This is the 5.4.193 stable release
arch/arm64/boot/dts/freescale/fsl-ls1028a-qds.dts
drivers/edac/synopsys_edac.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/mmc/host/sdhci.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
sound/soc/codecs/msm8916-wcd-analog.c
commit f28ad9069363dec7deb88032b70612755eed9ee6 upstream.
The current driver logic checks against 0 to determine whether the
periodic tx/rx threshold settings are set, but we may get bogus values
from uninitialized variables if no device property is set. Properly
default these variables to 0.
Fixes: 938a5ad1d305 ("usb: dwc3: Check for ESS TX/RX threshold config")
Cc: <stable@vger.kernel.org>
Signed-off-by: Thinh Nguyen <Thinh.Nguyen@synopsys.com>
Link: https://lore.kernel.org/r/cccfce990b11b730b0dae42f9d217dc6fb988c90.1649727139.git.Thinh.Nguyen@synopsys.com
This is the 5.4.132 stable release
Conflicts (manual resolve):
- drivers/gpu/drm/rockchip/cdn-dp-core.c:
Fix merge hiccup when integrating upstream commit 450c25b8a4c9c
("drm/rockchip: cdn-dp-core: add missing clk_disable_unprepare() on
error in cdn_dp_grf_write()")
- drivers/perf/fsl_imx8_ddr_perf.c:
Port upstream commit 3fea9b708ae37 ("drivers/perf: fix the missed
ida_simple_remove() in ddr_perf_probe()") manually to NXP version.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit 84524d1232ecca7cf8678e851b254f05cff4040a upstream.
Creation EP's debugfs called earlier than debugfs folder for dwc3
device created. As result EP's debugfs are created in '/sys/kernel/debug'
instead of '/sys/kernel/debug/usb/dwc3.1.auto'.
Moved dwc3_debugfs_init() function call before calling
dwc3_core_init_mode() to allow create dwc3 debugfs parent before
creating EP's debugfs's.
Fixes: 8d396bb0a5b6 ("usb: dwc3: debugfs: Add and remove endpoint dirs dynamically")
Cc: stable <stable@vger.kernel.org>
Reviewed-by: Jack Pham <jackp@codeaurora.org>
Signed-off-by: Minas Harutyunyan <Minas.Harutyunyan@synopsys.com>
Link: https://lore.kernel.org/r/01fafb5b2d8335e98e6eadbac61fc796bdf3ec1a.1623948457.git.Minas.Harutyunyan@synopsys.com
This is the 5.4.128 stable release
commit 4bf584a03eec674975ee9fe36c8583d9d470dab1 upstream.
When do system reboot, it calls dwc3_shutdown and the whole debugfs
for dwc3 has removed first, when the gadget tries to do deinit, and
remove debugfs for its endpoints, it meets NULL pointer dereference
issue when call debugfs_lookup. Fix it by removing the whole dwc3
debugfs later than dwc3_drd_exit.
[ 2924.958838] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000002
[ 2925.030994] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 2925.037005] pc : inode_permission+0x2c/0x198
[ 2925.041281] lr : lookup_one_len_common+0xb0/0xf8
[ 2925.045903] sp : ffff80001276ba70
[ 2925.049218] x29: ffff80001276ba70 x28: ffff0000c01f0000 x27: 0000000000000000
[ 2925.056364] x26: ffff800011791e70 x25: 0000000000000008 x24: dead000000000100
[ 2925.063510] x23: dead000000000122 x22: 0000000000000000 x21: 0000000000000001
[ 2925.070652] x20: ffff8000122c6188 x19: 0000000000000000 x18: 0000000000000000
[ 2925.077797] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000004
[ 2925.084943] x14: ffffffffffffffff x13: 0000000000000000 x12: 0000000000000030
[ 2925.092087] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f x9 : ffff8000102b2420
[ 2925.099232] x8 : 7f7f7f7f7f7f7f7f x7 : feff73746e2f6f64 x6 : 0000000000008080
[ 2925.106378] x5 : 61c8864680b583eb x4 : 209e6ec2d263dbb7 x3 : 000074756f307065
[ 2925.113523] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff8000122c6188
[ 2925.120671] Call trace:
[ 2925.123119] inode_permission+0x2c/0x198
[ 2925.127042] lookup_one_len_common+0xb0/0xf8
[ 2925.131315] lookup_one_len_unlocked+0x34/0xb0
[ 2925.135764] lookup_positive_unlocked+0x14/0x50
[ 2925.140296] debugfs_lookup+0x68/0xa0
[ 2925.143964] dwc3_gadget_free_endpoints+0x84/0xb0
[ 2925.148675] dwc3_gadget_exit+0x28/0x78
[ 2925.152518] dwc3_drd_exit+0x100/0x1f8
[ 2925.156267] dwc3_remove+0x11c/0x120
[ 2925.159851] dwc3_shutdown+0x14/0x20
