Add SuperSpeed descriptors to the Network USB
function drivers.
This has been lightly tested using a Linux host.
I was able to ssh from device to host and host to
device, no obvious problems seen.
Signed-off-by: Paul Zimmerman <paulz@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Remove obsolete functions:
1. ep_choose()
2. usb_find_endpoint()
Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org>
Change usb_ep_enable() prototype to use endpoint
descriptor from usb_ep.
This optimization spares the FDs from saving the
endpoint chosen descriptor. This optimization is
not full though. To fully exploit this change, one
needs to update all the UDCs as well since in the
current implementation each of them saves the
endpoint descriptor in it's internal (and extended)
endpoint structure.
__init, __initdata and __exit tags have have been removed from
various files to make it possible for gadgets that do not use
the __init/__exit tags to use those.
Files in question are related to:
* the core composite framework,
* the mass storage function (fixing a section mismatch) and
* ethernet driver (ACM, ECM, RNDIS).
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
A bunch of USB gadget drivers where never ported from the linux 2.4
series to 2.6 kernels. However there's some code still in the tree for
them which isn't used and is probably untested for ages.
As the chance of these drivers being forward ported is probably quite
small now it might be time to get rid of them.
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
The base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Change how the Ethernet/RNDIS gadget driver builds: don't
use separate compilation, since it works poorly when key
parts are library code (with init sections etc). Instead
be as close as we can to "gcc --combine ...".
This is a bit more complicated than most of the others
because it had to resolve a few symbol collisions.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This removes some unused members from the various USB functions.
This is a "CDC Ethernet" (ECM) function driver, extracted from the
all-in-one Ethernet gadget driver.
This is a good example of how to implement interface altsettings.
In fact it's currently the only such example in the gadget stack,
pending addition of OBEX support.
