path: root/drivers/usb/core/quirks.c
2013-01-11USB: Add device quirk for Microsoft VX700 webcamAndreas Fleig
Add device quirk for Microsoft Lifecam VX700 v2.0 webcams. Fixes squeaking noise of the microphone. Signed-off-by: Andreas Fleig <andreasfleig@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-16Merge 3.6-rc6 into usb-nextGreg Kroah-Hartman
This resolves the merge problems with: drivers/usb/dwc3/gadget.c drivers/usb/musb/tusb6010.c that had been seen in linux-next. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05USB: add device quirk for Joss Optical touchboardAlan Stern
This patch (as1604) adds a CONFIG_INTF_STRINGS quirk for the Joss infrared touchboard device. The device doesn't like to be asked for its interface strings. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: adam ? <adam3337@wp.pl> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-20usb: convert USB_QUIRK_RESET_MORPHS to USB_QUIRK_RESETLan Tianyu
Since the attribute avoid_reset_quirk is work for all devices including those devices that can't morph, convert USB_QUIRK_RESET_MORPHS to USB_QUIRK_RESET. Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcamsLaurent Pinchart
Most Logitech UVC webcams (both early models that don't advertise UVC compatibility and newer UVC-advertised devices) require the RESET_RESUME quirk. Instead of listing each and every model, match the devices based on the UVC interface information. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19usb: Add quirk detection based on interface informationLaurent Pinchart
When a whole class of devices (possibly from a specific vendor, or across multiple vendors) require a quirk, explictly listing all devices in the class make the quirks table unnecessarily large. Fix this by allowing matching devices based on interface information. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30usb: add USB_QUIRK_RESET_RESUME for M-Audio 88esSteffen Müller
Tested-by: Steffen Müller <steffen.mueller@radio-frei.de> Signed-off-by: Steffen Müller <steffen.mueller@radio-frei.de> Signed-off-by: Stefan Seyfried <seife+kernel@b1-systems.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-03USB: add quirk for another cameraOliver Neukum
The Guillemot Webcam Hercules Dualpix Exchange camera has been reported with a second ID. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-14USB: quirks: adding more quirky webcams to avoid squeaky audiosordna
The following patch contains additional affected webcam models, on top of the patches commited to linux-next 2394d67e446bf616a0885167d5f0d397bdacfdfc and 5b253d88cc6c65a23cefc457a5a4ef139913c5fc Signed-off-by: sordna <sordna@gmail.com> Cc: Oliver Neukum <oliver@neukum.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-14USB: add quirk for Logitech C600 web camJosh Boyer
We've had another report of the "chipmunk" sound on a Logitech C600 webcam. This patch resolves the issue. Cc: stable <stable@vger.kernel.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-29USB: add quirk for Logitech C300 web camJon Levell
My webcam is a Logitech C300 and I get "chipmunk"ed squeaky sound. The following trivial patch fixes it. Signed-off-by: Jon Levell <linuxusb@coralbark.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-18USB: add RESET_RESUME for webcams shown to be quirkyOliver Neukum
The new runtime PM code has shown that many webcams suffer from a race condition that may crash them upon resume. Runtime PM is especially prone to show the problem because it retains power to the cameras at all times. However system suspension may also crash the devices and retain power to the devices. The only way to solve this problem without races is in usbcore with the RESET_RESUME quirk. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: Add quirk for Samsung Android phone modemMaciej Szmigiero
My Galaxy Spica needs this quirk when in modem mode, otherwise it causes endless USB bus resets and is unusable in this mode. Unfortunately Samsung decided to reuse ID of its old CDMA phone SGH-I500 for the modem part. That's why in addition to this patch the visor driver must be prevented from binding to SPH-I500 ID, so ACM driver can do that. Signed-off-by: Maciej Szmigiero <mhej@o2.pl> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: add quirks entry for Keytouch QWERTY PanelAlan Stern
This patch (as1448) adds a quirks entry for the Keytouch QWERTY Panel firmware, used in the IEC 60945 keyboard. This device crashes during enumeration when the computer asks for its configuration string descriptor. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: kholis <nur.kholis.majid@gmail.com> CC: <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16USB: improve uses of usb_mark_last_busyAlan Stern
This patch (as1434) cleans up the uses of usb_mark_last_busy() in usbcore. The function will be called when a device is resumed and whenever a usage count is decremented. A call that was missing from the hub driver is added: A hub is used whenever one of its ports gets suspended (this prevents hubs from suspending immediately after their last child). In addition, the call to disable autosuspend support for new devices by default is moved from usb_detect_quirks() (where it doesn't really belong) into usb_new_device() along with all the other runtime-PM initializations. Finally, an extra pm_runtime_get_noresume() is added to prevent new devices from autosuspending while they are being registered. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16USB: use the runtime-PM autosuspend implementationAlan Stern
This patch (as1428) converts USB over to the new runtime-PM core autosuspend framework. One slightly awkward aspect of the conversion is that USB devices will now have two suspend-delay attributes: the old power/autosuspend file and the new power/autosuspend_delay_ms file. One expresses the delay time in seconds and the other in milliseconds, but otherwise they do the same thing. The old attribute can be deprecated and then removed eventually. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB delay init quirk for logitech Harmony 700-series devicesPhil Dibowitz
