After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
git://git.kernel.org/pub/scm/linux/kernel/git/sarah/xhci into usb-next
Sarah writes:
xhci: Platform updates, 64-bit DMA, and trace events for 3.12.
Hi Greg,
This pull request includes one new feature for the xhci-plat driver (device
tree support). Felipe was fine with the patch last I checked, but hadn't
provided an official Acked-by line.
This pull request also includes 13 patches from my FOSS Outreach Program for
Women (OPW) intern, Xenia. She fixed a bug in the xHCI driver so that the
driver can allocate 64-bit consistent DMA, converted the driver to use dynamic
debugging, and added a bunch of new trace events for the xHCI driver. The
python plugin for trace-cmd should be up on git hub shortly, although the trace
events are usable without it.
I'm very happy with the progress that Xenia has made, and I look forward to her
future contributions to the Linux kernel.
Sarah Sharp
commit 9841f37a1c ("usb: ehci: Add support for SINGLE_STEP_SET_FEATURE
test of EHSET") added additional code to the EHCI hub driver but it is
anticipated to only have a limited audience (e.g. embedded silicon
vendors and integrators). Avoid subjecting all EHCI (and in the future
maybe xHCI/OHCI, etc.) HCD users to code bloat by conditionally
compiling the EHSET-specific additions with a new Kconfig option,
CONFIG_USB_HCD_TEST_MODE.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
CONFIG_USB_XHCI_HCD_DEBUGGING option is used to enable
verbose debugging output for the xHCI host controller
driver.
In the current version of the xhci-hcd driver, this
option must be turned on, in order for the debugging
log messages to be displayed, and users may need to
recompile the linux kernel to obtain debugging
information that will help them track down problems.
This patch removes the above debug option to enable
debugging log messages at all times.
The aim of this is to rely on the debugfs and the
dynamic debugging feature for fine-grained management
of debugging messages and to not force users to set
the debug config option and compile the linux kernel
in order to have access in that information.
This patch, also, removes the XHCI_DEBUG symbol and the
functions dma_to_stream_ring(), xhci_test_radix_tree()
and xhci_event_ring_work() that are not useful anymore.
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v3.12 merge window
All patches here have been pending on linux-usb
and sitting in linux-next for a while now.
The biggest things in this tag are:
DWC3 learned proper usage of threaded IRQ
handlers and now we spend very little time
in hardirq context.
MUSB now has proper support for BeagleBone and
Beaglebone Black.
Tegra's USB support also got quite a bit of love
and is learning to use PHY layer and generic DT
attributes.
Other than that, the usual pack of cleanups and
non-critical fixes follow.
Signed-of-by: Felipe Balbi <balbi@ti.com>
drivers/usb/gadget/udc-core.c
drivers/usb/host/ehci-tegra.c
drivers/usb/musb/omap2430.c
drivers/usb/musb/tusb6010.c
When CONFIG_USB_SUPPORT is not selected we get things like:
scripts/kconfig/mconf Kconfig
warning: (MIPS_SEAD3 && PMC_MSP && CPU_CAVIUM_OCTEON) selects USB_EHCI_BIG_ENDIAN_MMIO which has unmet direct dependencies (USB_SUPPORT && USB)
It is much cleaner to make the various system Kconfigs select
USB_EHCI_BIG_ENDIAN_MMIO rather than move the system config
information into USB's Kconfig, but the warnings are annoying.
Eliminate the warning by moving the definition of
USB_EHCI_BIG_ENDIAN_MMIO outside of all the Kconfig if statements.
While we are at it move USB_OHCI_BIG_ENDIAN_DESC,
USB_OHCI_BIG_ENDIAN_MMIO, USB_OHCI_LITTLE_ENDIAN and
USB_EHCI_BIG_ENDIAN_DESC too, as they could very well suffer similar
problems for other systems.
Get rid of the redundant "default n" in USB_OHCI_BIG_ENDIAN_DESC and
Signed-off-by: David Daney <david.daney@cavium.com>
FOTG210 is an OTG controller which can be configured as an
USB2.0 host. FOTG210 host is an ehci-like controller with
some differences. First, register layout of FOTG210 is
incompatible with EHCI. Furthermore, FOTG210 is lack of
siTDs which means iTDs are used for both HS and FS ISO
transfer.
