path: root/drivers/usb/gadget/serial.c
2009-03-24USB: replace uses of __constant_{endian}Harvey Harrison
The base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb gadget: USB_GADGET_VBUS_DRAW Kconfig optionDavid Brownell
Offer a "how much VBUS power to request" configuration option for USB gadgets that aren't using board-specific customization of their gadget or (composite) configuration drivers. Also remove a couple pointless "depends on USB_GADGET" bits from the Kconfig text; booleans inside an "if USB_GADGET" will already have that dependency. Based on a patch from Justin Clacherty. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Justin Clacherty <justin@redfish-group.com> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17usb gadget: cdc obex glueFelipe Balbi
The following patch introduces a new f_obex.c function driver. It allows userspace obex servers to use usb as transport layer for their messages. [ dbrownell@users.sourceforge.net: various fixes and cleanups ] Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16usb gadget: link fixes for serial gadgetDavid Brownell
Change how the serial gadget driver builds: don't use separate compilation, since it works poorly when key parts are library code (with init sections etc). Instead be as close as we can to "gcc --combine ...". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget serial: use composite gadget frameworkDavid Brownell
This switches the serial gadget over to using the new "function" versions of the serial port interfacing code. The remaining code in the main source file is quite small... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: use new serial coreDavid Brownell
Teach "gadget serial" to use the new abstracted (and bugfixed) TTY glue, and remove all the orignal tangled-up code. Update the documentation accordingly. This is a net object code shrink and cleanup; it should make it a lot easier to see how the TTY glue should accomodate updates to the TTY layer, be bugfixed, etc. Notable behavior changes include: it can now support getty even when there's no USB connection; it fits properly into the mdev/udev world; and RX handling is better (throttling works, and low latency). Configurations with scripts setting up the /dev/ttygserial device node (with "experimental" major number) may want to change that to be a symlink pointing to the /dev/ttyGS0 file, as a migration aid; else, just switch entirely over to mdev/udev. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: serial gadget: descriptor cleanupDavid Brownell
Bugfix some serial gadget descriptors: - Stop mangling the low bits (controller type ID) of bcdDevice; just use the high bits for a driver revision code. - Serial numbers that aren't specific to individual devices are useless; stop reporting "0" for this. - Since it's not part of a CDC-conformant function, the "bulk only" configuration shouldn't be using "CDC Data" as its interface class. Switch over to using CLASS_VENDOR_SPEC (different value, 0xff). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: serial gadget: simplify endpoint handlingDavid Brownell
Switch serial gadget away from a *very* old idiom: just remember the endpoints we'll be using, instead of looking them up by name each time. This is a net code and data (globals) shrink. Also fix a small memory leak in the rmmod path, by working the same as the disconnect code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: serial gadget: remove needless data structureDavid Brownell
This removes a needless data structure from the serial gadget code; it's a small code shrink, and a larger data shrink. Since "struct usb_request" already has a "struct list_head" reserved for use by gadget drivers, the serial gadget code doesn't need to allocate wrapper structs to hold that list ... it can (and should!) just use the list_head provided for that exact use. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: serial gadget: cleanup/reorgDavid Brownell
Some cleanup/reorg of g_serial ... simplifying it, and disentangling its structure so morphing it into a "function" driver (combinable with other interfaces) should be less painful. - Remove most forward declarations * put tty and gadget driver structs after their contents * snug module init/exit decls next to their functions * reordered some functions - Other cleanup: * convert a funky macro to an inline function * snug up module params next to their declarations * add missing driver.owner * add separator lines between major driver sections - Add comments re potential parameter/#define changes: * only supports one port (shrank GS_NUM_PORTS) * changing from 9600-8-N-1 affects multiple sites - Remove net2280-specific optimization ... it was being done way too late, can be done by net2280 module options, and in any case doesn't matter at any sane serial data rates. There are no behavioral changes, but the macro thing saves I-space. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02usb serial gadget: CDC ACM fixesDavid Brownell
Based on a patch from <Aurel.Thomi@ruag.com>, this makes the CDC-ACM support in the serial gadget handle the SET_LINE_CODING and SET_CONTROL_LINE_STATE requests ... which should improve interop with at least MS-Windows "usbser.sys" if not some other ACM host drivers. It also adds a few REVISIT comments where this code plays a bit loose with the CDC ACM spec. If this were used to hook up to a real RS232 or modem link, those places would need a bit of work. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-30usb gadget: switch to put_char returning intAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: gadget: Hangup tty on g_serial disconnectSavin Zlobec
