path: root/drivers/tty
2012-08-16pmac_zilog,kdb: Fix console poll hook to return instead of loopJason Wessel
kdb <-> kgdb transitioning does not work properly with this UART driver because the get character routine loops indefinitely as opposed to returning NO_POLL_CHAR per the expectation of the KDB I/O driver API. The symptom is a kernel hang when trying to switch debug modes. Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16serial: mxs-auart: fix the wrong RTS hardware flow controlHuang Shijie
Without checking if the auart supports the hardware flow control or not, the old mxs_auart_set_mctrl() asserted the RTS pin blindly. This will causes the auart receives wrong data in the following case: The far-end has already started the write operation, and wait for the auart asserts the RTS pin. Then the auart starts the read operation, but mxs_auart_set_mctrl() may be called before we set the RTSCTS in the mxs_auart_settermios(). So the RTS pin is asserted in a wrong situation, and we get the wrong data in the end. This bug has been catched when I connect the mx23(DTE) to the mx53(DCE). This patch also replaces the AUART_CTRL2_RTS with AUART_CTRL2_RTSEN. We should use the real the hardware flow control, not the software-controled hardware flow control. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10serial: ifx6x60: fix paging fault on spi_register_driverFengguang Wu
[ 117.240866] BUG: unable to handle kernel paging request at 815b627c [ 117.240866] IP: [<813fe94b>] spi_register_driver+0xb/0x50 ... [ 117.240866] Call Trace: [ 117.240866] [<817de977>] ifx_spi_init+0xbe/0xf0 The root cause is, spi_register_driver() is trying to write into the passed *const* struct spi_driver. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10serial: Change Kconfig entry for CLPS711X-targetAlexander Shiyan
This trivial patch adds a short description for SERIAL_CLPS711X Kconfig entry, removes excess dependence on the ARM-platform (this is done globally for the platform), allows the driver to be compiled by default and removes unnecessary description about GRUB and LILO, because these bootloaders do not supported this platform. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01serial: sh-sci: fix compilation breakage, when DMA is enabledGuennadi Liakhovetski
A recent commit: commit d6fa5a4e7ab605370fd6c982782f84ef2e6660e7 Author: Guennadi Liakhovetski <g.liakhovetski@gmx.de> serial: sh-sci: prepare for conversion to the shdma base library is not sufficient to update the sh-sci driver to the new shdma driver layout. This caused compilation breakage, when CONFIG_SERIAL_SH_SCI_DMA is enabled. This patch trivially fixes the problem by updating the DMA descriptor manipulation code. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-07-31Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random subsystem patches from Ted Ts'o: "This patch series contains a major revamp of how we collect entropy from interrupts for /dev/random and /dev/urandom. The goal is to addresses weaknesses discussed in the paper "Mining your Ps and Qs: Detection of Widespread Weak Keys in Network Devices", by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman, which will be published in the Proceedings of the 21st Usenix Security Symposium, August 2012. (See https://factorable.net for more information and an extended version of the paper.)" Fix up trivial conflicts due to nearby changes in drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c} * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits) random: mix in architectural randomness in extract_buf() dmi: Feed DMI table to /dev/random driver random: Add comment to random_initialize() random: final removal of IRQF_SAMPLE_RANDOM um: remove IRQF_SAMPLE_RANDOM which is now a no-op sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op [ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op ...
2012-07-27Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "First ARM push of this merge window, post me coming back from holiday. This is what has been in linux-next for the last few weeks. Not much to say which isn't described by the commit summaries." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (32 commits) ARM: 7463/1: topology: Update cpu_power according to DT information ARM: 7462/1: topology: factorize the update of sibling masks ARM: 7461/1: topology: Add arch_scale_freq_power function ARM: 7456/1: ptrace: provide separate functions for tracing syscall {entry,exit} ARM: 7455/1: audit: move syscall auditing until after ptrace SIGTRAP handling ARM: 7454/1: entry: don't bother with syscall tracing on ret_from_fork path ARM: 7453/1: audit: only allow syscall auditing for pure EABI userspace ARM: 7452/1: delay: allow timer-based delay implementation to be selected ARM: 7451/1: arch timer: implement read_current_timer and get_cycles ARM: 7450/1: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs ARM: 7449/1: use generic strnlen_user and strncpy_from_user functions ARM: 7448/1: perf: remove arm_perf_pmu_ids global enumeration ARM: 7447/1: rwlocks: remove unused branch labels from trylock routines ARM: 7446/1: spinlock: use ticket algorithm for ARMv6+ locking implementation ARM: 7445/1: mm: update CONTEXTIDR register to contain PID of current process ARM: 7444/1: kernel: add arch-timer C3STOP feature ARM: 7460/1: remove asm/locks.h ARM: 7439/1: head.S: simplify initial page table mapping ARM: 7437/1: zImage: Allow DTB command line concatenation with ATAG_CMDLINE ARM: 7436/1: Do not map the vectors page as write-through on UP systems ...
