path: root/drivers/uio
2011-07-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: updated Documentation/ja_JP/SubmittingPatches debugfs: add documentation for debugfs_create_x64 uio: uio_pdrv_genirq: Add OF support firmware: gsmi: remove sysfs entries when unload the module Documentation/zh_CN: Fix messy code file email-clients.txt driver core: add more help description for "path to uevent helper" driver-core: modify FIRMWARE_IN_KERNEL help message driver-core: Kconfig grammar corrections in firmware configuration DOCUMENTATION: Replace create_device() with device_create(). DOCUMENTATION: Update overview.txt in Doc/driver-model. pti: pti_tty_install documentation mispelling.
2011-07-08uio: uio_pdrv_genirq: Add OF supportHans J. Koch
Adding OF binding to genirq. Version string is setup to the "devicetree". Compatible string is not setup for now but you can add your custom compatible string to uio_of_genirq_match structure. For example with "vendor,device" compatible string: static const struct of_device_id __devinitconst uio_of_genirq_match[] = { { .compatible = "vendor,device", }, { /* empty for now */ }, }; Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> CC: Hans J. Koch <hjk@hansjkoch.de> CC: Arnd Bergmann <arnd@arndb.de> CC: John Williams <john.williams@petalogix.com> CC: Grant Likely <grant.likely@secretlab.ca> CC: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-19uio: clean uioinfo when uninstall uio driverJie Zhou
The uioinfo should be cleaned up when uninstall, otherwise re-install failure of uio_pdrv_genirq.ko will happen. Signed-off-by: Jie Zhou <b30303@freescale.com> Signed-off-by: Aisheng Dong <b29396@freescale.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19uio: fix allocating minor id for uio deviceHillf Danton
The number of uio devices that could be used should be less than UIO_MAX_DEVICES by design, and this work guards any cases in which id more than UIO_MAX_DEVICES is utilized. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19uio: fix finding mm index for vmaHillf Danton
When finding mm index for vma it looks more flexible that the mm could be sparse, and both the size of mm and the pgoff of vma could give correct selection. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19uio_netx: Add support for netPLC cardsDaniel Trautmann
This patch adds support for Hilscher / IBHsoftec netPLC cards to uio_netx userspace IO driver. Changes from v1 -> v2: Fixed whitespace errors reported by scripts/checkpatch.pl which were caused by email client. Signed-off-by: Daniel Trautmann <dtrautmann@ibhsoftec-sps.de> Signed-off-by: "Hans J. Koch" <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07UIO: add PRUSS UIO driver supportPratheesh Gangadhar
This patch implements PRUSS (Programmable Real-time Unit Sub System) UIO driver which exports SOC resources associated with PRUSS like I/O, memories and IRQs to user space. PRUSS is dual 32-bit RISC processors which is efficient in performing embedded tasks that require manipulation of packed memory mapped data structures and handling system events that have tight real time constraints. This driver is currently supported on Texas Instruments DA850, AM18xx and OMAP-L138 devices. For example, PRUSS runs firmware for real-time critical industrial communication data link layer and communicates with application stack running in user space via shared memory and IRQs. Signed-off-by: Pratheesh Gangadhar <pratheesh@ti.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-10uio: Change mail address of Hans J. KochHans J. Koch
My old mail address doesn't exist anymore. This changes all occurrences to my new address. Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22uio: Statically allocate uio_class and use class .dev_attrs.Eric W. Biederman
Instead of adding uio class attributes manually after the uio device has been created and we have sent a uevent to userspace, use the class attribute mechanism. This removes races and makes the code simpler. At the same time don't bother to dynamically allocate a struct class for uio, just declare one statically. Less code is needed and it is easier to set the class parameters.tune the class Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Support 2^MINOR_BITS minorsEric W. Biederman
register_chrdev limits uio devices to 256 minor numbers which causes problems on one system I have with 384+ uio devices. So instead set UIO_MAX_DEVICES to the maximum number of minors and use alloc_chrdev_region to reserve the uio minors. The final result is that the code works the same but the uio driver now supports any minor the idr allocator comes up with. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Cleanup irq handling.Eric W. Biederman
Change the value of UIO_IRQ_NONE -2 to 0. 0 is well defined in the rest of the kernel as the value to indicate an irq has not been assigned. Update the calls to request_irq and free_irq to only ignore UIO_IRQ_NONE and UIO_IRQ_CUSTOM allowing the rest of the kernel's possible irq numbers to be used. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Don't clear driver dataEric W. Biederman
Currently uio sets it's driver data to NULL just as it is unregistering attributes. sysfs maks the guaranatee that it will not call attributes after device_destroy is called so this is unncessary and leads to lots of unnecessary code in uio.c Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: Fix lack of locking in init_uio_classEric W. Biederman
There is no locking in init_uio_class so multiple drivers can race and create multiple uio classes. Fix this by simplifying the code. In particular always register the uio class during module_init and make things simpler. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22uio: do not use PCI resources before pci_enable_device()Kulikov Vasiliy
