Remove the ehci_reset() call done in the ehci_run() routine of the
USB EHCI host controller driver and add an ehci_reset() call to the
probe processing of all EHCI platform drivers that do not already call
ehci_reset().
The call to ehci_reset() from ehci_run() was problematic for several
platform drivers, and unnecessary for others. This change moves the
decision to call ehci_reset() at driver startup to the platform
driver code.
Signed-off-by: Geoff Levand <geoff@infradead.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits)
MIPS: O32: Provide definition of registers ta0 .. ta3.
MIPS: perf: Add Octeon support for hardware perf.
MIPS: perf: Add support for 64-bit perf counters.
MIPS: perf: Reorganize contents of perf support files.
MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c
MIPS: Add accessor macros for 64-bit performance counter registers.
MIPS: Add probes for more Octeon II CPUs.
MIPS: Add more CPU identifiers for Octeon II CPUs.
MIPS: XLR, XLS: Add comment for smp setup
MIPS: JZ4740: GPIO: Check correct IRQ in demux handler
MIPS: JZ4740: GPIO: Simplify IRQ demuxer
MIPS: JZ4740: Use generic irq chip
MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines
MIPS: Alchemy: kill au1xxx.h header
MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines
MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep
MIPS: Alchemy: Redo PCI as platform driver
MIPS: Alchemy: more base address cleanup
MIPS: Alchemy: rewrite USB platform setup.
MIPS: Alchemy: abstract USB block control register access
Fix up trivial conflicts in:
arch/mips/alchemy/devboards/db1x00/platform.c
drivers/ide/Kconfig
drivers/mmc/host/au1xmmc.c
drivers/video/Kconfig
sound/mips/Kconfig
Alchemy chips have one or more registers which control access
to the usb blocks as well as PHY configuration. I don't want
the OHCI/EHCI glues to know about the different registers and bits;
new code hides the gory details of USB configuration from them.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Cc: linux-usb@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/2709/
create mode 100644 drivers/usb/host/alchemy-common.c
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
This patch (as1483) improves the ehci-hcd driver family by getting rid
of the reliance on the hcd->state variable. It has no clear owner and
it isn't protected by the usual HCD locks. In its place, the patch
adds a new, private ehci->rh_state field to record the state of the
root hub.
Along the way, the patch removes a couple of lines containing
redundant assignments to the state variable. Also, the QUIESCING
state simply gets changed to the RUNNING state, because the driver
doesn't make any distinction between them.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Remove a stray 'return 0' at the top of the suspend callback,
and move au1xxx_stop_ehc() out of the ehci spinlock since it takes
some time to complete.
The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
Signed-off-by: Jan Andersson <jan@gaisler.com>
There is a msleep with spin lock held during ehci pci suspend, which will
cause kernel BUG: scheduling while atomic. Fix that.
[ 184.139620] BUG: scheduling while atomic: kworker/u:11/416/0x00000002
[ 184.139632] 4 locks held by kworker/u:11/416:
[ 184.139640] #0: (events_unbound){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139669] #1: ((&entry->work)){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139686] #2: (&__lockdep_no_validate__){+.+.+.}, at: [<c127cde3>] __device_suspend+0x2c/0x154
[ 184.139706] #3: (&(&ehci->lock)->rlock){-.-...}, at: [<c132f3d8>] ehci_pci_suspend+0x35/0x7b
[ 184.139725] Modules linked in: serio_raw pegasus joydev mrst_gfx(C) battery
[ 184.139748] irq event stamp: 52
[ 184.139753] hardirqs last enabled at (51): [<c14fdaac>] mutex_lock_nested+0x258/0x293
[ 184.139766] hardirqs last disabled at (52): [<c14fe7b4>] _raw_spin_lock_irqsave+0xf/0x3e
[ 184.139777] softirqs last enabled at (0): [<c10371c1>] copy_process+0x3d2/0x109d
[ 184.139789] softirqs last disabled at (0): [< (null)>] (null)
[ 184.139802] Pid: 416, comm: kworker/u:11 Tainted: G C 2.6.37-6.3-adaptation-oaktrail #37
