The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
Signed-off-by: Jan Andersson <jan@gaisler.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Li Yang <leoli@freescale.com>
Previously a check was done on an ID register at the base of a CPU's
internal USB registers to determine if system interface regsiters were
present. The check looked for an ID register that had the format
ID[0:5] == ~ID[8:13] as described in the MPC5121 User's Manual to
determine if a MPC5121 or MPC83xx/85xx was being used.
There are two issues with this method:
- The ID register is not defined on the MPC83xx/85xx CPUs, so its
unclear what is being checked on them.
- Newer CPUs such as the P4080 also don't document the ID register, but
do share the same format as the MPC5121. Thus the previous code did
not set 'have_sysif_regs' properly which results in the P4080 not
properly initializing its USB ports.
Using the device tree 'compatible' node is a cleaner way to determine if
'have_sysif_regs' should be set and resolves the USB initialization issue
seen on the P4080.
Tested on a P4080-based system and compile tested on mpc512x_defconfig
with Freescale EHCI driver enabled.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: linuxppc-dev@lists.ozlabs.org
Extends FSL EHCI platform driver glue layer to support
MPC5121 USB controllers. MPC5121 Rev 2.0 silicon EHCI
registers are in big endian format. The appropriate flags
are set using the information in the platform data structure.
MPC83xx system interface registers are not available on
MPC512x, so the access to these registers is isolated in
MPC512x case. Furthermore the USB controller clocks
must be enabled before 512x register accesses which is
done by providing platform specific init callback.
The MPC512x internal USB PHY doesn't provide supply voltage.
For boards using different power switches allow specifying
DRVVBUS and PWR_FAULT signal polarity of the MPC5121 internal
PHY using "fsl,invert-drvvbus" and "fsl,invert-pwr-fault"
properties in the device tree USB nodes. Adds documentation
for this new device tree bindings.
Cc: Grant Likely <grant.likely@secretlab.ca>
tdi_reset is already taking care of setting host mode for tdi devices.
Don't duplicate code in platform driver.
Make ehci_halt a nop if the controller is not in host mode (otherwise it
will fail), and let's ehci_reset do the tdi_reset.
We need to move hcd->has_tt flags before ehci_halt, in order ehci_halt
knows we are a tdi device.
Before the setup routine was doing :
- put controller in host mode
- ehci_halt
- ehci_init
- hcd->has_tt = 1;
- ehci_reset
Now we do :
- hcd->has_tt = 1;
- ehci_halt
- ehci_init
- ehci_reset
PS : now we handle correctly the device -> host transition.
Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend
method used by PCI-based host controller drivers. ehci-hcd in
particular needs to know whether or not to enable wakeup when
suspending a controller. Although that information is currently
available through device_may_wakeup(), when support is added for
runtime suspend this will no longer be true.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1380) fixes a bug in the wakeup settings for EHCI host
controllers. When the controller is suspended, if it isn't enabled
for remote wakeup then we have to turn off all the port wakeup flags.
Disabling PCI PME# isn't good enough, because some systems (Intel)
evidently use alternate wakeup signalling paths.
In addition, the patch improves the handling of the Intel Moorestown
hardware by performing various power-up and power-down delays just
once instead of once for each port (i.e., the delays are moved outside
of the port loops). This requires extra code, but the total delay
time is reduced.
There are also a few additional minor cleanups.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
CC: Alek Du <alek.du@intel.com>
CC: stable <stable@kernel.org>
EHCI FSL controller preserve its state during sleep mode, so nothing
fancy needs to be done.
Though, during 'deep sleep' mode (as found in MPC831x CPUs) the
controller turns off and needs to be reinitialized upon resume.
This patch adds support for hibernation and resuming after deep sleep.
Based on Dave Liu and Jerry Huang's work[1].
[1] http://www.bitshrine.org/gpp/linux-fsl-2.6.24.3-MPC8315ERDB-usb-power-mangement.patch
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch fixes following warnings:
ehci-fsl.c:43:5: warning: symbol 'usb_hcd_fsl_probe' was not declared. Should it be static?
ehci-fsl.c:150:6: warning: symbol 'usb_hcd_fsl_remove' was not declared. Should it be static?
This patch (as1256) changes ehci-hcd and all the other drivers in the
EHCI family to make use of the new clear_tt_buffer callbacks. When a
Clear-TT-Buffer request is in progress for a QH, the QH is not allowed
to be linked into the async schedule until the request is finished.
At that time, if there are any URBs queued for the QH, it is linked
into the async schedule.
Cc: stable <stable@kernel.org>
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued
for an endpoint whose QH is already in the LINKED state, the QH
doesn't get refreshed. As a result, if usb_clear_halt() was called
during the time that the QH was linked but idle, the data toggle value
in the QH doesn't get reset.
The symptom is that after a clear_halt, data gets lost and transfers
time out. This problem is starting to show up now because the
"ehci-hcd unlink speedups" patch causes QHs with no queued URBs to
remain linked for a suitable time.
The patch utilizes the new endpoint_reset mechanism to fix the
problem. When an endpoint is reset, the new method forcibly unlinks
the QH (if necessary) and safely updates the toggle value. This
allows qh_update() to be simplified and avoids using usb_device's
toggle bits in a rather unintuitive way.
