This eliminates the last instance of a function's behavior
controlled by a parameter as Linus hates such things.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
This commit gets BOS(Binary Device Object Store) descriptor set for Super
Speed devices and High Speed devices which support BOS descriptor.
BOS descriptor is used to report additional USB device-level capabilities
that are not reported via the Device descriptor. By getting BOS descriptor
set, driver can check device's device-level capability such as LPM
capability.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
The usb_create_sysfs_intf_files() function always returned zero even
if it failed to create sysfs fails. Since this is a desired behaviour
there is no need to return return code at all. This commit changes
function's return type (form int) to void.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
USB defines usb_device_type pointing to usb_device_pm_ops that
provides system-wide PM callbacks only and usb_bus_type pointing to
usb_bus_pm_ops that provides runtime PM callbacks only. However,
the USB runtime PM callbacks may be defined in usb_device_pm_ops
which makes it possible to drop usb_bus_pm_ops and will allow us
to consolidate the handling of subsystems by the PM core code.
This patch (as1428) converts USB over to the new runtime-PM core
autosuspend framework. One slightly awkward aspect of the conversion
is that USB devices will now have two suspend-delay attributes: the
old power/autosuspend file and the new power/autosuspend_delay_ms
file. One expresses the delay time in seconds and the other in
milliseconds, but otherwise they do the same thing. The old attribute
can be deprecated and then removed eventually.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fake "address-of" expressions that evaluate to NULL generally confuse
readers and can provoke compiler warnings. This patch (as1412)
removes three such fake expressions, using "#ifdef"s in their place.
The semaphore is semantically a mutex. Convert it to a real mutex and
fix up a few places where code was relying on semaphore.h to be included
by device.h, as well as the users of the trylock function, as that value
is now reversed.
usb_find_device was the only one user of match_device, now
it is removed, so remove match_device to fix the compile warning
below reported by Stephen Rothwell:
drivers/usb/core/usb.c:596: warning: 'match_device'
defined but not used
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Now on one uses this function and it seems useless,
so remove usb_find_device.
[tom@tom linux-2.6-next]$ grep -r -n -I usb_find_device ./
drivers/media/dvb/dvb-usb/dvb-usb-init.c:160:static struct
dvb_usb_device_description * dvb_usb_find_device(struct usb_device
*udev,struct dvb_usb_device_properties *props, int *cold)
drivers/media/dvb/dvb-usb/dvb-usb-init.c:230: if ((desc =
dvb_usb_find_device(udev,props,&cold)) == NULL) {
drivers/usb/core/usb.c:630: * usb_find_device - find a specific usb device in the system
drivers/usb/core/usb.c:642:struct usb_device *usb_find_device(u16 vendor_id, u16 product_id)
This patch (as1368) fixes a rather obscure bug in usbmon: When tracing
URBs sent by the scatter-gather library, it accesses the data buffers
while they are still mapped for DMA.
The solution is to move the mapping and unmapping out of the s-g
library and into the usual place in hcd.c. This requires the addition
of new URB flag bits to describe the kind of mapping needed, since we
have to call dma_map_sg() if the HCD supports native scatter-gather
operation and dma_map_page() if it doesn't. The nice thing about
having the new flags is that they simplify the testing for unmapping.
The patch removes the only caller of usb_buffer_[un]map_sg(), so those
functions are #if'ed out. A later patch will remove them entirely.
As a result of this change, urb->sg will be set in situations where
it wasn't set previously. Hence the xhci and whci drivers are
adjusted to test urb->num_sgs instead, which retains its original
meaning and is nonzero only when the HCD has to handle a scatterlist.
Finally, even when a submission error occurs we don't want to hand
URBs to usbmon before they are unmapped. The submission path is
rearranged so that map_urb_for_dma() is called only for non-root-hub
URBs and unmap_urb_for_dma() is called immediately after a submission
error. This simplifies the error handling.
CC: <stable@kernel.org>
This patch (as1350) removes all usages of coherent buffers for USB
control-request setup-packet buffers. There's no good reason to
reserve coherent memory for these things; control requests are hardly
ever used in large quantity (the major exception is firmware
transfers, and they aren't time-critical). Furthermore, only seven
drivers used it. We might as well always use streaming DMA mappings
for setup-packet buffers, and remove some extra complexity from
usbcore.
The DMA-mapping portion of hcd.c is currently in flux. A separate
patch will be submitted to remove support for URB_NO_SETUP_DMA_MAP
after everything else settles down. The removal should go smoothly,
as by then nobody will be using it.
