This patch (as1087d) fixes a long-standing problem in usbcore: Device,
interface, and endpoint attributes aren't added until _after_ the
creation uevent has already been broadcast.
Unfortunately there are a few attributes which cannot be created that
early. The "descriptors" attribute is binary and so must be created
separately. The power-management attributes can't be created until
the dev/power/ group exists. And the interface string can vary from
one altsetting to another, so it has to be created dynamically.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Kay Sievers <kay.sievers@vrfy.org>
power.power_state is scheduled for removal. This patch (as1053)
removes all uses of that field from drivers/usb. Almost all of them
were write-only, the most significant exceptions being sl811-hcd.c and
u132-hcd.c.
Part of this patch was written by Pavel Machek.
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Pavel Machek <pavel@ucw.cz>
Fixes a number of coding style issues in the USB internal header files.
As it is global, give it a usb specific name in the global namespace.
Cc: Inaky Perez-Gonzalez <inaky@linux.intel.com>
These USB API functions will do the full authorization/deauthorization
to be used for a device. When authorized we effectively allow a
configuration to be set. Reverse that when deauthorized.
Effectively this means that we have to clean all the configuration
descriptors on deauthorize and reload them when we authorized. We could
do without throwing them out for wired devices, but for wireless, we can
read them only after authenticating, and thus, when authorizing an
authenticated device we would need to read them. So to simplify, always
release them on deauthorize(), re-read them on authorize().
Also fix leak reported by Ragner Magalhaes; in usb_deauthorize_device(),
bNumConfigurations was being set to zero before the for loop, and thus
the different raw descriptors where never being freed.
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
This patch (as944) adds an explicit "enabled" field to the
usb_host_endpoint structure and uses it in place of the current
mechanism. This is merely a time-space tradeoff; it makes checking
whether URBs may be submitted to an endpoint simpler. The existing
mechanism is efficient when converting urb->pipe to an endpoint
pointer, but it's not so efficient when urb->ep is used instead.
As a side effect, the procedure for enabling an endpoint is now a
little more complicated. The ad-hoc inline code in usb.c and hub.c
for enabling ep0 is now replaced with calls to usb_enable_endpoint,
which is no longer static.
This patch (as919) unifies the code paths used for normal resume and
for reset-resume. Earlier I had failed to note a section in the USB
spec which requires the host to resume a suspended port before
resetting it if the attached device is enabled for remote wakeup.
Since the port has to be resumed anyway, we might as well reuse the
existing code.
The main changes are:
usb_reset_suspended_device() is eliminated.
usb_root_hub_lost_power() is moved down next to the
hub_reset_resume() routine, to which it is logically
related.
finish_port_resume() does a port reset() if the device's
reset_resume flag is set.
usb_port_resume() doesn't check whether the port is initially
enabled if this is a USB-Persist sort of resume.
Code to perform the port reset is added to the resume pathway
for the non-CONFIG_USB_SUSPEND case.
This patch (as915b) combines the public routine usb_port_suspend() and
the private routine __usb_port_suspend() into a single function.
By removing the explicit mention of otg_port in the call to
__usb_port_suspend(), we prevent a possible error in which the system
tries to perform HNP on the wrong port when a non-targeted device is
plugged into a non-OTG port.
This patch (as886) adds the controversial USB-persist facility,
allowing USB devices to persist across a power loss during system
suspend.
The facility is controlled by a new Kconfig option (with appropriate
warnings about the potential dangers); when the option is off the
behavior will remain the same as it is now. But when the option is
on, people will be able to use suspend-to-disk and keep their USB
filesystems intact -- something particularly valuable for small
machines where the root filesystem is on a USB device!
This patch (as880) strives to keep the PM core's idea of a USB
interface's power state in synch with usbcore's own idea. In the end
this doesn't really matter, but it's better to be consistent.
o The "real" usb-devices export now a device node which can
populate /dev/bus/usb.
o The usb_device class is optional now and can be disabled in the
kernel config. Major/minor of the "real" devices and class devices
are the same.
o The environment of the usb-device event contains DEVNUM and BUSNUM to
help udev and get rid of the ugly udev rule we need for the class
devices.
o The usb-devices and usb-interfaces share the same bus, so I used
the new "struct device_type" to let these devices identify
themselves. This also removes the current logic of using a magic
platform-pointer.
The name of the device_type is also added to the environment
which makes it easier to distinguish the different kinds of devices
on the same subsystem.
It looks like this:
add@/devices/pci0000:00/0000:00:1d.1/usb2/2-1
ACTION=add
DEVPATH=/devices/pci0000:00/0000:00:1d.1/usb2/2-1
SUBSYSTEM=usb
SEQNUM=1533
MAJOR=189
MINOR=131
DEVTYPE=usb_device
PRODUCT=46d/c03e/2000
TYPE=0/0/0
BUSNUM=002
DEVNUM=004
This udev rule works as a replacement for usb_device class devices:
SUBSYSTEM=="usb", ACTION=="add", ENV{DEVTYPE}=="usb_device", \
NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", MODE="0644"
Updated patch, which needs the device_type patches in Greg's tree.