[ 2925.163432] platform_shutdown+0x28/0x38
[ 2925.167360] device_shutdown+0x15c/0x378
[ 2925.171291] kernel_restart_prepare+0x3c/0x48
[ 2925.175650] kernel_restart+0x1c/0x68
[ 2925.179316] __do_sys_reboot+0x218/0x240
[ 2925.183247] __arm64_sys_reboot+0x28/0x30
[ 2925.187262] invoke_syscall+0x48/0x100
[ 2925.191017] el0_svc_common.constprop.0+0x48/0xc8
[ 2925.195726] do_el0_svc+0x28/0x88
[ 2925.199045] el0_svc+0x20/0x30
[ 2925.202104] el0_sync_handler+0xa8/0xb0
[ 2925.205942] el0_sync+0x148/0x180
[ 2925.209270] Code: a9025bf5 2a0203f5 121f0056 370802b5 (79400660)
[ 2925.215372] ---[ end trace 124254d8e485a58b ]---
[ 2925.220012] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2925.227676] Kernel Offset: disabled
[ 2925.231164] CPU features: 0x00001001,20000846
[ 2925.235521] Memory Limit: none
[ 2925.238580] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
Cc: Jack Pham <jackp@codeaurora.org>
Tested-by: Jack Pham <jackp@codeaurora.org>
Signed-off-by: Peter Chen <peter.chen@kernel.org>
Link: https://lore.kernel.org/r/20210608105656.10795-1-peter.chen@kernel.org
(cherry picked from commit 2a042767814bd0edf2619f06fecd374e266ea068)
Link: https://lore.kernel.org/r/20210615080847.GA10432@jackp-linux.qualcomm.com
This is the 5.4.97 stable release
- drivers/usb/host/xhci.c:
- drivers/usb/host/xhci.h:
Merge commits 5f0ebd9dfcbee ("MLK-18794-1 usb: host: xhci: add .bus_suspend
override") and cfaf1a54fd4d8 ("MLK-16735 usb: host: add XHCI_CDNS_HOST flag")
from NXP tree with commit 9b269d1ce44e9 ("usb: xhci-mtk: fix unreleased
bandwidth data") and f4e4f067f94cf ("usb: xhci-mtk: fix unreleased bandwidth
data") from upstream.
- drivers/usb/host/xhci-plat.c:
Keep NXP implementation done in commit b600e087f2f29 ("MLK-24527-1 usb: host:
xhci-plat: add platform data support"), which covers the logic presented in
commit 2847d242a1e48 ("usb: host: xhci-plat: Use of_device_get_match_data()
helper") from upstream.
Merge upstream commit 40af962eb1d4c ("usb: host: xhci: mvebu: make USB 3.0 PHY
optional for Armada 3720"), which contains the logic of NXP commit cc2b8987ac7f2
("MLK-24527-3 usb: host: xhci-plat: add priv quirk for skip PHY
initialization"),
drop NXP implementation.
commit 0e5a3c8284a30f4c43fd81d7285528ece74563b5 upstream.
Commit fe8abf332b8f ("usb: dwc3: support clocks and resets for DWC3
core") introduced clock support and a new function named
dwc3_core_init_for_resume() which enables the clock before calling
dwc3_core_init() during resume as clocks get disabled during suspend.
Unfortunately in this commit the DWC3_GCTL_PRTCAP_OTG case was forgotten
and therefore during resume, a platform could call dwc3_core_init()
without re-enabling the clocks first, preventing to resume properly.
So update the resume path to call dwc3_core_init_for_resume() as it
should.
Fixes: fe8abf332b8f ("usb: dwc3: support clocks and resets for DWC3 core")
Cc: stable@vger.kernel.org
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
Link: https://lore.kernel.org/r/20210125161934.527820-1-gary.bisson@boundarydevices.com
This is the 5.4.73 stable release
- arch/arm/boot/dts/imx6sl.dtsi:
Commit [a1767c90194e2] in NXP tree is now covered with commit [5c4c2f437cead]
from upstream.
- drivers/gpu/drm/mxsfb/mxsfb_drv.c:
Resolve merge hunk for patch [ed8b90d303cf0] from upstream
- drivers/media/i2c/ov5640.c:
Patch [aa4bb8b8838ff] in NXP tree is now covered by patches [79ec0578c7e0a]
and [b2f8546056b35] from upstream. Changes from NXP patch [99aa4c8c18984] are
covered in upstream version as well.
- drivers/net/ethernet/freescale/fec_main.c:
Fix merge fuzz for patch [9e70485b40c83] from upstream.
- drivers/usb/cdns3/gadget.c:
Keep NXP version of the file, upstream version is not compatible.
- drivers/usb/dwc3/core.c:
- drivers/usb/dwc3/core.h:
Fix merge fuzz of patch [08045050c6bd2] together wth NXP patch [b30e41dc1e494]
- sound/soc/fsl/fsl_sai.c:
- sound/soc/fsl/fsl_sai.h:
Commit [2ea70e51eb72a] in NXP tree is now covered with commit [1ad7f52fe6683]
from upstream.
commit 266d0493900ac5d6a21cdbe6b1624ed2da94d47a upstream.