[ 184.139809] Call Trace:
[ 184.139820] [<c102eeff>] __schedule_bug+0x5e/0x65
[ 184.139829] [<c14fbca5>] schedule+0xac/0xc4c
[ 184.139840] [<c11d4845>] ? string+0x37/0x8b
[ 184.139853] [<c1044f21>] ? lock_timer_base+0x1f/0x3e
[ 184.139863] [<c14fe7da>] ? _raw_spin_lock_irqsave+0x35/0x3e
[ 184.139876] [<c1061590>] ? trace_hardirqs_off+0xb/0xd
[ 184.139885] [<c14fccdc>] schedule_timeout+0x283/0x2d9
[ 184.139896] [<c104516f>] ? process_timeout+0x0/0xa
[ 184.139906] [<c14fcd47>] schedule_timeout_uninterruptible+0x15/0x17
[ 184.139916] [<c104566a>] msleep+0x10/0x16
[ 184.139926] [<c132f316>] ehci_adjust_port_wakeup_flags+0x69/0xf6
[ 184.139937] [<c132f3eb>] ehci_pci_suspend+0x48/0x7b
[ 184.139946] [<c1326587>] suspend_common+0x52/0xbb
[ 184.139956] [<c1326625>] hcd_pci_suspend+0x26/0x28
[ 184.139967] [<c11e7182>] pci_pm_suspend+0x5f/0xd0
[ 184.139976] [<c127ca3a>] pm_op+0x5d/0xf0
[ 184.139986] [<c127ceac>] __device_suspend+0xf5/0x154
[ 184.139996] [<c127d2c8>] async_suspend+0x16/0x3a
[ 184.140006] [<c1058f54>] async_run_entry_fn+0x89/0x111
[ 184.140016] [<c104deb6>] process_one_work+0x295/0x4cb
[ 184.140026] [<c1058ecb>] ? async_run_entry_fn+0x0/0x111
[ 184.140036] [<c104e3d0>] worker_thread+0x17f/0x298
[ 184.140045] [<c104e251>] ? worker_thread+0x0/0x298
[ 184.140055] [<c105277f>] kthread+0x64/0x69
[ 184.140064] [<c105271b>] ? kthread+0x0/0x69
[ 184.140075] [<c1002efa>] kernel_thread_helper+0x6/0x1a
Signed-off-by: Yin Kangkai <kangkai.yin@intel.com>
CC: David Brownell <dbrownell@users.sourceforge.net>
CC: stable@kernel.org
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend
method used by PCI-based host controller drivers. ehci-hcd in
particular needs to know whether or not to enable wakeup when
suspending a controller. Although that information is currently
available through device_may_wakeup(), when support is added for
runtime suspend this will no longer be true.
This patch (as1380) fixes a bug in the wakeup settings for EHCI host
controllers. When the controller is suspended, if it isn't enabled
for remote wakeup then we have to turn off all the port wakeup flags.
Disabling PCI PME# isn't good enough, because some systems (Intel)
evidently use alternate wakeup signalling paths.
In addition, the patch improves the handling of the Intel Moorestown
hardware by performing various power-up and power-down delays just
once instead of once for each port (i.e., the delays are moved outside
of the port loops). This requires extra code, but the total delay
time is reduced.
There are also a few additional minor cleanups.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
CC: Alek Du <alek.du@intel.com>
CC: stable <stable@kernel.org>
I've been running variations of this patch for well over a year now;
my usual zoo of test devices didn't trigger any ill effects even
under heavy load. As a nice sideeffect idle-wakeups are reduced
from 20/s to about 2/s (EHCI hub with mouse and kbd).
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Use platform_get_resource() to fetch the memory resource and
resource_size() for calculate the length.
Cc: David Brownell <dbrownell@users.sourceforge.net>
move both ohci-au1xxx and ehci-au1xxx over to dev_pm_ops.
Tested on Au1200.
This patch (as1256) changes ehci-hcd and all the other drivers in the
EHCI family to make use of the new clear_tt_buffer callbacks. When a
Clear-TT-Buffer request is in progress for a QH, the QH is not allowed
to be linked into the async schedule until the request is finished.
At that time, if there are any URBs queued for the QH, it is linked
into the async schedule.
Cc: stable <stable@kernel.org>
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued
for an endpoint whose QH is already in the LINKED state, the QH
doesn't get refreshed. As a result, if usb_clear_halt() was called
during the time that the QH was linked but idle, the data toggle value
in the QH doesn't get reset.
The symptom is that after a clear_halt, data gets lost and transfers
time out. This problem is starting to show up now because the
"ehci-hcd unlink speedups" patch causes QHs with no queued URBs to
remain linked for a suitable time.
