commit 73f8bda9b5dc1c69df2bc55c0cbb24461a6391a9 upstream
Add a new device quirk that can be used to blacklist endpoints.
Since commit 3e4f8e21c4f2 ("USB: core: fix check for duplicate
endpoints") USB core ignores any duplicate endpoints found during
descriptor parsing.
In order to handle devices where the first interfaces with duplicate
endpoints are the ones that should have their endpoints ignored, we need
to add a blacklist.
Tested-by: edes <edes@gmx.net>
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
Link: https://lore.kernel.org/r/20200203153830.26394-2-johan@kernel.org
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 7529b2574a7aaf902f1f8159fbc2a7caa74be559 upstream.
Use new helpers to make LPM enabling/disabling more clear.
This is a preparation to subsequent patch.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Cc: stable <stable@vger.kernel.org> # after much soaking
commit 8a1b2725a60d3267135c15e80984b4406054f650 upstream.
Add a new USB_SPEED_SUPER_PLUS device speed, and make sure usb core can
handle the new speed.
In most cases the behaviour is the same as with USB_SPEED_SUPER SuperSpeed
devices. In a few places we add a "Plus" string to inform the user of the
new speed.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
The kernel supports the device authorization because of wireless USB.
These is usable for wired USB devices, too.
These new interface authorization allows to enable or disable
individual interfaces instead a whole device.
If a deauthorized interface will be authorized so the driver probing must
be triggered manually by writing INTERFACE to /sys/bus/usb/drivers_probe
Signed-off-by: Stefan Koch <stefan.koch10@gmail.com>
Commit 25cd2882e2fc ("usb/xhci: Change how we indicate a host supports
Link PM.") removed the code to set lpm_capable for USB 3.0 super-speed
root hub. The intention of that change was to avoid touching usb core
internal field, a.k.a. lpm_capable, and let usb core to set it by
checking U1 and U2 exit latency values in the descriptor.
Usb core checks and sets lpm_capable in hub_port_init(). Unfortunately,
root hub is a special usb device as it has no parent. Hub_port_init()
will never be called for a root hub device. That means lpm_capable will
by no means be set for the root hub. As the result, lpm isn't functional
at all in Linux kernel.
This patch add the code to check and set lpm_capable when registering a
root hub device. It could be back-ported to kernels as old as v3.15,
that contains the Commit 25cd2882e2fc ("usb/xhci: Change how we indicate
a host supports Link PM.").
Cc: stable@vger.kernel.org # 3.15
Reported-by: Kevin Strasser <kevin.strasser@linux.intel.com>
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so quite a few
depend on CONFIG_PM (or even dropped in some cases).
Replace CONFIG_PM_RUNTIME with CONFIG_PM in the USB core code
and documentation.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
USB hub started to use a workqueue instead of kthread. Let's make it clear from
the function names.
Signed-off-by: Petr Mladek <pmladek@suse.cz>
Per Alan:
"You mean from within hub_handle_remote_wakeup()? That routine will
never get called if CONFIG_PM_RUNTIME isn't enabled, because khubd
never sees wakeup requests if they arise during system suspend.
In fact, that routine ought to go inside the "#ifdef CONFIG_PM_RUNTIME"
portion of hub.c, along with the other suspend/resume code."
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
ACPI identifies peer ports by setting their 'group_token' and
'group_position' _PLD data to the same value. If a platform has tier
mismatch [1] , ACPI can override the default (USB3 defined) peer port
association for internal hubs. External hubs follow the default peer
association scheme.
Location data is cached as an opaque cookie in usb_port_location data.
Note that we only consider the group_token and group_position attributes
from the _PLD data as ACPI specifies that group_token is a unique
identifier.
When we find port location data for a port then we assume that the
firmware will also describe its peer port. This allows the
implementation to only ever set the peer once. This leads to a question
about what happens when a pm runtime event occurs while the peer
associations are still resolving. Since we only ever set the peer
information once, a USB3 port needs to be prevented from suspending
while its ->peer pointer is NULL (implemented in a subsequent patch).
There is always the possibility that firmware mis-identifies the ports,
but there is not much the kernel can do in that case.