Signed-off-by: Feng-Hsin Chiang <john453@faraday-tech.com>
ehci-omap needs NOP_USB_XCEIV PHY driver to function
properly, so select it. As the USB PHY drivers no longer
depend on USB_PHY, it is safe to select the PHY drivers.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Tested-by: Adrien Vergé <adrienverge@gmail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Convert PHY Drivers from menuconfig to menu so that the PHY drivers
can be explicitely selected by the controller drivers.
USB_PHY is no longer a user visible option. It is upto to the PHY
drivers to select it if needed. This patch does so for the existing
PHY drivers that use the USB_PHY library.
Doing so moves the USB_PHY and PHY driver selection problem from the
end user to the PHY and controller driver developer.
e.g.
Earlier, a controller driver (e.g. EHCI_OMAP) that needs to select
a PHY driver (e.g. NOP_PHY) couldn't do so because the PHY driver
depended on USB_PHY. Making the controller driver depend on USB_PHY
has a negative effect i.e. it becomes invisible to the user till
USB_PHY is enabled. Most end users will not familiar with this.
With this patch, the end user just needs to select the controller driver
needed for his/her platform without worrying about which PHY driver to
select.
Also update USB_EHCI_MSM, USB_LPC32XX and USB_OMAP to not depend
on USB_PHY any more. They can safely select the necessary PHY drivers.
[ balbi@ti.com : refreshed on top of my next branch. Changed bool
followed by default n into def_bool n ]
CC: Pavankumar Kondeti <pkondeti@codeaurora.org>
Acked-by: Roland Stigge <stigge@antcom.de>
This reverts commit 1dd3d123239179fad5de5dc00a6e0014a1918fde.
The email address for the developer now bounces, which means they have
moved on, so remove the driver until someone else from the company steps
up to maintain it.
transfer.
Signed-off-by: Yuan-Hsin Chen <yhchen@faraday-tech.com>
Pull MIPS updates from Ralf Baechle:
"MIPS updates:
- All the things that didn't make 3.10.
- Removes the Windriver PPMC platform. Nobody will miss it.
- Remove a workaround from kernel/irq/irqdomain.c which was there
exclusivly for MIPS. Patch by Grant Likely.
- More small improvments for the SEAD 3 platform
- Improvments on the BMIPS / SMP support for the BCM63xx series.
- Various cleanups of dead leftovers.
- Platform support for the Cavium Octeon-based EdgeRouter Lite.
Two large KVM patchsets didn't make it for this pull request because
their respective authors are vacationing"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits)
MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER
MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions
MIPS: SEAD3: Disable L2 cache on SEAD-3.
MIPS: BCM63xx: Enable second core SMP on BCM6328 if available
MIPS: BCM63xx: Add SMP support to prom.c
MIPS: define write{b,w,l,q}_relaxed
MIPS: Expose missing pci_io{map,unmap} declarations
MIPS: Malta: Update GCMP detection.
Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET"
MIPS: APSP: Remove <asm/kspd.h>
SSB: Kconfig: Amend SSB_EMBEDDED dependencies
MIPS: microMIPS: Fix improper definition of ISA exception bit.
MIPS: Don't try to decode microMIPS branch instructions where they cannot exist.
MIPS: Declare emulate_load_store_microMIPS as a static function.
MIPS: Fix typos and cleanup comment
MIPS: Cleanup indentation and whitespace
MIPS: BMIPS: support booting from physical CPU other than 0
MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS
MIPS: GIC: Fix gic_set_affinity infinite loop
MIPS: Don't save/restore OCTEON wide multiplier state on syscalls.
Pull ARM SoC specific changes from Arnd Bergmann:
"These changes are all to SoC-specific code, a total of 33 branches on
17 platforms were pulled into this. Like last time, Renesas sh-mobile
is now the platform with the most changes, followed by OMAP and
EXYNOS.
Two new platforms, TI Keystone and Rockchips RK3xxx are added in this
branch, both containing almost no platform specific code at all, since
they are using generic subsystem interfaces for clocks, pinctrl,
interrupts etc. The device drivers are getting merged through the
respective subsystem maintainer trees.