2012-07-27Merge branches 'audit', 'delay', 'fixes', 'misc' and 'sta2x11' into for-linusRussell King
2012-07-27Merge tag 'tty-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY/Serial patches from Greg Kroah-Hartman: "Here's the "tiny" set of patches for 3.6-rc1 for the tty layer and serial drivers. They were cherry-picked from the tty-next branch of the tty git tree, as they are small and "obvious" fixes. The larger changes, as mentioned before, will be saved for the 3.7-rc1 merge window. All of these changes have been in the linux-next releases for quite a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'tty-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: pch_uart: Fix parity setting issue pch_uart: Fix rx error interrupt setting issue pch_uart: Fix missing break for 16 byte fifo tty ldisc: Close/Reopen race prevention should check the proper flag pch_uart: Add eg20t_port lock field, avoid recursive spinlocks vt: fix race in vt_waitactive() serial/of-serial: Add LPC3220 standard UART compatible string serial/8250: Add LPC3220 standard UART type serial_core: Update buffer overrun statistics. serial: samsung: Fixed wrong comparison for baudclk_rate
2012-07-26pch_uart: Fix parity setting issueTomoya MORINAGA
Parity Setting value is reverse. E.G. In case of setting ODD parity, EVEN value is set. This patch inverts "if" condition. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26pch_uart: Fix rx error interrupt setting issueTomoya MORINAGA
Rx Error interrupt(E.G. parity error) is not enabled. So, when parity error occurs, error interrupt is not occurred. As a result, the received data is not dropped. This patch adds enable/disable rx error interrupt code. Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26pch_uart: Fix missing break for 16 byte fifoAlan Cox
Otherwise we fall back to the wrong value. Reported-by: <dcb314@hotmail.com> Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=44091 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26tty ldisc: Close/Reopen race prevention should check the proper flagShachar Shemesh
Commit acfa747b introduced the TTY_HUPPING flag to distinguish closed TTY from currently closing ones. The test in tty_set_ldisc still remained pointing at the old flag. This causes pppd to sometimes lapse into uninterruptible sleep when killed and restarted. Signed-off-by: Shachar Shemesh <shachar@liveu.tv> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26pch_uart: Add eg20t_port lock field, avoid recursive spinlocksDarren Hart
pch_uart_interrupt() takes priv->port.lock which leads to two recursive spinlock calls if low_latency==1 or CONFIG_PREEMPT_RT_FULL=y (one otherwise): pch_uart_interrupt spin_lock_irqsave(priv->port.lock, flags) case PCH_UART_IID_RDR_TO (data ready) handle_rx_to push_rx tty_port_tty_get spin_lock_irqsave(&port->lock, flags) <--- already hold this lock ... tty_flip_buffer_push ... flush_to_ldisc spin_lock_irqsave(&tty->buf.lock) spin_lock_irqsave(&tty->buf.lock) disc->ops->receive_buf(tty, char_buf) n_tty_receive_buf tty->ops->flush_chars() uart_flush_chars uart_start spin_lock_irqsave(&port->lock) <--- already hold this lock Avoid this by using a dedicated lock to protect the eg20t_port structure and IO access to its membase. This is more consistent with the 8250 driver. Ensure priv->lock is always take prior to priv->port.lock when taken at the same time. V2: Remove inadvertent whitespace change. V3: Account for oops_in_progress for the private lock in pch_console_write(). Note: Like the 8250 driver, if a printk is introduced anywhere inside the pch_console_write() critical section, the kernel will hang on a recursive spinlock on the private lock. The oops case is handled by using a trylock in the oops_in_progress case. Signed-off-by: Darren Hart <dvhart@linux.intel.com> CC: Tomoya MORINAGA <tomoya.rohm@gmail.com> CC: Feng Tang <feng.tang@intel.com> CC: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26vt: fix race in vt_waitactive()Rabin Vincent
