by: Jonathan Woithe (jwoithe@just42.net)
commit 48c0247d7b7bf58abb85a39021099529df365c4d upstream.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
commit 0cc7c6c7916b1b6f34350ff1473b80b9f7e459c0 upstream.
Interrupts were being cleaned up late in the shutdown handler, it is possible
that an interrupt can occur and schedule a tasklet that runs after the port is
cleaned up. There is a null dereference due to this race condition with the
following stacktrace:
[<c02092b0>] (atmel_tasklet_func+0x514/0x814) from [<c001fd34>] (tasklet_action+0x70/0xa8)
[<c001fd34>] (tasklet_action+0x70/0xa8) from [<c001f60c>] (__do_softirq+0x90/0x144)
[<c001f60c>] (__do_softirq+0x90/0x144) from [<c001fa18>] (irq_exit+0x40/0x4c)
[<c001fa18>] (irq_exit+0x40/0x4c) from [<c000e298>] (handle_IRQ+0x64/0x84)
[<c000e298>] (handle_IRQ+0x64/0x84) from [<c000d6c0>] (__irq_svc+0x40/0x50)
[<c000d6c0>] (__irq_svc+0x40/0x50) from [<c0208060>] (atmel_rx_dma_release+0x88/0xb8)
[<c0208060>] (atmel_rx_dma_release+0x88/0xb8) from [<c0209740>] (atmel_shutdown+0x104/0x160)
[<c0209740>] (atmel_shutdown+0x104/0x160) from [<c0205e8c>] (uart_port_shutdown+0x2c/0x38)
Signed-off-by: Marek Roszko <mark.roszko@gmail.com>
Acked-by: Leilei Zhao <leilei.zhao@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit fe43390702a1b5741fdf217063b05c7612b38303 upstream.
When the pl011 is being used for a console, pl011_console_write forces
the control register (CR) to enable the UART for transmission and then
restores this to the original value afterwards. It does this while
holding the port lock.
Unfortunately, when the uart is started or shutdown - say in response to
userland using the serial device for a terminal - then this updates the
control register without any locking.
This means we can have
pl011_console_write Save CR
pl011_startup Initialise CR, e.g. enable receive
pl011_console_write Restore old CR with receive not enabled
this result is a serial port which doesn't respond to any input.
A similar race in reverse could happen when the device is shutdown.
We can fix these problems by taking the port lock when updating CR.
Signed-off-by: Jon Medhurst <tixy@linaro.org>
commit d24c195f90cb1adb178d26d84c722d4b9e551e05 upstream.
Newer Intel PCHs with LPSS have the same Designware controllers than
Haswell but ACPI IDs are different. Add these IDs to the driver list.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit dc1dc2f8a5dd863bf2e79f338fc3ae29e99c683a upstream.
When booting a multi-platform m68k kernel on a non-Mac with "console=ttyS0"
on the kernel command line, it crashes with:
Unable to handle kernel NULL pointer dereference at virtual address (null)
Oops: 00000000
PC: [<0013ad28>] __pmz_startup+0x32/0x2a0
Call Trace: [<002c5d3e>] pmz_console_setup+0x64/0xe4
The normal tty driver doesn't crash, because init_pmz() checks
pmz_ports_count again after calling pmz_probe().
In the serial console initialization path, pmz_console_init() doesn't do
this, causing the driver to crash later.
Add a check for pmz_ports_count to fix this.
Cc: Finn Thain <fthain@telegraphics.com.au>
Acknowledge dma after aborting the RX dma request.
Bug 1423050
Bug 1415632
Change-Id: I1edfa49a92074aa37c9686865356091191be085b
Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/348692
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
Change device node name to match upstream driver.
Bug 1231069
Change-Id: Ica784dd54a6c00bf8ce9df60bed0e1a212cc99aa
Reviewed-on: http://git-master/r/299541
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
commit d969de8d83401683420638c8107dcfedb2146f37 upstream.
Due to missing braces on an if statement, in presence of a device_node a
port was always assigned -1, regardless of any alias entries in the
device tree. Conversely, if device_node was NULL, an unitialized port
ended up being used.
This patch adds the missing braces, fixing the issues.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
This reverts commit c131ba5b6169ae02c51c67e470df35e7ef71e21a.
Bug 1229695
Bug 1339412
Signed-off-by: Edgardo Handal <ehandal@nvidia.com>
Change-Id: I1ff590e58c82c7f4238e292fd6160502a8a8088c
Reviewed-on: http://git-master/r/299585
Reviewed-by: Matt Craighead <mcraighead@nvidia.com>
Reviewed-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
commit a9fbf4d591da6cd1d3eaab826c7c15f77fc8f6a3 upstream.
Commit d0380e6c3c0f6edb986d8798a23acfaf33d5df23 (early_printk:
consolidate random copies of identical code) added in 3.10 introduced
a check for con->index == -1 in early_console_register().
Initialize index to -1 for the xenboot console so earlyprintk=xen
works again.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 19b85cfb190eb9980eaf416bff96aef4159a430e upstream.
Fix tty_kref leak when tty_buffer_request room fails in dma-rx path.
Note that the tty ref isn't really needed anymore, but as the leak has
always been there, fixing it before removing should makes it easier to
backport the fix.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit fc0919c68cb2f75bb1af759315f9d7e2a9443c28 upstream.
Fix tty-kref leak introduced by commit 384e301e ("pch_uart: fix a
deadlock when pch_uart as console") which never put its tty reference.
commit cfd29aa0e81b791985e8428e6507e80e074e6730 upstream.
Fix potential tty-kref leak in stop_rx path.
commit 5cec7bf699c61d14f0538345076480bb8c8ebfbb upstream.