No need to trigger runtime pm in driver removal, otherwise if user
disable auto suspend via sys file, runtime suspend may be entered,
which will call dwc3_core_exit() again and there will be clock disable
not balance warning:
[ 2026.820154] xhci-hcd xhci-hcd.0.auto: remove, state 4
[ 2026.825268] usb usb2: USB disconnect, device number 1
[ 2026.831017] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
[ 2026.836806] xhci-hcd xhci-hcd.0.auto: remove, state 4
[ 2026.842029] usb usb1: USB disconnect, device number 1
[ 2026.848029] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[ 2026.865889] ------------[ cut here ]------------
[ 2026.870506] usb2_ctrl_root_clk already disabled
[ 2026.875082] WARNING: CPU: 0 PID: 731 at drivers/clk/clk.c:958
clk_core_disable+0xa0/0xa8
[ 2026.883170] Modules linked in: dwc3(-) phy_fsl_imx8mq_usb [last
unloaded: dwc3]
[ 2026.890488] CPU: 0 PID: 731 Comm: rmmod Not tainted
5.8.0-rc7-00280-g9d08cca-dirty #245
[ 2026.898489] Hardware name: NXP i.MX8MQ EVK (DT)
[ 2026.903020] pstate: 20000085 (nzCv daIf -PAN -UAO BTYPE=--)
[ 2026.908594] pc : clk_core_disable+0xa0/0xa8
[ 2026.912777] lr : clk_core_disable+0xa0/0xa8
[ 2026.916958] sp : ffff8000121b39a0
[ 2026.920271] x29: ffff8000121b39a0 x28: ffff0000b11f3700
[ 2026.925583] x27: 0000000000000000 x26: ffff0000b539c700
[ 2026.930895] x25: 000001d7e44e1232 x24: ffff0000b76fa800
[ 2026.936208] x23: ffff0000b76fa6f8 x22: ffff800008d01040
[ 2026.941520] x21: ffff0000b539ce00 x20: ffff0000b7105000
[ 2026.946832] x19: ffff0000b7105000 x18: 0000000000000010
[ 2026.952144] x17: 0000000000000001 x16: 0000000000000000
[ 2026.957456] x15: ffff0000b11f3b70 x14: ffffffffffffffff
[ 2026.962768] x13: ffff8000921b36f7 x12: ffff8000121b36ff
[ 2026.968080] x11: ffff8000119e1000 x10: ffff800011bf26d0
[ 2026.973392] x9 : 0000000000000000 x8 : ffff800011bf3000
[ 2026.978704] x7 : ffff800010695d68 x6 : 0000000000000252
[ 2026.984016] x5 : ffff0000bb9881f0 x4 : 0000000000000000
[ 2026.989327] x3 : 0000000000000027 x2 : 0000000000000023
[ 2026.994639] x1 : ac2fa471aa7cab00 x0 : 0000000000000000
[ 2026.999951] Call trace:
[ 2027.002401] clk_core_disable+0xa0/0xa8
[ 2027.006238] clk_core_disable_lock+0x20/0x38
[ 2027.010508] clk_disable+0x1c/0x28
[ 2027.013911] clk_bulk_disable+0x34/0x50
[ 2027.017758] dwc3_core_exit+0xec/0x110 [dwc3]
[ 2027.022122] dwc3_suspend_common+0x84/0x188 [dwc3]
[ 2027.026919] dwc3_runtime_suspend+0x74/0x9c [dwc3]
[ 2027.031712] pm_generic_runtime_suspend+0x28/0x40
[ 2027.036419] genpd_runtime_suspend+0xa0/0x258
[ 2027.040777] __rpm_callback+0x88/0x140
[ 2027.044526] rpm_callback+0x20/0x80
[ 2027.048015] rpm_suspend+0xd0/0x418
[ 2027.051503] __pm_runtime_suspend+0x58/0xa0
[ 2027.055693] dwc3_runtime_idle+0x7c/0x90 [dwc3]
[ 2027.060224] __rpm_callback+0x88/0x140
[ 2027.063973] rpm_idle+0x78/0x150
[ 2027.067201] __pm_runtime_idle+0x58/0xa0
[ 2027.071130] dwc3_remove+0x64/0xc0 [dwc3]
[ 2027.075140] platform_drv_remove+0x28/0x48
[ 2027.079239] device_release_driver_internal+0xf4/0x1c0
[ 2027.084377] driver_detach+0x4c/0xd8
[ 2027.087954] bus_remove_driver+0x54/0xa8
[ 2027.091877] driver_unregister+0x2c/0x58
[ 2027.095799] platform_driver_unregister+0x10/0x18
[ 2027.100509] dwc3_driver_exit+0x14/0x1408 [dwc3]
[ 2027.105129] __arm64_sys_delete_module+0x178/0x218
[ 2027.109922] el0_svc_common.constprop.0+0x68/0x160
[ 2027.114714] do_el0_svc+0x20/0x80
[ 2027.118031] el0_sync_handler+0x88/0x190
[ 2027.121953] el0_sync+0x140/0x180
[ 2027.125267] ---[ end trace 027f4f8189958f1f ]---
[ 2027.129976] ------------[ cut here ]------------
Fixes: fc8bb91bc83e ("usb: dwc3: implement runtime PM")
Signed-off-by: Li Jun <jun.li@nxp.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit 03c1fd622f72c7624c81b64fdba4a567ae5ee9cb upstream.
Add the phy cleanup if dwc3 mode init fail, which is the missing part of
de-init for dwc3 core init.
Fixes: c499ff71ff2a ("usb: dwc3: core: re-factor init and exit paths")
[ Upstream commit f580170f135af14e287560d94045624d4242d712 ]
SPLIT_BOUNDARY_DISABLE should be set for DesignWare USB3 DRD Core
of Hisilicon Kirin Soc when dwc3 core act as host.
