Pull MIPS updates from Ralf Baechle:
- Improvements to the tlb_dump code
- KVM fixes
- Add support for appended DTB
- Minor improvements to the R12000 support
- Various platform improvments for BCM47xx
- The usual pile of minor cleanups
- A number of BPF fixes and improvments
- Some improvments to the support for R3000 and DECstations
- Some improvments to the ATH79 platform support
- A major patchset for the JZ4740 SOC adding support for the CI20 platform
- Add support for the Pistachio SOC
- Minor BMIPS/BCM63xx platform support improvments.
- Avoid "SYNC 0" as memory barrier when unlocking spinlocks
- Add support for the XWR-1750 board.
- Paul's __cpuinit/__cpuinitdata cleanups.
- New Malta CPU board support large memory so enable ZONE_DMA32.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits)
MIPS: spinlock: Adjust arch_spin_lock back-off time
MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA
MIPS: BCM47xx: Simplify handling SPROM revisions
MIPS: Cobalt Don't use module_init in non-modular MTD registration.
MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/
MIPS: use for_each_sg()
MIPS: BCM47xx: Don't select BCMA_HOST_PCI
MIPS: BCM47xx: Add helper variable for storing NVRAM length
MIPS: IRQ/IP27: Move IRQ allocation API to platform code.
MIPS: Replace smp_mb with release barrier function in unlocks.
MIPS: i8259: DT support
MIPS: Malta: Basic DT plumbing
MIPS: include errno.h for ENODEV in mips-cm.h
MIPS: Define GCR_GIC_STATUS register fields
MIPS: BPF: Introduce BPF ASM helpers
MIPS: BPF: Use BPF register names to describe the ABI
MIPS: BPF: Move register definition to the BPF header
MIPS: net: BPF: Replace RSIZE with SZREG
MIPS: BPF: Free up some callee-saved registers
MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers
The Octeon OHCI is now supported by the ohci-platform driver, and
USB_OCTEON_OHCI is marked as deprecated. However, it is currently
still necessary to enable it in order to select
USB_OHCI_BIG_ENDIAN_MMIO. Make CPU_CAVIUM_OCTEON select that as well,
so that USB_OCTEON_OHCI is really obsolete.
The old ohci-octeon and ehci-octeon drivers also only enabled big-endian
MMIO in case the CPU was big-endian. Make the selections of
USB_EHCI_BIG_ENDIAN_MMIO and USB_OHCI_BIG_ENDIAN_MMIO conditional, to
match this.
Fixes: 2193dda5eec6 ("USB: host: Remove ehci-octeon and ohci-octeon drivers")
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: linux-mips@linux-mips.org
Cc: David Daney <david.daney@cavium.com>
Cc: Chandrakala Chavva <cchavva@caviumnetworks.com>
Cc: Paul Martin <paul.martin@codethink.co.uk>
Patchwork: https://patchwork.linux-mips.org/patch/10178/
Make Freescale EHCI driver an independent entity from ehci-hcd.c.
This involves
- using module_init/module_exit functions
- using overrides structure
- some necessary code cleanup
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This dependency no longer exists now that mach-msm has been
removed. Delete it.
Cc: linux-usb@vger.kernel.org
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v3.20 merge window
Here's the big pull request for Gadgets and PHYs. It's
a total of 217 non-merge commits with pretty much everything
being touched.
The most important bits are a ton of new documentation for
almost all usb gadget functions, a new isp1760 UDC driver,
several improvements to the old net2280 UDC driver, and
some minor tracepoint improvements to dwc3.
Other than that, a big list of minor cleanups, smaller bugfixes
and new features all over the place.
Signed-off-by: Felipe Balbi <balbi@ti.com>
The PPC_OF is a ppc specific option which is used to mean that the
firmware device tree access functions are available. Since all the
ppc platforms have a device tree, it is aways set to 'y' for ppc.
So it makes no sense to keep a such option in the current kernel.
Replace it with PPC
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Now that this is DRD, it doesn't make sense to keep it under
drivers/usb/host.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Remove special-purpose octeon drivers and instead use ehci-platform
and ohci-platform as suggested with
http://marc.info/?l=linux-mips&m=140139694721623&w=2
[andreas.herrmann:
fixed compile error]
Cc: Alex Smith <alex.smith@imgtec.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
The PLAT_S5P Kconfig symbol was removed in commit d78c16ccde96
("ARM: SAMSUNG: Remove remaining legacy code"). There are still
some references left, fix that by replacing them with ARCH_S5PV210.