One more SoC (u300) is now multiplatform capable and several others
(shmobile, exynos, msm, integrator, kirkwood, clps711x) are moving
towards that goal with this series but need more work.
Also noteworthy is the work on PCI here, which is traditionally part
of the SoC specific code. With the changes done by Thomas Petazzoni,
we can now more easily have PCI host controller drivers as loadable
modules and keep them separate from the platform code in
drivers/pci/host. This has already led to the discovery that three
platforms (exynos, spear and imx) are actually using an identical PCIe
host controller and will be able to share a driver once support for
spear and imx is added."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (480 commits)
ARM: integrator: let pciv3 use mem/premem from device tree
ARM: integrator: set local side PCI addresses right
ARM: dts: Add pcie controller node for exynos5440-ssdk5440
ARM: dts: Add pcie controller node for Samsung EXYNOS5440 SoC
ARM: EXYNOS: Enable PCIe support for Exynos5440
pci: Add PCIe driver for Samsung Exynos
ARM: OMAP5: voltagedomain data: remove temporary OMAP4 voltage data
ARM: keystone: Move CPU bringup code to dedicated asm file
ARM: multiplatform: always pick one CPU type
ARM: imx: select syscon for IMX6SL
ARM: keystone: select ARM_ERRATA_798181 only for SMP
ARM: imx: Synertronixx scb9328 needs to select SOC_IMX1
ARM: OMAP2+: AM43x: resolve SMP related build error
dmaengine: edma: enable build for AM33XX
ARM: edma: Add EDMA crossbar event mux support
ARM: edma: Add DT and runtime PM support to the private EDMA API
dmaengine: edma: Add TI EDMA device tree binding
arm: add basic support for Rockchip RK3066a boards
arm: add debug uarts for rockchip rk29xx and rk3xxx series
arm: Add basic clocks for Rockchip rk3066a SoCs
ARCH_EXYNOS is going to be excluded from PLAT_S5P, so it must be checked
separately in Exynos-related Kconfig entries.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Separate the Tegra on-chip host controller driver from
ehci-hcd host code so that it can be built as a separate driver module.
This work is part of enabling multi-platform kernels on ARM.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
[swarren, reworked Manjunath's patches to split them more logically,
minor re-order of added lines to better match layout of other split-up
HCD drivers and existing code, add MODULE_DEVICE_TABLE, fix
MODULE_LICENSE, adapted to change in earlier patches which removed the
ehci_driver_overrides addition, removed all PM code and solved circular
dependencies.]
Tested-by: Thierry Reding <thierry.reding@gmail.com>
CAVIUM_OCTEON_SOC most place we used to use CPU_CAVIUM_OCTEON. This
allows us to CPU_CAVIUM_OCTEON in places where we have no OCTEON SOC.
Remove CAVIUM_OCTEON_SIMULATOR as it doesn't really do anything, we can
get the same configuration with CAVIUM_OCTEON_SOC.
Cc: linux-mips@linux-mips.org
Cc: linux-ide@vger.kernel.org
Cc: linux-edac@vger.kernel.org
Cc: linux-i2c@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: spi-devel-general@lists.sourceforge.net
Cc: devel@driverdev.osuosl.org
Cc: linux-usb@vger.kernel.org
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Patchwork: https://patchwork.linux-mips.org/patch/5295/
The three options USB_ARCH_HAS_{EHCI,OHCI,XHCI} are all well beyond
their recommended shelf life. They have caused numerous build failures
over the years because they are never completely correct, and with
the move to splitting out the platform specific back-ends out of the
driver, there is no real need for them any more. Also, the use of making
USB_ARCH_HAS_HCD depend on it is questionable since one can always enable
dummy_hc these days.
This patch enables them unconditionally for all platforms and
architectures, which means it is now possible to build host controller
drivers for machines that are known not to come with this hardware,
but that is just how we treat most other drivers.
In order to minimise the impact on existing architecture code and
defconfig files, all the Kconfig are left present for now. All platforms
that currently do 'select USB_ARCH_HAS_*' should subsequently be changed
not to select that. All drivers depending on USB_ARCH_HAS_HCD should
be changed to depend on USB_SUPPORT instead.
