The drivers/usb/gadget directory contains many files.
Files which are related can be distributed into separate directories.
This patch moves the UDC drivers into a separate directory.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Add clock prepare and unprepare as required by clock framework.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
This patch adds "maxpacket_limit" to struct usb_ep. This field contains
maximum value of maxpacket supported by driver, and is set in driver probe.
This value should be used by autoconfig() function, because value of field
"maxpacket" is set to value from endpoint descriptor when endpoint becomes
enabled. So when autoconfig() function will be called again for this endpoint,
"maxpacket" value will contain wMaxPacketSize from descriptior instead of
maximum packet size for this endpoint.
For this reason this patch adds new field "maxpacket_limit" which contains
value of maximum packet size (which defines maximum endpoint capabilities).
This value is used in ep_matches() function used by autoconfig().
Value of "maxpacket_limit" should be set in UDC driver probe function, using
usb_ep_set_maxpacket_limit() function, defined in gadget.h. This function
set choosen value to both "maxpacket_limit" and "maxpacket" fields.
This patch modifies UDC drivers by adding support for maxpacket_limit.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Remove all section annotations to fix the
following section mismatches:
>> WARNING: drivers/usb/gadget/pxa27x_udc.o(.text+0x597c): Section mismatch in
reference from the function .pxa_udc_probe() to the function
.init.text:.udc_init_data.constprop.11()
The function .pxa_udc_probe() references
the function __init .udc_init_data.constprop.11().
This is often because .pxa_udc_probe lacks a __init
annotation or the annotation of .udc_init_data.constprop.11 is wrong.
>> WARNING: drivers/usb/gadget/pxa27x_udc.o(.text+0x5a04): Section mismatch in
.init.text:.pxa_ep_setup()
the function __init .pxa_ep_setup().
annotation or the annotation of .pxa_ep_setup is wrong.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
udc-core now handles that for us, which means
we can remove it from our driver.
udc-core now sets dma-related and parent fields
for us, we don't need to do it ourselves.
just removing some boilerplate code.
This driver can compile in any arch quite
easily by just removing a few headers and
dropping cpu_is_* check from module_init.
We don't need the ->register_my_device flag
anymore because all UDC drivers have been
properly converted.
Let's remove every history of it.
By simply setting a flag, we can drop some
boilerplate code.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Whenever ->udc_start() gets called, gadget driver
has already being bound to the udc controller, which
means that gadget->dev had to be already initialized
and added to driver model.
This patch fixes pxa27x mistake.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Mechanical change making use of the new (can we
still call it new ?) interface for registering
UDC drivers.
Pull ARM soc multiplatform enablement from Olof Johansson:
"This is a pretty significant branch. It's the introduction of the
first multiplatform support on ARM, and with this (and the later
branch) merged, it is now possible to build one kernel that contains
support for highbank, vexpress, mvebu, socfpga, and picoxcell. More
platforms will be convered over in the next few releases.
Two critical last things had to be done for this to be practical and
possible:
* Today each platform has its own include directory under
mach-<mach>/include/mach/*, and traditionally that is where a lot
of driver/platform shared definitions have gone, such as platform
data structures. They now need to move out to a common location
instead, and this branch moves a large number of those out to
include/linux/platform_data.
* Each platform used to list the device trees to compile for its
boards in mach-<mach>/Makefile.boot.
Both of the above changes will mean that there are some merge
conflicts to come (and some to resolve here). It's a one-time move
and once it settles in, we should be good for quite a while. Sorry
for the overhead."
Fix conflicts as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits)
ARM: add v7 multi-platform defconfig
ARM: msm: Move core.h contents into common.h
ARM: highbank: call highbank_pm_init from .init_machine
ARM: dtb: move all dtb targets to common Makefile
ARM: spear: move platform_data definitions
ARM: samsung: move platform_data definitions
ARM: orion: move platform_data definitions
ARM: vexpress: convert to multi-platform
ARM: initial multiplatform support
ARM: mvebu: move armada-370-xp.h in mach dir
ARM: vexpress: remove dependency on mach/* headers
ARM: picoxcell: remove dependency on mach/* headers
ARM: move all dtb targets out of Makefile.boot
ARM: picoxcell: move debug macros to include/debug
ARM: socfpga: move debug macros to include/debug
ARM: mvebu: move debug macros to include/debug
ARM: vexpress: move debug macros to include/debug
ARM: highbank: move debug macros to include/debug
ARM: move debug macros to common location
ARM: make mach/gpio.h headers optional
IRQ_USB was implicitly included by gpio.h. Use the existing variable
instead of IRQ_USB.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
This patch removes the global variable composite in composite.c.