The patch utilizes the new endpoint_reset mechanism to fix the
problem. When an endpoint is reset, the new method forcibly unlinks
the QH (if necessary) and safely updates the toggle value. This
allows qh_update() to be simplified and avoids using usb_device's
toggle bits in a rather unintuitive way.
CC: David Brownell <david-b@pacbell.net>
Tested-by: David <david@unsolicited.net>
Copy the OHCI/EHCI PM callbacks of the PCI implementation since
they work equally well on Au1xxx hardware.
Tested on Au1200.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
- Fold multiple probe/remove callbacks into one function;
- minor style fixes, no functional changes.
Tested on Au1200.
This patch (as1096) fixes an annoying problem: When a full-speed or
low-speed device is plugged into an EHCI controller, it fails to
enumerate at high speed and then is handed over to the companion
controller. But usbcore logs a misleading and unwanted error message
when the high-speed enumeration fails.
The patch adds a new HCD method, port_handed_over, which asks whether
a port has been handed over to a companion controller. If it has, the
error message is suppressed.
Various minor fixes to some SOC bus glue for EHCI:
- Remove a bogus copyright (by "me"!) which someone added to the FSL
driver, and an irrelevant comment.
- Un-break MODULE_ALIAS() directives after platform_bus hotplugging
acquired a backwards-incompatible change. (Which didn't fix ANY
of the in-tree drivers it prevented from hotplugging -- sigh.)
- Remove some bogus assignments of platform_bus_type; that's done by
the platform_bus code.
- Add some FIXMEs for drivers with that pointless two-level idiom for
probe() and remove() routines. ("Obfuscation" is a non-goal.)
That should help avoid future bus glue which copies that idiom.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This patch hands over the port to the companion when the
hub_port_connect_change fails.
Signed-off-by: Balaji Rao <balajirrao@gmail.com>
Cleanup: references to two PM routines (and HCD entry points)
that no longer exist are swapped with their replacements.
Evidently au1xxx and ppc-soc EHCI support doesn't get compiled
with power management very much, or these build bugs would have
been patched long ago.
Correctly initialize the on-chip EHCI controller on the AMCC PPC440EPx.
Fix "USB 0.0" initialization message, and properly put the controller
into a known state before starting it.
Add "FIXME" comment to the au1xxx bus glue which is doing the same wrong
thing here. (Who maintains that, now that AMD sold off Alchemy?) Remove
some false copyright attributions which were somehow placed in the au1xxx
bus glue then copied into ppc-soc.
Signed-off-by: Mike Nuss <mike@terascala.com>
Cc: K.Boge <karsten.boge@amd.com>
Cc: Jordan Crouse <jordan.crouse@amd.com>
If some problem occurs during ehci startup, for instance, request_irq fails,
echi hcd driver tries it best to cleanup, but fails to unregister reboot
notifier, which in turn leads to crash on reboot/poweroff.
The following patch resolves this problem by not using reboot notifiers
anymore, but instead making ehci/ohci driver get its own shutdown method. For
PCI, it is done through pci glue, for everything else through platform driver
glue.
One downside: sa1111 does not use platform driver stuff, and does not have its
own shutdown hook, so no 'shutdown' is called for it now. I'm not sure if it
is really necessary on that platform, though.
Signed-off-by: Aleks Gorelov <dared1st@yahoo.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: David Brownell <david-b@pacbell.net>
I received an DBAU1200 eval kit from AMD a few days ago and tried to
enable the USB2 port, but the current linux-2.6 GIT did not even
compile with CONFIG_SOC_1200, CONFIG_SOC_AU1X00, CONFIG_USB_EHCI and
CONFIG_USB_OHCI set.
Furthermore, in ehci-hcd.c, platform_driver_register() was called with
an improper argument of type 'struct device_driver *' which of course
ended up in a kernel oops. How could that ever have worked on your
machines?
Anyway, here's a trivial patch that makes the USB subsystem working
on my board for both OHCI and EHCI.
It also removes the /* FIXME use "struct platform_driver" */.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Greg KH <greg@kroah.com>
Including ehci-au1xxx.c on a non-Au1200 Alchemy only to have it throw
an error is stupid.
In some systems we may have both a platform EHCI controller and PCI EHCI
controller. Previously we couldn't build the EHCI support as a module due
to conflicting module_init() calls in the code.
ALCHEMY: Add EHCI support for AU1200
Updated by removing the OHCI support
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