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This patch splits the ohci-platform code from ohci-hcd out
into its own separate driver module.This work is part of enabling
In V2:
-Passed "hcd" argument instead of "ohci" in ohci_setup() because it is
using "struct usb_hcd" argument.
In V3:
-Directly passed "hcd" argument not required to call ohci_to_hcd() function.
This patch splits the PCI portion of ohci-hcd out into its
own separate driver module, called ohci-pci.
The major point of difficulty lies in ohci-pci's many vendor- and
device-specific workarounds. Some of them have to be applied before
calling ohci_start() some after, which necessitates a fair amount of
code motion. The other platform drivers require much smaller changes.
The complete sb800_prefetch() function moved to ohci-q.c,because its
only related to ohci-pci driver.
USB_OHCI_HCD_PCI symbol no longer dependence on STB03xxx, PPC_MPC52xx and
USB_OHCI_HCD_PPC_OF that's what removed.
V2:
- few specific content of pci related code in ohci_pci_start function has been moved to ohci_pci_reset
and rest of the generic code is written in ohci_start of ohci-hcd.c file.
V3:
- ohci_restart() has been called in ohci_pci_reset() function for to reset the ohci pci.
V4:
-sb800_prefetch() moved to ohci-q.c,because its only related to ohci-pci.
-no longer _creating_ CONFIG_USB_OHCI_PCI,creating CONFIG_USB_OHCI_HCD_PCI.
-overrides renamed with pci_override,its giving proper meaning.
V5:
-sb800_prefetch() moved to pci-quirks.c,because its only related to pci.
V6:
-sb800_prefetch() function has been moved to pci-quirks.c made as separate patch in 2/3.
-Most of the generic ohci pci changes moved in 2/3 patch,now this is complete ohci-pci separation patch.
V7:
-Unrelated include file has been removed from ohci.h file.
V8:
-USB_OHCI_HCD_PCI symbol does not dependence on STB03xxx, PPC_MPC52xx and USB_OHCI_HCD_PPC_OF.
We want these fixes.
FUSBH200-HCD is an USB2.0 hcd for Faraday FUSBH200.
FUSBH200 is an ehci-like controller with some differences.
First, register layout of FUSBH200 is incompatible with EHCI.
Furthermore, FUSBH200 is lack of siTDs which means iTDs
are used for both HS and FS ISO transfer.
The Kconfig settings for uhci-hcd are too permissive; they allow the
driver to be built without any bus-glue modules configured
(USB_UHCI_HCD enabled, PCI disabled, SPARC_LEON disabled, ARCH_VT8500
enabled, and USB_UHCI_PLATFORM disabled).
This patch fixes the problem by rearranging the dependencies. Now the
platform-dependent config options don't depend on USB_UHCI_HCD;
instead it depends on them. Furthermore, there is no user-selectable
choice as to which glue modules will be built. If USB_UHCI_HCD is
enabled then all applicable bus glues will be built.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Arnd Bergmann <arnd@arndb.de>
The Kconfig entry for USB_EHCI_MSM unconditionally selects USB_MSM_OTG,
which is now only visible when USB_PHY is also enabled.
This adds an appropriate dependency and enables USB_PHY in the msm
defconfig, avoiding the Kbuild warning:
warning: (USB_EHCI_MSM) selects USB_MSM_OTG which has unmet direct dependencies (USB_SUPPORT && USB_PHY && (USB || USB_GADGET) && ARCH_MSM)
Cc: Felipe Balbi <balbi@ti.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Don't select NOP_USB_XCEIV. Instead, board config
must select USB_PHY and the appropriate PHY driver.
Also add a hint in Kconfig so that users enabling
this driver manually enable the right PHY drivers as well.
Gets rid of the below warnings when USB_EHCI_HCD_OMAP
is enabled.
warning: (USB_EHCI_HCD_OMAP) selects NOP_USB_XCEIV which has unmet direct dependencies (USB_SUPPORT && USB_PHY)
This patch encloses all symbols depending on USB_XHCI_HCD within an if
USB_XHCI_HCD / endif block.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This patch removes the various depends on USB_OHCI_HCD from the OHCI HCD
drivers and enclose them within an if USB_OHCI_HCD / endif block. The
Octeon OHCI HCD driver has been moved around to remain in this block.