The private data which was saved there is now passed via an additional
argument to the bind() function in struct usb_gadget_driver.
Only the "old-style" UDC drivers have to be touched here, new style are
doing it right because this change is made in udc-core.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
usb_get_phy will return -ENODEV if it's not able to find the phy. Hence
fixed all the callers of usb_get_phy to check for this error condition
instead of relying on a non-zero value as success condition.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Add a linked list for keeping multiple PHY instances with different
types so that we can have separate USB2 and USB3 PHYs on one single
board. _get_phy_ has been changed so that the controller gets
the transceiver by type. _remove_phy_ has been added to let the phy
be removed from the phy list.
_transceiver() in otg.c is replaced with _phy. usb_set_transceiver is
replaced with usb_add_phy to make it similar to other usb standard
function names like usb_add_hcd.
This changes the otg functions so that they receive struct
otg instead of struct usb_phy as parameter and
converts all users of these functions to pass the otg member
of their usb_phy.
Includes fixes to IMX code from Sascha Hauer.
[ balbi@ti.com : fixed a compile warning on ehci-mv.c ]
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Acked-by: Li Yang <leoli@freescale.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Use the new usb_phy_* functions with transceiver
operations instead of the old otg functions.
Includes fixes from Sascha Hauer.
This commit renames the “speed” field of the usb_gadget_driver
structure to “max_speed”. This is so that to make it more
apparent that the field represents the maximum speed gadget
driver can support.
This also make the field look more like fields with the same
name in usb_gadget and usb_composite_driver structures. All
of those represent the *maximal* speed given entity supports.
After this commit, there are the following fields in various
structures:
* usb_gadget::speed - the current connection speed,
* usb_gadget::max_speed - maximal speed UDC supports,
* usb_gadget_driver::max_speed - maximal speed gadget driver
supports, and
* usb_composite_driver::max_speed - maximal speed composite
gadget supports.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
remove the following two paragraphs as they are not needed:
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public
License for more details.
You should have received a copy of the GNU General Public License along with
this program; if not, write to the Free Software Foundation, Inc.,59
Temple Place - Suite 330, Boston, MA 02111-1307, USA.
Signed-off-by: Klaus Schwarzkopf <schwarzkopf@sensortherm.de>
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
peripheral drivers are using usb_add_gadget()/usb_del_gadget() to
register/unregister to the udc-core.
The udc-core will take the first available gadget driver and attach
function driver which is calling usb_gadget_register_driver(). This is
the same behaviour we have right now.
Only dummy_hcd was tested, the others were compiled tested.
Cc: Anton Tikhomirov <av.tikhomirov@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Dan Carpenter <error27@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Cc: Roy Huang <roy.huang@analog.com>
Cc: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Yuan-Hsin Chen <yhchen@faraday-tech.com>
Cc: cxie4 <cxie4@marvell.com>
Cc: linux-geode@lists.infradead.org
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
To accomplish this the function to register a gadget driver takes the bind
function as a second argument. To make things clearer rename the function
to resemble platform_driver_probe.
This fixes many section mismatches like
WARNING: drivers/usb/gadget/g_printer.o(.data+0xc): Section mismatch in
reference from the variable printer_driver to the function
.init.text:printer_bind()
The variable printer_driver references
the function __init printer_bind()
All callers are fixed.
[m.nazarewicz@samsung.com: added dbgp]
Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com>
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
Reported-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
As reported by Antonio, there are cases where the ep->lock
can be taken twice, triggering a deadlock.
The typical sequence is :
irq_handler
-> gadget.complete()
-> pxa27x_udc.pxa_ep_queue() : ep->lock is taken
==> *deadlock*
The patch fixes this by :
- releasing the lock each time gadget.complete() is called
- adding a check in handle_ep() to detect a recursive call,
in which case the function becomes on no-op.