[mchehab: dropped a dev_dbg() as only traces are now allowwed on this driver]
Signed-off-by: Yu Chen <chenyu56@huawei.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
we introduce 3rd role for dwc3, but miss to handle power management
for it, this will cause re-init missing if power lost, and dwc3 is
not in an expected low power state, so add none role PM handling.
Reviewed-by: Peter Chen <peter.chen@nxp.com>
The GCC C compiler generates code that calls functions in the libgcc
library to implement the / and % operations with 64-bit operands on
32-bit CPUs. However, the Linux kernel is not linked against the libgcc
library, so such code will fail to link when building code for a 32-bit
Linux kernel:
LD .tmp_vmlinux.kallsyms1
arm-fsl-linux-gnueabi-ld.bfd: drivers/usb/dwc3/core.o: in function
`dwc3_core_init':
core.c:(.text+0x176c): undefined reference to `__aeabi_uldivmod'
arm-fsl-linux-gnueabi-ld.bfd: core.c:(.text+0x1778): undefined reference
Fix it by use the DIV_ROUND_DOWN_ULL.
build warning on armv7:
../drivers/usb/dwc3/core.c: In function ‘dwc3_frame_length_adjustment’:
../drivers/usb/dwc3/core.c:339:18: warning: integer overflow in
expression of type ‘long int’ results in ‘-728182784’ [-Woverflow]
339 | temp = 125000L * 1000000000L;
Considering there are various special handling for different dwc3
based integrations on SoC, introduce platform data to let glue
layer driver to pass those specific hanldings to dwc3 core driver,
like set_role_post and quirk flags for xhci and dwc3.
USB role class has 3 state: host, device and none, current dwc3 only
has 2 states: host and device, typec compliance test requires DUT
to stop one specific role USB data when parter removed by set its
to be none, so add none role support by stop current role.
enable auto suspend via sys file, runtime suspend may be entered,
unloaded: dwc3]
Do not try to queue a drd work if dr_mode is not USB_DR_MODE_OTG
because the work is not inited, this may be triggered by user try
to change mode file of debugfs on a single role port, which will
cause below kernel dump:
[ 60.115529] ------------[ cut here ]------------
[ 60.120166] WARNING: CPU: 1 PID: 627 at kernel/workqueue.c:1473
__queue_work+0x46c/0x520
[ 60.128254] Modules linked in:
[ 60.131313] CPU: 1 PID: 627 Comm: sh Not tainted
5.7.0-rc4-00022-g914a586-dirty #135
[ 60.139054] Hardware name: NXP i.MX8MQ EVK (DT)
[ 60.143585] pstate: a0000085 (NzCv daIf -PAN -UAO)
[ 60.148376] pc : __queue_work+0x46c/0x520
[ 60.152385] lr : __queue_work+0x314/0x520
[ 60.156393] sp : ffff8000124ebc40
[ 60.159705] x29: ffff8000124ebc40 x28: ffff800011808018
[ 60.165018] x27: ffff800011819ef8 x26: ffff800011d39980
[ 60.170331] x25: ffff800011808018 x24: 0000000000000100
[ 60.175643] x23: 0000000000000013 x22: 0000000000000001
[ 60.180955] x21: ffff0000b7c08e00 x20: ffff0000b6c31080
[ 60.186267] x19: ffff0000bb99bc00 x18: 0000000000000000
[ 60.191579] x17: 0000000000000000 x16: 0000000000000000
[ 60.196891] x15: 0000000000000000 x14: 0000000000000000
[ 60.202202] x13: 0000000000000000 x12: 0000000000000000
[ 60.207515] x11: 0000000000000000 x10: 0000000000000040
[ 60.212827] x9 : ffff800011d55460 x8 : ffff800011d55458
[ 60.218138] x7 : ffff0000b7800028 x6 : 0000000000000000
[ 60.223450] x5 : ffff0000b7800000 x4 : 0000000000000000
[ 60.228762] x3 : ffff0000bb997cc0 x2 : 0000000000000001
[ 60.234074] x1 : 0000000000000000 x0 : ffff0000b6c31088
[ 60.239386] Call trace:
[ 60.241834] __queue_work+0x46c/0x520
[ 60.245496] queue_work_on+0x6c/0x90
[ 60.249075] dwc3_set_mode+0x48/0x58
[ 60.252651] dwc3_mode_write+0xf8/0x150
[ 60.256489] full_proxy_write+0x5c/0xa8
[ 60.260327] __vfs_write+0x18/0x40
[ 60.263729] vfs_write+0xdc/0x1c8
[ 60.267045] ksys_write+0x68/0xf0
[ 60.270360] __arm64_sys_write+0x18/0x20
[ 60.274286] el0_svc_common.constprop.0+0x68/0x160
[ 60.279077] do_el0_svc+0x20/0x80
[ 60.282394] el0_sync_handler+0x10c/0x178
[ 60.286403] el0_sync+0x140/0x180
[ 60.289716] ---[ end trace 70b155582e2b7988 ]---
Per dwc3 databook, if GCTL.SOFITPSYNC is enabled, The DWC_usb3 uses
ref_clk for ITP counter when all the 2.0 ports are suspended.