Thist patch removes the depends on USB_EHCI_HCD that the various USB
EHCI HCD drivers use and encloses every driver within an if USB_EHCI_HCD
/ endif block. The EHCI HCD platform and Octeon drivers have been moved
around to remain enclosed within this block.
Just like the OHCI counter part we just can remove the architecture
specific symbols which prevent these configuration symbols from being
selected by platforms/architectures requiring it. The original
implementation did not scale at all since it required each and every
single architecture to be added for these configuration symbols to be
selected. Now it is up to the EHCI driver and/or platform to select
these configuration symbols accordingly.
This patch removes the depends on USB from all config symbols in
drivers/usb/host/Kconfig and replace that with an if USB / endif block
as suggested by Alan Stern. Some source ... Kconfig lines have been
shuffled around to permit a better regroupment of the Kconfig files
depending on "config USB" item. No functionnal change is introduced.
Separate the Qualcomm QSD/MSM on-chip host controller driver from
This work is part of enabling multi-platform kernels on ARM;
however, note that other changes are still needed before Qualcomm QSD/MSM
can be booted with a multi-platform kernel, which is not expected before
3.11.
With the infrastructure added by Alan Stern in patch 3e0232039
"USB: EHCI: prepare to make ehci-hcd a library module", we can
avoid this problem by turning a bus glue into a separate
module, as we do here for the msm bus glue.
In V5 (arnd):
- add FIXME about missing usb_add_hcd() or usb_remove_hcd() calls
In V3:
- Detailed commit message added here describing why this patch is required.
- Arranged #include's in alphabetical order.
- driver.name initialized hcd_name[] = "ehci-msm" in platform_driver
structure initialization instead of "msm-ehci", which was the reason
why it broke in EHCI USB testing
In V2:
Tegra patch related changes removed from this patch.
Acked-by: David Brown <davidb@codeaurora.org>
Separate the Atmel host controller driver from ehci-hcd host code
however, note that other changes are still needed before Atmel can be
booted with a multi-platform kernel. This is currently planned for
Linux-3.11.
module, as we do here for the Atmel bus glue.
In V4 (arnd):
- reordered #include statements.
- removed call to ehci_shutdown and the corresponding export
In V3:
- Detailed commit message added here about why this patch is required.
- Replaced hcd_name string "ehci-atmel" to "atmel-ehci".
- Inserted blank line in the Makefile to separate the EHCI drivers from
the following non-EHCI drivers.
- Exported ehci_shutdown symbol as it is needed by the Atmel driver.
- Eliminated ehci_atmel_setup routine because hcd registers
can be directly set in the ehci_atmel_drv_probe function.
In V2:
Resolved below compiler error.
drivers/usb/host/ehci-atmel.c: In function 'ehci_atmel_drv_remove':
drivers/usb/host/ehci-atmel.c:167: error: implicit declaration of function 'ehci_shutdown'
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Separate the Samsung S5P/EXYNOS host controller driver from ehci-hcd
however, note that other changes are still needed before S5P/EXYNOS can
be booted with a multi-platform kernel. We currently expect those
to get merged for 3.10.
module, as we do here for the s5p bus glue.
In V4 (arnd)
- revert some of the pointless changes.
- fix allocation of s5p specific data structure.
In V3:
- Detailed commit message added here, why this patch is required.
- MODULE_LICENSE is GPL v2.
- Added .extra_priv_size to eliminate the separate allocation of
the s5p_ehci_hcd structure and removed .reset function pointer
initialization.
- After using extra_priv_size initialization, struct usb_hcd *hcd
is redundant and can be removed from the probe function.
- Eliminated s5p_ehci_phy_enable,contents of statements moved
into the s5p_ehci_probe
- Eliminated s5p_ehci_phy_disable, contents of statements moved into
the s5p_ehci_remove.
In V2:
- Tegra patch related changes removed from this patch.
Acked-by: Jingoo Han <jg1.han@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Separate the SPEAr host controller driver from ehci-hcd host code
however, note that other changes are still needed before SPEAr can be
booted with a multi-platform kernel, but they are queued in the
arm-soc tree for 3.10.
module, as we do here for the SPEAr bus glue.