The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
[added compatibility macros so we can convert things easier - gregkh]
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Pedro Ribeiro <pedrib@gmail.com>
USB: Move hcd free_dev call into usb_disconnect
I found a way to oops the kernel:
1. Open a USB device through devio.
2. Remove the hcd module in the host kernel.
3. Close the devio file descriptor.
The problem is that closing the file descriptor does usb_release_dev
as it is the last reference. usb_release_dev then tries to invoke
the hcd free_dev function (or rather dereferencing the hcd driver
struct). This causes an oops as the hcd driver has already been
unloaded so the struct is gone.
This patch tries to fix this by bringing the free_dev call earlier
and into usb_disconnect. I have verified that repeating the
above steps no longer crashes with this patch applied.
Cc: stable <stable@kernel.org>
This patch (as1329) converts the USB stack over to the PM core's
runtime PM framework. This involves numerous changes throughout
usbcore, especially to hub.c and driver.c. Perhaps the most notable
change is that CONFIG_USB_SUSPEND now depends on CONFIG_PM_RUNTIME
instead of CONFIG_PM.
Several fields in the usb_device and usb_interface structures are no
longer needed. Some code which used to depend on CONFIG_USB_PM now
depends on CONFIG_USB_SUSPEND (requiring some rearrangement of header
files).
The only visible change in behavior should be that following a system
sleep (resume from RAM or resume from hibernation), autosuspended USB
devices will be resumed just like everything else. They won't remain
suspended. But if they aren't in use then they will naturally
autosuspend again in a few seconds.
Fix new kernel-doc warnings in usb core:
Warning(drivers/usb/core/usb.c:79): No description found for parameter 'config'
Warning(drivers/usb/core/usb.c:79): No description found for parameter 'iface_num'
Warning(drivers/usb/core/usb.c:79): No description found for parameter 'alt_num'
Warning(drivers/usb/core/hcd.c:1622): No description found for parameter 'udev'
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: Close usb_find_interface race v3
Revert "USB: Close usb_find_interface race"
USB drivers that create character devices call usb_register_dev in their
probe function. This associates the usb_interface device with that minor
number and creates the character device and announces it to the world.
However, the driver's probe function is called before the new
usb_interface is added to the driver's klist_devices.
This is a problem because userspace will respond to the character device
creation announcement by opening the character device. The driver's open
function will the call usb_find_interface to find the usb_interface
associated with that minor number. usb_find_interface will walk the
driver's list of devices and find the usb_interface with the matching
minor number.
Because the announcement happens before the usb_interface is added to the
driver's klist_devices, a race condition exists. A straightforward fix
is to walk the list of devices on usb_bus_type instead since the device
is added to that list before the announcement occurs.
bus_find_device calls get_device to bump the reference count on the found
device. It is arguable that the reference count should be dropped by the
caller of usb_find_interface instead of usb_find_interface, however,
the current users of usb_find_interface do not expect this.
The original version of this patch only matched against minor number
instead of driver and minor number. This version matches against both.
Signed-off-by: Russ Dill <Russ.Dill@gmail.com>
This reverts commit a2582bd478c13c574d4c16ef1209d333f2a25935.
It turned out to be buggy and broke USB printers from working.
Cc: Russ Dill <Russ.Dill@gmail.com>
Fix the following sparse warning:
drivers/usb/core/usb.c:1033:15: warning: symbol 'usb_debug_devices' was not declared. Should it be static?
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
Refactor out the code to find alternate interface settings into
usb_find_alt_setting(). Print a debugging message and return null if the
alt setting is not found.
While we're at it, correct a bug in the refactored code. The interfaces
in the configuration's interface cache are not necessarily in numerical
order, so we can't just use the interface number as an array index. Loop
through the interface caches, looking for the correct interface.
minor number.
The xHCI driver needs to set the route string in the slot context of all
devices, not just SuperSpeed devices. The route string concept was added
in the USB 3.0 specification, section 10.1.3.2. Each hub in the topology
is expected to have no more than 15 ports in order for the route string of
a device to be unique. SuperSpeed hubs are restricted to only having 15
ports, but FS/LS/HS hubs are not. The xHCI specification says that if the
port number the device is under is greater than 15, that portion of the
route string shall be set to 15.
usb_buffer_map_sg should return negative on error according to
its documentation. But dma_map_sg returns 0 on error. Take this
into account and return -ENOMEM in such situation.
While at it, return -EINVAL instead of -1 when wrong input is
passed in.
If this wasn't done, usb_sg_* operations used after usb_sg_init
which returned 0 may cause oopses/deadlocks since we don't init
structures/entries, esp. completion and status entry.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (143 commits)
USB: xhci depends on PCI.
USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries.
USB: xhci: Respect critical sections.
USB: xHCI: Fix interrupt moderation.
USB: xhci: Remove packed attribute from structures.
usb; xhci: Fix TRB offset calculations.
USB: xhci: replace if-elseif-else with switch-case
USB: xhci: Make xhci-mem.c include linux/dmapool.h
USB: xhci: drop spinlock in xhci_urb_enqueue() error path.