[1]: xhci 1.1 appendix D figure 131
[2]: acpi 5 section 6.1.8
[alan]: don't do default peering when acpi data present
Assume that the peer of a superspeed port is the port with the same id
on the shared_hcd root hub. This identification scheme is required of
external hubs by the USB3 spec [1]. However, for root hubs, tier mismatch
may be in effect [2]. Tier mismatch can only be enumerated via platform
firmware. For now, simply perform the nominal association.
A new lock 'usb_port_peer_mutex' is introduced to synchronize port
device add/remove with peer lookups. It protects peering against
changes to hcd->shared_hcd, hcd->self.root_hub, hdev->maxchild, and
port_dev->child pointers.
[1]: usb 3.1 section 10.3.3
[2]: xhci 1.1 appendix D
Cc: Alan Stern <stern@rowland.harvard.edu>
[alan: usb_port_peer_mutex locking scheme]
The current port name "portX" is ambiguous. Before adding more port
messages rename ports to "<hub-device-name>-portX"
This is an ABI change, but the suspicion is that it will go unnoticed as
the port power control implementation has been broken since its
introduction. If however, someone was relying on the old name we can
add sysfs links from the old name to the new name.
Additionally, it unifies/simplifies port dev_printk messages and modifies
instances of:
dev_XXX(hub->intfdev, ..."port %d"...
dev_XXX(&hdev->dev, ..."port%d"...
into:
dev_XXX(&port_dev->dev, ...
Now that the names are unique usb_port devices it would be nice if they
could be included in /sys/bus/usb. However, it turns out that this
breaks 'lsusb -t'. For now, create a dummy port driver so that print
messages are prefixed "usb 1-1-port3" rather than the
subsystem-ambiguous " 1-1-port3".
Finally, it corrects an odd usage of sscanf("port%d") in usb-acpi.c.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg KH:
"Here's the big USB pull request for 3.15-rc1.
The normal set of patches, lots of controller driver updates, and a
smattering of individual USB driver updates as well.
All have been in linux-next for a while"
* tag 'usb-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (249 commits)
xhci: Transition maintainership to Mathias Nyman.
USB: disable reset-resume when USB_QUIRK_RESET is set
USB: unbind all interfaces before rebinding any
usb: phy: Add ulpi IDs for SMSC USB3320 and TI TUSB1210
usb: gadget: tcm_usb_gadget: stop format strings
usb: gadget: f_fs: add missing spinlock and mutex unlock
usb: gadget: composite: switch over to ERR_CAST()
usb: gadget: inode: switch over to memdup_user()
usb: gadget: f_subset: switch over to PTR_RET
usb: gadget: lpc32xx_udc: fix wrong clk_put() sequence
USB: keyspan: remove dead debugging code
USB: serial: add missing newlines to dev_<level> messages.
USB: serial: add missing braces
USB: serial: continue to write on errors
USB: serial: continue to read on errors
USB: serial: make bulk_out_size a lower limit
USB: cypress_m8: fix potential scheduling while atomic
devicetree: bindings: document lsi,zevio-usb
usb: chipidea: add support for USB OTG controller on LSI Zevio SoCs
usb: chipidea: imx: Use dev_name() for ci_hdrc name to distinguish USBs
When a driver doesn't have pre_reset, post_reset, or reset_resume
methods, the USB core unbinds that driver when its device undergoes a
reset or a reset-resume, and then rebinds it afterward.
The existing straightforward implementation can lead to problems,
because each interface gets unbound and rebound before the next
interface is handled. If a driver claims additional interfaces, the
claim may fail because the old binding instance may still own the
additional interface when the new instance tries to claim it.
This patch fixes the problem by first unbinding all the interfaces
that are marked (i.e., their needs_binding flag is set) and then
rebinding all of them.
The patch also makes the helper functions in driver.c a little more
uniform and adjusts some out-of-date comments.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: "Poulain, Loic" <loic.poulain@intel.com>
Since it is needed outside usbcore and exposed in include/linux/usb.h,
it conflicts with enum dev_state in rt2x00 wireless driver.
Mark it as usb specific to avoid conflicts in the future.
Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com>
A device should not be able to be used concurrently both by
the server and the client. Claiming the port used by the
shared device ensures no interface drivers bind to it and
that it is not usable from the server.