For this usage, GUCTL.REFCLKPER needs to update to be nano seconds
the period of ref_clk; and GFLADJ.GFLADJ_REFCLK_FLADJ needs to update
to be the frame length adjustment to be applied when SOF/ITP counter is
running on the ref_clk, the value is derived as follows:
FLADJ_REF_CLK_FLADJ=
((125000/ref_clk_period_integer)-(125000/ref_clk_period)) * ref_clk_period where
- the ref_clk_period_integer is the integer value of the ref_clk period
got by truncating the decimal (fractional) value that is programmed in
the GUCTL.REF_CLK_PERIOD field.
- the ref_clk_period is the ref_clk period including the fractional
value.
For imx8mp case, the ref_clk is 24M, so ref_clk_period_integer is 41,
and fladj is 2032.
Review-by: Peter Chen <peter.chen@nxp.com>
* tag 'v5.4.47': (2193 commits)
Linux 5.4.47
KVM: arm64: Save the host's PtrAuth keys in non-preemptible context
KVM: arm64: Synchronize sysreg state on injecting an AArch32 exception
arch/arm/boot/dts/imx6qdl.dtsi
arch/arm/mach-imx/Kconfig
arch/arm/mach-imx/common.h
arch/arm/mach-imx/suspend-imx6.S
arch/arm64/boot/dts/freescale/imx8qxp-mek.dts
arch/powerpc/include/asm/cacheflush.h
drivers/cpufreq/imx6q-cpufreq.c
drivers/dma/imx-sdma.c
drivers/firmware/imx/imx-scu.c
drivers/net/ethernet/freescale/fec.h
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
drivers/net/phy/phy_device.c
drivers/usb/dwc3/gadget.c
include/uapi/linux/dma-buf.h
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
[ Upstream commit 7ba6b09fda5e0cb741ee56f3264665e0edc64822 ]
In certain circumstances, the XHCI SuperSpeed instance in park mode
can fail to recover, thus on Amlogic G12A/G12B/SM1 SoCs when there is high
load on the single XHCI SuperSpeed instance, the controller can crash like:
xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command.
xhci-hcd xhci-hcd.0.auto: Host halt failed, -110
xhci-hcd xhci-hcd.0.auto: xHCI host controller not responding, assume dead
hub 2-1.1:1.0: hub_ext_port_status failed (err = -22)
xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
usb 2-1.1-port1: cannot reset (err = -22)
Setting the PARKMODE_DISABLE_SS bit in the DWC3_USB3_GUCTL1 mitigates
the issue. The bit is described as :
"When this bit is set to '1' all SS bus instances in park mode are disabled"
Synopsys explains:
The GUCTL1.PARKMODE_DISABLE_SS is only available in
dwc_usb3 controller running in host mode.
This should not be set for other IPs.
This can be disabled by default based on IP, but I recommend to have a
property to enable this feature for devices that need this.
CC: Dongjin Kim <tobetter@gmail.com>
Cc: Jianxin Pan <jianxin.pan@amlogic.com>
Cc: Thinh Nguyen <thinhn@synopsys.com>
Cc: Jun Li <lijun.kernel@gmail.com>
Reported-by: Tim <elatllat@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The DRD module calls dwc3_set_mode() on role switches, i.e. when a device is
being plugged in. In order to support continuous runtime power management when
plugging in / unplugging a cable, we need to call pm_runtime_get_sync() in
this path.
Signed-off-by: Martin Kepplinger <martin.kepplinger@puri.sm>
In case system resume by device mode event(e.g, VBUS), runtime resume
will happen before system resume, to avoid doing device mode resume
again when system resume, add a core init flag.
On some platforms, if the ITP counter clock is from utmi_clk, and
the usb2 suspended firstly, then the ITP clock will miss, to resolve
this, we can use soft ITP sync to make dwc3 core use ref_clk for ITP
counter.
Merge Linux stable release v5.4.24 into imx_5.4.y
* tag 'v5.4.24': (3306 commits)
Linux 5.4.24
blktrace: Protect q->blk_trace with RCU
kvm: nVMX: VMWRITE checks unsupported field before read-only field
arch/arm/boot/dts/imx6sll-evk.dts
arch/arm/boot/dts/imx7ulp.dtsi
arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi
drivers/clk/imx/clk-composite-8m.c
drivers/gpio/gpio-mxc.c
drivers/irqchip/Kconfig
drivers/mmc/host/sdhci-of-esdhc.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/dpaa/dpaa_eth.c
drivers/net/ethernet/mscc/ocelot.c
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
drivers/net/phy/realtek.c
drivers/pci/controller/mobiveil/pcie-mobiveil-host.c
drivers/tee/optee/shm_pool.c
kernel/sched/cpufreq.c
net/core/xdp.c
sound/soc/fsl/fsl_esai.c
sound/soc/sof/core.c
sound/soc/sof/imx/Kconfig
sound/soc/sof/loader.c
DWC3 glue layer driver may need private API to interact with core
driver, here addd a dwc3_priv_data struct and which only has one
API for setting after usb mode set.
If dwc->dev is already suspended in device mode, don't do it again.
commit 09ed259fac621634d51cd986aa8d65f035662658 upstream.
VBUS should be turned off when leaving the host mode.
Set GCTL_PRTCAP to device mode in teardown to de-assert DRVVBUS pin to
turn off VBUS power.
Fixes: 5f94adfeed97 ("usb: dwc3: core: refactor mode initialization to its own function")
Signed-off-by: Bin Liu <b-liu@ti.com>
This reverts commit 89a9cc47513e91bc91ba2c438d5e422a0c8d05e7.
