path: root/drivers/uio
2020-02-28uio: fix a sleep-in-atomic-context bug in uio_dmem_genirq_irqcontrol()Jia-Ju Bai
[ Upstream commit b74351287d4bd90636c3f48bc188c2f53824c2d4 ] The driver may sleep while holding a spinlock. The function call path (from bottom to top) in Linux 4.19 is: kernel/irq/manage.c, 523: synchronize_irq in disable_irq drivers/uio/uio_dmem_genirq.c, 140: disable_irq in uio_dmem_genirq_irqcontrol drivers/uio/uio_dmem_genirq.c, 134: _raw_spin_lock_irqsave in uio_dmem_genirq_irqcontrol synchronize_irq() can sleep at runtime. To fix this bug, disable_irq() is called without holding the spinlock. This bug is found by a static analysis tool STCheck written by myself. Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com> Link: https://lore.kernel.org/r/20191218094405.6009-1-baijiaju1990@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-27uio: Fix an Oops on loadDan Carpenter
commit 432798195bbce1f8cd33d1c0284d0538835e25fb upstream. I was trying to solve a double free but I introduced a more serious NULL dereference bug. The problem is that if there is an IRQ which triggers immediately, then we need "info->uio_dev" but it's not set yet. This patch puts the original initialization back to how it was and just sets info->uio_dev to NULL on the error path so it should solve both the Oops and the double free. Fixes: f019f07ecf6a ("uio: potential double frees if __uio_register_device() fails") Reported-by: Mathias Thore <Mathias.Thore@infinera.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> Tested-by: Mathias Thore <Mathias.Thore@infinera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13uio: ensure class is registered before devicesAlexandre Belloni
[ Upstream commit ae61cf5b9913027c6953a79ed3894da4f47061bd ] When both uio and the uio drivers are built in the kernel, it is possible for a driver to register devices before the uio class is registered. This may result in a NULL pointer dereference later on in get_device_parent() when accessing the class glue_dirs spinlock. The trace looks like that: Unable to handle kernel NULL pointer dereference at virtual address 00000140 [...] [<ffff0000089cc234>] _raw_spin_lock+0x14/0x48 [<ffff0000084f56bc>] device_add+0x154/0x6a0 [<ffff0000084f5e48>] device_create_groups_vargs+0x120/0x128 [<ffff0000084f5edc>] device_create+0x54/0x60 [<ffff0000086e72c0>] __uio_register_device+0x120/0x4a8 [<ffff000008528b7c>] jaguar2_pci_probe+0x2d4/0x558 [<ffff0000083fc18c>] local_pci_probe+0x3c/0xb8 [<ffff0000083fd81c>] pci_device_probe+0x11c/0x180 [<ffff0000084f88bc>] driver_probe_device+0x22c/0x2d8 [<ffff0000084f8a24>] __driver_attach+0xbc/0xc0 [<ffff0000084f69fc>] bus_for_each_dev+0x4c/0x98 [<ffff0000084f81b8>] driver_attach+0x20/0x28 [<ffff0000084f7d08>] bus_add_driver+0x1b8/0x228 [<ffff0000084f93c0>] driver_register+0x60/0xf8 [<ffff0000083fb918>] __pci_register_driver+0x40/0x48 Return EPROBE_DEFER in that case so the driver can register the device later. Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-19uio: potential double frees if __uio_register_device() failsDan Carpenter
[ Upstream commit f019f07ecf6a6b8bd6d7853bce70925d90af02d1 ] The uio_unregister_device() function assumes that if "info->uio_dev" is non-NULL that means "info" is fully allocated. Setting info->uio_de has to be the last thing in the function. In the current code, if request_threaded_irq() fails then we return with info->uio_dev set to non-NULL but info is not fully allocated and it can lead to double frees. Fixes: beafc54c4e2f ("UIO: Add the User IO core code") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13uio: fix incorrect memory leak cleanupSuman Anna
[ Upstream commit 0d83539092ddb1ab79b4d65bccb866bf07ea2ccd ] Commit 75f0aef6220d ("uio: fix memory leak") has fixed up some memory leaks during the failure paths of the addition of uio attributes, but still is not correct entirely. A kobject_uevent() failure still needs a kobject_put() and the kobject container structure allocation failure before the kobject_init() doesn't need a kobject_put(). Fix this properly. Fixes: 75f0aef6220d ("uio: fix memory leak") Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31uio: fix dmem_region_start computationJan Viktorin