Commit 9df89d85b407690afa46ddfbccc80bec6869971d "usbcore: set
lpm_capable field for LPM capable root hubs" was created under the
assumption that all USB host controllers should have USB 3.0 Link PM
enabled for all devices under the hosts.
Unfortunately, that's not the case. The xHCI driver relies on knowledge
of the host hardware scheduler to calculate the LPM U1/U2 timeout
values, and it only sets lpm_capable to one for Intel host controllers
(that have the XHCI_LPM_SUPPORT quirk set).
When LPM is enabled for some Fresco Logic hosts, it causes failures with
a AgeStar 3UBT USB 3.0 hard drive dock:
Jan 11 13:59:03 sg-laptop kernel: usb 3-1: new SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:03 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed.
Jan 11 13:59:08 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed.
Jan 11 13:59:08 sg-laptop kernel: usb-storage 3-1:1.0: USB Mass Storage device detected
Jan 11 13:59:08 sg-laptop mtp-probe[613]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1"
Jan 11 13:59:08 sg-laptop mtp-probe[613]: bus: 3, device: 2 was not an MTP device
Jan 11 13:59:08 sg-laptop kernel: scsi6 : usb-storage 3-1:1.0
Jan 11 13:59:13 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed.
Jan 11 13:59:18 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed.
Jan 11 13:59:18 sg-laptop kernel: usbcore: registered new interface driver usb-storage
Jan 11 13:59:40 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:41 sg-laptop kernel: usb 3-1: device descriptor read/8, error -71
Jan 11 13:59:41 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:46 sg-laptop kernel: usb 3-1: device descriptor read/8, error -110
Jan 11 13:59:46 sg-laptop kernel: scsi 6:0:0:0: Device offlined - not ready after error recovery
Jan 11 13:59:46 sg-laptop kernel: usb 3-1: USB disconnect, device number 2
lspci for the affected host:
04:00.0 0c03: 1b73:1000 (rev 04) (prog-if 30 [XHCI])
Subsystem: 1043:1039
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 19
Region 0: Memory at dd200000 (32-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [80] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <2us, L1 <32us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Kernel driver in use: xhci_hcd
Kernel modules: xhci_hcd
The commit was backported to stable kernels, and will need to be
reverted there as well.
Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com>
Reported-by: Sergey Galanov <sergey.e.galanov@gmail.com>
This patch sets the lpm_capable field for root hubs with LPM capabilities.
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
Reported-by: Martin MOKREJS <mmokrejs@gmail.com>
This patch (as1675) removes the CONFIG_USB_SUSPEND option, essentially
replacing it everywhere with CONFIG_PM_RUNTIME (except for one place
in hub.c, where it is replaced with CONFIG_PM because the code needs
to be used in both runtime and system PM). The net result is code
shrinkage and simplification.
There's very little point in keeping CONFIG_USB_SUSPEND because almost
everybody enables it. The few that don't will find that the usbcore
module has gotten somewhat bigger and they will have to take active
measures if they want to prevent hubs from being runtime suspended.
CC: Peter Chen <peter.chen@freescale.com>
This reverts commit 88bb965ed711e8a5984e70208ebc901a6ff4141f.
The linux-next branch of linux-pm tree has replaced
acpi_power_resource_(un)register_device() with new routines.
Commit 88bb965 will cause conflict in the linux-next tree.
So revert it and this will not affect other functions. Will
send a new patch with new routines after 3.9 merge window.
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
This patch is to register usb port's acpi power resources. Create
link between usb port device and its acpi power resource.
ACPI provide "_PLD" and "_UPC" aml methods to describe usb port
visibility and connectability. This patch is to add usb_hub_adjust_DeviceRemovable()
to adjust usb hub port's DeviceRemovable according ACPI information and invoke it in
the rh_call_control(). When hub descriptor request is issued at first time,
usb port device isn't created and usb port is not bound with acpi. So first
hub descriptor request is not changed based on ACPI information. After usb
port devices being created, call usb_hub_adjust_DeviceRemovable in the hub_configure()
and then set hub port's DeviceRemovable according ACPI information and this also works
for non-root hub.
The USB 2.0 specification says that bMaxPower is the maximum power
consumption expressed in 2 mA units and the USB 3.0 specification says
that it is expressed in 8 mA units.
This patch adds a helper function usb_get_max_power() which computes the
value based on config & usb_device's speed value. The the device descriptor
dump computes the value on its own.