IRQ and resource[] may not have correct values until after PCI hotplug setup occurs at pci_enable_device() time. The semantic match that finds this problem is as follows: // <smpl> @@ identifier x; identifier request ~= "pci_request.*|pci_resource.*"; @@ ( * x->irq | * x->resource | * request(x, ...) ) ... *pci_enable_device(x) // </smpl> Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-05uio: Remove IRQF_DISABLED flag from uio_cif.cHans J. Koch
Remove IRQF_DISABLED since it is deprecated and a no-op in the current kernel. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05uio: Remove IRQF_DISABLED from uio_sercos3.cHans J. Koch
Remove IRQF_DISABLED since it is deprecated and a no-op in the current kernel. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05uio: Remove IRQF_DISABLED flag from uio_pdrv_genirq.cHans J. Koch
Remove IRQF_DISABLED flag since it is deprecated and a no-op in the current kernel. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07UIO: Remove SMX Cryptengine driverHans J. Koch
Ben Nizette, the author of this driver, told me in a private mail that this project has been cancelled. He suggested to remove the driver for now, and will come back with a new version should the hardware really exist. This patch completely removes the driver. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Ben Nizette <bn@niasdigital.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07UIO: minor Kconfig fixesJohn Ogness
Two trivial fixes for the Userspace IO Kconfig file: 1) uio_sercos3 is a PCI driver, so let it depend on PCI. 2) "default n" under UIO_PCI_GENERIC is luxury since it is already the default. Acked-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07UIO: Add a driver for Hilscher netX-based fieldbus cardsHans J. Koch
This patch adds a Userspace IO driver for netX-based fieldbus cards by Hilscher (see http://www.hilscher.com). ATM, cifX and comX cards are supported. The userspace part for this driver is provided by Hilscher and should come with the card. The driver is in use for several months now and has been tested by people at Hilscher and Linutronix. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-13uio: pm_runtime_disable is needed if failedKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (262 commits) sh: mach-ecovec24: Add user debug switch support sh: Kill off unused se_skipped in alignment trap notification code. sh: Wire up HAVE_SYSCALL_TRACEPOINTS. video: sh_mobile_lcdcfb: use both register sets for display panning video: sh_mobile_lcdcfb: implement display panning sh: Fix up sh7705 flush_dcache_page() build. sh: kfr2r09: document the PLL/FLL <-> RF relationship. sh: mach-ecovec24: need asm/clock.h. sh: mach-ecovec24: deassert usb irq on boot. sh: Add KEYSC support for EcoVec24 sh: add kycr2_delay for sh_keysc sh: cpufreq: Include CPU id in info messages. sh: multi-evt support for SH-X3 proto CPU. sh: clkfwk: remove bogus set_bus_parent() from SH7709. sh: Fix the indication point of the liquid crystal of AP-325RXA(AP3300) sh: Add EcoVec24 romImage defconfig sh: USB disable process is needed if romImage boot for EcoVec24 sh: EcoVec24: add HIZA setting for LED sh: EcoVec24: write MAC address in boot sh: Add romImage support for EcoVec24 ...
2009-09-15uio: add generic driver for PCI 2.3 devicesMichael S. Tsirkin
This adds a generic uio driver that can bind to any PCI device. First user will be virtualization where a qemu userspace process needs to give guest OS access to the device. Interrupts are handled using the Interrupt Disable bit in the PCI command register and Interrupt Status bit in the PCI status register. All devices compliant to PCI 2.3 (circa 2002) and all compliant PCI Express devices should support these bits. Driver detects this support, and won't bind to devices which do not support the Interrupt Disable Bit in the command register. It's expected that more features of interest to virtualization will be added to this driver in the future. Possibilities are: mmap for device resources, MSI/MSI-X, eventfd (to interface with kvm), iommu. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15UIO: remove 'default n' from KconfigDaniel Mack
'default n' is the default, there is no need for these lines. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-23uio: Runtime PM for UIO devicesMagnus Damm
This patch modifies the uio_pdrv_genirq driver to support Runtime PM. The power management implementation simply runtime resumes the device at open() time and runtime suspends it at release() time. The user space driver is responsible for re-initializing the hardware after open(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-16UIO: fix specific device driver missing statement for depmodHans J. Koch
On Fri, Apr 10, 2009 at 01:50:50PM -0700, Andrew Morton wrote: > On Fri, 10 Apr 2009 13:32:01 GMT > bugzilla-daemon@bugzilla.kernel.org wrote: > > > http://bugzilla.kernel.org/show_bug.cgi?id=13059 drivers/uio/uio_cif.c misses a MODULE_DEVICE_TABLE, this fixes it. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24UIO: Take offset into account when determining number of pages that can be ↵Ian Abbott
mapped If a UIO memory region does not start on a page boundary but straddles one, the number of actual pages that overlap the memory region may be calculated incorrectly because the offset isn't taken into account. If userspace sets the mmap length to offset+size, it may fail with -EINVAL if UIO thinks it's trying to allocate too many pages. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Cc: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24uio: add the uio_aec driverBrandon Philips