I also got a bugzilla assigned for this. :)
https://bugzilla.novell.com/show_bug.cgi?id=250659
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch (as866) adds new entry points for external USB device
suspend and resume requests, as opposed to internally-generated
autosuspend or autoresume. It also changes the existing
remote-wakeup code paths to use the new routines, since remote wakeup
is not the same as autoresume.
As part of the change, it turns out to be necessary to do remote
wakeup of root hubs from a workqueue. We had been using khubd, but it
does autoresume rather than an external resume. Using the
ksuspend_usb_wq workqueue for this purpose seemed a logical choice.
This patch (as864) moves the work routine for USB autosuspend from one
source file to another. This permits the removal of one whole global
symbol (!) and should smooth the way for more changes in the future.
This patch (as861) adds sysfs attributes to expose the autosuspend
delay value for each USB device. If the user changes the delay from 0
(no autosuspend) to a positive value, an autosuspend is attempted.
This patch (as859) makes the default USB autosuspend delay a module
parameter of usbcore. By setting the delay value at boot time, users
will be able to prevent the system from autosuspending devices which
for some reason can't handle it.
The patch also stores the autosuspend delay as a per-device value. A
later patch will allow the user to change the value, tailoring the
delay for each individual device. A delay value of 0 will prevent
autosuspend.
This adds a blacklist to the USB core to handle some autosuspend and
string issues that devices have.
Originally written by Oliver, but hacked up a lot by Greg.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
This is needed for the quirk match code.
Cc: Oliver Neukum <oliver@neukum.name>
Thanks to several earlier patches, usb_autosuspend_device() and
usb_autoresume_device() are never called with a second argument other
than 1. This patch (as819) removes the now-redundant argument.
It also consolidates some common code between those two routines,
putting it into a new subroutine called usb_autopm_do_device(). And
it includes a sizable kerneldoc update for the affected functions.
The problem with remembering a user space process by its pid is that it is
possible that the process will exit, pid wrap around will occur.
Converting to a struct pid avoid that problem, and paves the way for
implementing a pid namespace.
Also since usb is the only user of kill_proc_info_as_uid rename
kill_proc_info_as_uid to kill_pid_info_as_uid and have the new version take
a struct pid.
This patch (as791b) fixes things up to avoid compiler warnings or
errors when CONFIG_USB_SUSPEND or CONFIG_PM isn't set.
This patch (as787) creates a new workqueue thread to handle delayed
USB autosuspend requests. Previously the code used keventd. However
it turns out that the hub driver's suspend routine calls
flush_scheduled_work(), making it a poor candidate for running in
keventd (the call immediately deadlocks). The solution is to use a
new thread instead of keventd.
This patch (as740) removes the existing support for autosuspend of
root hubs. That support fit in rather awkwardly with the rest of
usbcore and it was used only by ohci-hcd. It won't be needed any more
since the hub driver will take care of autosuspending all hubs, root
or external.
This patch (as739) adds the basic infrastructure for USB autosuspend
and autoresume. The main features are:
PM usage counters added to struct usb_device and struct
usb_interface, indicating whether it's okay to autosuspend
them or they are currently in use.
Flag added to usb_device indicating whether the current
suspend/resume operation originated from outside or as an
autosuspend/autoresume.
Flag added to usb_driver indicating whether the driver
supports autosuspend. If not, no device bound to the driver
will be autosuspended.
Mutex added to usb_device for protecting PM operations.
Unlike the device semaphore, the locking rule for the pm_mutex
is that you must acquire the locks going _up_ the device tree.
New routines handling autosuspend/autoresume requests for
interfaces and devices.
Suspend and resume requests are propagated up the device tree
(but not outside the USB subsystem).
work_struct added to usb_device, for carrying out delayed
Autoresume added (and autosuspend prevented) during probe and
disconnect.
drivers/usb/core/hub.c: In function `hub_events':
drivers/usb/core/hub.c:2591: warning: statement with no effect
This patch marks some USB core's functions parameters as const. This
improves the design (we're saying to the caller that its parameter is
not going to be modified) and may help in compiler's optimisation work.
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Making structs const prevents accidental bugs and with the proper debug
options they're protected against corruption.
This patch (as736) makes the hub driver more readable by improving the
usage of "#ifdef CONFIG_PM" and "#ifdef CONFIG_USB_SUSPEND".
Currently we rely on intf->dev.power.power_state.event for tracking
whether intf is suspended. This is not a reliable technique because
that value is owned by the PM core, not by usbcore. This patch (as718b)
adds a new flag so that we can accurately tell which interfaces are
suspended and which aren't.