On USB cable disconnect g_serial doesn't hangup the port tty, which results in an endless read on the tty device. With the following patch the read and select behave correctly when the cable is unplugged. Tested on at91rm9200 Signed-off-by: Savin Zlobec <savin@epiko.si> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: gadget code switches to pr_err() and friendsDavid Brownell
We now have pr_err(), pr_warning(), and friends ... start using them in the gadget stack instead of printk(KERN_ERR) and friends. This gives us shorter lines and somewhat increased readability. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: move <linux/usb_gadget.h> to <linux/usb/gadget.h>David Brownell
Move <linux/usb_gadget.h> to <linux/usb/gadget.h>, reducing some of the clutter in the main include directory. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: serial gadget: Disable endpoints on unloadVitaly Bordug
After Serial gadget is being unloaded, neither serial itself, nor other gadget stuff can be loaded subsequently. Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: gadget: serial gadget cleanupsDavid Brownell
Clean up the serial gadget, using newer APIs and conventions: - gadget_is_dualspeed() and gadget_is_otg() ... #ifdef removal - Remove many now-needless #includes - Use the DEBUG and VERBOSE_DEBUG conventions; turned up a bug in the original debug messaging - Various whitespace fixes. This gave only a minor object code shrinkage, but the source looks much cleaner in various places. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Al Borchers <alborchers@steinerpoint.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: fix serial gadget ACM breakageDavid Brownell
Two of the CDC ACM control requests in the serial gadget have never been correct, and have been reported to cause serious troubles ... as in, soft lockup and maybe watchdog reset (depending on hardware). This patch makes those request fail cleanly, rather than misbehaving. Someone using CDC ACM should fix them according to the FIXME comments which now replace the previous bugs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: use mutex instead of semaphore in the USB gadget serial driverMatthias Kaehlcke
The USB gadget serial driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-12USB: usb serial gadget, sparse fixesDavid Brownell
Fix a few serial gadget issues reported by the latest "sparse": some functions should have been defined as static, not just declared that way. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: fix g_serial small errorBryan O'Donoghue
A SET_LINE_CODING control request should return a zero length packet as an ACK to the host, during the status phase of a USB transaction. The return value of gs_setup_class() is treated as the number of bytes to write in the status phase of the control request, by gs_setup(). For this case, the value returned by gs_setup_class should be zero for SET_LINE_CODING but, right now, appears to be sizeof(struct usb_cdc_line_coding). However, if after doing the memcpy of the line coding descriptor we set the variable "ret" to be zero, we should return the appropiate ZLP to the host as an ACK in the status phase of the control request. I've tested this out using Linux as both host and slave and confirmed that the following small change fixes the spurious return of sizeof(struct usb_cdc_line_coding)/wLength bytes in the status phase of a USB_CDC_REQ_SET_LINE_CODING request. It's not a huge bug but, it is worth fixing. Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: <linux/usb_ch9.h> becomes <linux/usb/ch9.h>David Brownell
This moves <linux/usb_ch9.h> to <linux/usb/ch9.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: gadget driver unbind() is optional; section fixes; miscDavid Brownell
Allow gadget drivers to omit the unbind() method. When they're statically linked, that's an appropriate memory saving tweak. Similarly, provide consistent/simpler handling for a should-not-happen error case: removing a peripheral controller driver when a gadget driver is still loaded. Such code dates back to early versions of the first implementation of the gadget API, and has never been triggered. Includes relevant section annotation fixs for gmidi.c, file_storage.c, and serial.c; we don't yet have an "init or exit" annotation. Also some whitespace fixes in gmidi.c (space at EOL, before tabs, etc). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27USB: usb serial gadget smp related bugEugeny S. Mints
Adjust dev->dev_lock spinlock lock/unlock calls to be safe for SMP case. Otherwise the following sequence may lead to a deadlock in SMP case: gs_send()->usb_ep_queue() ->(in case a request is satisfied immediatly) gs_write_complete() for ex for pxa2xx_udc.c: usb_ep_queue()->pxa2xx_ep_queue()->write_fifo()->done()->gs_write_complete() (through req.complete pointer) Signed-off-by: Eugeny S. Mints <emints@ru.mvista.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: gadget section fixupsDavid Brownell
