path: root/drivers/usb/gadget/fsl_usb2_udc.h
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: gadget code switches to pr_err() and friendsDavid Brownell
We now have pr_err(), pr_warning(), and friends ... start using them in the gadget stack instead of printk(KERN_ERR) and friends. This gives us shorter lines and somewhat increased readability. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: fsl_usb2_udc: Get max ep number from DCCPARAMS registerLi Yang
Currently the driver is expecting max ep number in platform data which isn't passing this information. This patch fix the problem by reading it from DCCPARAMS(Device Controller Capability Parameters) register. The change also need some reordering of the probe code. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: add Freescale high-speed USB SOC device controller driverLi Yang
Freescale high-speed USB SOC can be found on some Freescale processors among different architectures. It supports both host and device functions. This driver adds its device support for Linux USB Gadget layer. It is tested on MPC8349 and MPC8313, but should work on other platforms with minor tweaks. The driver passed USBCV 1.3 compliance tests. Note that this driver doesn't yet include OTG support. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jiang Bo <tanya.jiang@freescale.com> Signed-off-by: Bruce Schmid <duck@freescale.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
