This patch (as1641) fixes a minor bug in ehci-hcd left over from when
the Chipidea driver was converted to the "ehci-hcd is a library"
scheme. The test for whether the Chipidea platform driver is active
should be IS_ENABLED(), not defined().
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Without this, platform drivers e.g. ehci-omap.c will see a
different version of struct ehci_hcd than ehci-hcd.c and
break reference to 'debug_dir' and 'priv' members when
CONFIG_USB_DEBUG is enabled.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1630) cleans up a few minor items resulting from the
split-up of the ehci-hcd driver:
Remove the product_desc string from the ehci_driver_overrides
structure. All drivers will use the generic "EHCI Host
Controller" string. (This was requested by Felipe Balbi.)
Allow drivers to pass a NULL pointer to ehci_init_driver()
if they don't have to override any settings.
Remove a #define symbol that is no longer used from the
ChipIdea host driver.
Rename overrides to pci_overrides in ehci-pci.c, for
consistency with ehci-platform.c.
Mark the *_overrides structures as __initdata.
Reviewed-by: Felipe Balbi <balbi@ti.com>
This patch (as1627) splits the ehci-hcd core code, which has become a
separate library module, out from the ChipIdea host driver. Instead
of #include-ing ehci-hcd.c directly, the ChipIdea module will now use
the ehci-hcd library in a normal fashion.
This fixes a build error caused by commit
3e0232039967d7a1a06c013d097458b4d5892af1 (USB: EHCI: prepare to make
ehci-hcd a library module); I had forgotten about the unorthodox way
the ChipIdea driver uses the ehci-hcd code.
Acked-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
This patch (as1626) splits the ehci-platform code from ehci-hcd out
into its own separate driver module.
This patch (as1625) splits the PCI portion of ehci-hcd out into its
own separate driver module, called ehci-pci. Consistently with the
current practice, the decision whether to build this module is not
user-configurable. If EHCI and PCI are enabled then the module will
be built, always.
CC: Felipe Balbi <balbi@ti.com>
This patch (as1624) prepares ehci-hcd for being split up into a core
library and separate platform driver modules. A generic
ehci_hc_driver structure is created, containing all the "standard"
values, and a new mechanism is added whereby a driver module can
specify a set of overrides to those values. In addition the
ehci_setup(), ehci_suspend(), and ehci_resume() routines need to be
EXPORTed for use by the drivers.
As a side effect of this change, a few routines no longer need to be
marked __maybe_unused.
This patch (as1623) removes the ehci_port_power() routine and all the
places that call it. There's no reason for ehci-hcd to change the
port power settings; the hub driver takes care of all that stuff.
There is one exception: When the controller is resumed from
hibernation or following a loss of power, the ports that are supposed
to be handed over to a companion controller must be powered on first.
Otherwise the handover won't work. This process is not visible to the
hub driver, so it has to be handled in ehci-hcd.
This patch (as1622) removes the USB-2.1 Link Power Management code
from the ehci-hcd driver. This code was never integrated with
usbcore, it is full of bugs, and it was not getting used by anybody.
However, the debugging code for dumping the LPM-related fields in the
EHCI registers is left in place. In theory it might be useful to see
these values, even though we don't use them.
This essentially amounts to a partial revert of commit
aa4d8342988d0c1a79ff19b2ede1e81dfbb16ea5 (USB: EHCI: EHCI 1.1
addendum: preparation) and an almost full revert of commit
48f24970144479c29b8cee6d2e1dbedf6dcf9cfb (USB: EHCI: EHCI 1.1
addendum: Basic LPM feature support) plus its follow-ons.
In preparation for splitting the ehci-hcd driver into a core library
and separate platform-specific driver modules, this patch (as1617)
changes the way ehci_read_frame_index() is handled.
Since the same core library will have to work with both PCI and
non-PCI platforms, the quirk handler routine will be compiled
unconditionally. The decision about whether to call it or simply to
read the frame index register is made at run time, based on whether
the frame_index_bug quirk flag is set.
Acked-by: Felipe Balbi <balbi@ti.com>
The users have been converted to use the ehci platform driver instead, thus
making the ehci-cns3xxx driver obsolete, so remove it.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The platform code has been converted to use the ehci-platform driver instead
thus obsoleting the ehci-au1xxx driver, which can be removed.
The platform code has been migrated to register the ehci-platform driver, thus
obsoleting the ehci-xls driver, which can be removed.
The platform code registering the Loongson 1B EHCI driver has now been
converted to register the ehci-platform driver instead, thus obsoleting the
ehci-ls1x driver, which can be removed.
