maxpacket is set by the udc driver for ep0 very early. This value is
copied by the function gadget used later for the USB_DT_DEVICE and
USB_DT_DEVICE_QUALIFIER query. This seems to work fine so far. For USB3
we need set a different value here. In SS speed it is 2^x with x=9 and
in HS we set something <= 64. If the UDC starts in SS and continues in
HS after the cable has been plugged it will report a too small value.
There setting of this value is defered and taken automaticly from the
ep0 pointer where the UDC driver can update it according to the speed it
detected _after_ a cable has been plugged.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Change usb_ep_enable() prototype to use endpoint
descriptor from usb_ep.
This optimization spares the FDs from saving the
endpoint chosen descriptor. This optimization is
not full though. To fully exploit this change, one
needs to update all the UDCs as well since in the
current implementation each of them saves the
endpoint descriptor in it's internal (and extended)
endpoint structure.
Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org>
This patch (as1471) deprecates the File-backed Storage Driver and
schedules its replacement for the 3.8 kernel release (about two years
from now). Users are advised to switch to the Mass Storage Gadget
instead.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Comparing an unsigned integer with greater than or equal to zero is
always true. So, it is safe to remove similar checks from
'f_mass_storage.c' and 'file_storage.c'
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This reverts commit 806e8f8fcc27e1753947bd9f059ba2316cf8f92a.
To quote Alan Stern:
The necessity for this patch has been under discussion.
It turns out the UDC that Mian has been working on and Felipe's
UDC have contradictory requirements. Mian's UDC driver wants a
bulk-OUT transfer length to be shorter than the maxpacket size
if a short packet is expected, whereas Felipe's UDC hardware
always needs bulk-OUT transfer lengths to be evenly divisible by
the maxpacket size.
Mian has agreed to go back over the driver to resolve this
conflict. This means we probably will not want this patch after
all. (In fact, we may ultimately decide to change the gadget
framework to require that bulk-OUT transfer lengths _always_ be
divisible by the maxpacket size -- only the g_file_storage and
g_mass_storage gadgets would need to be changed.)
Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
This patch (as1455) removes the extra padding sent by g_file_storage
and g_mass_storage when the gadget wants to send less data than
requested by the host and isn't allowed to halt the bulk-IN endpoint.
Although the Bulk-Only Transport specification requires the padding to
be present, it isn't truly needed since the transfer will be terminated
by a short packet anyway. Furthermore, many existing devices don't
bother to send any padding.
Acked-By: Michal Nazarewicz <mina86@mina86.com>
CC: Roger Quadros <roger.quadros@nokia.com>
Mass-storage and file-storage gadgets align the length to maximum-packet-size
when preparing the request to receive CBW. This is unnecessary and prevents the
controller driver from knowing that a short-packet is expected.
It is incorrect to set short_not_ok when preparing the request to receive CBW.
CBW will be a short-packet so short_not_ok must not be set.
This makes bh->bulk_out_intended_length unnecessary so it is also removed.
Signed-off-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
This commit fixes some issues with File-backed Storage Gadget
error recovery when registering LUN's devices.
First of all, when device_register() fails the device still
needs to be put. However, because lun_release() decreases
fsg->ref reference counter the counter must be incremented
beforehand.
Second of all, after any of the device_create_file()s fails,
device_unregister() is called which in turn (indirectly) calls
lun_release() which decrements fsg->ref. So, again, the
reference counter must be incremented beforehand.
Lastly, if the first or the second device_create_file()
succeeds, the files are never removed. To fix it,
device_remove_file() needs to be called. This is done by
simply marking LUN as registered prior to creating files so
that fsg_unbind() can handle removing files.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Reported-by: Rahul Ruikar <rahul.ruikar@gmail.com>
This commit changes storage_common.h, file_storage.c and
f_mass_storage.c to use definitions of SCSI commands from
scsi/scsi.h file instead of redefining the commands in
storage_common.c.
scsi/scsi.h header file was missing READ_FORMAT_CAPACITIES and
READ_HEADER so this commit also add those to the header.