The Logitech Harmony 700 series needs an extra delay during initialization. This patch adds a USB quirk which enables such a delay and adds the device to the quirks list. Signed-off-by: Phil Dibowitz <phil@ipom.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: add quirk for Broadcom BT dongleOliver Neukum
This device needs to be reset when resuming Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: adds Artisman USB dongle to list of quirky devicesPaul Mortier
When an attempt is made to read the interface strings of the Artisman Watchdog USB dongle (idVendor:idProduct 04b4:0526) an error is written to the dmesg log (uhci_result_common: failed with status 440000) and the dongle resets itself, resulting in a disconnect/reconnect loop. Adding the dongle to the list of devices in quirks.c, with the same quirk Alan Stern's previous patch for the Saitek Cyborg Gold 3D joystick, stops the device from resetting and allows it to be used with no problems. Signed-off-by: Paul Mortier <mortier@btinternet.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: Add a new quirk: USB_QUIRK_HONOR_BNUMINTERFACESHans de Goede
Add a new quirk USB_QUIRK_HONOR_BNUMINTERFACES, when this quirk is set and a device has more interface descriptors in a configuration then it claims to have in config->bNumInterfaces, ignore all additional interfaces. This is needed for devices which try to hide unused interfaces by only lowering config->bNumInterfaces, and which can't handle if you try to talk to the "hidden" interfaces. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: change handling of negative autosuspend delaysAlan Stern
This patch (as1327) changes the way negative autosuspend delays prevent device from autosuspending. The current code checks for negative values explicitly in the autosuspend_check() routine. The updated code keeps things from getting that far by using usb_autoresume_device() to increment the usage counter when a negative delay is set, and by using usb_autosuspend_device() to decrement the usage counter when a non-negative delay is set. This complicates the set_autosuspend() attribute method code slightly, but it will reduce the overall power management overhead. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: implement usb_enable_autosuspendAlan Stern
This patch (as1326) adds usb_enable_autosuspend() and usb_disable_autosuspend() routines for use by drivers. If a driver knows that its device can handle suspends and resumes correctly, it can enable autosuspend all by itself. This is equivalent to the user writing "auto" to the device's power/level attribute. The implementation differs slightly from what it used to be. Now autosuspend is disabled simply by doing usb_autoresume_device() (to increment the usage counter) and enabled by doing usb_autosuspend_device() (to decrement the usage counter). The set_level() attribute method is updated to use the new routines, and the USB Power-Management documentation is updated. The patch adds a usb_enable_autosuspend() call to the hub driver's probe routine, allowing the special-case code for hubs in quirks.c to be removed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: storage: Never reset devices that will morph to an old modeOliver Neukum
Some devices must be switched to a new mode to fully use them. A reset would make them revert to the old mode. Therefore a reset must not be used for error handling with such devices. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: add quirk to avoid config and interface stringsAlan Stern
Apparently the Configuration and Interface strings aren't used as often as the Vendor, Product, and Serial strings. In at least one device (a Saitek Cyborg Gold 3D joystick), attempts to read the Configuration string cause the device to stop responding to Control requests. This patch (as1226) adds a quirks flag, telling the kernel not to read a device's Configuration or Interface strings, together with a new quirk for the offending joystick. Reported-by: Melchior FRANZ <melchior.franz@gmail.com> Tested-by: Melchior FRANZ <melchior.franz@gmail.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> [2.6.28 and 2.6.29, nothing earlier] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-17Merge branch 'for-linus' of ↵tip-x86-pci-ioapic-boot-irq-quirks-2008-06-23_09.52_Montip-x86-mm-remove-arch-get-ram-range-2008-06-23_09.06_Montip-x86-mm-debug-2008-06-23_09.04_Montip-core-debugobjects-2008-06-23_08.51_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: appletouch - implement reset-resume logic Input: i8042 - retry failed CTR writes when resuming Input: i8042 - add Fujitsu-Siemens Amilo Pro V2030 to nomux table Input: pcspkr - remove negative dependency on snd-pcsp Manually fixed up trivial conflict in drivers/usb/core/quirks.c
2008-06-17Input: appletouch - implement reset-resume logicOliver Neukum
On some boxes the touchpad needs to be reinitialized after resume to make it function again. This fixes bugzilla #10825. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-29USB: add another scanner quirkRené Rebe
Like the HP53{00,70} scanner other devices of the OEM Avision require the USB_QUIRK_STRING_FETCH_255 to correct set a configuration with "recent" Linux kernels. Signed-off-by: René Rebe <rene@exactcode.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: enable USB-PERSIST by defaultAlan Stern
This patch (as1052) enables USB-PERSIST for all devices by default. The user won't have to remember to enable it explicitly for devices containing mounted filesystems. Eventually userspace tools like hal may be able to set the persist attribute automatically when a filesystem is mounted on a USB device. When that time comes this patch can be reverted, if people think it matters. This approach has the advantage of giving the user the ability to turn off USB-PERSIST for devices with mounted filesystems, rather than making the kernel always assume it should be on. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: new quirk flag to avoid Set-InterfaceAlan Stern
