path: root/drivers/usb/c67x00/c67x00-ll-hpi.c
2008-06-04usb/c67x00 endianness annotationsAl Viro
2008-05-12Fix c67x00-ll-hpi compilation failure (bug #10627)Fernando Luis Vázquez Cao
This patch fixes bug #10627 which caused the compilation error below. CC [M] drivers/usb/c67x00/c67x00-ll-hpi.o drivers/usb/c67x00/c67x00-ll-hpi.c: In function `ll_recv_msg': drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: `HZ' undeclared (first use in this function) drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: (Each undeclared identifier is reported only once drivers/usb/c67x00/c67x00-ll-hpi.c:243: erreur: for each function it appears in.) Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02USB: add Cypress c67x00 OTG controller HCD driverPeter Korsgaard
This patch adds HCD support for the Cypress c67x00 family of devices. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02USB: add Cypress c67x00 low level interface codePeter Korsgaard
This patch adds the low level support code for the Cypress c67x00 family of OTG controllers. The low level code is responsible for register access and implements the software protocol for communicating with the 16bit microcontroller inside the c67x00 device. Communication is done over the HPI interface (16bit SRAM-like parallel bus). Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