This driver is not registered by any in-tree user. If needed it the EHCI
driver can be reinstatied using the ehci-platform driver with caps_offset to
0x100.
This patch (as1609) changes the way ehci-hcd uses the "Isochronous
Scheduling Threshold" in its calculations. Until now the code has
ignored the threshold except for certain Intel PCI-based controllers.
This violates the EHCI spec.
The new code takes the threshold into account always, removing the
need for the fs_i_thresh quirk flag. In addition it implements the
"full frame cache" setting more efficiently, moving forward only as
far as the next frame boundary instead of always moving forward 8
microframes.
Just like for the in-tree early console debug port driver, the
hypervisor - when using a debug port based console - also needs to be
told about controller resets, so it can suppress using and then
re-initialize the debug port accordingly.
Other than the in-tree driver, the hypervisor driver actually cares
about doing this only for the device where the debug is port actually
in use, i.e. it needs to be told the coordinates of the device being
reset (quite obviously, leveraging the addition done for that would
likely benefit the in-tree driver too).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg Kroah-Hartman:
"Here's the big USB patch set for the 3.6-rc1 merge window.
Lots of little changes in here, primarily for gadget controllers and
drivers. There's some scsi changes that I think also went in through
the scsi tree, but they merge just fine. All of these patches have
been in the linux-next tree for a while now.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fix up trivial conflicts in include/scsi/scsi_device.h (same libata
conflict that Jeff had already encountered)
* tag 'usb-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (207 commits)
usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcams
usb: Add quirk detection based on interface information
usb: s3c-hsotg: Add header file protection macros in s3c-hsotg.h
USB: ehci-s5p: Add vbus setup function to the s5p ehci glue layer
USB: add USB_VENDOR_AND_INTERFACE_INFO() macro
USB: notify phy when root hub port connect change
USB: remove 8 bytes of padding from usb_host_interface on 64 bit builds
USB: option: add ZTE MF821D
USB: sierra: QMI mode MC7710 moved to qcserial
USB: qcserial: adding Sierra Wireless devices
USB: qcserial: support generic Qualcomm serial ports
USB: qcserial: make probe more flexible
USB: qcserial: centralize probe exit path
USB: qcserial: consolidate usb_set_interface calls
USB: ehci-s5p: Add support for device tree
USB: ohci-exynos: Add support for device tree
USB: ehci-omap: fix compile failure(v1)
usb: host: tegra: pass correct pointer in ehci_setup()
USB: ehci-fsl: Update ifdef check to work on 64-bit ppc
USB: serial: keyspan: Removed unrequired parentheses.
This change adds OHCI and EHCI support for the tilegx's on-chip
USB hardware.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This patch (as1589) resolves some unlikely races involving system
shutdown or controller death in ehci-hcd:
Shutdown races with both root-hub resume and controller
resume.
Controller death races with root-hub suspend.
A new bitflag is added to indicate that the controller has been shut
down (whether for system shutdown or because it died). Tests are
added in the suspend and resume pathways to avoid reactivating the
controller after any sort of shutdown.
This patch (as1588) adjusts the locking in ehci-hcd's various halt,
shutdown, and suspend/resume pathways. We want to hold the spinlock
while writing device registers and accessing shared variables, but not
while polling in a loop.
In addition, there's no need to call ehci_work() at times when no URBs
can be active, i.e., in ehci_stop() and ehci_bus_suspend().
Finally, ehci_adjust_port_wakeup_flags() is called only in situations
where interrupts are enabled; therefore it can use spin_lock_irq
rather than spin_lock_irqsave.
This patch (as1587) simplifies ehci-hcd's scan_isoc() routine by
eliminating some local variables, declaring boolean-valued values as
bool rather than unsigned, changing variable names to make more sense,
and so on.
The logic at the end of the routine is cut down significantly. The
scanning doesn't have to catch up all the way to where the hardware
is; it merely has to catch up to where the hardware was when the last
interrupt occurred. If the hardware has made more progress since then
and issued another interrupt, a rescan will catch up to it.
This patch (as1586) replaces the kernel timer used by ehci-hcd as an
I/O watchdog with an hrtimer event.
Unlike in the current code, the watchdog event is now always enabled
whenever any isochronous URBs are active. This will prevent bugs
caused by the periodic schedule wrapping around with no completion
interrupts; the watchdog handler is guaranteed to scan the isochronous
transfers at least once during each iteration of the schedule. The
extra overhead will be negligible: one timer interrupt every 100 ms.
This patch (as1585) fixes a bug in ehci-hcd's scheme for scanning
interrupt QHs.