Fixes: d78c16ccde96 ("ARM: SAMSUNG: Remove remaining legacy code")
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 3.18-rc1. Also in here is the PHY
tree, as it seems to fit well with the USB tree for various reasons...
Anyway, lots of little changes in here, all over the place, full
details in the changelog
All have been in the linux-next tree for a while with no issues"
* tag 'usb-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (244 commits)
USB: host: st: fix typo 'CONFIG_USB_EHCI_HCD_ST'
uas: Reduce number of function arguments for uas_alloc_foo functions
xhci: Allow xHCI drivers to be built as separate modules
xhci: Export symbols used by host-controller drivers
xhci: Check for XHCI_COMP_MODE_QUIRK when disabling D3cold
xhci: Introduce xhci_init_driver()
usb: hcd: add generic PHY support
usb: rename phy to usb_phy in HCD
usb: gadget: uvc: fix up uvcg_v4l2_get_unmapped_area typo
USB: host: st: fix ehci/ohci driver selection
usb: host: ehci-exynos: Remove unnecessary usb-phy support
usb: core: return -ENOTSUPP for all targeted hosts
USB: Remove .owner field for driver
usb: core: log higher level message on malformed LANGID descriptor
usb: Add LED triggers for USB activity
usb: Rename usb-common.c
usb: gadget: Refactor request completion
usb: gadget: Introduce usb_gadget_giveback_request()
usb: dwc2/gadget: move phy bus legth initialization
phy: remove .owner field for drivers using module_platform_driver
Instead of building all of the xHCI code into a single module, separate
it out into the core (xhci-hcd), PCI (xhci-pci, now selected by the new
config option CONFIG_USB_XHCI_PCI), and platform (xhci-plat) drivers.
Also update the PCI/platform drivers with module descriptions/licenses
and have them register their respective drivers in their initcalls.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
The newly added sti ehci and ohci drivers come with a single
Kconfig entry that does not depend on either of the base drivers,
which leads to a link error when they are disabled:
drivers/built-in.o: In function `ohci_platform_init':
:(.init.text+0x14788): undefined reference to `ohci_init_driver'
To fix that, this patch introduces two separate Kconfig options
with proper dependencies, which avoids the problem and is also
more consistent with the other glue drivers.
Fixes: d115837259ada ("usb: host: ohci-st: Add OHCI driver support for ST STB devices")
Cc: Peter Griffin <peter.griffin@linaro.org>
This patch fix spelling typos found in Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
An HWA is a USB device so it depends on USB.
Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com>
This patch adds the glue code required to ensure the on-chip OHCI
controller works on STi consumer electronics SoC's from STMicroelectronics.
It mainly manages the setting and enabling of the relevant clocks and manages
the reset / power signals to the IP block.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The R-Car H2 and M2 SoCs come with an xHCI controller that requires
some specific initializations related to the firmware downloading and
some specific registers. This patch adds the support for this special
configuration as an xHCI quirk executed during probe and start.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: "mathias.nyman@intel.com" <mathias.nyman@intel.com>
This patch makes the msm ehci driver available to use on QCOM SOCs,
which have the same IP.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Felipe Balbi <balbi@ti.com>
The dependency on the isp1301 driver is not something that
should be in the main OHCI driver but rather the SoC specific
part of it.
This moves the dependency for LPC32xx into USB_OHCI_HCD_LPC32XX,
and changes the 'select ISP1301_OMAP' to a similar 'depends on'.
Since the same dependency exists for the client driver, do the
same change there.
Cc: linux-omap@vger.kernel.org
The PHY setup code of the TI DaVinci DA8xx OHCI controller
uses ad-hoc register access using a pointer that is meant to
be used only by the DaVinci platform implementation and that
is intentionally not exported to loadable modules. This results
in a link error on configurations that use a modular OHCI
code on this platform.
While the proper solution for this problem would be to
implement a real PHY driver shared by ohci-da8xx and musb-da8xx,
this patch for now just works around the build error by
only allowing the ohci-da8xx code to be built-in.
The Armada 375 and 38x SoCs come with an XHCI controller that requires
some specific initialization related to the MBus windows
configuration. This patch adds the support for this special
configuration as an XHCI quirk executed during probe.