In V4 (arnd):
- renamed all 'struct spear_ehci' pointers from 'ehci' to the
less ambiguous 'sehci'.
- folded trivial spear_start_ehci/spear_stop_ehci functions into
callers.
- brought back initialization of ehci->caps.
In V3:
- Eliminated ehci_spear_setup routine because hcd registers can
be directly set in the spear_ehci_hcd_drv_probe function.
- spear_overrides struct initialized.
- Converted to using .extra_priv_size for allocating spear_ehci,
and updated all users of that structure.
- to_spear_ehci() macro modified for spear_ehci.
In V2:
- Replaced spear as SPEAr everywhere, leaving functions/variables/config options.
Signed-off-by: Deepak Saxena <dsaxena@linaro.org>
Acked-by: Viresh Kumar <viresh.linux@gmail.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: spear-devel@list.st.com
Separate the Orion host controller driver from ehci-hcd host
code into its own driver module because of following reason.
With the multiplatform changes in arm-soc tree, it becomes
possible to enable the mvebu platform (which uses
ehci-orion) at the same time as other platforms that require
a conflicting EHCI bus glue. At the moment, this results
in a warning like
drivers/usb/host/ehci-hcd.c:1297:0: warning: "PLATFORM_DRIVER" redefined [enabled by default]
drivers/usb/host/ehci-hcd.c:1277:0: note: this is the location of the previous definition
drivers/usb/host/ehci-orion.c:334:31: warning: 'ehci_orion_driver' defined but not used [-Wunused-variable]
and an ehci driver that only works on one of them.
module, as we do here for the orion bus glue.
An earlier version of this patch was included in 3.9 but caused
a regression there, which has subsequently been fixed.
While we are here, use the opportunity to disabiguate the two
Marvell EHCI controller implementations in Kconfig.
In V4 (arnd):
- Improve Kconfig text
In V3:
- More detail provided in commit message regarding this patch.
- Replaced hcd_name string "ehci-orion" into "orion-ehci".
- In ehci_init_driver calling second argument passed as NULL instead of
ehci_orion_overrides because ehci_orion_overrides is removed.
In V2:
Acked-by: Jason Cooper <jason@lakedaemon.net>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Felipe writes:
usb: patches for v3.10 merge window
Here is the big Gadget & PHY pull request. Many of us have
been really busy lately getting multiple drivers to a better
position.
Since this pull request is so large, I will divide it in sections
so it's easier to grasp what's included.
- cleanups:
. UDC drivers no longer touch gadget->dev, that's now udc-core
responsibility
. Many more UDC drivers converted to usb_gadget_map/unmap_request()
. UDC drivers no longer initialize DMA-related fields from gadget's
device structure
. UDC drivers don't touch gadget.dev.driver directly
. UDC drivers don't assign gadget.dev.release directly
. Removal of some unused DMA_ADDR_INVALID
. Introduction of CONFIG_USB_PHY
. All phy drivers have been moved to drivers/usb/phy and renamed to
a common naming scheme
. Fix PHY layer so it never returns a NULL pointer, also fix all
callers to avoid using IS_ERR_OR_NULL()
. Sparse fixes all over the place
. drivers/usb/otg/ has been deleted
. Marvel drivers (mv_udc, ehci-mv, mv_otg and mv_u3d) improved clock
usage
- new features:
. UDC core now provides a generic way for tracking and reporting
UDC's state (not attached, resuming, suspended, addressed,
default, etc)
. twl4030-usb learned that it shouldn't be enabled during init
. Full DT support for DWC3 has been implemented
. ab8500-usb learned about pinctrl framework
. nop PHY learned about DeviceTree and regulators
. DWC3 learned about suspend/resume
. DWC3 can now be compiled in host-only and gadget-only (as well as
DRD) configurations
. UVC now enables streaming endpoint based on negotiated speed
. isp1301 now implements the PHY API properly
. configfs-based interface for gadget drivers which will lead to
the removal of all code which just combines functions together
to build functional gadget drivers.
. f_serial and f_obex were converted to new configfs interface while
maintaining old interface around.