Don't limit DRD for higher IP version.
This feature is telling how to configure cache type on 4 different
transfer types: Data Read, Desc Read, Data Write and Desc write. For each
treasfer type, controller has a 4-bit register field to enable different
cache type. Quoted from DWC3 data book Table 6-5 Cache Type Bit Assignments:
MBUS_TYPE| bit[3] |bit[2] |bit[1] |bit[0]
AHB |Cacheable |Bufferable |Privilegge |Data
AXI3 |Write Allocate|Read Allocate|Cacheable |Bufferable
AXI4 |Allocate Other|Allocate |Modifiable |Bufferable
AXI4 |Other Allocate|Allocate |Modifiable |Bufferable
Native |Same as AXI |Same as AXI |Same as AXI|Same as AXI
Note: The AHB, AXI3, AXI4, and PCIe busses use different names for certain
signals, which have the same meaning:
Bufferable = Posted
Cacheable = Modifiable = Snoop (negation of No Snoop)
In most cases, driver support is not required unless the default values of
registers are not correct *and* DWC3 node has enabled dma-coherent. So far we
have observed USB device detect failure on some Layerscape platforms if this
programming was not applied.
Related struct:
struct dwc3_cache_type {
u8 transfer_type_datard;
u8 transfer_type_descrd;
u8 transfer_type_datawr;
u8 transfer_type_descwr;
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Reviewed-by: Jun Li <jun.li@nxp.com>
This reverts commit ebceaf435cc96892d22b334b2a6517374c0d6a6e.
Will use next version patch to replace this.
transfer type, controller has a 4-bit register field to enable different
Bufferable = Posted
Related struct:
- Advantage of park mode
When only a single Async endpoint is active.
- Behavior of park mode
1. The controller prefetches data/TRBs to do 3 * burst_size worth
of packets.
2. When park mode is disabled there will be some delay between
bursts on the USB. This can be avoided if park mode is enabled
in cases of only one endpoint is active.
3. But this delay is significant only with systems of large
latencies.
4. We have noticed that in cases where a device NAKs often, it
tends to bring down the performance for a single endpoint case.
- Issue on "park mode"
1. LSP (List Processor) goes in and out of park mode irrespective
of the fact that there are more endpoints active. #LSP consider
that there is only one endpoint active.
2. This causes master scheduler and transaction handlers to think
that they are in park mode even though they are not. This is
because request to transaction handlers, generated by HSCH is
in park mode when the request is made
3. This causes a case where the master scheduler calculates wrongly
the number of TRB cache space available.
4. Because of the wrongly calculated number of TRB spaces, the core
fetches more TRBS than there is space for.
5. This causes overwriting the TRB cache area into the TRQ cache
area which is next to the TRB cache area.
6. This causes invalidating an entry in the TRQ
7. This causes transaction handlers to ignore a request in the TRQ
which it should have processed.
8. This causes the main scheduler to hang because it is waiting for
status from transaction handler.
9. This causes host controller to hang.
- Work Around
Disabling park mode for super speed by setting GUCTL1[17] to be 1.
The STAR number is 9001415732, which is target to be released around
May,2020.
Reviewed-by: Ran Wang <ran.wang_1@nxp.com>
When DWC3 is set to host mode by programming register DWC3_GCTL, VBUS
(or its control signal) will be turned on immediately on related Root Hub
ports. Then, the VBUS is turned off for a little while(15us) when do xhci
reset (conducted by xhci driver) and back to normal finally, we can
observe a negative glitch of related signal happen.
This VBUS glitch might cause some USB devices enumeration fail if kernel
boot with them connected. Such as LS1012AFWRY/LS1043ARDB/LX2160AQDS
/LS1088ARDB with Kingston 16GB USB2.0/Kingston USB3.0/JetFlash Transcend
4GB USB2.0 drives. The fail cases include enumerated as full-speed device
or report wrong device descriptor, etc.
One SW workaround which can fix this is by programing all xhci PORTSC[PP]
to 0 to turn off VBUS immediately after setting host mode in DWC3 driver
(per signal measurement result, it will be too late to do it in
xhci-plat.c or xhci.c). Then, after xhci reset complete in xhci driver,
PORTSC[PP]s' value will back to 1 automatically and VBUS on at that time,
no glitch happen and normal enumeration process has no impact.
During the USB certification CV9 test, if we report OTG descriptor
to test suite, it will require doing OTG test, but in fact, it does
not support OTG-compliance in dwc3 driver.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Since the new dwc3 use bulk clks including the suspend clk, so we can
use it to calculate the power down scale value.
Acked-by: Peter Chen <peter.chen@nxp.com>
layerscape board sometimes reported some usb call trace, that is due to
kernel sent LPM tokerns automatically when it has no pending transfers
and think that the link is idle enough to enter L1, which procedure will
ask usb register has a recovery,then kernel will compare USBx_GFLADJ and
set GFLADJ_30MHZ, GFLADJ_30MHZ_REG until GFLADJ_30MHZ is equal 0x20, if
the conditions were met then issue occur, but whatever the conditions
whether were met that usb is all need keep GFLADJ_30MHZ of value is 0x20
(xhci spec ask use GFLADJ_30MHZ to adjust any offset from clock source
that generates the clock that drives the SOF counter, 0x20 is default
value of it)That is normal logic, so need remove the call trace.