Two new compatible strings are added to identify the Armada 375 and
Armada 38x XHCI controllers, and therefore enable the relevant quirk.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Signed-off-by: David Mosberger <davidm@egauge.net>
Commit a27345434134 "usb: phy: msm: Use reset framework for LINK
and PHY resets" introduced a mandatory call to reset_control_get
into the msm usb phy driver, which means we have to add a Kconfig
dependency on the API to avoid this build error:
phy/phy-msm-usb.c: In function 'msm_otg_read_dt':
phy/phy-msm-usb.c:1461:2: error: implicit declaration of function 'devm_reset_control_get' [-Werror=implicit-function-declaration]
motg->link_rst = devm_reset_control_get(&pdev->dev, "link");
Since the usb-ehci-msm driver currently selects the OTG driver,
we could still get a broken dependency here. To solve that,
this patch also removes the 'select', which turns out to be
unnecessary.
Reviewed-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Pull trivial tree updates from Jiri Kosina:
"Usual rocket science -- mostly documentation and comment updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
sparse: fix comment
doc: fix double words
isdn: capi: fix "CAPI_VERSION" comment
doc: DocBook: Fix typos in xml and template file
Bluetooth: add module name for btwilink
driver core: unexport static function create_syslog_header
mmc: core: typo fix in printk specifier
ARM: spear: clean up editing mistake
net-sysfs: fix comment typo 'CONFIG_SYFS'
doc: Insert MODULE_ in module-signing macros
Documentation: update URL to hfsplus Technote 1150
gpio: update path to documentation
ixgbe: Fix format string in ixgbe_fcoe.
Kconfig: Remove useless "default N" lines
user_namespace.c: Remove duplicated word in comment
CREDITS: fix formatting
treewide: Fix typo in Documentation/DocBook
mm: Fix warning on make htmldocs caused by slab.c
ata: ata-samsung_cf: cleanup in header file
idr: remove unused prototype of idr_free()
A number of Kconfig entries default to (uppercase) "N". It was clearly
intended to use "default n". But since (lowercase) "n" is the default
anyway, these lines might as well be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The Kconfig entries for USB_U132_HCD and USB_FTDI_ELAN default to
(uppercase) "M". But in Kconfig (lowercase) "m" is a magic symbol. "M"
is an ordinary symbol. As "M" is never set these Kconfig symbols will
also not be set by default.
Since I'm not aware of a reason why these driver should be set by
default, let's just drop these lines (that basically do nothing).
The initial versions of the devicetree enablement patches for ehci-platform
used "ehci-platform" as compatible string. However this was disliked by various
reviewers because the platform bus is a Linux invention and devicetree is
supposed to be OS agnostic. After much discussion I gave up, added a:
"depends on !PPC_OF" to Kconfig to avoid a known conflict with PPC-OF platforms
and went with the generic usb-ehci as requested.
In retro-spect I should have chosen something different, the dts files for many
existing boards already claim to be compatible with "usb-ehci", ie they have:
compatible = "ti,ehci-omap", "usb-ehci";
In theory this should not be a problem since the "ti,ehci-omap" entry takes
presedence, but in practice using a conflicting compatible string is an issue,
because it makes which driver gets used depend on driver registration order.
This patch changes the compatible string claimed by ehci-platform to
"generic-ehci", avoiding the driver registration / module loading ordering
problems, and removes the "depends on !PPC_OF" workaround.
Tested-by: Kevin Hilman <khilman@linaro.org>
Currently ehci-platform is only used in combination with devicetree when used
with some Via socs. By extending it to (optionally) get clks and a phy from
devicetree, and enabling / disabling those on power_on / off, it can be used
more generically. Specifically after this commit it can be used for the
ehci controller on Allwinner sunxi SoCs.
Since ehci-platform is intended to handle any generic enough non pci ehci
device, add a "usb-ehci" compatibility string.
There already is a usb-ehci device-tree bindings document, update this
with clks and phy bindings info.
Although actually quite generic so far the via,vt8500 compatibilty string
had its own bindings document. Somehow we even ended up with 2 of them. Since
these provide no extra information over the generic usb-ehci documentation,
this patch removes them.
The ehci-ppc-of.c driver also claims the usb-ehci compatibility string,
even though it mostly is ibm,usb-ehci-440epx specific. ehci-platform.c is
not needed on ppc platforms, so add a !PPC_OF dependency to it to avoid
2 drivers claiming the same compatibility string getting build on ppc.