USB: Change names of SuperSpeed ep companion descriptor structs.
USB: xhci: Avoid compiler reordering in Link TRB giveback.
USB: xhci: Clean up xhci_irq() function.
USB: xhci: Avoid global namespace pollution.
USB: xhci: Fix Link TRB handoff bit twiddling.
USB: xhci: Fix register write order.
USB: xhci: fix some compiler warnings in xhci.h
USB: xhci: fix lots of compiler warnings.
USB: xhci: use xhci_handle_event instead of handle_event
USB: xhci: URB cancellation support.
USB: xhci: Scatter gather list support for bulk transfers.
Add host controller driver API and a slot_id variable to struct
usb_device. This allows the xHCI host controller driver to ask the
hardware to allocate a slot for the device when a struct usb_device is
allocated. The slot needs to be allocated at that point because the
hardware can run out of internal resources, and we want to know that very
early in the device connection process. Don't call this new API for root
hubs, since they aren't real devices.
Add HCD API to let the host controller choose the device address. This is
especially important for xHCI hardware running in a virtualized
environment. The guests running under the VM don't need to know which
addresses on the bus are taken, because the hardware picks the address for
them. Announce SuperSpeed USB devices after the address has been assigned
by the hardware.
Don't use the new get descriptor/set address scheme with xHCI. Unless
special handling is done in the host controller driver, the xHC can't
issue control transfers before you set the device address. Support for
the older addressing scheme will be added when the xHCI driver supports
the Block Set Address Request (BSR) flag in the Address Device command.
This patch adds a hex route string to each USB device. The route string is used
by the USB 3.0 host controller to send packets through the device tree. USB 3.0
hubs use this string to route packets to the correct port. This is fundamental
bus change from USB 2.0, where all packets were broadcast across the bus.
Devices (including hubs) under a root port receive the route string 0x0. Every
four bits in the route string represent a port on a hub. This length works
because USB 3.0 hubs are limited to 15 ports, and USB 2.0 hubs (with potentially
more ports) will never see packets with a route string. A port number of 0
means the packet is destined for that hub.
For example, a peripheral device might have a route string of 0x00097.
This means the device is connected to port 9 of the hub at depth 1.
The hub at depth 1 is connected to port 7 of a hub at depth 0.
The hub at depth 0 is connected to a root port.
and dma_sync_sg_for_cpu
This replaces dma_sync_single() and dma_sync_sg() with
dma_sync_single_for_cpu() and dma_sync_sg_for_cpu() respectively
because they is an obsolete API; include/linux/dma-mapping.h says:
/* Backwards compat, remove in 2.7.x */
#define dma_sync_single dma_sync_single_for_cpu
#define dma_sync_sg dma_sync_sg_for_cpu
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
The endpoint devices look like simple attribute groups now, and no longer
like devices with a specific subsystem. They will also no longer emit uevents.
It also removes the device node requests for endpoint devices, which are not
implemented for now.
The usb_host class isn't used for anything anymore (it was used for
debug files, but they have moved to debugfs a few kernel releases ago),
so let's delete it before someone accidentally puts a file in it.
People are very used to the devices file in usbfs. Now that we have
moved usbfs to be an "embedded" option only, the developers miss the
file, they had grown quite attached to it over all of these years. This
patch brings it back and puts it in the usb debugfs directory, so that
the developers don't feel sad anymore.
Add a common usb directory in debugfs that the usb subsystem can use.
This adds support for USB drivers to report their requested nodename to
userspace. It also updates a number of USB drivers to provide the
needed subdirectory and device name to be used for them.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Wireless USB endpoint state has a sequence number and a current
window and not just a single toggle bit. So allow HCDs to provide a
endpoint_reset method and call this or clear the software toggles as
required (after a clear halt, set configuration etc.).
usb_settoggle() and friends are then HCD internal and are moved into
core/hcd.h and all device drivers call usb_reset_endpoint() instead.
If the device endpoint state has been reset (with a clear halt) but
the host endpoint state has not then subsequent data transfers will
not complete. The device will only work again after it is reset or
disconnected.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
This patch (as1197) fixes an error introduced recently. Since a
significant number of devices can't handle Set-Interface requests, we
no longer call usb_set_interface() when a driver unbinds from an
interface, provided the interface is already in altsetting 0. However
the interface still does get disabled, and the call to
usb_set_interface() was the only thing re-enabling it. Since the
interface doesn't get re-enabled, further attempts to use it fail.
So the patch adds a call to usb_enable_interface() when a driver
unbinds and the interface is in altsetting 0. For this to work
right, the interface's endpoints have to be re-enabled but their
toggles have to be left alone. Therefore an additional argument is
added to usb_enable_endpoint() and usb_enable_interface(), a flag
indicating whether or not the endpoint toggles should be reset.