Cc: James Bottomley <James.Bottomley@suse.de>
This patch (as1413) changes g_file_storage to avoid generating a bogus
automatic serial-number string descriptor. If the user doesn't provide
a valid serial number via a module parameter then a warning is logged
and the gadget won't have any serial string descriptor at all.
Acked-by: David Brownell <david-b@pacbell.net>
CC: Michal Nazarewicz <m.nazarewicz@samsung.com>
To accomplish this the function to register a gadget driver takes the bind
function as a second argument. To make things clearer rename the function
to resemble platform_driver_probe.
This fixes many section mismatches like
WARNING: drivers/usb/gadget/g_printer.o(.data+0xc): Section mismatch in
reference from the variable printer_driver to the function
.init.text:printer_bind()
The variable printer_driver references
the function __init printer_bind()
All callers are fixed.
[m.nazarewicz@samsung.com: added dbgp]
Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com>
This reverts a commit which proposed an invalid solution
for a section mismatch. Next 3 commits will fix it correctly.
drivers/usb/gadget/mass_storage.c
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
The dev_attr_nofua file was created during fsg_bind() but
was never removed. Made it a bit more symmetrical and added
code to remove the file in fsg_unbind().
Acked-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Moved the serial parameter handling code out of "#ifdef
CONFIG_USB_FILE_STORAGE_TEST".
This modifies Yann Cantin's commit "USB: Add a serial number
parameter to g_file_storage" module as per Alan Stern's request.
Tested-by: Anand Gadiyar <gadiyar@ti.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Yann Cantin <yann.cantin@laposte.net>
MS Windows mounts removable storage in "Removal optimized mode" by
default. All the writes to the media are synchronous which is achieved
by setting FUA (Force Unit Access) bit in SCSI WRITE(10,12) commands.
This prevents I/O requests aggregation in block layer dramatically
decreasing performance.
This patch brings an option to accept or ignore mentioned bit
a) via specifying module parameter "nofua", or
b) through sysfs entry
/sys/devices/platform/_UDC_/gadget/gadget-lunX/nofua
(_UDC_ is the name of the USB Device Controller driver)
Patch is based on the work that was done by Denis Karpov for Maemo 5
platform.
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Cc: Denis Karpov <ext-denis.2.karpov@nokia.com>
Cc: Adrian Hunter <adrian.hunter@nokia.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
In may gadgets bind and bind like functions were in a init section
as they were only run during initialisation. However, being
callback functions they were referenced from structures in “normal”
sections. Changing the tag from “__init” to “__ref” fixes the
warnings.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
This patch add a serial number parameter to the g_file_storage
module. There's validity checks against the string passed to comply
with the specs.
Signed-off-by: Yann Cantin <yann.cantin@laposte.net>
Cc: Michał Nazarewicz <m.nazarewicz@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
No one is calling this anymore as everyone has switched to
invalidate_mapping_pages long time ago. Also update a few
references to it in comments. nfs has two more, but I can't
easily figure what they are actually referring to, so I left
them as-is.
A bunch of USB gadget drivers where never ported from the linux 2.4
series to 2.6 kernels. However there's some code still in the tree for
them which isn't used and is probably untested for ages.
As the chance of these drivers being forward ported is probably quite
small now it might be time to get rid of them.
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (21 commits)
ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks()
ext3: Fix data / filesystem corruption when write fails to copy data
ext4: Support for 64-bit quota format
ext3: Support for vfsv1 quota format
quota: Implement quota format with 64-bit space and inode limits
quota: Move definition of QFMT_OCFS2 to linux/quota.h
ext2: fix comment in ext2_find_entry about return values
ext3: Unify log messages in ext3
ext2: clear uptodate flag on super block I/O error
ext2: Unify log messages in ext2
ext3: make "norecovery" an alias for "noload"
ext3: Don't update the superblock in ext3_statfs()
ext3: journal all modifications in ext3_xattr_set_handle
ext2: Explicitly assign values to on-disk enum of filetypes
quota: Fix WARN_ON in lookup_one_len
const: struct quota_format_ops
ubifs: remove manual O_SYNC handling
afs: remove manual O_SYNC handling
kill wait_on_page_writeback_range
vfs: Implement proper O_SYNC semantics
The f_mass_storage.c has been changed into a composite function.
mass_storage.c file has been introduced which defines a
g_mass_storage gadget based on composite framework.