The patch is still not good enough for ep0. For this unique
endpoint, another well thought over patch will be needed.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Use resource_size().
hardware reports wrong interrupt. Although such a situation should not
happen, the compiler complains about this access.
This patch adds a sanity check and generates warning to detect such
issues.
Signed-off-by: Enrico Scholz <enrico.scholz@sigma-chemnitz.de>
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Since the PXA 27x UDC automatically ACK's some control
packets such as SET_INTERFACE, the gadgets may not get a
chance to process the request before another control packet
is received. The Linux gadgets do not expect to receive
setup callbacks out of order. The file storage gadget only
saves the "highest" priority request.
The PXA27x UDC driver must make sure it only sends one up at
a time, allowing the gadget to make changes before
continuing. In theory, the host would be NACK'd while the
gadget processes the change but the UDC has already ACK'd
the request. If another request is sent by the host that is
not automatically ACK'd by the UDC, then the throttling
happens properly to regain sync.
The observed case was the file_storage gadget timing out on
a BulkReset request because the SET_INTERFACE was being
processed by the gadget. Since SET_INTERFACE is higher
priority than BulkReset, the BulkReset was dropped. This
was exacerbated by turning on the debug which delayed the
fsg signal processing thread.
This also fixes the "should never get in
WAIT_ACK_SET_CONF_INTERF state here!!!" warning.
Reported-by: Vernon Sauder <vernoninhand@gmail.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
index 51790b0..1937d8c 100644
Got pxa27x_udc working on the pxa320 Nomad platform. The
problem was that the pxa3xx UDC is not quite compatible with
the pxa27x UDC in how it handles back-to-back control
packets. The pxa27x probably drops them by default, but the
pxa320 does not, and you have to detect it and set the OPC
bit to clear the zero-length packet.
Signed-off-by: Aric Blumer <aric@sdgsystems.com>
Follow pxa27x change in OTGPH handling, and use the newly
defined pxa27x_clear_otgph().
Acked-by: Eric Miao <eric.miao@marvell.com>
This patch is a merge of patches :
- fix function doc and debug
- cleanup loop count
- optimize code to remove local variable and extra check
- init 'req' before use
- add missing iounmap call
[dbrownell@users.sourceforge.net: capitalize IN/OUT directions in doc]
Signed-off-by: Vernon Sauder <vsauder@inhand.com>
[folded by Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
priv is checked not to be NULL near the beginning of the function and not
changed subsequently, making the test redundant.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
// </smpl>
Add the vbus_draw() callback to inform the transceiver, if
it exists, how much current may be drawn. The decision is
taken on gadget driver side using the configuration chosen
by the host and its bMaxPower field. Some systems can use
the host's VBUS supply to augment or recharge a battery.
(There's also a default of 100 mA for unconfigured devices,
or 8 mA if they're OTG devices.)
When a transceiver driver is used, no automatic udc enable
is done. The transceiver (OTG or not) should :
- take care of VBus sensing
- call usb_gadget_vbus_connect()
- call usb_gadget_vbus_disconnect()
The pullup should remain within this driver's management,
either by gpio_pullup of udc_command() fields.
On vbus_session() call, optionally activate D+ pullup
resistor and enable the udc, or deactivate D+ pullup
resistor and disable the udc.
It is intentional to not handle any VBus sense related irq.
An external transceiver driver (like gpio_vbus) should
catch VBus sense signal, and call usb_gadget_vbus_connect()
or usb_gadget_vbus_disconnect().
Prepare pxa27x_udc to handle usb D+ pullup properly : it
should connect the pullup resistor and disconnect it only
if no external transceiver is handling it.
[ dbrownell@users.sourceforge.net: kerneldoc and gpio fixes ]
no argument named @index in pio_irq_disable, and
no argument named @req in inc_ep_stats_bytes,
remove them.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Where devices only have one consumer, passing a consumer clock ID
has no real benefit. Remove it.
The request allocation code doesn't need to check if the
endpoint is not NULL, as the only caller in
include/linux/usb/gadget.h, usb_ep_alloc_request() needs the
endpoint pointer to have a correct value to trigger the
allocation code.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