Convert ep93xx to use the OHCI platform driver and remove the
ohci-ep93xx bus glue driver.
Enable CONFIG_OHCI_HCD_PLATFORM in the ep93xx_defconfig so that USB
is still enabled by default on the EP93xx platform.
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Olof Johansson <olof@lixom.net>
Currently, Samsung is using 'EXYNOS' as the name of Samsung SoCs.
Thus, ehci-exynos is preferred than ehci-s5p.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Separate the OHCI pxa27x/pxa3xx host controller driver from
ohci-hcd host code so that it can be built as a separate driver
module. This work is part of enabling multi-platform kernels on
ARM.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
Signed-off-by: Deepak Saxena <dsaxena@linaro.org>
Separate the OHCI EP93XX host controller driver from ohci-hcd
host code so that it can be built as a separate driver module.
This work is part of enabling multi-platform kernels on ARM.
Separate the OHCI NXP host controller driver from ohci-hcd
Many place function name and struct name started with usb,
current scenario replaced usb with ohci for proper naming.
Separate the Samsung OHCI S3C24xx/S3C64xx host controller driver
from ohci-hcd host code so that it can be built as a separate
driver module.This work is part of enabling multi-platform.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Separate the TI OHCI Atmel host controller driver from ohci-hcd
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Separate the ST OHCI SPEAr host controller driver from ohci-hcd
Cc: Viresh Kumar <viresh.linux@gmail.com>
Separate the TI OHCI OMAP3 host controller driver from ohci-hcd
Cc: Anand Gadiyar <gadiyar@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Separate the TI OHCI OMAP1/2 host controller driver from ohci-hcd
Separate the Samsung OHCI EXYNOS host controller driver from ohci-hcd
Cc: Vivek Gautam <gautam.vivek@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Separate the W90X900(W90P910) on-chip host controller driver from
ehci-hcd host code so that it can be built as a separate driver module.
This work is part of enabling multi-platform kernels on ARM;
however, note that other changes are still needed before W90X900(W90P910)
can be booted with a multi-platform kernel
and an ehci driver that only works on one of them.
With the infrastructure added by Alan Stern in patch 3e0232039
"USB: EHCI: prepare to make ehci-hcd a library module", we can
avoid this problem by turning a bus glue into a separate
module, as we do here for the w90X900 bus glue.
This patch is rebased on greghk/usb-next 3.12 rc1.
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Now, chipidea host has already depended on USB_EHCI_HCD
Signed-off-by: Peter Chen <peter.chen@freescale.com>
After the last architecture switched to generic hard irqs the config
options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code
for !CONFIG_GENERIC_HARDIRQS can be removed.
git://git.kernel.org/pub/scm/linux/kernel/git/sarah/xhci into usb-next
Sarah writes:
xhci: Platform updates, 64-bit DMA, and trace events for 3.12.
Hi Greg,
This pull request includes one new feature for the xhci-plat driver (device
tree support). Felipe was fine with the patch last I checked, but hadn't
provided an official Acked-by line.
This pull request also includes 13 patches from my FOSS Outreach Program for
Women (OPW) intern, Xenia. She fixed a bug in the xHCI driver so that the
driver can allocate 64-bit consistent DMA, converted the driver to use dynamic
debugging, and added a bunch of new trace events for the xHCI driver. The
python plugin for trace-cmd should be up on git hub shortly, although the trace
events are usable without it.
I'm very happy with the progress that Xenia has made, and I look forward to her
future contributions to the Linux kernel.
Sarah Sharp
commit 9841f37a1c ("usb: ehci: Add support for SINGLE_STEP_SET_FEATURE
test of EHSET") added additional code to the EHCI hub driver but it is
anticipated to only have a limited audience (e.g. embedded silicon
vendors and integrators). Avoid subjecting all EHCI (and in the future
maybe xHCI/OHCI, etc.) HCD users to code bloat by conditionally
compiling the EHSET-specific additions with a new Kconfig option,
CONFIG_USB_HCD_TEST_MODE.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
CONFIG_USB_XHCI_HCD_DEBUGGING option is used to enable
verbose debugging output for the xHCI host controller
driver.
In the current version of the xhci-hcd driver, this
option must be turned on, in order for the debugging
log messages to be displayed, and users may need to
recompile the linux kernel to obtain debugging
information that will help them track down problems.
This patch removes the above debug option to enable
debugging log messages at all times.