At first one might think these flags aren't needed, since interfaces
will be suspended along with their devices. It turns out there are a
couple of intermediate situations where that's not quite true, such as
while processing a remote-wakeup request.
This patch (as717b) removes the existing recursion in hub resume code:
Resuming a hub will no longer automatically resume the devices attached
to the hub.
At the same time, it adds one level of recursion: Suspending a USB
device will automatically suspend all the device's interfaces. Failure
at an intermediate stage will cause all the already-suspended interfaces
to be resumed. Attempts to suspend or resume an interface by itself will
do nothing, although they won't return an error. Thus the regular
system-suspend and system-resume procedures should continue to work as
before; only runtime PM will be affected.
The patch also removes the code that tests state of the interfaces
before suspending a device. It's no longer needed, since everything
gets suspended together.
This patch (as732) adds a usb_device_driver structure, for representing
drivers that manage an entire USB device as opposed to just an
interface. Support routines like usb_register_device_driver,
usb_deregister_device_driver, usb_probe_device, and usb_unbind_device
are also added.
Unlike an earlier version of this patch, the new code is type-safe. To
accomplish this, the existing struct driver embedded in struct
usb_driver had to be wrapped in an intermediate wrapper. This enables
the core to tell at runtime whether a particular struct driver belongs
to a device driver or to an interface driver.
This revised patch (as713b) moves a few routines among source files in
usbcore. Some driver-related code in usb.c (claiming interfaces and
matching IDs) is moved to driver.c, where it belongs. Also the
usb_generic stuff in driver.c is moved to a new source file: generic.c.
(That's the reason for revising the patch.) Although not very big now,
it will get bigger in a later patch.
None of the code has been changed; it has only been re-arranged.
This revised patch (as715b) renames usb_suspend_device to
usb_port_suspend, usb_resume_device to usb_port_resume, and
finish_device_resume to finish_port_resume. There was no objection to
the original version of the patch so this should be okay to apply.
The revision was needed only because I have re-arranged the order of the
earlier patches.
The usbfs code doesn't provide sufficient mutual exclusion among open,
release, and remove. Release vs. remove is okay because they both
acquire the device lock, but open is not exclusive with either one. All
three routines modify the udev->filelist linked list, so they must not
run concurrently.
Apparently someone gave this a minimum amount of thought in the past by
explicitly acquiring the BKL at the start of the usbdev_open routine.
Oddly enough, there's a comment pointing out that locking is unnecessary
because chrdev_open already has acquired the BKL.
But this ignores the point that the files in /proc/bus/usb/* are not
char device files; they are regular files and so they don't get any
special locking. Furthermore it's necessary to acquire the same lock in
the release and remove routines, which the code does not do.
Yet another problem arises because the same file_operations structure is
accessible through both the /proc/bus/usb/* and /dev/usb/usbdev* file
nodes. Even when one of them has been removed, it's still possible for
userspace to open the other. So simple locking around the individual
remove routines is insufficient; we need to lock the entire
usb_notify_remove_device notifier chain.
Rather than rely on the BKL, this patch (as723) introduces a new private
mutex for the purpose. Holding the BKL while invoking a notifier chain
doesn't seem like a good idea.
This patch updates the USB core to save and pass the sending task secid when
sending signals upon AIO completion so that proper security checking can be
applied by security modules.
Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Instead of a kobject, will make things easier in the future (don't know
what I was thinking when I did this originally...)
This makes it easier to modify in the future without touching anything else.
This patch (as605) removes the private udev->serialize semaphore,
relying instead on the locking provided by the embedded struct device's
semaphore. The changes are confined to the core, except that the
usb_trylock_device routine now uses the return convention of
down_trylock rather than down_read_trylock (they return opposite values
for no good reason).
A couple of other associated changes are included as well:
Now that we aren't concerned about HCDs that avoid using the
hcd glue layer, usb_disconnect no longer needs to acquire the
usb_bus_lock -- that can be done by usb_remove_hcd where it
belongs.
Devices aren't locked over the same scope of code in
usb_new_device and hub_port_connect_change as they used to be.
This shouldn't cause any trouble.
Along with the preceding driver core patch, this needs a lot of testing.
This will make the dynamic-id stuff easier to do, as it will be
self-contained.
No logic was changed at all.
This patch (as592) makes a few small improvements to the way device
strings are handled, and it fixes some bugs in a couple of other sysfs
attribute routines. (Look at show_configuration_string() to see what I
mean.)
This should let us get rid of all of the different hooks in the USB core for
when something has changed.
Also, some other parts of the kernel have wanted to know this kind of
information at times.
It's only used locally.
The way we're looking at USB suspend lately doesn't expect drivers to
call usb_suspend_device() or usb_resume_device() directly; that'll
be implicit when no interfaces are in use.