The variable i contains a total number of resources (including IORESOURCE_IRQ). However, we want the dmem_region_start to point after the last resource of type IORESOURCE_MEM. The original behaviour leads (very likely) to skipping several UIO mapping regions and makes them useless. Fix this by computing dmem_region_start from the uiomem which points to the last used UIO mapping. Fixes: 0a0c3b5a24bd ("Add new uio device for dynamic memory allocation") Signed-off-by: Jan Viktorin <viktorin@rehivetech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-01uio: add missing error codesDan Carpenter
My static checker complains that "ret" could be uninitialized at the end, which is true but it's more likely that it would be set to zero. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04uio: fix false positive __might_sleep warning splatMichal Hocko
Andy has reported a __might_sleep warning [ 5174.883617] WARNING: CPU: 0 PID: 1532 at /home/agrover/git/kernel/kernel/sched/core.c:7389 __might_sleep+0x7d/0x90() [ 5174.884407] do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffffa02a5821>] uio_read+0x91/0x170 [uio] [ 5174.885198] Modules linked in: tcm_loop target_core_user uio target_core_pscsi target_core_file target_core_iblock iscsi_target_mod target_core_mod uinput fuse nfsv3 nfs_acl nfs lockd grace fscache sunrpc microcode i2c_piix4 virtio_balloon i2c_core xfs libcrc32c crc32c_intel virtio_net virtio_blk [ 5174.887351] CPU: 0 PID: 1532 Comm: tcmu-runner Not tainted 4.2.0-rc7+ [ 5174.887853] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 [ 5174.888633] ffffffff81a3b870 ffff880045393ca8 ffffffff817afaae 0000000000000000 [ 5174.889224] ffff880045393cf8 ffff880045393ce8 ffffffff8109a846 ffff880045393cd8 [ 5174.889793] ffffffffa02a7150 00000000000002dc 0000000000000000 ffff880045008000 [ 5174.890375] Call Trace: [ 5174.890562] [<ffffffff817afaae>] dump_stack+0x4c/0x65 [ 5174.890938] [<ffffffff8109a846>] warn_slowpath_common+0x86/0xc0 [ 5174.891388] [<ffffffff8109a8c6>] warn_slowpath_fmt+0x46/0x50 [ 5174.891808] [<ffffffffa02a5821>] ? uio_read+0x91/0x170 [uio] [ 5174.892237] [<ffffffffa02a5821>] ? uio_read+0x91/0x170 [uio] [ 5174.892653] [<ffffffff810c584d>] __might_sleep+0x7d/0x90 [ 5174.893055] [<ffffffff811ea023>] __might_fault+0x43/0xa0 [ 5174.893448] [<ffffffff817b31ce>] ? schedule+0x3e/0x90 [ 5174.893820] [<ffffffffa02a58c2>] uio_read+0x132/0x170 [uio] [ 5174.894240] [<ffffffff810cbb80>] ? wake_up_q+0x70/0x70 [ 5174.894620] [<ffffffff81236168>] __vfs_read+0x28/0xe0 [ 5174.894993] [<ffffffff81353233>] ? security_file_permission+0xa3/0xc0 [ 5174.895541] [<ffffffff8123678f>] ? rw_verify_area+0x4f/0xf0 [ 5174.896006] [<ffffffff812368ba>] vfs_read+0x8a/0x140 [ 5174.896391] [<ffffffff817b28f5>] ? __schedule+0x425/0xcc0 [ 5174.896788] [<ffffffff812375d9>] SyS_read+0x49/0xb0 The warning is a false positive because uio_read doesn't depent on TASK_INTERRUPTIBLE after copy_to_user so it is safe to silence the warning by an explicit setting the state to TASK_RUNNING in the path which might call into TASK_RUNNING. Reported-by: Andy Grover <agrover@redhat.com> Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04uio: uio_fsl_elbc_gpcm: Fix module autoload for OF platform driverLuis de Bethencourt
This platform driver has a OF device ID table but the OF module alias information is not created so module autoloading won't work. Signed-off-by: Luis de Bethencourt <luis@debethencourt.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-05uio: UIO_PRUSS should depend on HAS_DMAGeert Uytterhoeven
If NO_DMA=y: ERROR: "dma_alloc_coherent" [drivers/uio/uio_pruss.ko] undefined! ERROR: "dma_free_coherent" [drivers/uio/uio_pruss.ko] undefined! Add a dependency on HAS_DMA to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-05uio: uio_fsl_elbc_gpcm: Use module_platform_driverVaishali Thakkar
Use module_platform_driver for drivers whose init and exit functions only register and unregister, respectively. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @a@ identifier f, x; @@ -static f(...) { return platform_driver_register(&x); } @b depends on a@ identifier e, a.x; @@ -static e(...) { platform_driver_unregister(&x); } @c depends on a && b@ identifier a.f; declarer name module_init; @@ -module_init(f); @d depends on a && b && c@ identifier b.e, a.x; declarer name module_exit; declarer name module_platform_driver; @@ -module_exit(e); +module_platform_driver(x); Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-05uio: Destroy uio_idr on module exitJohannes Thumshirn
Destroy uio_idr on module exit, reclaiming the allocated memory. This was detected by the following semantic patch (written by Luis Rodriguez <mcgrof@suse.com>) <SmPL> @ defines_module_init @ declarer name module_init, module_exit; declarer name DEFINE_IDR; identifier init; @@ module_init(init); @ defines_module_exit @ identifier exit; @@ module_exit(exit); @ declares_idr depends on defines_module_init && defines_module_exit @ identifier idr; @@ DEFINE_IDR(idr); @ on_exit_calls_destroy depends on declares_idr && defines_module_exit @ identifier declares_idr.idr, defines_module_exit.exit; @@ exit(void) { ... idr_destroy(&idr); ... } @ missing_module_idr_destroy depends on declares_idr && defines_module_exit && !on_exit_calls_destroy @ identifier declares_idr.idr, defines_module_exit.exit; @@ exit(void) { ... +idr_destroy(&idr); } </SmPL> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from configMatwey V. Kornilov
mach-dependant stuff has been removed by 2eb2478d471e ("uio: uio_pruss: replace private SRAM API with genalloc") There is no need to keep depends on ARCH_DAVINCI_DA850 Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12uio: pruss: Add CONFIG_HAS_IOMEM dependenceMatwey V. Kornilov
uio_pruss uses io memory, that should be explicitly depend on it Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12uio: pruss: Include <linux/sizes.h>Matwey V. Kornilov
uio_pruss references SZ_16K and SZ_256K defines, but linux/sizes.h is not included. Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24uio: don't free irq that was not requestedStephen Hemminger
UIO base driver should only free_irq that it has requested. UIO supports drivers without interrupts (irq == 0) or custom handlers. This fixes warnings like: WARNING: CPU: 1 PID: 5478 at kernel/irq/manage.c:1244 __free_irq+0xa9/0x1e0() Trying to free already-free IRQ 0 Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03Revert "uio: constify of_device_id array"Greg Kroah-Hartman
This reverts commit 4d8beff2ae07fad85d723b4cdf704b05f0ed4794. It causes build warnings, and it's incorrect as we do write to this structure. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Fabian Frederick <fabf@skynet.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-25uio: constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-20uio: Request/free irq separate from dev lifecycleBrian Russell
Separate irq request/free from the device lifecycle. After device unregister the parent module can call pci_disable_msi. >From the PCI MSI how to: "Before calling this function, a device driver must always call free_irq() on any interrupt for which it previously called request_irq(). Failure to do so results in a BUG_ON(), leaving the device with MSI enabled and thus leaking its vector." So we need to separately free the irq at unregister to allow the device to be kept around in the case of it still having open FDs. Signed-off-by: Brian Russell <brussell@brocade.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12uio: uio_fsl_elbc_gpcm: new driverJohn Ogness
