path: root/drivers/uio
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21UIO: generic irq handling for some uio platform devicesMagnus Damm
This is V3 of uio_pdrv_genirq.c, a platform driver for UIO with generic IRQ handling code. This driver is very similar to the regular UIO platform driver, but is only suitable for devices that are connected to the interrupt controller using unique interrupt lines. The uio_pdrv_genirq driver includes generic interrupt handling code which disables the serviced interrupt in the interrupt controller and makes the user space driver responsible for acknowledging the interrupt in the device and reenabling the interrupt in the interrupt controller. Shared interrupts are not supported since the in-kernel interrupt handler will disable the interrupt line in the interrupt controller, and in a shared interrupt configuration this will stop other devices from delivering interrupts. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21UIO: uio_pdrv: fix license specificationUwe Kleine-König
Thanks to Magnus Damm for pointing that out. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21UIO: uio_pdrv: fix memory leakUwe Kleine-König
2008-07-21UIO: add generic UIO platform driverUwe Kleine-König
This patch adds a generic UIO platform driver. It eliminates the need for a dedicated kernel module for simple platform devices. Users only need to implement their irq handler in platform code and fill a struct uio_info there. This helps avoiding code duplication as UIO platform drivers often share a lot of common code. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21UIO: Add write function to allow irq maskingHans J. Koch
Sometimes it is necessary to enable/disable the interrupt of a UIO device from the userspace part of the driver. With this patch, the UIO kernel driver can implement an "irqcontrol()" function that does this. Userspace can write an s32 value to /dev/uioX (usually 0 or 1 to turn the irq off or on). The UIO core will then call the driver's irqcontrol function. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21UIO: fix UIO Kconfig dependenciesUwe Kleine-König
ae210f188614bb3d1ee3f19c64e28e3cdd44877c introduced a big "if UIO"/"endif" where all uio drivers are defined. So know there is no need for them to depend explicitly on UIO. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-06-20UIO: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-20UIO: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19UIO: hold a reference to the device's owner while the device is openUwe Kleine-König
Otherwise the device might just disappear while /dev/uioX is being used which results in an Oops. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Hans J Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19UIO: Implement a UIO interface for the SMX CryptengineBen Nizette
This patch implements a UIO interface for the SMX Cryptengine. The Cryptengine found on the Nias Digital SMX board is best suited for a UIO interface. It is not wired in to the cryptographic API as the engine handles it's own keys, algorithms, everything. All that we know about is that if there's room in the buffer, you can write data to it and when there's data ready, you read it out again. There isn't necessarily even any direct correlation between data going in and data coming out again, the engine may consume or generate data all on its own. This driver is for proprietary hardware but we're always told to submit the drivers anyway; here you are. :-) This is version 4 of this patch and addresses all issues raised by Hans-Jürgen Koch and Paul Mundt in their reviews. Slightly altered is Paul's suggestion to use DRV_NAME and DRV_VERSION as the UIO version and name. While at the moment they are the same, there is no reason for them to stay that way. Nevertheless we now at least provide a MODULE_VERSION macro to keep modinfo happy. Signed-off-by: Ben Nizette <bn@niasdigital.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Hans J Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19UIO: Remove needless PCI_DEVICE_ID definition from uio_cif.cHans-Jürgen Koch
Meanwhile, PCI_DEVICE_ID_PLX_9030 is defined in pci_ids.h, no need to define it again in the driver. Signed-off-by: Hans J. Koch <hjk@linutronix.de> CC: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19uio: mark pci_device_id hilscher_pci_ids[] __devinitdataDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19uio: Kconfig improvementsDenis Cheng
2008-03-24UIO: add pgprot_noncached() to UIO mmap codeJean-Samuel Chenard
Mapping of physical memory in UIO needs pgprot_noncached() to ensure that IO memory is not cached. Without pgprot_noncached(), it (accidentally) works on x86 and arm, but fails on PPC. Signed-off-by: Jean-Samuel Chenard <jsamch@gmail.com> Signed-off-by: Hans J Koch <hjk@linutronix.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21UIO: fix Greg's stupid changesBrandon Philips
This fixes two bugs with UIO that cropped up recently in -rc1 1) WARNING: at fs/sysfs/file.c:334 sysfs_open_file when trying to open a map addr/size file - complaining about missing sysfs_ops for ktype 2) Permission denied when reading uio/uio0/maps/map0/{addr,size} when files are mode S_IRUGO Also fix a typo: attr_attribute -> addr_attribute Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06uio: nopageNick Piggin
Convert uio from nopage to fault. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Hans J Koch <hjk@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24UIO: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: rename kobject_init_ng() to kobject_init()Greg Kroah-Hartman
Now that the old kobject_init() function is gone, rename kobject_init_ng() to kobject_init() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: rename kobject_add_ng() to kobject_add()Greg Kroah-Hartman
Now that the old kobject_add() function is gone, rename kobject_add_ng() to kobject_add() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24UIO: fix kobject usageGreg Kroah-Hartman
The uio kobject code is "wierd". This patch should hopefully fix it up to be sane and not leak memory anymore. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-18UIO: Hilscher CIF card driverHans-Jürgen Koch
this is a patch that adds support for Hilscher CIF DeviceNet and Profibus cards. I tested it on a Kontron CPX board, and Thomas reviewed it. You can find the user space part here: http://www.osadl.org/projects/downloads/UIO/user/cif-0.1.0.tar.gz Notes: cif_api.c is the main file you want to look at. It contains the functions to open, close, mmap and so on. cif_dps.c adds functions specific to Profibus cards, and cif_dn.c contains functions for DeviceNet cards. cif.c is a universal playground, it's just a small test program. The user space part of this UIO driver is still work in progress, and not everything is tested yet. At the moment, the thread in cif_api.c contains some code that artificially makes the card generate interrupts, this was added for testing and will be removed later. But the driver already contains all the functions needed for useful operation, so it gives a good idea of how such a thing looks like. For comparison, here's what you get from the manufacturer (www.hilscher.com) when you ask for a Linux 2.6 driver: http://www.tglx.de/private/hjk/cif-orig-2.6.tar.bz2 WARNING: Don't look at the code for too long, you might become sick :-) Signed-off-by: Hans-Jürgen Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-18UIO: Add the User IO core codeHans J. Koch
This interface allows the ability to write the majority of a driver in userspace with only a very small shell of a driver in the kernel itself. It uses a char device and sysfs to interact with a userspace process to process interrupts and control memory accesses. See the docbook documentation for more details on how to use this interface. From: Hans J. Koch <hjk@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