This is a forward-ported version of a patch which fixes Bugzilla
#12301.
Reported-by: David Roka <roka@dawid.hu>
Reported-by: Erik Ekman <erik@kryo.se>
Tested-by: Erik Ekman <erik@kryo.se>
Tested-by: Alon Bar-Lev <alon.barlev@gmail.com>
This patch (as1185) makes usbcore take advantage of the bus
notifications sent out by the driver core. Now we can create all our
device and interface attribute files before the device or interface
uevent is broadcast.
A side effect is that we no longer create the endpoint "pseudo"
devices at the same time as a device or interface is registered -- it
seems like a bad idea to try registering an endpoint before the
registration of its parent is complete. So the routines for creating
and removing endpoint devices have been split out and renamed, and
they are called explicitly when needed. A new bitflag is used for
keeping track of whether or not the interface's endpoint devices have
been created, since (just as with the interface attributes) they vary
with the altsetting and hence can be changed at random times.
Cc: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1177) modifies the USB core suspend and resume
routines. The resume functions now will take a pm_message_t argument,
so they will know what sort of resume is occurring. The new argument
is also passed to the port suspend/resume and bus suspend/resume
routines (although they don't use it for anything but debugging).
In addition, special pm_message_t values are used for user-initiated,
device-initiated (i.e., remote wakeup), and automatic suspend/resume.
By testing these values, drivers can tell whether or not a particular
suspend was an autosuspend. Unfortunately, they can't do the same for
resumes -- not until the pm_message_t argument is also passed to the
drivers' resume methods. That will require a bigger change.
IMO, the whole Power Management framework should have been set up this
way in the first place.
Impact: cleanup
Found this when I changed args to __module_param_call. We now have
core_param for exactly this, but Greg assures me "nousb" is used as a
module parameter, so we need the #ifdef MODULE.
Cc: Pete Zaitcev <zaitcev@redhat.com>
This patch (as1160b) adds support routines for asynchronous autosuspend
and autoresume, with accompanying documentation updates. There
already are several potential users of this interface, and others are
likely to arise as autosuspend support becomes more widespread.
This patch (as1161) changes the interface to
usb_lock_device_for_reset(). The existing interface is apparently not
very clear, judging from the fact that several of its callers don't
use it correctly. The new interface always returns 0 for success and
it always requires the caller to unlock the device afterward.
The new routine will not return immediately if it is called while the
driver's probe method is running. Instead it will wait until the
probe is over and the device has been unlocked. This shouldn't cause
any problems; I don't know of any cases where drivers call
usb_lock_device_for_reset() during probe.
PM: Simplify the new suspend/hibernation framework for devices
Following the discussion at the Kernel Summit, simplify the new
device PM framework by merging 'struct pm_ops' and
'struct pm_ext_ops' and removing pointers to 'struct pm_ext_ops'
from 'struct platform_driver' and 'struct pci_driver'.
After this change, the suspend/hibernation callbacks will only
reside in 'struct device_driver' as well as at the bus type/
device class/device type level. Accordingly, PCI and platform
device drivers are now expected to put their suspend/hibernation
callbacks into the 'struct device_driver' embedded in
'struct pci_driver' or 'struct platform_driver', respectively.
Acked-by: Pavel Machek <pavel@suse.cz>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
This patch (as1129) adds support for the new PM callbacks to usbcore.
The new callbacks merely invoke the same old USB power management
routines as the old ones did.
A minor improvement is that the callbacks are present only in the
"USB-device" device_type structure, rather than in the bus_type
structure. This way they will be invoked only for USB devices, not
for USB interfaces. The core USB PM routines automatically handle
suspending and resuming interfaces along with their devices.
The bus_id field is going away, use the dev_set_name() function
to set it properly.
The bus_id field is going away, use the dev_name() function instead.
This patch (as1087d) fixes a long-standing problem in usbcore: Device,
interface, and endpoint attributes aren't added until _after_ the
creation uevent has already been broadcast.
Unfortunately there are a few attributes which cannot be created that
early. The "descriptors" attribute is binary and so must be created
separately. The power-management attributes can't be created until
the dev/power/ group exists. And the interface string can vary from
one altsetting to another, so it has to be created dynamically.
Remove the code that acquires all device semaphores from the suspend
code path as it causes multiple problems to appear (most notably,
http://bugzilla.kernel.org/show_bug.cgi?id=10030) and revert the
change introduced by commit 4145ed6dc597a9bea5f6ae8c574653b2de10620f
depending on the code being removed.
Remove pm_sleep_lock()/pm_sleep_unlock() from device_add() to avoid
the issue reported at http://bugzilla.kernel.org/show_bug.cgi?id=9874.
It should fix the regreesions reported at:
