send_request_dev_dep_msg_in() use a buffer allocated on the stack.
Fix by kmalloc()ing the buffer.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Converting the header to BIT for readability. No functional
change.
Add dtr_rts tty-port operation which implements proper DTR/RTS handling
(e.g. only lower DTR/RTS during shutdown if HUPCL is set).
Note that modem-control locking still needs to be added throughout the
driver.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
There's no need to call usb_mark_last_busy after having increased the PM
counter in write(). The device will be marked busy by USB core when the
PM counter is balanced in the completion handler.
There's no need to update the runtime PM last_busy field on read urb
errors (e.g. when the urb is being killed on shutdown).
Now that acm_set_control() handles runtime PM properly, the only
remaining reason for the PM operations in shutdown is to clear the
needs_remote_wakeup flag before the final put.
Note that this also means that we now need to grab the write_lock to
prevent racing with resume.
Remove redundant disconnect test from shutdown(), which is never called
post disconnect() where we do synchronous hangup.
We can simply the runtime PM locking as there's no need to check the
susp_count in the read path (at least not since killing the rx tasklet).
Specifically, the read urbs will never be resubmitted by the completion
handler when killed during suspend.
Make sure only to decrement the PM counters if they were actually
incremented.
Note that the USB PM counter, but not necessarily the driver core PM
counter, is reset when the interface is unbound.
Fixes: 11ea859d64b6 ("USB: additional power savings for cdc-acm devices
that support remote wakeup")
Make sure to kill any already submitted read urbs on read-urb submission
failures in open in order to prevent doing I/O for a closed port.
Fixes: 088c64f81284 ("USB: cdc-acm: re-write read processing")
Fix errors during open not being returned to userspace. Specifically,
failed control-line manipulations or control or read urb submissions
would not be detected.
Fixes: 7fb57a019f94 ("USB: cdc-acm: Fix potential deadlock (lockdep
warning)")
We must not do the usb_autopm_put_interface() before submitting the read
urbs or we might end up doing I/O to a suspended device.
Make sure to check return value of autopm get in write() in order to
avoid urb leak and PM counter imbalance on errors.
Cc: <stable@vger.kernel.org> # v2.6.27
We should stop I/O unconditionally at suspend rather than rely on the
tty-port initialised flag (which is set prior to stopping I/O during
shutdown) in order to prevent suspend returning with URBs still active.
Fix runtime PM handling of control messages by adding the required PM
counter operations.
The current ACM runtime-suspend implementation is broken in several
ways:
Firstly, it buffers only the first write request being made while
suspended -- any further writes are silently dropped.
Secondly, writes being dropped also leak write urbs, which are never
reclaimed (until the device is unbound).
Thirdly, even the single buffered write is not cleared at shutdown
(which may happen before the device is resumed), something which can
lead to another urb leak as well as a PM usage-counter leak.
Fix this by implementing a delayed-write queue using urb anchors and
making sure to discard the queue properly at shutdown.
Reported-by: Xiao Jin <jin.xiao@intel.com>
Fix race between write() and resume() due to improper locking that could
lead to writes being reordered.
Resume must be done atomically and susp_count be protected by the
write_lock in order to prevent racing with write(). This could otherwise
lead to writes being reordered if write() grabs the write_lock after
susp_count is decremented, but before the delayed urb is submitted.
Fix race between write() and suspend() which could lead to writes being
dropped (or I/O while suspended) if the device is runtime suspended
while a write request is being processed.
Specifically, suspend() releases the write_lock after determining the
device is idle but before incrementing the susp_count, thus leaving a
window where a concurrent write() can submit an urb.
By specifying NO_UNION_NORMAL the ACM driver does only use the first two
USB interfaces (modem data & control). The AT Port, Diagnostic and NMEA
interfaces are left to the USB serial driver.
Signed-off-by: Michael Ulbricht <michael.ulbricht@systec-electronic.com>
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Cc: stable <stable@vger.kernel.org>
If acm_submit_read_urbs() fails in acm_port_activate(), error handling
code calls usb_autopm_put_interface() while it is already called
before acm_submit_read_urbs(). The patch reorganizes error handling code
to avoid double decrement of USB interface's PM-usage counter.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Acked-by: Oliver Neukum <oliver@neukum.org>
Do not decrement resp_count if it's already 0.
We set resp_count to 0 when the device is closed. The next open and
read will try to clear the WDM_READ flag if there was leftover data
in the read buffer. This fix is necessary to prevent resubmitting
the read URB in a tight loop because resp_count becomes negative.
The bug can easily be triggered from userspace by not reading all
data in the read buffer, and then closing and reopening the chardev.
Fixes: 8dd5cd5395b9 ("usb: cdc-wdm: avoid hanging on zero length reads")
Cc: <stable@vger.kernel.org> # 3.13
Signed-off-by: Bjørn Mork <bjorn@mork.no>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This resolves the merge issue with drivers/usb/host/ohci-at91.c
commit 73e06865ead1 ("USB: cdc-wdm: support back-to-back
USB_CDC_NOTIFY_RESPONSE_AVAILABLE notifications") implemented
queued response handling. This added a new requirement: The read
urb must be resubmitted every time we clear the WDM_READ flag if
the response counter indicates that the device is waiting for a
read.
Fix by factoring out the code handling the WMD_READ clearing and
possible urb submission, calling it everywhere we clear the flag.
Without this fix, the driver ends up in a state where the read urb
is inactive, but the response counter is positive after a zero
length read. This prevents the read urb from ever being submitted
again and the driver appears to be hanging.
Fixes: 73e06865ead1 ("USB: cdc-wdm: support back-to-back USB_CDC_NOTIFY_RESPONSE_AVAILABLE notifications")
Cc: Greg Suarez <gsuarez@smithmicro.com>
Cc: stable <stable@vger.kernel.org> # 3.13
Reported-by: Oliver Neukum <oneukum@suse.de>
Acked-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: David Cluytens <david.cluytens@gmail.com>
An ioctl that does depends on communication with a device should
prevent suspension of teh device.
Simple straightforward implementation. Just returning the statistics
gathered for TIOCMIWAIT
This implements TIOCMIWAIT for TIOCM_DSR, TIOCM_RI and TIOCM_CD
Disconnect is handled as TIOCM_CD or an error.
The only notification supported by the Device Management class is
Response Available. But this driver is also used as a subdriver of
other CDC classes, allowing notifications like Speed Change and
Network Connection. This results in log messages which are only
confusing to an end user:
[66255.801874] cdc_mbim 1-3:1.5: unknown notification 42 received: index 5 len 8
These drivers use cdc-wdm as a subdriver to allow access to an
embedded management protocol, and all management is expected to
use this protocol. There is therefore no need to handle any of
these optional CDC notifications. Instead we can let the cdc-wdm
driver recognize them and log a debug level message instead of an
error.
Reported-by: Rob Gardner <robmatic@gmail.com>
notifications
Some MBIM devices send back-to-back USB_CDC_NOTIFY_RESPONSE_AVAILABLE notifications
when sending a message over multiple fragments or when there are unsolicited
messages available.
Count up the number of USB_CDC_NOTIFY_RESPONSE_AVAILABLE notifications received
and decrement the count and submit the urb for the next response each time userspace
completes a read the response.
Signed-off-by: Greg Suarez <gsuarez@smithmicro.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
In auditing the usbtmc sysfs files, a bunch of them were being created
as "read only", yet they have logic to handle writing to. So fix them
up by setting the permissions properly.
We want these USB fixes in this branch as well.
Both could want to submit the same URB. Some checks of the flag
intended to prevent that were missing.
CC: stable@vger.kernel.org
Fix probe of Rigol devices on big-endian machines. A quirk for these
devices was introduced by commit c2e314835 ("USB: usbtmc: Set
rigol_quirk if device is listed") but was only enabled on little-endian
machines.
Cc: stable@vger.kernel.org
kfree(data) will be called implicitly.
There is a few cases where braces are not needed. This patch removes
unnecessary '& 255' pieces as well when lvalue type is u8.
Additionally remove useless label.
Recent patch series introduces few trailing spaces. This patch removes them.
No functional change.
bInterval must be on the range 1 - 16, if we
want to pass the maximum allowed, we should
be passing 16
Signed-off-by: Felipe Balbi <balbi@ti.com>
When writing data we were:
lock
do some work
unlock
call function
lock
do some work
unlock
return
return
It turns out, that "function" was only ever called in the one place, so
instead of locking/unlocking for no good reason, just inline the
function and only grab the lock once.
This has sped up the pathological case of sending 1 byte packets to a
loop-back cdc-acm device from 49600 bytes per second to 50100 bytes a
second on my workstation. A tiny increase yes, but noticable, and now
the spinlock isn't the hottest thing on the perf graph anymore. Yes, we
are still waiting for the hardware for the most part, but getting rid of
a spinlock_irq_save() call for every packet is still a good thing.
And we end up deleting lines of code, always a win overall.
This was found by using a Teensy 3.0 device and the test program and
firmware located at:
http://www.pjrc.com/teensy/benchmark_usb_serial_receive.html
Reported-by: Paul Stoffregen <paul@pjrc.com>
These patches implement a modification of the USBTMC
protocol to allow operation with Rigol equipment. Cosmetic change to show
that 12 is the USBTMC header size.
Signed-off-by: Alexandre Peixoto Ferreira <alexandref75@gmail.com>
protocol to allow operation with Rigol equipment. The usbtmc_read function is
modified so if the quirk is active, the TMC header is sent with the size of
the data as the whole size of the request. If the quirk is inactive, the TMC
request is sent once per bulk transfer and with size limited to the bulk
transfer size. In the case of the quirk, only the first response contains the
TMC header and the others are just data.
protocol to allow operation with Rigol equipment. It an idVendor and
idProduct is found on the usbtmc_id_quirk array, the rigol_quirk is set for
this device.
protocol to allow operation with Rigol equipment. The TMC request portion of
the code in function usbtmc_read is segregated to a function
send_request_dev_dep_msg_in as implemented by tommie in
https://github.com/tommie/linux/blob/usbtmc-rigol/drivers/usb/class/usbtmc.c
allowing the reuse later.
protocol to allow operation with Rigol equipment. Rigol requires that a
single TMC request to receive any buffer size and bulk requests to get the
data. The original algorithm sends a TMC request for each subset of the data
(a single USB transaction). The modification is only active for Rigol
equipment, vendor and product set is contained in the array usbtmc_id_quirk.
This patch creates the rigol_quirk variable and the arrays for the
idvendor and idproduct.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Assorted fixes and cleanups to the existing drivers plus a new driver
for IMS Passenger Control Unit device they use for ther in-flight
entertainment system."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (44 commits)
Input: trackpoint - Optimize trackpoint init to use power-on reset
Input: apbps2 - convert to devm_ioremap_resource()
Input: ALPS - use %ph to print buffers
ARM - shmobile: Armadillo800EVA: Move st1232 reset pin handling
Input: st1232 - add reset pin handling
Input: st1232 - convert to devm_* infrastructure
Input: MT - handle semi-mt devices in core
Input: adxl34x - use spi_get_drvdata()
Input: ad7877 - use spi_get_drvdata() and spi_set_drvdata()
Input: ads7846 - use spi_get_drvdata() and spi_set_drvdata()
Input: ims-pcu - fix a memory leak on error
Input: sysrq - supplement reset sequence with timeout functionality
Input: tegra-kbc - support for defining row/columns based on SoC
Input: imx_keypad - switch to using managed resources
Input: arc_ps2 - add support for device tree
Input: mma8450 - fix signed 12bits to 32bits conversion
Input: eeti_ts - remove redundant null check
Input: edt-ft5x06 - remove redundant null check before kfree
Input: ad714x - add CONFIG_PM_SLEEP to suspend/resume functions
Input: adxl34x - add CONFIG_PM_SLEEP to suspend/resume functions
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg Kroah-Hartman:
"Here's the big USB pull request for 3.10-rc1.
Lots of USB patches here, the majority being USB gadget changes and
USB-serial driver cleanups, the rest being ARM build fixes / cleanups,
and individual driver updates. We also finally got some chipidea
fixes, which have been delayed for a number of kernel releases, as the
maintainer has now reappeared.
All of these have been in linux-next for a while"
* tag 'usb-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (568 commits)
USB: ehci-msm: USB_MSM_OTG needs USB_PHY
USB: OHCI: avoid conflicting platform drivers
USB: OMAP: ISP1301 needs USB_PHY
USB: lpc32xx: ISP1301 needs USB_PHY
USB: ftdi_sio: enable two UART ports on ST Microconnect Lite
usb: phy: tegra: don't call into tegra-ehci directly
usb: phy: phy core cannot yet be a module
USB: Fix initconst in ehci driver
usb-storage: CY7C68300A chips do not support Cypress ATACB
USB: serial: option: Added support Olivetti Olicard 145
USB: ftdi_sio: correct ST Micro Connect Lite PIDs
ARM: mxs_defconfig: add CONFIG_USB_PHY
ARM: imx_v6_v7_defconfig: add CONFIG_USB_PHY
usb: phy: remove exported function from __init section
usb: gadget: zero: put function instances on unbind
usb: gadget: f_sourcesink.c: correct a copy-paste misnomer
usb: gadget: cdc2: fix error return code in cdc_do_config()
usb: gadget: multi: fix error return code in rndis_do_config()
usb: gadget: f_obex: fix error return code in obex_bind()
USB: storage: convert to use module_usb_driver()
Inside usbtmc_ioctl_clear_out_halt()/usbtmc_ioctl_clear_in_halt(),
usb_clear_halt() needn't any buffer to pass in, so remove the
unnecessary memory allocation.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
