git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits)
EHCI: fix direction handling for interrupt data toggles
USB: serial: add IDs for WinChipHead USB->RS232 adapter
USB: OHCI: fix another regression for NVIDIA controllers
usb: gadget: m66592-udc: add pullup function
usb: gadget: m66592-udc: add function for external controller
usb: gadget: r8a66597-udc: add pullup function
usb: renesas_usbhs: support multi driver
usb: renesas_usbhs: inaccessible pipe is not an error
usb: renesas_usbhs: care buff alignment when dma handler
USB: PL2303: correctly handle baudrates above 115200
usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift
usb: renesas_usbhs: compile/config are rescued
usb: renesas_usbhs: fixup comment-out
usb: update email address in ohci-sh and r8a66597-hcd
usb: r8a66597-hcd: add function for external controller
EHCI: only power off port if over-current is active
USB: mon: Allow to use usbmon without debugfs
USB: EHCI: go back to using the system clock for QH unlinks
ehci: add pci quirk for Ordissimo and RM Slate 100 too
ehci: refactor pci quirk to use standard dmi_check_system method
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
This patch (as1477) fixes a problem affecting a few types of EHCI
controller. Contrary to what one might expect, these controllers
automatically stop their internal frame counter when no ports are
enabled. Since ehci-hcd currently relies on the frame counter for
determining when it should unlink QHs from the async schedule, those
controllers run into trouble: The frame counter stops and the QHs
never get unlinked.
Some systems have also experienced other problems traced back to
commit b963801164618e25fbdc0cd452ce49c3628b46c8 (USB: ehci-hcd unlink
speedups), which made the original switch from using the system clock
to using the frame counter. It never became clear what the reason was
for these problems, but evidently it is related to use of the frame
counter.
To fix all these problems, this patch more or less reverts that commit
and goes back to using the system clock. But this can't be done
cleanly because other changes have since been made to the scan_async()
subroutine. One of these changes involved the tricky logic that tries
to avoid rescanning QHs that have already been seen when the scanning
loop is restarted, which happens whenever an URB is given back.
Switching back to clock-based unlinks would make this logic even more
complicated.
Therefore the new code doesn't rescan the entire async list whenever a
giveback occurs. Instead it rescans only the current QH and continues
on from there. This requires the use of a separate pointer to keep
track of the next QH to scan, since the current QH may be unlinked
while the scanning is in progress. That new pointer must be global,
so that it can be adjusted forward whenever the _next_ QH gets
unlinked. (uhci-hcd uses this same trick.)
Simplification of the scanning loop removes a level of indentation,
which accounts for the size of the patch. The amount of code changed
is relatively small, and it isn't exactly a reversion of the
b963801164 commit.
This fixes Bugzilla #32432.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@kernel.org>
Tested-by: Matej Kenda <matejken@gmail.com>
There are cases, when 80% max isochronous bandwidth is too limiting.
For example I have two USB video capture cards which stream uncompressed
video, and to stream full NTSC + PAL videos we'd need
NTSC 640x480 YUV422 @30fps ~17.6 MB/s
PAL 720x576 YUV422 @25fps ~19.7 MB/s
isoc bandwidth.
Now, due to limited alt settings in capture devices NTSC one ends up
streaming with max_pkt_size=2688 and PAL with max_pkt_size=2892, both
with interval=1. In terms of microframe time allocation this gives
NTSC ~53us
PAL ~57us
and together
~110us > 100us == 80% of 125us uframe time.
So those two devices can't work together simultaneously because the'd
over allocate isochronous bandwidth.
80% seemed a bit arbitrary to me, and I've tried to raise it to 90% and
both devices started to work together, so I though sometimes it would be
a good idea for users to override hardcoded default of max 80% isoc
bandwidth.
After all, isn't it a user who should decide how to load the bus? If I
can live with 10% or even 5% bulk bandwidth that should be ok. I'm a USB
newcomer, but that 80% set in stone by USB 2.0 specification seems to be
chosen pretty arbitrary to me, just to serve as a reasonable default.
NOTE 1
for two streams with max_pkt_size=3072 (worst case) both time
allocation would be 60us+60us=120us which is 96% periodic bandwidth
leaving 4% for bulk and control. Alan Stern suggested that bulk then
would be problematic (less than 300*8 bittimes left per microframe), but
I think that is still enough for control traffic.