pm_restore_console() is called from the suspend/resume path, and this calls vt_move_to_console(), which calls vt_waitactive(). There's a race in this path which causes the process which requests the suspend to sleep indefinitely waiting for an event which already happened: P1 P2 vt_move_to_console() set_console() schedule_console_callback() vt_waitactive() check n == fg_console +1 console_callback() switch_screen() vt_event_post() // no waiters vt_event_wait() // forever Fix the race by ensuring we're registered for the event before we check if it's already completed. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26serial/of-serial: Add LPC3220 standard UART compatible stringRoland Stigge
This patch adds a "compatible" string for the new 8250 UART type PORT_LPC3220. This is necessary for initializing LPC32xx UARTs via DT. Signed-off-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26serial/8250: Add LPC3220 standard UART typeRoland Stigge
LPC32xx has "Standard" UARTs that are actually 16550A compatible but have bigger FIFOs. Since the already supported 16X50 line still doesn't match here, we agreed on adding a new type. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26serial_core: Update buffer overrun statistics.Corbin
Currently, serial drivers don't report buffer overruns. When a buffer overrun occurs, tty_insert_flip_char returns 0, and no attempt is made to insert that same character again (i.e. it is lost). This patch reports buffer overruns via the buf_overrun field in the port's icount structure. Signed-off-by: Corbin Atkinson <corbin.atkinson@xxxxxx> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26serial: samsung: Fixed wrong comparison for baudclk_rateKyoungil Kim
port->baudclk_rate should be compared to the rate of port->baudclk, because port->baudclk_rate was assigned as the rate of port->baudclk previously. So to check that the current baudclk rate is same as previous rate, the target of comparison sholud be the rate of port->baudclk. Signed-off-by: Jun-Ho, Yoon <junho78.yoon@samsung.com> Signed-off-by: Kyoungil Kim <ki0351.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-24Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This time we have a new dmaengine driver from the tegra folks. Also we have Guennadi's cleanup of sh drivers which incudes a library for sh drivers. And the usual odd fixes in bunch of drivers and some nice cleanup of dw_dmac from Andy." Fix up conflicts in drivers/mmc/host/sh_mmcif.c * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: Cleanup logging messages mmc: sh_mmcif: switch to the new DMA channel allocation and configuration dma: sh: provide a migration path for slave drivers to stop using .private dma: sh: use an integer slave ID to improve API compatibility dmaengine: shdma: prepare to stop using struct dma_chan::private sh: remove unused DMA device pointer from SIU platform data ASoC: siu: don't use DMA device for channel filtering dmaengine: shdma: (cosmetic) simplify a static function dmaengine: at_hdmac: add a few const qualifiers dw_dmac: use 'u32' for LLI structure members, not dma_addr_t dw_dmac: mark dwc_dump_lli inline dma: mxs-dma: Export missing symbols from mxs-dma.c dma: shdma: convert to the shdma base library ASoC: fsi: prepare for conversion to the shdma base library usb: renesas_usbhs: prepare for conversion to the shdma base library ASoC: siu: prepare for conversion to the shdma base library serial: sh-sci: prepare for conversion to the shdma base library mmc: sh_mobile_sdhi: prepare for conversion to the shdma base library mmc: sh_mmcif: remove unneeded struct sh_mmcif_dma, prepare to shdma conversion dma: shdma: prepare for conversion to the shdma base library ...