Currently a single routine takes care of scanning everything on the
periodic schedule. Whenever an interrupt occurs, it scans all
isochronous and interrupt URBs scheduled for frames that have elapsed
since the last scan.
This has two disadvantages. The first is relatively minor: An
interrupt QH is likely to end up getting scanned multiple times,
particularly if the last scan was not fairly recent. (The current
code avoids this by maintaining a periodic_stamp in each interrupt
QH.)
The second is more serious. The periodic schedule wraps around. If
the last scan occurred during frame N, and the next scan occurs when
the schedule has gone through an entire cycle and is back at frame N,
the scanning code won't look at any frames other than N. Consequently
it won't see any QHs that completed during frame N-1 or earlier.
The patch replaces the entire frame-based approach for scanning
interrupt QHs with a new routine using a list-based approach, the same
as for async QHs. This has a slight disadvantage, because it means
that all interrupt QHs have to be scanned every time. But it is more
robust than the current approach.
This patch (as1584) fixes a minor bug that has been present in
ehci-hcd since the beginning.
Scanning the schedules for URB completions is single-threaded. If a
completion interrupt occurs while an URB is being given back, the
interrupt handler realizes that a scan is in progress on another CPU
and avoids starting a new one.
This means that completion events can be lost. If an URB completes
after it has been scanned but while a scan is still in progress, the
driver won't notice and won't rescan the completed URB.
The patch fixes the problem by adding a new flag to indicate that
another scan is needed after the current scan is done. The flag gets
set whenever a completion interrupt occurs while a scan is in
progress. The rescan will see the completion, thus preventing it from
getting lost.
This patch (as1583) changes ehci-hcd to use an hrtimer event for
unlinking empty (unused) async QHs instead of using a kernel timer.
The check for empty QHs is moved to a new routine, where it doesn't
require going through an entire scan of both the async and periodic
schedules. And it can unlink multiple QHs at once, unlike the current
code.
This patch (as1582) changes ehci-hcd's strategy for unlinking async
QHs. Currently the driver never unlinks more than one QH at a time.
This can be inefficient and cause unnecessary delays, since a QH
cannot be reused while it is waiting to be unlinked.
The new strategy unlinks all the waiting QHs at once. In practice the
improvement won't be very big, because it's somewhat uncommon to have
two or more QHs waiting to be unlinked at any time. But it does
happen, and in any case, doing things this way makes more sense IMO.
The change requires the async unlinking code to be refactored
slightly. Now in addition to the routines for starting and ending an
unlink, there are new routines for unlinking a single QH and starting
an IAA cycle. This approach is needed because there are two separate
paths for unlinking async QHs:
When a transfer error occurs or an URB is cancelled, the QH
must be unlinked right away;
When a QH has been idle sufficiently long, it is unlinked
to avoid consuming DMA bandwidth uselessly.
In the first case we want the unlink to proceed as quickly as
possible, whereas in the second case we can afford to batch several
QHs together and unlink them all at once. Hence the division of
labor.
This patch (as1581) replaces the iaa_watchdog kernel timer used by
ehci-hcd with an hrtimer event, in keeping with the general conversion
to high-res timers.
This patch (as1580) makes ehci_iso_stream structures behave more like
QHs, in that they will remain allocated until their isochronous
endpoint is disabled. This will come in useful in the future, when
periodic bandwidth gets allocated as an altsetting is installed rather
than on-the-fly.
For now, the change to the ehci_iso_stream lifetimes means that each
structure is always deallocated at exactly one spot in
ehci_endpoint_disable() and never used again. As a result, it is no
longer necessary to use reference counting on these things, and the
patch removes it.
This patch (as1579) adds an hrtimer event to handle deallocation of
iTDs and siTDs in ehci-hcd.
Because of the frame-oriented approach used by the EHCI periodic
schedule, the hardware can continue to access the Transfer Descriptor
for isochronous (or split-isochronous) transactions for up to a
millisecond after the transaction completes. The iTD (or siTD) must
not be reused before then.
The strategy currently used involves putting completed iTDs on a list
of cached entries and every so often returning them to the endpoint's
free list. The new strategy reduces overhead by putting completed
iTDs back on the free list immediately, although they are not reused
until it is safe to do so.
When the isochronous endpoint stops (its queue becomes empty), the
iTDs on its free list get moved to a global list, from which they will
be deallocated after a minimum of 2 ms. This delay is what the new
hrtimer event is for.
Overall this may not be a tremendous improvement over the current
code, but to me it seems a lot more clear and logical. In addition,
it removes the need for each iTD to keep a reference to the
ehci_iso_stream it belongs to, since the iTD never needs to be moved
back to the stream's free list from the global list.