NOTE 2
Sarah Sharp expressed concern that maxing out periodic bandwidth
could lead to vendor-specific hardware bugs on host controllers, because
> It's entirely possible that you'll run into
> vendor-specific bugs if you try to pack the schedule with isochronous
> transfers. I don't think any hardware designer would seriously test or
> validate their hardware with a schedule that is basically a violation of
> the USB bus spec (more than 80% for periodic transfers).
So far I've only tested this patch on my HP Mini 5103 with N10 chipset
kirr@mini:~$ lspci
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller
00:02.1 Display controller: Intel Corporation N10 Family Integrated Graphics Controller
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation N10/ICH7 Family SATA AHCI Controller (rev 02)
01:00.0 Network controller: Broadcom Corporation BCM4313 802.11b/g/n Wireless LAN Controller (rev 01)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8059 PCI-E Gigabit Ethernet Controller (rev 11)
and the system works stable with 110us/uframe (~88%) isoc bandwith allocated for
above-mentioned isochronous transfers.
NOTE 3
This feature is off by default. I mean max periodic bandwidth is set to
100us/uframe by default exactly as it was before the patch. So only those of us
who need the extreme settings are taking the risk - normal users who do not
alter uframe_periodic_max sysfs attribute should not see any change at all.
NOTE 4
I've tried to update documentation in Documentation/ABI/ thoroughly, but
only "TBD" was put into Documentation/usb/ehci.txt -- the text there seems
to be outdated and much needing refreshing, before it could be amended.
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
The only sysfs attr implemented so far is "companion" from ehci-hub.c,
but in the next patch we are going to add another sysfs file, so prior
to that let's structure things and move already-in-there sysfs code to
separate file.
NOTE: All the code I'm moving into this new file was written by Alan
Stern (in 57e06c11 "EHCI: force high-speed devices to run at full
speed"; Jan 16 2007), that's why I'm putting
Copyright (C) 2007 by Alan Stern
there after explicit request from the author.
Following the loss of David Brownell, I volunteer to maintain the
ohci-hcd and ehci-hcd drivers. This patch (as1472) makes it official.
There is no need to have a "\n" on a MODULE_PARM_DESC, remove it
Signed-off-by: Niels de Vos <ndevos@redhat.com>
This patch (as1467) removes the last usages of hcd->state from
usbcore. We no longer check to see if an interrupt handler finds that
a controller has died; instead we rely on host controller drivers to
make an explicit call to usb_hc_died().
This fixes a regression introduced by commit
9b37596a2e860404503a3f2a6513db60c296bfdc (USB: move usbcore away from
hcd->state). It used to be that when a controller shared an IRQ with
another device and an interrupt arrived while hcd->state was set to
HC_STATE_HALT, the interrupt handler would be skipped. The commit
removed that test; as a result the current code doesn't skip calling
the handler and ends up believing the controller has died, even though
it's only temporarily stopped. The solution is to ignore HC_STATE_HALT
following the handler's return.
As a consequence of this change, several of the host controller
drivers need to be modified. They can no longer implicitly rely on
usbcore realizing that a controller has died because of hcd->state.
The patch adds calls to usb_hc_died() in the appropriate places.
The patch also changes a few of the interrupt handlers. They don't
expect to be called when hcd->state is equal to HC_STATE_HALT, even if
the controller is still alive. Early returns were added to avoid any
confusion.
Tested-by: Manuel Lauss <manuel.lauss@googlemail.com>
CC: Rodolfo Giometti <giometti@linux.it>
CC: Olav Kongas <ok@artecdesign.ee>
This patch adds support for the GRLIB GRUSBHC EHCI controller from
Aeroflex Gaisler. The controller is typically found on LEON/GRLIB
SoCs.
Tested on GR-LEON4-ITX with with little endian interface and on
LEON3 system on GR-PCI-XC5V development board for big endian
controller.
Signed-off-by: Jan Andersson <jan@gaisler.com>
The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
The Atheros AR71XX/AR91XX SoCs have a built-in EHCI controller.
This patch adds the necessary glue code to make the generic EHCI
driver usable for them.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
This patch adds host USB high speed driver for samsung S5P series. This
is initial driver and we need additional implementation to support some
functions like power management.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt: Eliminate of_platform_{,un}register_driver
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
The Tegra 2 SoC has 3 EHCI compatible USB controllers. This patch adds
the necessary glue to allow the ehci-hcd driver to work on Tegra 2
SoCs.