2012-07-24Merge tag 'stable/for-linus-3.6-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen update from Konrad Rzeszutek Wilk: "Features: * Performance improvement to lower the amount of traps the hypervisor has to do 32-bit guests. Mainly for setting PTE entries and updating TLS descriptors. * MCE polling driver to collect hypervisor MCE buffer and present them to /dev/mcelog. * Physical CPU online/offline support. When an privileged guest is booted it is present with virtual CPUs, which might have an 1:1 to physical CPUs but usually don't. This provides mechanism to offline/online physical CPUs. Bug-fixes for: * Coverity found fixes in the console and ACPI processor driver. * PVonHVM kexec fixes along with some cleanups. * Pages that fall within E820 gaps and non-RAM regions (and had been released to hypervisor) would be populated back, but potentially in non-RAM regions." * tag 'stable/for-linus-3.6-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: populate correct number of pages when across mem boundary (v2) xen PVonHVM: move shared_info to MMIO before kexec xen: simplify init_hvm_pv_info xen: remove cast from HYPERVISOR_shared_info assignment xen: enable platform-pci only in a Xen guest xen/pv-on-hvm kexec: shutdown watches from old kernel xen/x86: avoid updating TLS descriptors if they haven't changed xen/x86: add desc_equal() to compare GDT descriptors xen/mm: zero PTEs for non-present MFNs in the initial page table xen/mm: do direct hypercall in xen_set_pte() if batching is unavailable xen/hvc: Fix up checks when the info is allocated. xen/acpi: Fix potential memory leak. xen/mce: add .poll method for mcelog device driver xen/mce: schedule a workqueue to avoid sleep in atomic context xen/pcpu: Xen physical cpus online/offline sys interface xen/mce: Register native mce handler as vMCE bounce back point x86, MCE, AMD: Adjust initcall sequence for xen xen/mce: Add mcelog support for Xen platform
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-19xen/hvc: Fix up checks when the info is allocated.Konrad Rzeszutek Wilk
Coverity would complain about this - even thought it looks OK. CID 401957 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-opTheodore Ts'o
With the changes in the random tree, IRQF_SAMPLE_RANDOM is now a no-op; interrupt randomness is now collected unconditionally in a very low-overhead fashion; see commit 775f4b297b. The IRQF_SAMPLE_RANDOM flag was scheduled to be removed in 2009 on the feature-removal-schedule, so this patch is preparation for the final removal of this flag. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2012-07-13serial: sh-sci: prepare for conversion to the shdma base libraryGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-07-10tty/hvc_opal: Fix debug function nameBenjamin Herrenschmidt
udbg_init_debug_opal() should be udbg_init_debug_opal_raw() as the caller in arch/powerpc/kernel/udbg.c expects Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-03serial: mxs-auart: Allow device tree probingFabio Estevam
Allow device tree probing. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Alan Cox <alan@linux.intel.com> Cc: <linux-serial@vger.kernel.org> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Subodh Nijsure <snijsure@grid-net.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-07-02Merge branch 'imx/sparse-irq' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into next/irq From Shawn Guo <shawn.guo@linaro.org>, this makes it possible to use sparse irqs with mach-imx. * 'imx/sparse-irq' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ() Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-01tty: serial: imx: remove the use of MXC_INTERNAL_IRQSShawn Guo
As the part of the effort to enable SPARE_IRQ for imx platform, the macro MXC_INTERNAL_IRQS will be removed. The imx serial driver has a references to it for a decision on flags of request_irq call based on rtsirq is beyond MXC_INTERNAL_IRQS. However the searching on imx platform code tells that rtsirq will never be beyond MXC_INTERNAL_IRQS. That said, the check, consequently the reference to MXC_INTERNAL_IRQS are not needed, so remove them. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: linux-serial@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-06-28ARM: 7433/1: serial: use the new linux/sizes.hAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-06-20Merge tag 'tty-3.5-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull serial driver fixes from Greg Kroah-Hartman: "Here are 3 patches resolving a boot regression (the mop500 fix), a build warning fix, and a kernel-doc fix. All tiny, but should go into the final 3.5 release. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'tty-3.5-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial/amba-pl011: move custom pin control to driver serial: fix serial_txx9.c build warning/typo serial: fix kernel-doc warnings in 8250.c
2012-06-15Merge tag 'stable/for-linus-3.5-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull five Xen bug-fixes from Konrad Rzeszutek Wilk: - When booting as PVHVM we would try to use PV console - but would not validate the parameters causing us to crash during restore b/c we re-use the wrong event channel. - When booting on machines with SR-IOV PCI bridge we didn't check for the bridge and tried to use it. - Under AMD machines would advertise the APERFMPERF resulting in needless amount of MSRs from the guest. - A global value (xen_released_pages) was not subtracted at bootup when pages were added back in. This resulted in the balloon worker having the wrong account of how many pages were truly released. - Fix dead-lock when xen-blkfront is run in the same domain as xen-blkback. * tag 'stable/for-linus-3.5-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: mark local pages as FOREIGN in the m2p_override xen/setup: filter APERFMPERF cpuid feature out xen/balloon: Subtract from xen_released_pages the count that is populated. xen/pci: Check for PCI bridge before using it. xen/events: Add WARN_ON when quick lookup found invalid type. xen/hvc: Check HVM_PARAM_CONSOLE_[EVTCHN|PFN] for correctness. xen/hvc: Fix error cases around HVM_PARAM_CONSOLE_PFN xen/hvc: Collapse error logic.
