USB support in the Meson8 SoCs is provided by a DWC2 controller which
works with the same settings as Meson8b and GXBB. Using the generic
"snps,dwc2" binding results in an endless stream of "Overcurrent change
detected" messages.
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
(internal PHY)
This patch introduces a new parameter to activate USB OTG HS/FS core
embedded phy transceiver. The STM32F4x9 SoC uses the GGPIO register
to enable the transceiver.
Also add the dwc2_set_params function for stm32f4 otg fs.
Acked-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Bruno Herrera <bruherrera@gmail.com>
Add dwc2_check_param_tx_fifo_sizes function which validates
the members of g_tx_fifo_size array and sets to average or
default values if it is needed.
Cc: Stefan Wahren <stefan.wahren@i2se.com>
Signed-off-by: Sevak Arakelyan <sevaka@synopsys.com>
Signed-off-by: John Youn <johnyoun@synopsys.com>
Remove legacy DWC2_G_P_LEGACY_TX_FIFO_SIZE array for TX FIFOs.
Update dwc2_set_param_tx_fifo_sizes function to calculate
and assign default average FIFO depth to each member of
g_tx_fifo_size array. Total FIFO size, EP Info block's size,
FIFO operation mode and device operation mode are taken into
consideration during the calculation.
The Hi6220's usb controller is limited in that it does not
support "Split Transactions", so it does not support communicating
with low-speed and full-speed devices behind a high-speed hub.
Thus it requires a quirk so that we can manually drop the usb
speed when low/full-speed are attached, and bump back to high
speed when they are removed.
Cc: Wei Xu <xuwei5@hisilicon.com>
Cc: Guodong Xu <guodong.xu@linaro.org>
Cc: Amit Pundir <amit.pundir@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: John Youn <johnyoun@synopsys.com>
Cc: Douglas Anderson <dianders@chromium.org>
Cc: Chen Yu <chenyu56@huawei.com>
Cc: Vardan Mikayelyan <mvardan@synopsys.com>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Cc: Felipe Balbi <felipe.balbi@linux.intel.com>
Cc: linux-usb@vger.kernel.org
Signed-off-by: Chen Yu <chenyu56@huawei.com>
[jstultz: Reworked to simplify the patch, and made
commit log to be more specific about the issue]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Remove debugging prints to show params.
Further reduce the set of parameters set by platforms. Many of them are
unnecessary as they should be reported by hardware. They should only
need to be overridden if there is a problem.
Check these parameters only for true or false. There is no need to check
for greater or less than 0.
Remove the platform-specific static param structs and set only those
params that are necessary for each platform.
Check that core parameters have valid values and adjust them if they
aren't.
After setting the default core parameter values, read in the device
properties and modify core parameter values if needed.
Initialize the core parameters to their default, auto-detected values.
Remove all the previous dwc2_set_param* methods. Most of what this code
is doing is handling defaults for "not set" values and other trivial
checks. The checking can be simplified and will be done in a later
commit.
This allows us to change only those parameters that won't work with
default settings. It also allows us to use non-int parameters.
The otg_ver parameter only controls the SRP pulsing method and defaults
to the 1.3 behavior. It is unused and can be removed.
Fix lines over 80 characters.
This commmit is the result of running checkpatch --fix.
The results were verified for correctness. Some of the fixes result in
line over 80 char which we will fix manually later.
The following is a summary of what was done by checkpatch:
* Remove externs on function prototypes.
* Replace symbolic permissions with octal.
* Align code to open parens.
* Replace 'unsigned' with 'unsigned int'.
* Remove unneccessary blank lines.
* Add blank lines after declarations.
* Add spaces around operators.
* Remove unnecessary spaces after casts.
* Replace 'x == NULL' with '!x'.
* Replace kzalloc() with kcalloc().
* Concatenate multi-line strings.
* Use the BIT() macro.
Commit 05ee799f2021 ("usb: dwc2: Move gadget settings into core_params")
changes to type u16 for DT binding "g-rx-fifo-size" and
"g-np-tx-fifo-size" but use type u32 for "g-tx-fifo-size". Finally the
the first two parameters cannot be passed successfully with wrong data
format. This is found the data transferring broken on 96boards Hikey.
This patch is to change all parameters to u32 type, and verified on
Hikey board the DT parameters can pass successfully.
[johnyoun: minor rebase]
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
The current default for gadget DMA descriptor results on bcm2835 in a
unnecessary error message:
Invalid value 1 for param gadget-dma-desc
So fix this by using hw->dma_desc_enable as default value.