Recent section changes broke gadget builds on some platforms. This patch is the best fix that's available until better section markings exist: - There's a lot of cleanup code that gets used in both init and exit paths; stop marking it as "__exit". (Best fix for this would be an "__init_or_exit" section marking, putting the cleanup in __init when __exit sections get discarded else in __exit.) - Stop marking the use-once probe routines as "__init" since references to those routines are not allowed from driver structures. They're now marked "__devinit", which in practice is a net lose. (Best fix for this is likely to separate such use-once probe routines from the driver structure ... but in general, all busses that aren't hotpluggable will be forced to waste memory for all probe-only code.) In general these broken section rules waste an average of two to four kBytes per driver of code bloat ... because none of the relevant code can ever be reused after module initialization. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move <linux/usb_cdc.h> to <linux/usb/cdc.h>David Brownell
This moves <linux/usb_cdc.h> to <linux/usb/cdc.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: gadget-serial: do not save/restore IRQ flags in gs_close()Franck Bui-Huu
As pointed out by David Brownell, we know that IRQs are never blocked when calling gs_close function. So the save/restore IRQ flags are pointless. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: gadget-serial: fix a deadlock when closing the serial deviceFranck Bui-Huu
When closing the device, the driver acquires/release twice the port lock before/after waiting for the data to be completely sent. Therefore it will dead lock. This patch fixes it and also uses the generic scheduler services for waiting for an event. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: kzalloc() conversion in drivers/usb/gadgetEric Sesterhenn
this patch converts drivers/usb to kzalloc usage. Compile tested with allyes config. I think there was a bug in drivers/usb/gadget/inode.c because it used sizeof(*data) for the kmalloc() and sizeof(data) for the memset(), since sizeof(data) just returns the size for a pointer. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: gadget driver section fixupsDavid Brownell
This adds __init section annotations to gadget driver bind() routines to remove calls from .text into .init sections (for endpoint autoconfig). Likewise it adds __exit section annotations to their unbind() routines. The specification of the gadget driver register/unregister functions is updated to explicitly allow use of those sections. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] Remove usb gadget generic driver methodsRussell King
USB gadget drivers make no use of these, remove the pointless comments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] USB: One potential problem in gadget/serial.cFengwei Yin
It looks like that the gs_serial module maybe sleep with spinlock in gs_close. Sometimes, system hang when I remove the gs_serial module. From: Fengwei Yin <xaityyy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-09-08[PATCH] USB: Gadget library: centralize gadget controller numbersDavid Brownell
This patch centralizes the assignment of bcdDevice numbers for different gadget controllers. This won't improve the object code at all, but it does save a lot of repetitive and error-prone source code ... and will simplify the work of supporting a new controller driver, since most new gadget drivers will no longer need patches (unless some hardware quirks limit USB protocol messaging). Added minor cleanups and identifer hooks for the UDC in the Freescale iMX series processors. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: gadget driver updates (SETUP api change)David Brownell
This updates most of the gadget framework to expect SETUP packets use USB byteorder (matching the annotation in <linux/usb_ch9.h> and usage in the host side stack): - definition in <linux/usb_gadget.h> - gadget drivers: Ethernet/RNDIS, serial/ACM, file_storage, gadgetfs. - dummy_hcd It also includes some other similar changes as suggested by "sparse", which was used to detect byteorder bugs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] USB: Spelling fixes for drivers/usb.Steven Cole
Here are some spelling corrections for drivers/usb. cancelation -> cancellation succesful -> successful cancelation -> cancellation decriptor -> descriptor Initalize -> Initialize wierd -> weird Protocoll -> Protocol occured -> occurred successfull -> successful Procesing -> Processing devide -> divide Isochronuous -> Isochronous noticable -> noticeable Basicly -> Basically transfering -> transferring intialize -> initialize Incomming -> Incoming additionnal -> additional asume -> assume Unfortunatly -> Unfortunately retreive -> retrieve tranceiver -> transceiver Compatiblity -> Compatibility Incorprated -> Incorporated existance -> existence Ununsual -> Unusual Signed-off-by: Steven Cole <elenstev@mesatop.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] USB: kfree cleanup for drivers/usb/* - no need to check for NULLJesper Juhl
Get rid of a bunch of redundant NULL pointer checks in drivers/usb/*, there's no need to check a pointer for NULL before calling kfree() on it. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/drivers/usb/class/audio.c ===================================================================