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
In the upcoming USB port power off patches, we need to know whether a
USB port can ever see a disconnect event. Often USB ports are internal
to a system, and users can't disconnect USB devices from that port.
Sometimes those ports will remain empty, because the OEM chose not to
connect an internal USB device to that port.
According to ACPI Spec 9.13, PLD indicates whether USB port is
user visible and _UPC indicates whether a USB device can be connected to
the USB port (we'll call this "connectible"). Here's a matrix of the
possible combinations:
Visible Connectible
Name Example
Yes No Unknown (Invalid state.)
Yes Yes Hot-plug USB ports on the outside of a laptop.
A user could freely connect and disconnect
USB devices.
No Yes Hard-wired A USB modem hard-wired to a port on the
inside of a laptop.
No No Not used The port is internal to the system and
will remain empty.
Represent each of these four states with an enum usb_port_connect_type.
The four states are USB_PORT_CONNECT_TYPE_UNKNOWN,
USB_PORT_CONNECT_TYPE_HOT_PLUG, USB_PORT_CONNECT_TYPE_HARD_WIRED, and
USB_PORT_NOT_USED. When we get the USB port's acpi_handle, store the
state in connect_type in struct usb_port.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
In the ACPI DSDT table, only usb root hub and usb ports are ACPI device
nodes. Originally, we bound the usb port's ACPI node to the usb device
attached to the port. However, we want to access those ACPI port
methods when the port is empty, and there's no usb_device associated
with that port.
Now that the usb port is a real device, we can bind the port's ACPI node
to struct usb_port instead.
When a whole class of devices (possibly from a specific vendor, or
across multiple vendors) require a quirk, explictly listing all devices
in the class make the quirks table unnecessarily large. Fix this by
allowing matching devices based on interface information.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This patch is to convert port_owners type from void * to struct dev_state *
in order to make code more readable.
Built-in USB devices will typically have a representation in the system
ACPI tables. Add support for binding the two together so the USB code can
make use of the associated methods.
This eliminates the last instance of a function's behavior
controlled by a parameter as Linus hates such things.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Move usb_translate_errors from usb core to linux/usb.h as it is meant to
be accessed from drivers.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
If the device pass the USB2 software LPM and the host supports hardware
LPM, enable hardware LPM for the device to let the host decide when to
put the link into lower power state.
If hardware LPM is enabled for a port and driver wants to put it into
suspend, it must first disable hardware LPM, resume the port into U0,
and then suspend the port.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
This commit gets BOS(Binary Device Object Store) descriptor set for Super
Speed devices and High Speed devices which support BOS descriptor.
BOS descriptor is used to report additional USB device-level capabilities
that are not reported via the Device descriptor. By getting BOS descriptor
set, driver can check device's device-level capability such as LPM
capability.
The usb_create_sysfs_intf_files() function always returned zero even
if it failed to create sysfs fails. Since this is a desired behaviour
there is no need to return return code at all. This commit changes
function's return type (form int) to void.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
USB defines usb_device_type pointing to usb_device_pm_ops that
provides system-wide PM callbacks only and usb_bus_type pointing to
usb_bus_pm_ops that provides runtime PM callbacks only. However,
the USB runtime PM callbacks may be defined in usb_device_pm_ops
which makes it possible to drop usb_bus_pm_ops and will allow us
to consolidate the handling of subsystems by the PM core code.
This converts error codes specific to USB to generic error codes
that can be returned to user space. Tests showed that it is so small
that it is better inlined.
This patch (as1428) converts USB over to the new runtime-PM core
autosuspend framework. One slightly awkward aspect of the conversion
is that USB devices will now have two suspend-delay attributes: the
old power/autosuspend file and the new power/autosuspend_delay_ms
file. One expresses the delay time in seconds and the other in
milliseconds, but otherwise they do the same thing. The old attribute
can be deprecated and then removed eventually.
This patch (as1329) converts the USB stack over to the PM core's
runtime PM framework. This involves numerous changes throughout
usbcore, especially to hub.c and driver.c. Perhaps the most notable
change is that CONFIG_USB_SUSPEND now depends on CONFIG_PM_RUNTIME
instead of CONFIG_PM.