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Calls to USB2 generic PHY calibrate() method has been moved to HCD core,
which now successfully handles generic PHYs and their calibration after
every HCD reset. This fixes all the timing issues related to PHY
calibration done directly from DWC3 driver: incorrect operation after
system suspend/resume or USB3.0 detection failure when XHCI-plat driver
compiled as separate module.
Tested-by: Anand Moon <linux.amoon@gmail.com>
Tested-by: Jochen Sprickerhof <jochen@sprickerhof.de>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Link: https://lore.kernel.org/r/20190829053028.32438-3-m.szyprowski@samsung.com
dwc->hird_threshold field should store "snps,hird_threshold" property
only and not a combination of multiple properties. Remove the value of
"snps,is-utmi-l1-suspend" property from the field dwc->hird_threshold.
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
Use clk_bulk_prepare_enable() and clk_bulk_disable_unprepare() to
simplify code a bit. No functional change intended.
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Cc: Felipe Balbi <balbi@kernel.org>
Cc: Chris Healy <cphealy@gmail.com>
Cc: linux-usb@vger.kernel.org
Use devres to get clocks and drop explicit clock freeing. No
Starting from DWC_usb31 version 1.90a and later, the DCTL.CSFRST bit
will not be cleared until after all the internal clocks are synchronized
during soft-reset. This may take a little more than 50ms. Set the
polling rate at 20ms instead.
Use use device_property_count_u32() directly, that makes code neater.
Gadget applications may have a requirement to disable the U1 and U2
entry based on the usecase. Below are few usecases where the disabling
U1/U2 entries may be possible.
Usecase 1:
When combining dwc3 with an redriver for a USB Type-C device solution, it
sometimes have problems with leaving U1/U2 for certain hosts, resulting in
link training errors and reconnects. For this U1/U2 state entries may be
avoided.
Usecase 2:
When performing performance benchmarking on mass storage gadget the
U1 and U2 entries can be disabled.
Usecase 3:
When periodic transfers like ISOC transfers are used with bInterval
of 1 which doesn't require the link to enter into U1 or U2 state entry
(since ping is issued from host for every uframe interval). In this
case the U1 and U2 entry can be disabled.
Disablement of U1/U2 can be done by setting U1DevExitLat and U2DevExitLat
values to 0 in the BOS descriptor. Host on seeing 0 value for U1DevExitLat
and U2DevExitLat, it doesn't send SET_SEL requests to the gadget. There
may be some hosts which may send SET_SEL requests even after seeing 0 in
the UxDevExitLat of BOS descriptor. To aviod U1/U2 entries for these type
of hosts, dwc3 controller can be programmed to reject those U1/U2 requests
by not enabling ACCEPTUxENA bits in DCTL register.
This patch updates the same.
Signed-off-by: Anurag Kumar Vulisha <anurag.kumar.vulisha@xilinx.com>
Signed-off-by: Claus H. Stovgaard <cst@phaseone.com>
The required clocks needs to be enabled before the first register
access. After commit fe8abf332b8f ("usb: dwc3: support clocks and resets
for DWC3 core"), this happens when the dwc3_core_is_valid function is
called, but the mentioned commit adds that call in the wrong place,
before the clocks are enabled. So, move that call after the
clk_bulk_enable() to ensure the clocks are enabled and the reset
deasserted.
I detected this while, as experiment, I tried to move the clocks and resets
from the glue layer to the DWC3 core on a Samsung Chromebook Plus.
That was not detected before because, in most cases, the glue layer
initializes SoC-specific things and then populates the child "snps,dwc3"
with those clocks already enabled.
Fixes: b873e2d0ea1ef ("usb: dwc3: Do core validation early on probe")
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
The max possible value for DCTL.LPM_NYET_THRES is 15 and not 255. Change
the default value to 15.
Fixes: 80caf7d21adc ("usb: dwc3: add lpm erratum support")
The setting of the dr_mode may need to check the controller's revision.
The revision is set in the dwc3_core_is_valid(), which comes after
dr_mode setting. Let's move it closer to the start of the dwc3_probe()
function and before calling dwc3_get_dr_mode().