This driver provides UIO access to memory of a peripheral connected to the Freescale enhanced local bus controller (eLBC) interface using the general purpose chip-select mode (GPCM). Signed-off-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12uio/uio_pci_generic: don't return zero on failure path in probe()Alexey Khoroshilov
If uio_register_device() fails in probe(), it breaks off initialization, deallocates all resources, but returns zero. The patch adds proper error code propagation. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-11-07uio: support memory sizes larger than 32 bitsCristian Stoica
This is a completion to 27a90700a4275c5178b883b65927affdafa5185c The size field is also increased to allow values larger than 32 bits on platforms that have more than 32 bit physical addresses. Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-10-20uio: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-02uio: Export definition of struct uio_deviceAndy Grover
In order to prevent a O(n) search of the filesystem to link up its uio node with its target configuration, TCMU needs to know the minor number that UIO assigned. Expose the definition of this struct so TCMU can access this field. Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-07-13Merge 3.16-rc5 into char-misc-nextGreg Kroah-Hartman
This resolves a number of merge issues with changes in this tree and Linus's tree at the same time. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09uio: uio_pruss: use struct deviceAndre Heider
Get rid of the repeating &dev->dev constructs and prevent introducing new ones. Signed-off-by: Andre Heider <a.heider@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-17Revert "uio: fix vma io range check in mmap"Greg Kroah-Hartman
This reverts commit ddb09754e6c7239e302c7b675df9bbd415f8de5d. Linus objected to this originally, I can see why it might be needed, but given that no one spoke up defending this patch, I'm going to revert it. If you have hardware that requires this change, please speak up in the future and defend the patch. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Bin Wang <binw@marvell.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Norbert Ciosek <norbertciosek@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27uio: fix vma io range check in mmapBin Wang
the vma range size is always page size aligned in mmap, while the real io space range may not be page aligned, thus leading to range check failure in the uio_mmap_physical(). for example, in a case of io range size "mem->size == 1KB", and we have (vma->vm_end - vma->vm_start) == 4KB, due to "len" is aligned to page size in do_mmap_pgoff(). now fix this issue by align mem->size to page size in the check. Signed-off-by: Bin Wang <binw@marvell.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27drivers: uio_dmem_genirq: Fix memory leak in uio_dmem_genirq_probe()Daeseok Youn
When platform_get_irq() is failed after "priv" allocated, it need to free "priv". But the label of bad0 doesn't try to free about "priv". So this patch changes that lable to "bad1". But "bad1" has pm_runtime_disable() call, this function should be called when uio_register_device() is failed. So it is moved into handling error for uio_register_device(). Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20uio: fix devm_request_irq usageAaro Koskinen
Commit e6789cd3dfb553077606ccafeb05e0043f072481 (uio: Simplify uio error path by using devres functions) converted uio to use devm_request_irq(). This introduced a change in behaviour since the IRQ is associated with the parent device instead of the created UIO device. The IRQ will remain active after uio_unregister_device() is called, and some drivers will crash because of this. The patch fixes this. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Cc: stable <stable@vger.kernel.org> # 3.13 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16Merge 3.13-rc4 into char-misc-nextGreg Kroah-Hartman
We want these fixes in here.