CC: David Brownell <david-b@pacbell.net>
Tested-by: David <david@unsolicited.net>
A couple of USB register initializations had to be changed on MPC85xx
platforms. This is due to the internal SoC buses being different on
MPC83xx SoCs vs MPC85xx SoCs.
We currently handle this via an ifdef since 83xx and 85xx are mutually
exclusive kernel builds.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
The bus_id field is going away, use the dev_name() function instead.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1096) fixes an annoying problem: When a full-speed or
low-speed device is plugged into an EHCI controller, it fails to
enumerate at high speed and then is handed over to the companion
controller. But usbcore logs a misleading and unwanted error message
when the high-speed enumeration fails.
The patch adds a new HCD method, port_handed_over, which asks whether
a port has been handed over to a companion controller. If it has, the
error message is suppressed.
This patch (as1095) cleans up the HCD glue and several of the EHCI
bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it
means the same thing as the hcd->has_tt flag, so it is removed and the
other flag used in its place.
Some of the bus-glue files didn't get the relinquish_port method added
to their hc_driver structures. Although that routine currently
doesn't do anything for controllers with an integrated TT, in the
future it might. So the patch adds it where it is missing.
Lastly, some of the bus-glue files have erroneous entries for their
hc_driver's suspend and resume methods. These method pointers are
specific to PCI and shouldn't be used otherwise.
(The patch also includes an invisible whitespace fix.)
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Various minor fixes to some SOC bus glue for EHCI:
- Remove a bogus copyright (by "me"!) which someone added to the FSL
driver, and an irrelevant comment.
- Un-break MODULE_ALIAS() directives after platform_bus hotplugging
acquired a backwards-incompatible change. (Which didn't fix ANY
of the in-tree drivers it prevented from hotplugging -- sigh.)
- Remove some bogus assignments of platform_bus_type; that's done by
the platform_bus code.
- Add some FIXMEs for drivers with that pointless two-level idiom for
probe() and remove() routines. ("Obfuscation" is a non-goal.)
That should help avoid future bus glue which copies that idiom.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This patch hands over the port to the companion when the
hub_port_connect_change fails.
Signed-off-by: Balaji Rao <balajirrao@gmail.com>
Host controller IRQs are supposed to be serviced with interrupts
disabled. This patch (as1026) adds an IRQF_DISABLED flag to all the
controller drivers that lack it. It also replaces the
spin_lock_irqsave() and spin_unlock_irqrestore() calls in uhci_irq()
with simple spin_lock() and spin_unlock().
This fixes Bugzilla #9335.
Acked-by: David Brownell <david-b@pacbell.net>
For MPC831x support, change the ehci-fsl driver to preserve
bits set in platform code. Add a common CONFIG_USB_EHCI_FSL
to indicate presence of Freescale EHCI SOC. Add FSL_USB2_DR_OTG
operating mode support, thus both host and device can work for the
mini-ab receptacle. Note: this doesn't enable OTG protocol
support.
Signed-off-by: Li Yang <leoli@freescale.com>
Cc: David Brownell <david-b@pacbell.net>
The patch fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=7482.
It sets USB snooping on 4G space for PowerPC platforms without
CONFIG_NOT_COHERENT_CACHE defined.
Reported-by: Stefan Meyer <reyems@telkomsa.net>
Cc: Greg KH <greg@kroah.com>
This patch implements supports for EHCI controllers whose MMIO
registers are big endian and enables that functionality for
the Toshiba SCC chip. It does _not_ add support for big endian
in-memory data structures as this is not needed for that chip
and I hope it will never be.
The guts of the patch are to convert readl(...) to
ehci_readl(ehci, ...) and similarly for register writes.
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
If some problem occurs during ehci startup, for instance, request_irq fails,
echi hcd driver tries it best to cleanup, but fails to unregister reboot
notifier, which in turn leads to crash on reboot/poweroff.
The following patch resolves this problem by not using reboot notifiers
anymore, but instead making ehci/ohci driver get its own shutdown method. For
PCI, it is done through pci glue, for everything else through platform driver
glue.
One downside: sa1111 does not use platform driver stuff, and does not have its
own shutdown hook, so no 'shutdown' is called for it now. I'm not sure if it
is really necessary on that platform, though.
Signed-off-by: Aleks Gorelov <dared1st@yahoo.com>
In some systems we may have both a platform EHCI controller and PCI EHCI
controller. Previously we couldn't build the EHCI support as a module due
to conflicting module_init() calls in the code.
In setting up the of PHY we masked off too many bits, instead just
initialize PORTSC for the type of PHY we are using.
On the MPC834x processors the multiport host (MPH) EHCI controller has an
erratum in which the port number in the queue head expects to be 0..N-1
instead of 1..N. If we are on one of these chips we subtract one from
the port number before putting it into the queue head.
Adding a Host Mode USB driver for the Freescale 83xx.
This driver supports both the Dual-Role (DR) controller and the
Multi-Port-Host (MPH) controller present in the Freescale MPC8349. It has
been tested with the MPC8349CDS reference system. This driver depends on
platform support code for setting up the pins on the device package in a
manner appropriate for the board in use. Note that this patch requires
selecting the EHCI controller option under the USB Host menu.
Signed-off-by: Randy Vinson <rvinson@mvista.com>