2012-06-13Merge branches 'sh/urgent', 'sh/core', 'sh/clockevents', 'sh/asm-generic' ↵Paul Mundt
and 'sh/trivial' into sh-fixes-for-linus
2012-06-13serial: sh-sci: Make probe fail for ports that exceed the maximum countLaurent Pinchart
The driver supports a maximum number of ports configurable at compile time. Make sure the probe() method fails when registering a port that exceeds the maximum instead of returning success without registering the port. This fixes a crash at system suspend time, when the driver tried to suspend a non-registered port using the UART core. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-06-13serial: sh-sci: Fix probe error pathsLaurent Pinchart
When probing fails, the driver must not try to cleanup resources that have not been initialized. Fix this. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-06-12serial/amba-pl011: move custom pin control to driverLinus Walleij
We had a boot regression in Ux500 in the merge window because two orthogonal pin control schemes for the PL011 were merged at the same time: - One using the .init() and .exit() hooks into the platform for Ux500 putting the pins into default vs sleep state respectively as the port was started/stopped. commit a09806607fd20bed2f8c41fe22793386790a14aa "ARM: ux500: switch to using pinctrl for uart0" - One hogging the default setting at PL011 probe() commit 258e055111d3cde2607e0d04eb91da2f7a59b591 "serial: amba-pl011: adopt pinctrl support" To get a solution that works for both let's scrap the stuff in the platform callbacks, instead have the driver itself select default and sleep states when the port is started/stopped. Hopefully this works for all clients. Platform callbacks are bad for device tree migration anyway, so this rids us of another problem in Ux500. Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Reported-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12serial: fix serial_txx9.c build warning/typoRandy Dunlap
Fix kconfig symbol test to use "defined": drivers/tty/serial/serial_txx9.c: warning: "CONFIG_CONSOLE_POLL" is not defined [-Wundef] Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12serial: fix kernel-doc warnings in 8250.cRandy Dunlap
Fix kernel-doc warnings in drivers/tty/serial/8250/8250.c: Warning(drivers/tty/serial/8250/8250.c:3128): No description found for parameter 'up' Warning(drivers/tty/serial/8250/8250.c:3128): Excess function parameter 'port' description in 'serial8250_register_8250_port' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-02tty: Revert the tty locking series, it needs more workLinus Torvalds
This reverts the tty layer change to use per-tty locking, because it's not correct yet, and fixing it will require some more deep surgery. The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but there are several smaller commits that built upon it, they also get reverted here. The list of reverted commits is: fde86d310886 - tty: add lockdep annotations 8f6576ad476b - tty: fix ldisc lock inversion trace d3ca8b64b97e - pty: Fix lock inversion b1d679afd766 - tty: drop the pty lock during hangup abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock() fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call d29f3ef39be4 - tty_lock: Localise the lock The revert had a trivial conflict in the 68360serial.c staging driver that got removed in the meantime. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31tty: add lockdep annotationsEric Dumazet
tty_lock_pair() do the right thing to avoid deadlocks, but should instruct LOCKDEP of this to avoid a splat. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The whole series has been sitting in -next for quite a while with no complaints. The last change to the series was before the weekend the removal of an SPI patch which Grant - even though previously acked by himself - appeared to raise objections. So I removed it until the situation is clarified. Other than that all the patches have the acks from their respective maintainers, all MIPS and x86 defconfigs are building fine and I'm not aware of any problems introduced by this series. Among the key features for this patch series is a sizable patchset for Lantiq which among other things introduces support for Lantiq's flagship product, the FALCON SOC. It also means that the opensource developers behind this patchset have overtaken Lantiq's competing inhouse development team that was working behind closed doors. Less noteworthy the ath79 patchset which adds support for a few more chip variants, cleanups and fixes. Finally the usual dose of tweaking of generic code." Fix up trivial conflicts in arch/mips/lantiq/xway/gpio_{ebu,stp}.c where printk spelling fixes clashed with file move and eventual removal of the printk. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (81 commits) MIPS: lantiq: remove orphaned code MIPS: Remove all -Wall and almost all -Werror usage from arch/mips. MIPS: lantiq: implement support for FALCON soc MTD: MIPS: lantiq: verify that the NOR interface is available on falcon soc MTD: MIPS: lantiq: implement OF support watchdog: MIPS: lantiq: implement OF support and minor fixes SERIAL: MIPS: lantiq: implement OF support GPIO: MIPS: lantiq: convert gpio-stp-xway to OF GPIO: MIPS: lantiq: convert gpio-mm-lantiq to OF and of_mm_gpio GPIO: MIPS: lantiq: move gpio-stp and gpio-ebu to the subsystem folder MIPS: pci: convert lantiq driver to OF MIPS: lantiq: convert dma to platform driver MIPS: lantiq: implement support for clkdev api MIPS: lantiq: drop ltq_gpio_request() and gpio_to_irq() OF: MIPS: lantiq: implement irq_domain support OF: MIPS: lantiq: implement OF support MIPS: lantiq: drop mips_machine support OF: PCI: const usage needed by MIPS MIPS: Cavium: Remove smp_reserve_lock. MIPS: Move cache setup to setup_arch(). ...