Several fields in the usb_device and usb_interface structures are no
longer needed. Some code which used to depend on CONFIG_USB_PM now
depends on CONFIG_USB_SUSPEND (requiring some rearrangement of header
files).
The only visible change in behavior should be that following a system
sleep (resume from RAM or resume from hibernation), autosuspended USB
devices will be resumed just like everything else. They won't remain
suspended. But if they aren't in use then they will naturally
autosuspend again in a few seconds.
This patch (as1324) makes a small change to the code used for remote
wakeup of root hubs. hcd_resume_work() now calls the hub driver's
remote-wakeup routine instead of implementing its own version.
The patch is complicated by the need to rename remote_wakeup() to
usb_remote_wakeup(), make it non-static, and declare it in a header
file. There's also the additional complication required to make
everything work when CONFIG_PM isn't set; the do-nothing inline
routine had to be moved into the header file.
This patch (as1297) adds a "remove" attribute to each USB device's
directory in sysfs. Writing to this attribute causes the device to be
deconfigured (the same as writing 0 to the "bConfigurationValue"
attribute) and then tells the hub driver to disable the device's
upstream port. The device remains locked during these activities so
there is no possibility of it getting reconfigured in between. The
port will remain disabled until after the device is unplugged.
The purpose of this is to provide a means for user programs to imitate
the "Safely remove hardware" applet in Windows. Some devices do
expect their ports to be disabled before they are unplugged, and they
provide visual feedback to users indicating when they can safely be
unplugged.
The security implications are minimal. Writing to the "remove"
attribute is no more dangerous than writing to the
"bConfigurationValue" attribute.
Cc: David Zeuthen <davidz@redhat.com>
This patch (as1258) implements a feature that users have been asking
for: It gives programs the ability to "claim" a port on a hub, via a
new usbfs ioctl. A device plugged into a "claimed" port will not be
touched by the kernel beyond the immediate necessities of
initialization and enumeration.
In particular, when a device is plugged into a "claimed" port, the
kernel will not select and install a configuration. And when a config
is installed by usbfs or sysfs, the kernel will not probe any drivers
for any of the interfaces. (However the kernel will fetch various
string descriptors during enumeration. One could argue that this
isn't really necessary, but the strings are exported in sysfs.)
The patch does not guarantee exclusive access to these devices; it is
still possible for more than one program to open the device file
concurrently. Programs are responsible for coordinating access among
themselves.
A demonstration program showing how to use the new interface can be
found in an attachment to
http://marc.info/?l=linux-usb&m=124345857431452&w=2
The patch also makes a small simplification to the hub driver,
replacing a bunch of more-or-less useless variants of "out of memory"
with a single message.
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The endpoint devices look like simple attribute groups now, and no longer
like devices with a specific subsystem. They will also no longer emit uevents.
It also removes the device node requests for endpoint devices, which are not
implemented for now.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The usb_host class isn't used for anything anymore (it was used for
debug files, but they have moved to debugfs a few kernel releases ago),
so let's delete it before someone accidentally puts a file in it.
This patch (as1198) fixes a conceptual bug: Somewhere along the line
we managed to confuse USB class devices with USB char devices. As a
result, the code to send a disconnect signal to userspace would not be
built if both CONFIG_USB_DEVICE_CLASS and CONFIG_USB_DEVICEFS were
disabled.
The usb_fs_classdev_common_remove() routine has been renamed to
usbdev_remove() and it is now called whenever any USB device is
removed, not just when a class device is unregistered. The notifier
registration and unregistration calls are no longer conditionally
compiled. And since the common removal code will always be called as
part of the char device interface, there's no need to call it again as
part of the usbfs interface; thus the invocation of
usb_fs_classdev_common_remove() has been taken out of
usbfs_remove_device().
Reported-by: Alon Bar-Lev <alon.barlev@gmail.com>
Tested-by: Alon Bar-Lev <alon.barlev@gmail.com>
Cc: stable <stable@kernel.org>
This patch (as1200) finishes some fixes that were left incomplete by
an earlier patch.
Although nobody has addressed this issue in the past, it turns out
that we need to distinguish between two different modes of disabling
and enabling endpoints. In one mode only the data structures in
usbcore are affected, and in the other mode the host controller and
device hardware states are affected as well.