This patch (as1057) fixes a problem with the X-Rite/Gretag-Macbeth Eye-One Pro display colorimeter; the device crashes when it receives a Set-Interface request. A new quirk (USB_QUIRK_NO_SET_INTF) is introduced and a quirks entry is created for this device. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04USB: spruce up the device blacklistAlan Stern
This patch (as1040) fixes up the blacklist of USB device quirks. A couple of lines are broken to comply with the 80-column rule, and entries are sorted into the proper numerical order. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: quirks and unusual_devs entry for Actions flash driveAlan Stern
This patch (as1033) adds a quirks entry and an unusual_devs entry for the Actions Semiconductor flash drive. This device has a 64-byte string descriptor, which it doesn't terminate with a 0-length packet. Oddly enough, the reporter's logs show that when the device was plugged in at boot time, it changes its behavior completely -- it uses a different product ID, product string descriptor, and bDeviceClass. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: quirks for known quirky audio devicesOliver Neukum
RESET_RESUME entries for some sound devices that need it. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: remove USB_QUIRK_NO_AUTOSUSPENDAlan Stern
This patch (as995) cleans up the remains of the former NO_AUTOSUSPEND quirk. Since autosuspend is disabled by default, we will let userspace worry about which devices can safely be suspended. Thus the lengthy series of quirk entries is no longer needed, and neither is the quirk ID. I suppose someone might eventually run across a hub that can't be suspended; let's ignore the possibility for now. The patch also cleans up the hasty way in which autosuspend gets disabled. Setting udev->autosuspend_delay to -1 wasn't quite right, because the value is always supposed to be a multiple of HZ. It's better to leave the delay value alone and set autosuspend_disabled, which is what the quirk routine used to do. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-13USB: disable autosuspend by default for non-hubsAlan Stern
This patch (as965) disables autosuspend by default for all USB devices other than hubs. We are seeing too many devices that can't suspend or resume properly, the blacklist is growing unreasonably quickly, and this sort of thing should be handled in userspace. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: another quirky device (LCD display)Oliver Neukum
this time it is an LCD. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: More USB_QUIRK_RESET_RESUME devicesLamarque Vieira Souza
I would like have the attached patch added to Linux kernel. The three usb flash memories listed in the patch are being used in Intel's ClassmatePC and need USB_QUIRK_RESET_RESUME to work reliably when resuming from ram.
2007-09-11USB: quirky flash driveOliver Neukum
That drive is quite odd. It has 2K sectors, times out getting string descriptors and needs a quirk. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: prevent Genesys USB-IDE from autosuspendingAlan Stern
This patch (as986) prevents the troublesome Genesys USB-IDE adapter from autosuspending. It may not be necessary for all such devices, but the one in Bugzilla #8892 sometimes fails to resume. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: prevent Thomson card reader from autosuspendingAlan Stern
This patch (as985) prevents the SGS THomson Microelectronics 4in1 card reader from autosuspending. This resolves Bugzilla #8885. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: Add iPhone device id to the quirk list.Matt Colyer
2007-08-22usb quirks: Add Canon EOS 5D (PC Connection mode) to the autosuspend blacklistPaul Walmsley
Recent versions of the Linux kernel auto-suspend attached USB devices. After this happens to the Canon EOS 5D camera, the camera's interrupt endpoints don't seem to wake back up correctly, causing further use with libgphoto2 to fail with a -114 "OS error in camera communication" error. A similar fix is probably necessary for this camera in PTP mode, which identifies as USB product id 0x3102, but we haven't tested this. As part of our testing process, we tried the USB_QUIRK_RESET_RESUME quirk also, it's not helpful in this case. Signed-off-by: Raj Kumar <rkumar@archive.org> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: another quirky deviceOliver Neukum
for the drive Jean reported. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: quirky mass storage deviceOliver Neukum
this device has been reported to break with autosuspend. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: blacklist Samsung ML-2010 printerOliver Neukum
Hi, this printer does not survive suspension. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: quirks: multicard reader doesn't like autosuspendDavid Brownell
It appears that one reason the "iConnect"-labeled multi-card reader was on sale for only $5 is that it doesn't handle suspend/resume correctly. Other than that, it was a good deal for a highspeed MMC/SD bridge. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: yet another quirky deviceOliver Neukum
another quirky scanner. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: Add CanonScan LiDE30 to the quirk listJohann Felix Soden
This patch adds CanoScan N1240U/LiDE30 (Scanner) to the list of quirky USB devices. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: even more quirksOliver Neukum
The number of quirky devices seems to be large. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: more quirky devicesOliver Neukum
our list of devices which cannot be suspended keeps growing. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