2012-05-29tty: fix ldisc lock inversion traceAlan Cox
This is caused by tty_release using tty_lock_pair to lock both sides of the pty/tty pair, and then tty_ldisc_release dropping and relocking one side only. We can drop both fine, so drop both to avoid any lock ordering concerns. Rework the release path to fix the new locking model. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29pty: Fix lock inversionAlan Cox
The ptmx_open path takes the tty and devpts locks in the wrong order because tty_init_dev locks and returns a locked tty. As far as I can tell this is actually safe anyway because the tty being returned is new so nobody can get a reference to lock it at this point. However we don't even need the devpts lock at this point, it's only held as a byproduct of the way the locks were pushe down. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-26Merge branches 'fixes-for-linus', 'generic', 'cavium', 'module.h-fixes', ↵Ralf Baechle
'next/ath79' and 'next/lantiq' into mips-for-linux-next
2012-05-24xen/hvc: Check HVM_PARAM_CONSOLE_[EVTCHN|PFN] for correctness.Konrad Rzeszutek Wilk
We need to make sure that those parameters are setup to be correct. As such the value of 0 is deemed invalid and we find that we bail out. The hypervisor sets by default all of them to be zero and when the hypercall is done does a simple: a.value = d->arch.hvm_domain.params[a.index]; Which means that if the Xen toolstack forgot to setup the proper HVM_PARAM_CONSOLE_EVTCHN (or the PFN one), we would get the default value of 0 and use that. CC: stable@kernel.org Fixes-Oracle-Bug: 14091238 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-24xen/hvc: Fix error cases around HVM_PARAM_CONSOLE_PFNKonrad Rzeszutek Wilk
We weren't resetting the parameter to be passed in to a known default. Nor were we checking the return value of hvm_get_parameter. CC: stable@kernel.org Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-24xen/hvc: Collapse error logic.Konrad Rzeszutek Wilk
All of the error paths are doing the same logic. In which case we might as well collapse them in one path. CC: stable@kernel.org Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-23Merge branch 'delete-mca' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull the MCA deletion branch from Paul Gortmaker: "It was good that we could support MCA machines back in the day, but realistically, nobody is using them anymore. They were mostly limited to 386-sx 16MHz CPU and some 486 class machines and never more than 64MB of RAM. Even the enthusiast hobbyist community seems to have dried up close to ten years ago, based on what you can find searching various websites dedicated to the relatively short lived hardware. So lets remove the support relating to CONFIG_MCA. There is no point carrying this forward, wasting cycles doing routine maintenance on it; wasting allyesconfig build time on validating it, wasting I/O on git grep'ping over it, and so on." Let's see if anybody screams. It generally has compiled, and James Bottomley pointed out that there was a MCA extension from NCR that allowed for up to 4GB of memory and PPro-class machines. So in *theory* there may be users out there. But even James (technically listed as a maintainer) doesn't actually have a system, and while Alan Cox claims to have a machine in his cellar that he offered to anybody who wants to take it off his hands, he didn't argue for keeping MCA support either. So we could bring it back. But somebody had better speak up and talk about how they have actually been using said MCA hardware with modern kernels for us to do that. And David already took the patch to delete all the networking driver code (commit a5e371f61ad3: "drivers/net: delete all code/drivers depending on CONFIG_MCA"). * 'delete-mca' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: MCA: delete all remaining traces of microchannel bus support. scsi: delete the MCA specific drivers and driver code serial: delete the MCA specific 8250 support. arm: remove ability to select CONFIG_MCA