The earlier patch added an extra argument to the routines in the
enable_endpoint pathways to reflect this difference. This patch adds
corresponding arguments to the disable_endpoint pathways. Without
this change, the endpoint toggle state can get out of sync between
the host and the device. The exact mechanism depends on the details
of the host controller (whether or not it stores its own copy of the
toggle values).
Reported-by: Dan Streetman <ddstreet@ieee.org>
Tested-by: Dan Streetman <ddstreet@ieee.org>
This patch (as1197) fixes an error introduced recently. Since a
significant number of devices can't handle Set-Interface requests, we
no longer call usb_set_interface() when a driver unbinds from an
interface, provided the interface is already in altsetting 0. However
the interface still does get disabled, and the call to
usb_set_interface() was the only thing re-enabling it. Since the
interface doesn't get re-enabled, further attempts to use it fail.
So the patch adds a call to usb_enable_interface() when a driver
unbinds and the interface is in altsetting 0. For this to work
right, the interface's endpoints have to be re-enabled but their
toggles have to be left alone. Therefore an additional argument is
added to usb_enable_endpoint() and usb_enable_interface(), a flag
indicating whether or not the endpoint toggles should be reset.
This is a forward-ported version of a patch which fixes Bugzilla
#12301.
Reported-by: David Roka <roka@dawid.hu>
Reported-by: Erik Ekman <erik@kryo.se>
Tested-by: Erik Ekman <erik@kryo.se>
This patch (as1185) makes usbcore take advantage of the bus
notifications sent out by the driver core. Now we can create all our
device and interface attribute files before the device or interface
uevent is broadcast.
A side effect is that we no longer create the endpoint "pseudo"
devices at the same time as a device or interface is registered -- it
seems like a bad idea to try registering an endpoint before the
registration of its parent is complete. So the routines for creating
and removing endpoint devices have been split out and renamed, and
they are called explicitly when needed. A new bitflag is used for
keeping track of whether or not the interface's endpoint devices have
been created, since (just as with the interface attributes) they vary
with the altsetting and hence can be changed at random times.
Cc: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1177) modifies the USB core suspend and resume
routines. The resume functions now will take a pm_message_t argument,
so they will know what sort of resume is occurring. The new argument
is also passed to the port suspend/resume and bus suspend/resume
routines (although they don't use it for anything but debugging).
In addition, special pm_message_t values are used for user-initiated,
device-initiated (i.e., remote wakeup), and automatic suspend/resume.
By testing these values, drivers can tell whether or not a particular
suspend was an autosuspend. Unfortunately, they can't do the same for
resumes -- not until the pm_message_t argument is also passed to the
drivers' resume methods. That will require a bigger change.
IMO, the whole Power Management framework should have been set up this
way in the first place.
This patch (as1160b) adds support routines for asynchronous autosuspend
and autoresume, with accompanying documentation updates. There
already are several potential users of this interface, and others are
likely to arise as autosuspend support becomes more widespread.
This patch (as1129) adds support for the new PM callbacks to usbcore.
The new callbacks merely invoke the same old USB power management
routines as the old ones did.
A minor improvement is that the callbacks are present only in the
"USB-device" device_type structure, rather than in the bus_type
structure. This way they will be invoked only for USB devices, not
for USB interfaces. The core USB PM routines automatically handle
suspending and resuming interfaces along with their devices.
USB device files are accessible in two ways: as files in usbfs and as
character device nodes. The two paths are supposed to behave
identically, but they don't. When the underlying USB device is
unplugged, disconnect signals are sent to processes with open usbfs
files (if they requested these signals) but not to processes with open
device node files.
This patch (as1104) fixes the bug by moving the disconnect-signalling
code into a common subroutine which is called from both paths.
Putting this subroutine in devio.c removes the only out-of-file
reference to struct dev_state, and so the structure's declaration can
be moved from usb.h into devio.c.
Finally, the new subroutine performs one extra action: It kills all
the outstanding async URBs. (I'd kill the outstanding synchronous
URBs too, if there was any way to do it.) In the past this hasn't
mattered much, because devices were unregistered from usbfs only
when they were disconnected. But now the unregistration can also
occur whenever devices are unbound from the usb_generic driver. At
any rate, killing URBs when a device is unregistered from usbfs seems
like a good thing to do.