Fixes: dec4b55677e ("usb: dwc2: gadget: Add descriptor DMA parameter")
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
The current defaults for DMA results on a non-DMA platform in a unnecessary
error message:
Invalid value 0 for param gadget-dma
So fix this by using dma_capable as default value.
Fixes: 9962b62f1be ("usb: dwc2: Deprecate g-use-dma binding")
According to the Devicetree ePAPR [1] the datatypes u8 and u16 are
not defined. So using device_property_read_u16() would result in
a partial read of a 32-bit big-endian integer which is not intended.
So we better read the complete 32-bit value. This fixes a regression
on bcm2835 where the values for g-rx-fifo-size and g-np-tx-fifo-size
always read as zero:
Invalid value 0 for param g-rx-fifo-size
Invalid value 0 for param g-np-tx-fifo-size
[1] - http://elinux.org/images/c/cf/Power_ePAPR_APPROVED_v1.1.pdf
Fixes: 05ee799f202 ("usb: dwc2: Move gadget settings into core_params")
Since commit "usb: dwc2: Improve handling of host and device hwparams" the
host mode specific hardware parameter aren't initialized in peripheral mode
from the register settings anymore. So we better do not set them in this
case which avoids the following warnings on bcm2835:
256 invalid for host_nperio_tx_fifo_size. Check HW configuration.
512 invalid for host_perio_tx_fifo_size. Check HW configuration.
Fixes: 55e1040e424b ("usb: dwc2: Improve handling of host and device hwparams")
This patch adds support for the "amcc,usb-otg" device
which is found in the PowerPC Canyonlands' dts.
The device definition was added by:
commit c89b3458d8cc ("powerpc/44x: Add USB DWC DTS entry to Canyonlands
board")
but without any driver support as the dwc2 driver wasn't available at
that time.
Note: The system can't use the generic "snps,dwc2" compatible
because of the special ahbcfg configuration. The default
GAHBCFG_HBSTLEN_INCR4 of snps,dwc2 can cause a system hang
when the USB and SATA is used concurrently.
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
This patch moves the the host_dma initialization
before dwc2_set_param_dma_desc_enable() and
dwc2_set_param_dma_desc_fs_enable(). The reason being
that both function need it.
Fixes: 1205489cee75bf39 ("usb: dwc2: Get host DMA device properties")
Added new core param for low speed, which can be used only when SNPSID
is equal to DWC2_CORE_FS_IOT. When LS mode is enabled, we are
restricting ep types and providing to upper layer only INTR and CTRL
endpoints.
Signed-off-by: Vardan Mikayelyan <mvardan@synopsys.com>
Add new device IDs for IOT gadget. Done changes in probe to
configure core accordingly depending on device ID value.
This property was mistakenly added, then removed, so don't read it in.
Add a parameter for descriptor DMA and set it based on hardware
capabilities. This won't actually be used by the gadget until later,
when the descriptor DMA code is in place.
Signed-off-by: Vahram Aharonyan <vahrama@synopsys.com>
This is not needed as the gadget now fully supports DMA and it can
autodetect it. This was initially added because gadget DMA mode was only
partially implemented so could not be automatically enabled.
The driver will automatically enable host DMA and use it if available.
This is consistent with the behavior of all existing platforms.
Read in the "snps,host-dma-disable" device property to disable it.
Rename it so that it is more consistent with the gadget dma parameter.
It only affects host-mode operation so prefix it with "host".
Move the gadget devicetree settings into the core_params structure and
document them. Then set and check them in params.c, with the addition of
some helper functions, and remove the equivalent code in gadget.c.
Because these parameters came from the standalone s3c driver, they have
a fixed default value rather than an autodetected one. Preserve and
document this behavior to avoid any compatibility issues.
This hardware parameter is not host specific. It also applies to device
mode. Drop the "host" from the name to make that clear.
Remove the unnecessary prototypes for all the parameter setting
functions and declare those functions 'static' in the params.c file.
Also remove the duplicate documentation that went along with them. They
are already documented as part of the params structure definition.
Then move the constants that went along with the prototype into the
structure.
Replace this by statically defining a function with defaults, and just
assigning it. This will allow us to use parameters of any type and any
default value.
Consolidate and move all the parameter initialization code from the
probe function to params.c.
This makes it consistent with the hw_params struct and simplifies the
memory management for future refactoring. Fix up usage in all files.
Add a params.c file and move all driver parameter code there, including
all the static parameter definitions.