Commit 'e7f3880cd9b98c5bf9391ae7acdec82b75403776'
tty: Fix recursive deadlock in tty_perform_flush()
introduced a regression where tcflush() does not generate
SIGTTOU for background process groups.
Make sure ioctl(TCFLSH) calls tty_check_change() when
invoked from the line discipline.
Reported-by: Oleg Nesterov <oleg@redhat.com>
commit 03e1261778cca782d41a3d8e3945ca88cf93e01e upstream.
Starting from v3.10 (probably commit f91e2590410b: "tty: Signal
foreground group processes in hangup") disassociate_ctty() sends SIGCONT
if tty && on_exit. This breaks LSB test-suite, in particular test8 in
_exit.c and test40 in sigcon5.c.
Put the "!on_exit" check back to restore the old behaviour.
Review by Peter Hurley:
"Yes, this regression was introduced by me in that commit. The effect
of the regression is that ptys will receive a SIGCONT when, in similar
circumstances, ttys would not.
The fact that two test vectors accidentally tripped over this
regression suggests that some other apps may as well.
Thanks for catching this"
Reported-by: Karel Srot <ksrot@redhat.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
This is the 3.10.12 stable release
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
So that the upstream common clk infrastructure can live side by side.
Change-Id: I0fe0ef8cd207d27b707821eed838c75b8ec04025
Change the port name to SERIAL_TEGRA, driver name to serial-hs-tegra
and add some new compatible value for making easy to use.
bug 1349711
Change-Id: I6f16002c6b9a55954439f748b824fbba6364034c
Reviewed-on: http://git-master/r/269395
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Enable GCOV profiling in serial when enabled in defconfig.
Bug 1227962
Change-Id: I13a2ad9dfa3a8e5a58059bd7f5a207036f3d3d8e
Signed-off-by: Konsta Holtta <kholtta@nvidia.com>
Reviewed-on: http://git-master/r/264343
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Move serial-tegra header file to platform_data and renamed
as serial-tegra from serial_tegra.
Change-Id: I5c7b761192e40591453f626c3b6376742f9e5b70
Reviewed-on: http://git-master/r/264389
There is new high speed serial driver as serial-tegra and
legacy driver tegra_hsuart is no more used. Hence removing this
driver.
bug 1349711
Change-Id: I414a0cb24026e2bb9df46843739e449f45c437cc
Reviewed-on: http://git-master/r/263930
Update tx_circular buffer only when TX_DMA is pending.
Bug 1332139
Change-Id: I9d94066ca209c153e92468e544d107b310ddf206
Reviewed-on: http://git-master/r/259148
Tegra UART IIR sometimes not consistent with its IRQ signal
which will generate continous spurious interrupts, inorder to
recover from this, generate legal modem interrupt and handle it.
So add a seperate interrupt handler for tegra.
Bug 1229695
Bug 1339412
Change-Id: I1e8145fea015ece24150d3ef8a640695576b5826
Reviewed-on: http://git-master/r/256273
Tested-by: Alexander Van Brunt <avanbrunt@nvidia.com>
Rename device name to ttyHS* from ttyTHS*.
Bug 1323103
Change-Id: I98f83782e904ad27b61ec8cb754c64b5715ba4cd
Reviewed-on: http://git-master/r/233263
(cherry picked from commit 1b57a306934d92d1b9d2121b6a6f511f8321807f)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Reviewed-on: http://git-master/r/247128
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Tested-by: Dan Willemsen <dwillemsen@nvidia.com>
added chip data and also compatible, data fields in of_device_id
for T114 SOC.
Bug 1323103
Change-Id: Iea39ffa247c29f21e87be6b650f5f3b4aa960fbe
Signed-off-by: Kunal Agrawal <kunala@nvidia.com>
Reviewed-on: http://git-master/r/219674
(cherry picked from commit 0e22fbc3a4d1ff0e3d4d139742f74c59a9b41f6b)
Reviewed-on: http://git-master/r/247127
support registration of uart devices through board files also
Bug 1323103
Change-Id: Ie17bb8e204d11a83b0ac4935654fb1536d9c43d2
Reviewed-on: http://git-master/r/211162
(cherry picked from commit fcea3df82bc7a5136872c04b8429ac7f636f508d)
Reviewed-on: http://git-master/r/247126
This is the WAR for spurious interrupts for PORT_TEGRA.
Bug 1229695
Change-Id: Ia4c92577399334a50faacabd38ae3fac4f71a9d3
Reviewed-on: http://git-master/r/205164
(cherry picked from commit 969c7612e7569e6e2504ec2d8f532e4fb8e3d875)
Reviewed-on: http://git-master/r/215684
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
after-upstream-android
arch/arm/common/Kconfig
arch/arm/mm/Makefile
arch/arm/mm/cache-l2x0.c
arch/arm/mm/mmu.c
drivers/input/Kconfig
drivers/input/Makefile
drivers/power/Kconfig
kernel/futex.c
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
An intial high frequency pluse is seen while checking
for a National Semiconductor SuperIO chip. Disabling the
check by default.
Reviewed-on: http://git-master/r/131698
Change-Id: I6950958d8949fb7e02fe2fe1b5716223d4b0e23e
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/138941
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R638951e83c44e4ce27d9f89833dc9d16cef5ed3b
WAR to enable console prints when console service is not started
for port type TEGRA.
Bug 958959
Change-Id: I51e582d16195171f1f8bae9324e2ddece4638281
Signed-off-by: Pradeep Kumar <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/92814
Reviewed-by: Joshua Cha <joshuac@nvidia.com>
Tested-by: Joshua Cha <joshuac@nvidia.com>
Rebase-Id: Rcde9f4b18b8d520ba87f9cb3b0e49d8d3e55108c