Since storage_common.c no longer references mod_data object
it is now possible to include it before mod_data object is
defined. This makes it possible to move some defines that
are used as default values of mod_data fields to be defined
in storage_common.c file (where they should be set from
the beginning).
Also, show_ro(), show_file(), store_ro() and store_file()
have been moved to storage_common.c with LUN's device's
drvdata changed from pointing to fsg_dev to pointing to
rw_semaphore (&fsg->filesem).
removable and cdrom flag has been added to the fsg_lun structure
removing any references to mod_data object from storage_common.c.
As of read-only flag, previously it was set if a read-only
backing file was specified (which is good) and remained set
even after the file has been closed (which may be considered an
issue). Currently, the initial read-only flag is preserved so
if it was unset each time file is opened code will try to open
it read-write even if previous file was opened read-only.
Prefixed some identifiers that were defined in storage_common.c file
with "fsg_". Not all identifiers were prefixed but the ones that are
most likely to produce conflicts when used with other USB functions.
Moved parts of the file_storage.c file which do not reference fsg_dev
structure to newly created storage_common.c file. dump_msg() and
dump_cdb() have been changed to macros to remove fsg_dev reference.
While Linux provided an O_SYNC flag basically since day 1, it took until
Linux 2.4.0-test12pre2 to actually get it implemented for filesystems,
since that day we had generic_osync_around with only minor changes and the
great "For now, when the user asks for O_SYNC, we'll actually give
O_DSYNC" comment. This patch intends to actually give us real O_SYNC
semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC
patches which are required before this patch it's actually surprisingly
simple, we just need to figure out when to set the datasync flag to
vfs_fsync_range and when not.
This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's
numerical value to keep binary compatibility, and adds a new real O_SYNC
flag. To guarantee backwards compatiblity it is defined as expanding to
both the O_DSYNC and the new additional binary flag (__O_SYNC) to make
sure we are backwards-compatible when compiled against the new headers.
This also means that all places that don't care about the differences can
just check O_DSYNC and get the right behaviour for O_SYNC, too - only
places that actuall care need to check __O_SYNC in addition. Drivers and
network filesystems have been updated in a fail safe way to always do the
full sync magic if O_DSYNC is set. The few places setting O_SYNC for
lower layers are kept that way for now to stay failsafe.
We enforce that O_DSYNC is set when __O_SYNC is set early in the open path
to make sure we always get these sane options.
Note that parisc really screwed up their headers as they already define a
O_DSYNC that has always been a no-op. We try to repair it by using it for
the new O_DSYNC and redefinining O_SYNC to send both the traditional
O_SYNC numerical value _and_ the O_DSYNC one.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Andreas Dilger <adilger@sun.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Ulrich Drepper <drepper@redhat.com>
This patch (as1233) makes g_file_storage use the "unaligned" accessors.
This is based on work originally done by Harvey Harrison.
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This patch (as1231) fixes a use-after-free bug in g_file_storage. A
device's name may not be available after the device is unregistered,
even if the device structure itself is still allocated. Since
close_backing_file() prints a LUN's name for debugging, it shouldn't
be called after the LUN has been unregistered.
That whole area needed to be cleaned up; the backing files were
getting closed in a couple of different places. The patch fixes
things so that they get closed in just one place, as part of the
unbind procedure, immediately before the LUN is unregistered.
* 'bkl-removal' of git://git.lwn.net/linux-2.6:
Rationalize fasync return values
Move FASYNC bit handling to f_op->fasync()
Use f_lock to protect f_flags
Rename struct file->f_ep_lock
The base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Traditionally, changes to struct file->f_flags have been done under BKL
protection, or with no protection at all. This patch causes all f_flags
changes after file open/creation time to be done under protection of
f_lock. This allows the removal of some BKL usage and fixes a number of
longstanding (if microscopic) races.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This patch (as1220) automatically disables stalls when g_file_storage
finds itself running with an Atmel device controller, because the
Atmel hardware/driver isn't capable of halting bulk endpoints
correctly.