The platform data is used to configure board-specific phy settings and
to configure the operating mode, as one of the ports may be used as a otg
port. For additional power saving, the driver supports powering down the
phy on bus suspend when it is used, for example, to connect an internal
device that use an out-of-band remote wakeup mechanism (e.g. a gpio).
Signed-off-by: Benoit Goby <benoit@android.com>
The SH EHCI/OHCI driver hardcoded the CPU type in {ehci,ohci}-hcd.c.
So if we will add the new CPU, we had to add to the hcd driver each time.
The patch adds the CONFIG_USB_{EHCI,OHCI}_SH configuration. So if we
want to use the SH EHCI/OHCI, we only enable the configuration.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
This patch moves the AMD PLL quirk code in OHCI/EHCI driver to pci-quirks.c,
and exports the functions to be used by xHCI driver later.
AMD PLL quirk disable the optional PM feature inside specific
SB700/SB800/Hudson-2/3 platforms under the following conditions:
1. If an isochronous device is connected to OHCI/EHCI/xHCI port and is active;
2. Optional PM feature that powers down the internal Bus PLL when the link is
in low power state is enabled.
Without AMD PLL quirk, USB isochronous stream may stutter or have breaks
occasionally, which greatly impair the performance of audio/video streams.
Currently AMD PLL quirk is implemented in OHCI and EHCI driver, and will be
added to xHCI driver too. They are doing similar things actually, so move
the quirk code to pci-quirks.c, which has several advantages:
1. Remove duplicate defines and functions in OHCI/EHCI (and xHCI) driver and
make them cleaner;
2. AMD chipset information will be probed only once and then stored.
Currently they're probed during every OHCI/EHCI initialization, move
the detect code to pci-quirks.c saves the repeat detect cost;
3. Build up synchronization among OHCI/EHCI/xHCI driver. In current
code, every host controller enable/disable PLL only according to
its own status, and may enable PLL while there is still isoc transfer on
other HCs. Move the quirk to pci-quirks.c prevents this issue.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alex He <alex.he@amd.com>
Get rid of users of of_platform_driver in drivers/usb. The
of_platform_{,un}register_driver functions are going away, so the
users need to be converted to using the platform_bus_type directly.
This patch add bus glue for USB controller commonly found in PMC-Sierra MSP71xx family of SoC's.
Signed-off-by: Anoop P A <anoop.pa@gmail.com>
TDI driver does the ehci_reset in their reset callback.
Don't reset in ehci_run because configuration settings done in
platform driver will be reset.
This will allow to make msm use ehci_run.
Signed-off-by: Matthieu CASTET <castet.matthieu@parrot.com>
This patch (as1440) fixes a bug in ehci-hcd. ehci->periodic_size is
used to compute the size in a dma_alloc_coherent() call, but then it
gets changed later on. As a result, the corresponding call to
dma_free_coherent() passes a different size from the original
allocation. Fix the problem by adjusting ehci->periodic_size before
carrying out any of the memory allocations.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
CC: David Brownell <david-b@pacbell.net>
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits)
USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004)
USB: serial: ftdi_sio: add support for TIOCSERGETLSR
USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport
USB: atmel_usba_udc: fix freeing irq in usba_udc_remove()
usb: ehci-omap: fix tll channel enable mask
usb: ohci-omap3: fix trivial typo
USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096
USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's
USB: gadget: update ci13xxx to work with g_ether
USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers
Revert "USB: musb: pm: don't rely fully on clock support"
Revert "USB: musb: blackfin: pm: make it work"
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
Manually fix up trivial conflicts in USB Kconfig changes in:
arch/arm/mach-omap2/Kconfig
arch/sh/Kconfig
drivers/usb/Kconfig
drivers/usb/host/ehci-hcd.c
and annoying chip clock data conflicts in:
arch/arm/mach-omap2/clock3xxx_data.c
arch/arm/mach-omap2/clock44xx_data.c
into devel-stable
* usb-next: (132 commits)
usb: gadget: f_ncm.c added
usb: gadget: u_ether: prepare for NCM
usb: pch_udc: Fix setup transfers with data out
usb: pch_udc: Fix compile error, warnings and checkpatch warnings
usb: add ab8500 usb transceiver driver
USB: gadget: Implement runtime PM for MSM bus glue driver
USB: gadget: Implement runtime PM for ci13xxx gadget
USB: gadget: Add USB controller driver for MSM SoC
USB: gadget: Introduce ci13xxx_udc_driver struct
USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask
USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc
USB: gadget: Separate out PCI bus code from ci13xxx_udc
This patch adds support for EHCI compliant HSUSB Host controller found
on MSM chips. The root hub has a single port and TT is built into it.