2013-12-08uio: uio_mf624: remove DEFINE_PCI_DEVICE_TABLE macroJingoo Han
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro is not preferred. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-02uio: we cannot mmap unaligned page contentsLinus Torvalds
In commit 7314e613d5ff ("Fix a few incorrectly checked [io_]remap_pfn_range() calls") the uio driver started more properly checking the passed-in user mapping arguments against the size of the actual uio driver data. That in turn exposed that some driver authors apparently didn't realize that mmap can only work on a page granularity, and had tried to use it with smaller mappings, with the new size check catching that out. So since it's not just the user mmap() arguments that can be confused, make the uio mmap code also verify that the uio driver has the memory allocated at page boundaries in order for mmap to work. If the device memory isn't properly aligned, we return [ENODEV] The fildes argument refers to a file whose type is not supported by mmap(). as per the open group documentation on mmap. Reported-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/uio/uio_pruss.c: use gen_pool_dma_alloc() to allocate sram memoryNicolin Chen
Since gen_pool_dma_alloc() is introduced, we implement it to simplify code. Signed-off-by: Nicolin Chen <b42378@freescale.com> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-07Merge tag 'char-misc-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc patches from Greg KH: "Here's the big char/misc driver patchset for 3.13-rc1. Lots of stuff in here, including some new drivers for Intel's "MIC" co-processor devices, and a new eeprom driver. Other things include the driver attribute cleanups, extcon driver updates, hyperv updates, and a raft of other miscellaneous driver fixes. All of these have been in linux-next for a while" * tag 'char-misc-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (121 commits) misc: mic: Fixes for randconfig build errors and warnings. tifm: fix error return code in tifm_7xx1_probe() w1-gpio: Use devm_* functions w1-gpio: Detect of_gpio_error for first gpio uio: Pass pointers to virt_to_page(), not integers uio: fix memory leak misc/at24: avoid infinite loop on write() misc/93xx46: avoid infinite loop on write() misc: atmel_pwm: add deferred-probing support mei: wd: host_init propagate error codes from called functions mei: replace stray pr_debug with dev_dbg mei: bus: propagate error code returned by mei_me_cl_by_id mei: mei_cl_link remove duplicated check for open_handle_count mei: print correct device state during unexpected reset mei: nfc: fix memory leak in error path lkdtm: add tests for additional page permissions lkdtm: adjust recursion size to avoid warnings lkdtm: isolate stack corruption test mei: move host_clients_map cleanup to device init mei: me: downgrade two errors to debug level ...
2013-10-29uio: Pass pointers to virt_to_page(), not integersBen Hutchings
Most architectures define virt_to_page() as a macro that casts its argument such that an argument of type unsigned long will be accepted without complaint. However, the proper type is void *, and passing unsigned long results in a warning on MIPS. Compile-tested only. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29uio: fix memory leakCong Ding
we have to call kobject_put() to clean up the kobject after function kobject_init(), kobject_add(), or kobject_uevent() is called. Signed-off-by: Cong Ding <dinggnu@gmail.com> Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-29Fix a few incorrectly checked [io_]remap_pfn_range() callsLinus Torvalds
Nico Golde reports a few straggling uses of [io_]remap_pfn_range() that really should use the vm_iomap_memory() helper. This trivially converts two of them to the helper, and comments about why the third one really needs to continue to use remap_pfn_range(), and adds the missing size check. Reported-by: Nico Golde <nico@ngolde.de> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org.
2013-09-26uio: uio_sercos3: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26uio: uio_netx: remove unnecessary pci_set_drvdata()Jingoo Han
2013-09-26uio: uio_mf624: remove unnecessary pci_set_drvdata()Jingoo Han
2013-09-26uio: uio_cif: remove unnecessary pci_set_drvdata()Jingoo Han
2013-09-26uio: uio_aec: remove unnecessary pci_set_drvdata()Jingoo Han
2013-09-26uio: Simplify uio error path by using devres functionsMichal Simek
Using devres functions simplify driver error path. - Use devm_kzalloc - Use devm_request_irq Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26drivers: uio: mf624_disable_interrupt() can be staticFengguang Wu
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Rostislav Lisovy <lisovy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-08-30drivers: uio: Kconfig: add MMU dependancy for UIOChen Gang
The User space I/O drivers are useful, only when user space meaningful (MMU must be enabled). So need let it depend on MMU, or can not pass compiling, the related error (allmodconfig for H8300): CC [M] drivers/uio/uio.o drivers/uio/uio.c: In function 'uio_mmap_physical': drivers/uio/uio.c:650:2: error: implicit declaration of function 'pgprot_noncached' [-Werror=implicit-function-declaration] drivers/uio/uio.c:650:20: error: incompatible types when assigning to type 'pgprot_t' from type 'int' Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-30drivers: uio: Add driver for Humusoft MF624 DAQ PCI cardRostislav Lisovy