This patch (as1578) adds an hrtimer event to handle the death of an
EHCI controller. When a controller dies, it doesn't necessarily stop
running right away. The new event polls at 1-ms intervals to see when
all activity has safely stopped. This replaces a busy-wait polling
loop in the current code.
This patch (as1577) adds hrtimer support for unlinking interrupt QHs
in ehci-hcd. The current code relies on a fixed delay of either 2 or
55 us, which is not always adequate and in any case is totally bogus.
Thanks to internal caching, the EHCI hardware may continue to access
an interrupt QH for more than a millisecond after it has been unlinked.
In fact, the EHCI spec doesn't say how long to wait before using an
unlinked interrupt QH. The patch sets the delay to 9 microframes
minimum, which ought to be adequate.
This patch (as1576) adds hrtimer support for managing ehci-hcd's
async schedule. Just as with the earlier change to the periodic
schedule management, two new hrtimer events take care of everything.
One event polls at 1-ms intervals to see when the Asynchronous
Schedule Status (ASS) flag matches the Asynchronous Schedule Enable
(ASE) value; the schedule's state must not be changed until it does.
The other event delays for 15 ms after the async schedule becomes
empty before turning it off.
The new events replace a busy-wait poll and a kernel timer usage.
They also replace the rather illogical method currently used for
indicating the async schedule should be turned off: attempting to
unlink the dedicated QH at the head of the async list.
This patch (as1575) removes special code added for status polling of
the EHCI controller in PS3 systems. While the controller is running,
the polling is now carried out by an hrtimer handler. When the
controller is suspending or stopping, we use the same polling routine
as the old code -- but in neither case do we need to conclude that the
controller has died if the polling goes on for too long.
As a result the entire handshake_on_error_set_halt() routine is now
unused, so it is removed from the driver.
This patch (as1573) adds hrtimer support for managing ehci-hcd's
periodic schedule. There are two issues to deal with.
First, the schedule's state (on or off) must not be changed until the
hardware status has caught up with the current command. This is
handled by an hrtimer event that polls at 1-ms intervals to see when
the Periodic Schedule Status (PSS) flag matches the Periodic Schedule
Enable (PSE) value.
Second, the schedule should not be turned off as soon as it becomes
empty. Turning the schedule on and off takes time, so we want to wait
until the schedule has been empty for a suitable period before turning
it off. This is handled by an hrtimer event that gets set to expire
10 ms after the periodic schedule becomes empty.
The existing code polls (for up to 1125 us and with interrupts
disabled!) to check the status, and doesn't implement a delay before
turning off the schedule. Furthermore, if the polling fails then the
driver decides that the controller has died. This has caused problems
for several people; some controllers can take 10 ms or more to turn
off their periodic schedules.
This patch fixes these issues. It also makes the "broken_periodic"
workaround unnecessary; there is no longer any danger of turning off
the periodic schedule after it has been on for less than 1 ms.
This patch (as1572) begins the conversion of ehci-hcd over to using
high-resolution timers rather than old-fashioned low-resolution kernel
timers. This reduces overhead caused by timer roundoff on systems
where HZ is smaller than 1000. Also, the new timer framework
introduced here is much more logical and easily extended than the
ad-hoc approach ehci-hcd currently uses for timers.
An hrtimer structure is added to ehci_hcd, along with a bitflag array
and an array of ktime_t values, to keep track of which timing events
are pending and what their expiration times are.
Only the infrastructure for the timing operations is added in this
patch. Later patches will add routines for handling each of the
various timing events the driver needs. In some cases the new hrtimer
handlers will replace the existing handlers for ehci-hcd's kernel
timers; as this happens the old timers will be removed. In other
cases the new timing events will replace busy-wait loops.
This patch (as1571) adds a new state for ehci-hcd's root hubs:
EHCI_RH_STOPPING. This value is used at times when the root hub is
being stopped and we don't know whether or not the hardware has
finished all its DMA yet.
Although the purpose may not be apparent, this distinction will come
in useful later on. Future patches will avoid actions that depend on
the root hub being operational (like turning on the async or periodic
schedules) when they see the state is EHCI_RH_STOPPING.
This patch (as1570) adds a pointer for the end of ehci-hcd's
async-unlink list. The list (which is actually a queue) is singly
linked, so having a pointer to its end makes adding new entries easier
-- there's no longer any need to scan through the whole list.
In principle it could be changed to a standard doubly-linked list. It
turns out that doing so actually makes the code less clear, so I'm
leaving it as is.
This patch (as1569) renames the ehci->reclaim list in ehci-hcd. The
word "reclaim" is used in the EHCI specification to mean something
quite different, and "unlink_next" is more descriptive of the list's
purpose anyway.