This patch removes those APIs from visibility outside usbcore.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
drivers/usb/core/hub.c | 12 ++++--------
drivers/usb/core/usb.h | 4 ++++
include/linux/usb.h | 5 -----
3 files changed, 8 insertions(+), 13 deletions(-)
This patch collects various small updates related to root hubs, to shrink
later patches which build on them.
- For root hub suspend/resume support:
* Make the existing usb_hcd_resume_root_hub() routine respect pmcore
locking, exporting and using the dpm_runtime_resume() method.
* Add a new usb_hcd_suspend_root_hub() to pair with that routine.
(Essential to make OHCI autosuspend behave again...)
* HC_SUSPENDED by itself only refers to the root hub's downstream ports.
So let HCDs see root hub URBs unless the parent device is suspended.
- Remove an assertion we no longer need (and now, also don't want).
- Generic suspend/resume updates to work better with swsusp.
* Ignore the FREEZE vs SUSPEND distinction for hardware; trying to
use it breaks the swsusp snapshots it's supposed to help (sigh).
* On resume, mark devices as resumed right away, but then
do nothing else if the device is marked NOTATTACHED.
These changes shouldn't be very noticable by themselves.
drivers/base/power/runtime.c | 1
drivers/usb/core/hcd.c | 64 ++++++++++++++++++++++++++++++++++++++-----
drivers/usb/core/hcd.h | 1
drivers/usb/core/hub.c | 45 ++++++++++++++++++++++++------
drivers/usb/core/usb.c | 20 +++++++++----
drivers/usb/core/usb.h | 1
6 files changed, 111 insertions(+), 21 deletions(-)
This updates the handling of power state for USB interfaces.
- Formalizes an existing invariant: interface "power state" is a boolean:
ON when I/O is allowed, and FREEZE otherwise. It does so by defining
some inlined helpers, then using them.
- Adds a useful invariant: the only interfaces marked active are those
bound to non-suspended drivers. Later patches build on this invariant.
- Simplifies the interface driver API (and removes some error paths) by
removing the requirement that they record power state changes during
suspend and resume callbacks. Now usbcore does that.
A few drivers were simplified to address that last change.
drivers/usb/core/hub.c | 33 +++++++++------------
drivers/usb/core/message.c | 1
drivers/usb/core/usb.c | 65 +++++++++++++++++++++++++++++++++----------
drivers/usb/core/usb.h | 18 +++++++++++
drivers/usb/input/hid-core.c | 2 -
drivers/usb/misc/usbtest.c | 10 ------
drivers/usb/net/pegasus.c | 2 -
drivers/usb/net/usbnet.c | 2 -
8 files changed, 85 insertions(+), 48 deletions(-)
All the same issues - we can't just save the pointer to the thread, we
must save the pid/uid/euid combination.
This patch introduces a /sys/class/usb_device/ class
where every connected usb-device will show up:
tree /sys/class/usb_device/
|-- usb1.1
| |-- dev
| `-- device -> ../../../devices/pci0000:00/0000:00:1d.0/usb1
|-- usb2.1
| |-- dev
| `-- device -> ../../../devices/pci0000:00/0000:00:1d.1/usb2
The presence of the "dev" file lets udev create real device nodes.
kay@pim:~/src/linux-2.6> tree /dev/bus/usb/
/dev/bus/usb/
|-- 1
| `-- 1
|-- 2
| `-- 1
udev rule:
SUBSYSTEM="usb_device", PROGRAM="/sbin/usb_device %k", NAME="%c"
(echo $1 | /bin/sed 's/usb\([0-9]*\)\.\([0-9]*\)/bus\/usb\/\1\/\2/')
This makes libusb pick up the real nodes instead of the mounted usbfs:
export USB_DEVFS_PATH=/dev/bus/usb
Background:
All this makes it possible to manage usb devices with udev instead of
the devfs solution. We are currently working on a pam_console/resmgr
replacement driven by udev and a pam-helper. It applies ACL's to device
nodes, which is required for modern desktop functionalty like
"Fast User Switching" or multiple local login support.
New patch with its own major. I've succesfully disabled usbfs and use real
nodes only on my box. With: "export USB_DEVFS_PATH=/dev/bus/usb" libusb picks
up the udev managed nodes instead of reading usbfs files.
This makes udev to provide symlinks for libusb to pick up:
SUBSYSTEM="usb_device", PROGRAM="/sbin/usbdevice %k", SYMLINK="%c"
/sbin/usbdevice:
#!/bin/sh
echo $1 | /bin/sed 's/usbdev\([0-9]*\)\.\([0-9]*\)/bus\/usb\/\1\/\2/'
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
static.
Index: gregkh-2.6/drivers/usb/core/usb.h
infrastructure for it.
Let it rip!