- non-critical fixes:
. UVC gadget driver got fixes for Endpoint usage and stream calculation
. ab8500-usb fixed unbalanced clock and regulator API usage
. twl4030-usb got a fix for when OMAP3 is booted with cable connected
. fusb300_udc got a fix for DMA usage
. UVC got fixes for two assertions of the USB Video Class Compliance
specification revision 1.1
. build warning issues caused by recent addition of __must_check to
regulator API
These are all changes which deserve a mention, all other changes are related
to these one or minor spelling fixes and other similar tasks.
USB_ULPI and USB_ULPI_VIEWPORT shouldn't really
be selected directly by anyone, but since Tegra
still needs some time before turning ulpi viewport
into a proper PHY driver, we need to keep the
selects in place.
This patch just fixes the conditional select
so that it will continue to build after merging
the latest PHY layer changes.
there are no more users of CONFIG_USB_OTG_UTILS
left in tree, we can remove it just fine.
[ kishon@ti.com : fixed a linking error due
to original patch forgetting to change
drivers/usb/Makefile ]
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
In PHY mode we need to have the nop-usb-xceiv transceiver
driver to operate, so select it in Kconfig.
Acked-by: Felipe Balbi <balbi@ti.com>
This patch (as1645) converts ehci-omap over to the new "ehci-hcd is a
library" approach, so that it can coexist peacefully with other EHCI
platform drivers and can make use of the private area allocated at
the end of struct ehci_hcd.
This reverts commit d57ada0c37ecf836259c205442c15c7679a6dc3e.
All of these are wrong and need to be reverted for now.
Cc: Manjunath Goudar <manjunath.goudar@linaro.org>
Cc: Tony Prisk <linux@prisktech.co.nz>
Cc: Alexey Charkov <alchark@gmail.com>
This reverts commit 6ed3c43d05f6d0d55f17947bc287f35318fd96f8.
All of these are wrong, and need to be reverted for now.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
This reverts commit e2ced16661b807b0a5db4f00000eaeb21da4b251.
All of these are wrong, and need to be removed for now until they can
get reworked properly.
The recent patches from Manjunath Goudar introduced two small
mistakes in the Kconfig help text for the new options. Let's
fix those and the other entries that have become stale over time.
in a warning like
possible to enable the vt8500 platform at the same time
as other platforms that require a conflicting EHCI bus
glue. At the moment, this results in a warning like
drivers/usb/host/ehci-hcd.c:1277:0: warning: "PLATFORM_DRIVER" redefined [enabled by default]
drivers/usb/host/ehci-hcd.c:1257:0: note: this is the location of the previous definition
drivers/usb/host/ehci-omap.c:319:31: warning: 'ehci_hcd_omap_driver' defined but not used [-Wunused-variable]
module, as we do here for the vt8500 bus glue.
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Add a couple of missing GENERIC_HARDIRQS dependencies to fix link
errors like below on s390:
ERROR: "devm_request_threaded_irq" [drivers/usb/gadget/mv_udc.ko] undefined!
This patch (as1643b) fixes a build error in ehci-hcd when compiling for
ARM with allmodconfig:
drivers/usb/host/ehci-hcd.c:1285:0: warning: "PLATFORM_DRIVER" redefined [enabled by default]
drivers/usb/host/ehci-hcd.c:1255:0: note: this is the location of the previous definition
drivers/usb/host/ehci-mxc.c:280:31: warning: 'ehci_mxc_driver' defined but not used [-Wunused-variable]
The fix is to convert ehci-mxc over to the new "ehci-hcd is a library"
scheme so that it can coexist peacefully with the ehci-platform
driver. As part of the conversion the ehci_mxc_priv data structure,
which was allocated dynamically, is now placed where it belongs: in
the private area at the end of struct ehci_hcd.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
This patch (as1626) splits the ehci-platform code from ehci-hcd out
This patch (as1625) splits the PCI portion of ehci-hcd out into its
own separate driver module, called ehci-pci. Consistently with the
current practice, the decision whether to build this module is not
user-configurable. If EHCI and PCI are enabled then the module will
be built, always.
CC: Felipe Balbi <balbi@ti.com>
All users have been converted to use the OHCI platform driver instead, thus
making ohci-sh obsolete, so remove it.