This driver depends on OTG driver for PHY initialization, clock
management and powering up VBUS.
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
When ASPM PM Feature is enabled on UMI link, devices that use ISOC stream of
data transfer may be exposed to longer latency causing less than optimal per-
formance of the device. The longer latencies are normal and are due to link
wake time coming out of low power state which happens frequently to save
power when the link is not active.
The following code will make exception for certain features of ASPM to be by
passed and keep the logic normal state only when the ISOC device is connected
and active. This change will allow the device to run at optimal performance
yet minimize the impact on overall power savings.
Signed-off-by: Alex He <alex.he@amd.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: stable <stable@kernel.org>
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6 into work
* 'sh/ehci' of master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Convert to USB_ARCH_HAS_OHCI/EHCI selects.
usb: ehci-sh: Add missing ehci helpers.
usb: ehci-sh: Fix up fault in shutdown path.
sh: Add EHCI support for SH7786.
usb: ehci-hcd: Add support for SuperH EHCI.
usb: ohci-sh: Set IRQ as shared.
Introduce the CONFIG_USB_EHCI_HCD_OMAP option to select
EHCI support on OMAP3 and later chips. This scales better
than having a long line of dependencies for each new OMAP
with EHCI support.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
The CNS3XXX SOC has include USB EHCI and OHCI compatible controllers.
This patch adds the necessary glue logic to allow ehci-hcd and ohci-hcd
drivers to work on CNS3XXX
The EHCI and OHCI controllers share a common clock control and reset
bit, therefore additional check for the timming of enabling and disabling
is required. The USB bit of PLL Power Down Control is also shared by OTG,
24MHzUART clock, Crypto clock, PCIe reference clock, and Clock Scale
Generator. Therefore we only ensure it is enabled, while not disabling it.
Signed-off-by: Mac Lin <mkl0301@gmail.com>
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
This patch adds support for ehci and ohci controller in the SPEAr platform.
Changes since V2:
added clear_tt_buffer_complete in ehci_spear_hc_driver
Signed-off-by: Deepak Sikri <deepak.sikri@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
This patch (as1435) fixes an obscure and unlikely race in ehci-hcd.
When an async URB is unlinked, the corresponding QH is removed from
the async list. If the QH's endpoint is then disabled while the URB
is being given back, ehci_endpoint_disable() won't find the QH on the
async list, causing it to believe that the QH has been lost. This
will lead to a memory leak at best and quite possibly to an oops.
The solution is to trust usbcore not to lose track of endpoints. If
the QH isn't on the async list then it doesn't need to be taken off
the list, but the driver should still wait for the QH to become IDLE
before disabling it.
In theory this fixes Bugzilla #20182. In fact the race is so rare
that it's not possible to tell whether the bug is still present.
However, adding delays and making other changes to force the race
seems to show that the patch works.
Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
CC: stable <stable@kernel.org>
VIA and WonderMedia Systems-on-Chip feature a standard EHCI host
controller. This adds necessary glue to use the standard driver
with these systems.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
This adds a trivial stub for supporting EHCI mode of the on-chip
SH USB host controllers.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The OCTEON II SOC has USB EHCI and OHCI controllers connected directly
to the internal I/O bus. This patch adds the necessary 'glue' logic
to allow ehci-hcd and ohci-hcd drivers to work on OCTEON II.
The OCTEON normally runs big-endian, and the ehci/ohci internal
registers have host endianness, so we need to select
USB_EHCI_BIG_ENDIAN_MMIO.
The ehci and ohci blocks share a common clocking and PHY
infrastructure. Initialization of the host controller and PHY clocks
is common between the two and is factored out into the
octeon2-common.c file.
Setting of USB_ARCH_HAS_OHCI and USB_ARCH_HAS_EHCI is done in
arch/mips/Kconfig in a following patch.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-usb@vger.kernel.org
To: dbrownell@users.sourceforge.net
Patchwork: http://patchwork.linux-mips.org/patch/1675/
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
tdi_reset is already taking care of setting host mode for tdi devices.
Don't duplicate code in platform driver.
Make ehci_halt a nop if the controller is not in host mode (otherwise it
will fail), and let's ehci_reset do the tdi_reset.