The aim of this is to rely on the debugfs and the
dynamic debugging feature for fine-grained management
of debugging messages and to not force users to set
the debug config option and compile the linux kernel
in order to have access in that information.
This patch, also, removes the XHCI_DEBUG symbol and the
functions dma_to_stream_ring(), xhci_test_radix_tree()
and xhci_event_ring_work() that are not useful anymore.
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Felipe writes:
usb: patches for v3.12 merge window
All patches here have been pending on linux-usb
and sitting in linux-next for a while now.
The biggest things in this tag are:
DWC3 learned proper usage of threaded IRQ
handlers and now we spend very little time
in hardirq context.
MUSB now has proper support for BeagleBone and
Beaglebone Black.
Tegra's USB support also got quite a bit of love
and is learning to use PHY layer and generic DT
attributes.
Other than that, the usual pack of cleanups and
non-critical fixes follow.
Signed-of-by: Felipe Balbi <balbi@ti.com>
drivers/usb/gadget/udc-core.c
drivers/usb/host/ehci-tegra.c
drivers/usb/musb/omap2430.c
drivers/usb/musb/tusb6010.c
When CONFIG_USB_SUPPORT is not selected we get things like:
scripts/kconfig/mconf Kconfig
warning: (MIPS_SEAD3 && PMC_MSP && CPU_CAVIUM_OCTEON) selects USB_EHCI_BIG_ENDIAN_MMIO which has unmet direct dependencies (USB_SUPPORT && USB)
It is much cleaner to make the various system Kconfigs select
USB_EHCI_BIG_ENDIAN_MMIO rather than move the system config
information into USB's Kconfig, but the warnings are annoying.
Eliminate the warning by moving the definition of
USB_EHCI_BIG_ENDIAN_MMIO outside of all the Kconfig if statements.
While we are at it move USB_OHCI_BIG_ENDIAN_DESC,
USB_OHCI_BIG_ENDIAN_MMIO, USB_OHCI_LITTLE_ENDIAN and
USB_EHCI_BIG_ENDIAN_DESC too, as they could very well suffer similar
problems for other systems.
Get rid of the redundant "default n" in USB_OHCI_BIG_ENDIAN_DESC and
Signed-off-by: David Daney <david.daney@cavium.com>
FOTG210 is an OTG controller which can be configured as an
USB2.0 host. FOTG210 host is an ehci-like controller with
some differences. First, register layout of FOTG210 is
incompatible with EHCI. Furthermore, FOTG210 is lack of
siTDs which means iTDs are used for both HS and FS ISO
transfer.
Signed-off-by: Feng-Hsin Chiang <john453@faraday-tech.com>
ehci-omap needs NOP_USB_XCEIV PHY driver to function
properly, so select it. As the USB PHY drivers no longer
depend on USB_PHY, it is safe to select the PHY drivers.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Tested-by: Adrien Vergé <adrienverge@gmail.com>
Convert PHY Drivers from menuconfig to menu so that the PHY drivers
can be explicitely selected by the controller drivers.
USB_PHY is no longer a user visible option. It is upto to the PHY
drivers to select it if needed. This patch does so for the existing
PHY drivers that use the USB_PHY library.
Doing so moves the USB_PHY and PHY driver selection problem from the
end user to the PHY and controller driver developer.
e.g.
Earlier, a controller driver (e.g. EHCI_OMAP) that needs to select
a PHY driver (e.g. NOP_PHY) couldn't do so because the PHY driver
depended on USB_PHY. Making the controller driver depend on USB_PHY
has a negative effect i.e. it becomes invisible to the user till
USB_PHY is enabled. Most end users will not familiar with this.
With this patch, the end user just needs to select the controller driver
needed for his/her platform without worrying about which PHY driver to
select.
Also update USB_EHCI_MSM, USB_LPC32XX and USB_OMAP to not depend
on USB_PHY any more. They can safely select the necessary PHY drivers.
[ balbi@ti.com : refreshed on top of my next branch. Changed bool
followed by default n into def_bool n ]
CC: Pavankumar Kondeti <pkondeti@codeaurora.org>
Acked-by: Roland Stigge <stigge@antcom.de>
This reverts commit 1dd3d123239179fad5de5dc00a6e0014a1918fde.
The email address for the developer now bounces, which means they have
moved on, so remove the driver until someone else from the company steps
up to maintain it.