UIO driver for the Adrienne Electronics Corporation PCI time code device. This device differs from other UIO devices since it uses I/O ports instead of memory mapped I/O. In order to make it possible for UIO to work with this device a utility, uioport, can be used to read and write the ports. uioport is designed to be a setuid program and checks the permissions of the /dev/uio* node and if the user has write permissions it will use iopl and out*/in* to access the device. [1] git clone git://ifup.org/philips/uioport.git Signed-off-by: Brandon Philips <brandon@ifup.org> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24UIO: Add name attributes for mappings and port regionsHans J. Koch
If a UIO device has several memory mappings, it can be difficult for userspace to find the right one. The situation becomes even worse if the UIO driver can handle different versions of a card that have different numbers of mappings. Benedikt Spranger has such cards and pointed this out to me. Thanks, Bene! To address this problem, this patch adds "name" sysfs attributes for each mapping. Userspace can use these to clearly identify each mapping. The name string is optional. If a driver doesn't set it, an empty string will be returned, so this patch won't break existing drivers. The same problem exists for port region information, so a "name" attribute is added there, too. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06UIO: Pass information about ioports to userspace (V2)Hans J. Koch
Devices sometimes have memory where all or parts of it can not be mapped to userspace. But it might still be possible to access this memory from userspace by other means. An example are PCI cards that advertise not only mappable memory but also ioport ranges. On x86 architectures, these can be accessed with ioperm, iopl, inb, outb, and friends. Mike Frysinger (CCed) reported a similar problem on Blackfin arch where it doesn't seem to be easy to mmap non-cached memory but it can still be accessed from userspace. This patch allows kernel drivers to pass information about such ports to userspace. Similar to the existing mem[] array, it adds a port[] array to struct uio_info. Each port range is described by start, size, and porttype. If a driver fills in at least one such port range, the UIO core will simply pass this information to userspace by creating a new directory "portio" underneath /sys/class/uio/uioN/. Similar to the "mem" directory, it will contain a subdirectory (portX) for each port range given. Note that UIO simply passes this information to userspace, it performs no action whatsoever with this data. It's userspace's responsibility to obtain access to these ports and to solve arch dependent issues. The "porttype" attribute tells userspace what kind of port it is dealing with. This mechanism could also be used to give userspace information about GPIOs related to a device. You frequently find such hardware in embedded devices, so I added a UIO_PORT_GPIO definition. I'm not really sure if this is a good idea since there are other solutions to this problem, but it won't hurt much anyway. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06UIO: uio_pdrv_genirq: allow custom irq_flagsMike Frysinger
I can't think of a reason why the driver prevents people from setting any custom bits in their platform device, but I can think of some reasons for allowing custom flags. Like setting the IRQF_TRIGGER_... bits. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06UIO: use pci_ioremap_bar() in drivers/uioArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/uio. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: UIO: BKL removal
2008-10-16UIO: BKL removalJonathan Corbet
Fill in needed locking around idr accesses, then remove the big kernel lock from the UIO driver. Since there are no in-tree UIO drivers with open() methods, no further BKL pushdown is required. Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-10-16UIO: Fix mapping of logical and virtual memoryAndrew G. Harvey
mmap() doesn't work as expected for UIO_MEM_LOGICAL or UIO_MEM_VIRTUAL mappings. The offset into the memory needs to be added, otherwise uio_vma_fault always returns the first page only. Note that for UIO userspace calls mmap() with offset = N * getpagesize() to access mapping N. This must be compensated when calculating the offset. A comment was added to explain this since it is not obvious. Signed-off-by: Andrew G. Harvey <agh@cisco.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16UIO: add automata sercos3 pci card supportJohn Ogness
Here is a new version of the patch to support the Automata Sercos III PCI card driver. I now check that the IRQ is enabled before accepting the interrupt. I still use a logical OR to store the enabled interrupts and I've added a second use of a logical OR when restoring the enabled interrupts. I added an explanation of why I do this in comments at the top of the source file. Since I use a logical OR, I also removed the extra checks if the Interrupt Enable Register and ier0_cache are 0. Signed-off-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16UIO: Change driver name of uio_pdrvHans J. Koch
The generic UIO platform device driver should be given a unique driver ID and not just "uio". This is especially important since we now have a similar driver named uio_pdrv_genirq. Currently, there's no user of this driver in the mainline kernel. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16UIO: Add alignment warnings for uio-memHans J. Koch
This patch adds an "offset" attribute for UIO mappings. It shows the difference between the actual start address of the memory and the start address of the page. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