dwc3_gadget_suspend() is called under dwc->lock spinlock. In such context
calling synchronize_irq() is not allowed. Move the problematic call out
of the protected block to fix the following kernel BUG during system
suspend:
BUG: sleeping function called from invalid context at kernel/irq/manage.c:112
in_atomic(): 1, irqs_disabled(): 128, pid: 1601, name: rtcwake
6 locks held by rtcwake/1601:
#0: f70ac2a2 (sb_writers#7){.+.+}, at: vfs_write+0x130/0x16c
#1: b5fe1270 (&of->mutex){+.+.}, at: kernfs_fop_write+0xc0/0x1e4
#2: 7e597705 (kn->count#60){.+.+}, at: kernfs_fop_write+0xc8/0x1e4
#3: 8b3527d0 (system_transition_mutex){+.+.}, at: pm_suspend+0xc4/0xc04
#4: fc7f1c42 (&dev->mutex){....}, at: __device_suspend+0xd8/0x74c
#5: 4b36507e (&(&dwc->lock)->rlock){....}, at: dwc3_gadget_suspend+0x24/0x3c
irq event stamp: 11252
hardirqs last enabled at (11251): [<c09c54a4>] _raw_spin_unlock_irqrestore+0x6c/0x74
hardirqs last disabled at (11252): [<c09c4d44>] _raw_spin_lock_irqsave+0x1c/0x5c
softirqs last enabled at (9744): [<c0102564>] __do_softirq+0x3a4/0x66c
softirqs last disabled at (9737): [<c0128528>] irq_exit+0x140/0x168
Preemption disabled at:
[<00000000>] (null)
CPU: 7 PID: 1601 Comm: rtcwake Not tainted
5.0.0-rc3-next-20190122-00039-ga3f4ee4f8a52 #5252
Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[<c01110f0>] (unwind_backtrace) from [<c010d120>] (show_stack+0x10/0x14)
[<c010d120>] (show_stack) from [<c09a4d04>] (dump_stack+0x90/0xc8)
[<c09a4d04>] (dump_stack) from [<c014c700>] (___might_sleep+0x22c/0x2c8)
[<c014c700>] (___might_sleep) from [<c0189d68>] (synchronize_irq+0x28/0x84)
[<c0189d68>] (synchronize_irq) from [<c05cbbf8>] (dwc3_gadget_suspend+0x34/0x3c)
[<c05cbbf8>] (dwc3_gadget_suspend) from [<c05bd020>] (dwc3_suspend_common+0x154/0x410)
[<c05bd020>] (dwc3_suspend_common) from [<c05bd34c>] (dwc3_suspend+0x14/0x2c)
[<c05bd34c>] (dwc3_suspend) from [<c051c730>] (platform_pm_suspend+0x2c/0x54)
[<c051c730>] (platform_pm_suspend) from [<c05285d4>] (dpm_run_callback+0xa4/0x3dc)
[<c05285d4>] (dpm_run_callback) from [<c0528a40>] (__device_suspend+0x134/0x74c)
[<c0528a40>] (__device_suspend) from [<c052c508>] (dpm_suspend+0x174/0x588)
[<c052c508>] (dpm_suspend) from [<c0182134>] (suspend_devices_and_enter+0xc0/0xe74)
[<c0182134>] (suspend_devices_and_enter) from [<c0183658>] (pm_suspend+0x770/0xc04)
[<c0183658>] (pm_suspend) from [<c0180ddc>] (state_store+0x6c/0xcc)
[<c0180ddc>] (state_store) from [<c09a9a70>] (kobj_attr_store+0x14/0x20)
[<c09a9a70>] (kobj_attr_store) from [<c02d6800>] (sysfs_kf_write+0x4c/0x50)
[<c02d6800>] (sysfs_kf_write) from [<c02d594c>] (kernfs_fop_write+0xfc/0x1e4)
[<c02d594c>] (kernfs_fop_write) from [<c02593d8>] (__vfs_write+0x2c/0x160)
[<c02593d8>] (__vfs_write) from [<c0259694>] (vfs_write+0xa4/0x16c)
[<c0259694>] (vfs_write) from [<c0259870>] (ksys_write+0x40/0x8c)
[<c0259870>] (ksys_write) from [<c0101000>] (ret_fast_syscall+0x0/0x28)
Exception stack(0xed55ffa8 to 0xed55fff0)
Fixes: 01c10880d242 ("usb: dwc3: gadget: synchronize_irq dwc irq in suspend")
When we read an array of integers from device properties,
the temporary buffer is allocated.
However, in case of dwc3_set_incr_burst_type() it's not freed.
Free allocated buffer immediately after use.
In DWC_usb31 version 1.70a-ea06 and prior, for highspeed and fullspeed
isochronous IN, BIT[15:14] of the 16-bit microframe number reported by
the XferNotReady event are invalid. The driver uses this number to
schedule the isochronous transfer and passes it to the START TRANSFER
command. Because this number is invalid, the command may fail. If
BIT[15:14] matches the internal 16-bit microframe, the START TRANSFER
command will pass and the transfer will start at the scheduled time, if
it is off by 1, the command will still pass, but the transfer will start
2 seconds in the future. For all other conditions, the START TRANSFER
command will fail with bus-expiry.
In order to workaround this issue, we can test for the correct
combination of BIT[15:14] by sending START TRANSFER commands with
different values of BIT[15:14]: 'b00, 'b01, 'b10, and 'b11. Each
combination is 2^14 uframe apart (or 2 seconds). 4 seconds into the
future will result in a bus-expiry status. As the result, within the 4
possible combinations for BIT[15:14], there will be 2 successful and 2
failure START COMMAND status. One of the 2 successful command status
will result in a 2-second delay start. The smaller BIT[15:14] value is
the correct combination.
Since there are only 4 outcomes and the results are ordered, we can
simply test 2 START TRANSFER commands with BIT[15:14] combinations 'b00
and 'b01 to deduce the smaller successful combination.
Let test0 = test status for combination 'b00 and test1 = test status for
'b01 of BIT[15:14]. The correct combination is as follow:
if test0 fails and test1 passes, BIT[15:14] is 'b01
if test0 fails and test1 fails, BIT[15:14] is 'b10
if test0 passes and test1 fails, BIT[15:14] is 'b11
if test0 passes and test1 passes, BIT[15:14] is 'b00
Synopsys STAR 9001202023: Wrong microframe number for isochronous IN
endpoints.