Reported-by: Stanislaw Gruszka <stf_xl@wp.pl>
In some obscure scenarios e.g. passing a 0-byte backing file
storage, wait_for_completion() would wait forever in fsg_cleanup().
Prevent it by completing the thread in fsg_bind() error path.
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
This patch (as1172) adds the ability to emulate a CD-ROM drive to
g_file_storage. The emulation is limited, since it presents as a disc
containing a single data track and no audio tracks. Still, it may
come in useful on occasion.
Fsync currently has a fdatawrite/fdatawait pair around the method call,
and a mutex_lock/unlock of the inode mutex. All callers of fsync have
to duplicate this, but we have a few and most of them don't quite get
it right. This patch adds a new vfs_fsync that takes care of this.
It's a little more complicated as usual as ->fsync might get a NULL file
pointer and just a dentry from nfsd, but otherwise gets afile and we
want to take the mapping and file operations from it when it is there.
Notes on the fsync callers:
- ecryptfs wasn't calling filemap_fdatawrite / filemap_fdatawait on the
lower file
- coda wasn't calling filemap_fdatawrite / filemap_fdatawait on the host
file, and returning 0 when ->fsync was missing
- shm wasn't calling either filemap_fdatawrite / filemap_fdatawait nor
taking i_mutex. Now given that shared memory doesn't have disk
backing not doing anything in fsync seems fine and I left it out of
the vfs_fsync conversion for now, but in that case we might just
not pass it through to the lower file at all but just call the no-op
simple_sync_file directly.
[and now actually export vfs_fsync]
Offer a "how much VBUS power to request" configuration option
for USB gadgets that aren't using board-specific customization
of their gadget or (composite) configuration drivers.
Also remove a couple pointless "depends on USB_GADGET" bits
from the Kconfig text; booleans inside an "if USB_GADGET" will
already have that dependency.
Based on a patch from Justin Clacherty.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Justin Clacherty <justin@redfish-group.com>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Try to workaround issues with bad SCSI implementations
by ignoring the command size error.
Change how the file storage gadget driver builds: don't
use separate compilation, since it works poorly when key
parts are library code (with init sections etc). Instead
be as close as we can to "gcc --combine ...".
We want to use WARN() as a variant of WARN_ON(), however a few drivers are
using WARN() internally. This patch renames these to WARNING() to avoid the
namespace clash. A few cases were defining but not using the thing, for those
cases I just deleted the definition.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Greg KH <greg@kroah.com>
Cc: Karsten Keil <kkeil@suse.de>
The bus_id field is going away, use the dev_set_name() function
to set it properly.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The bus_id field is going away, use the dev_name() function instead.
clear-feature ignore
Gadget tells controller driver to ignore Clear-Feature(HALT_ENDPOINT)
Signed-off-by: David Lopo <lopo.david@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
This patch (as1061) makes g_file_storage more compliant with the
Bulk-Only Transport specification. After an invalid CBW is received,
the gadget must ignore any further bulk-OUT data until it is reset.
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to
reflect this.
[akpm@linux-foundation.org: fix build in mm/memory.c]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Christoph Hellwig <hch@infradead.org>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
We now have pr_err(), pr_warning(), and friends ... start using
them in the gadget stack instead of printk(KERN_ERR) and friends.
This gives us shorter lines and somewhat increased readability.
The task_struct->pid member is going to be deprecated, so start
using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in
the kernel.
The first thing to start with is the pid, printed to dmesg - in
this case we may safely use task_pid_nr(). Besides, printks produce
more (much more) than a half of all the explicit pid usage.
[akpm@linux-foundation.org: git-drm went and changed lots of stuff]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Airlie <airlied@linux.ie>
Move <linux/usb_gadget.h> to <linux/usb/gadget.h>, reducing
some of the clutter in the main include directory.
This patch (as983) makes a test for minimum-length command sizes in
g_file_storage less restrictive. It doesn't matter because commands
with bad lengths will be detected later on anyway, and doing it like
this makes the driver interoperable with certain buggy hosts such as
the JVC HiFi (reported by Samuel Hangouet).