Similarly, the "reclaim" field in the ehci_stats structure is renamed
"iaa", which is more meaningful (to experts, anyway) and is a better
match for the "lost_iaa" field.
This patch (as1568) introduces symbolic constants for some of the
less-frequently used bitfields in the QH structure. This makes the
code a little easier to read and understand.
This patch (as1567) removes ehci-hcd's reference counting of QH
structures. It's not necessary to refcount these things because they
always get deallocated at exactly one spot in ehci_endpoint_disable()
(except for two special QHs, ehci->async and ehci->dummy) and are
never used again.
This patch (as1566) removes the code in ehci-hcd's resume routines
which tries to restart or cancel any transfers left active while the
root hub or controller was asleep. This code isn't necessary, because
all URBs are terminated before the root hub is suspended.
Currently, EHCI initialization turns off the controller (in case it
was left running by the firmware) before setting up the ehci_hcd data
structure. This patch (as1565) reverses that order.
Although it doesn't matter now, it will matter later on when future
additions to ehci_halt() will want to acquire a spinlock that gets
initialized by ehci_init().
This patch (as1564c) converts the EHCI platform drivers to use the
central ehci_setup() routine for generic controller initialization
rather than each having its own idiosyncratic approach.
The major point of difficulty lies in ehci-pci's many vendor- and
device-specific workarounds. Some of them have to be applied before
calling ehci_setup() and some after, which necessitates a fair amount
of code motion. The other platform drivers require much smaller
changes.
One point not addressed by the patch is whether ports should be
powered on or off following initialization. The different drivers
appear to handle this pretty much at random. In fact it shouldn't
matter, because the hub driver turns on power to all ports when it
binds to the root hub. Straightening that out will be left for
another day.
This patch (as1563) removes a lot of duplicated code by moving the
EHCI controller suspend/resume routines into the core driver, where
the various platform drivers can invoke them as needed.
Not only does this simplify these platform drivers, this also makes it
easier for other platform drivers to add suspend/resume support in the
future.
Note: The patch does not touch the ehci-fsl.c file, because its
approach to suspend and resume is so different from all the others.
It will have to be handled specially by its maintainer.
This patch (as1562) cleans up the definitions of the EHCI extended
registers to be consistent with the definitions of the standard
registers. This makes the code look a lot nicer, with no functional
change.
After commit aaa0ef289afe9186f81e2340114ea413eef0492a "PS3 EHCI QH
read work-around", Terratec Grabby (em28xx) stopped working with AMD
Geode LX 800 (USB controller AMD CS5536). Since this is a PS3 only
fix, the following patch adds a conditional block around it.
Signed-off-by: Ricardo Martins <rasm@fe.up.pt>
Cc: stable <stable@vger.kernel.org>
This reverts commit 1996e6c572969a8cf6d7fa97eef621219acd94a9.
It turned out to not be needed, now that the real fix has been
committed.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@kernel.org>
The 3d9545cc375d117554a9b35dfddadf9189c62775(EHCI: maintain the
ehci->command value properly) introducs one command register
configuration lost problem by the below line in ehci_reset:
ehci->command = ehci_readl(ehci, &ehci->regs->command);
After writting RESET into command register, it is restored to
its default value per EHCI spec[1], so the previous configuration
will be lost, and may introduce some problems reported recently:
- imx51 Babbage board detect usb hub failed[2], reported
by Richard Zhao.
- mouse and keyboard hangs in linux-next found by
Dan Carpenter and Greg-KH.
So this patch just removes the line to fix these problems, and
keep configurating command register consistent as before the commit
3d9545cc(EHCI: maintain the ehci->command value properly).
[1], 4.1 Host Controller Initialization of EHCI Specification 1.0
[2], failed dmesg log:
usb 1-1: new high-speed USB device number 2 using mxc-ehci
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 7 ports detected
mxc-ehci mxc-ehci.1: fatal error
mxc-ehci mxc-ehci.1: HC died; cleaning up
mxc-ehci mxc-ehci.1: force halt; handshake f5780344 00004000 00004000 -> -110
usb 1-1: USB disconnect, device number 2
Reported-by: Richard Zhao <richard.zhao@freescale.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Chen Peter-B29397 <B29397@freescale.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This patch (as1556) works around a bug in the Philips ISP1562 EHCI
controller. Although the controller claims to support frame-list
lengths smaller than the default of 1024 for its periodic schedule, in
fact smaller values don't work. A new quirk flag is added to indicate
when the bug is present, and if it is then the schedule size is left
at the default value.