We need to move hcd->has_tt flags before ehci_halt, in order ehci_halt
knows we are a tdi device.
Before the setup routine was doing :
- put controller in host mode
- ehci_halt
- ehci_init
- hcd->has_tt = 1;
- ehci_reset
Now we do :
- hcd->has_tt = 1;
- ehci_halt
- ehci_init
- ehci_reset
PS : now we handle correctly the device -> host transition.
Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com>
fs/exofs/inode.c
This patch (as1407) fixes a bug in ehci-hcd's isochronous scheduler.
All its calculations should be done in terms of microframes, but for
full-speed devices, sched->span is stored in frames. It needs to be
converted.
This fix is liable to expose problems in other drivers. The old code
would accept URBs that should not have been accepted, so drivers have
had no reason to avoid submitting URBs that exceeded the maximum
schedule length. In an attempt to partially compensate for this, the
patch also adjusts the schedule length from a minimum of 256 frames up
to a minimum of 512 frames.
If we use the HCD_LOCAL_MEM flag and dma_declare_coherent_memory() to
enforce the host controller's local memory utilization we also need to
disable native scatter-gather support, otherwise hcd_alloc_coherent() in
map_urb_for_dma() is called with urb->transfer_buffer == NULL, that
triggers a NULL pointer dereference.
We can also consider to add a WARN_ON() and return an error code to
better catch this problem in the future.
At the moment no driver seems to hit this bug, so I should
consider this a low-priority fix.
Signed-off-by: Andrea Righi <arighi@develer.com>
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
This patch will enable Per-port event feature defined in EHCI 1.1
addendum. This feature addresses an issue where HCD is currently
required to read and parse PORTSC for all enabled root hub ports. With
this patch, the overhead will be reduced.
Signed-off-by: Alek Du <alek.du@intel.com>
With this patch, the LPM capable EHCI host controller can put device
into L1 sleep state which is a mode that can enter/exit quickly, and
reduce power consumption.
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
EHCI 1.1 addendum introduced several energy efficiency extensions for
EHCI USB host controllers:
1. LPM (link power management)
2. Per-port change
3. Shorter periodic frame list
4. Hardware prefetching
This patch is intended to define the HW bits and debug interface for
EHCI 1.1 addendum. The LPM and Per-port change patches will be sent out
after this patch.
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
This patch fixes the driver to allow both CONFIG_USB_EHCI_HCD_PPC_OF and
CONFIG_USB_ECHI_HCD_XILINX to be selected.
CC: John Linn <john.linn@xilinx.com>
CC: Alan Stern <stern@rowland.harvard.edu>
The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
This patch (as1369) fixes a problem in ehci-hcd. Some controllers
occasionally run into trouble when the driver reclaims siTDs too
quickly. This can happen while streaming audio; it causes the
controller to crash.
The patch changes siTD reclamation to work the same way as iTD
reclamation: Completed siTDs are stored on a list and not reused until
at least one frame has passed.
Tested-by: Nate Case <ncase@xes-inc.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The EHCI driver stores in usb_host_endpoint.hcpriv a pointer to either
an ehci_qh or an ehci_iso_stream structure, and uses the contents of the
hw_info1 field to distinguish the two cases.
After ehci_qh was split into hw and sw parts, ehci_iso_stream must also
be adjusted so that it again looks like an ehci_qh structure.
This fixes a NULL pointer access in ehci_endpoint_disable() when it
tries to access qh->hw->hw_info1.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com>
Replace ARCH_OMAP34XX with ARCH_OMAP3
This patch (as1330) fixes a bug in khbud's handling of remote
wakeups. When a device sends a remote-wakeup request, the parent hub
(or the host controller driver, for directly attached devices) begins
the resume sequence and notifies khubd when the sequence finishes. At
this point the port's SUSPEND feature is automatically turned off.
However the device needs an additional 10-ms resume-recovery time
(TRSMRCY in the USB spec). Khubd does not wait for this delay if the
SUSPEND feature is off, and as a result some devices fail to behave
properly following a remote wakeup. This patch adds the missing
delay to the remote-wakeup path.
It also extends the resume-signalling delay used by ehci-hcd and
uhci-hcd from 20 ms (the value in the spec) to 25 ms (the value we use
for non-remote-wakeup resumes). The extra time appears to help some
devices.
Cc: Rickard Bellini <rickard.bellini@ericsson.com>
This patch (as1300) adds native scatter-gather support to ehci-hcd.
