Following enhancements are done:
a. Update driver with common phy interface
b. Make host driver independent of phy type and
remove unnecessary CONFIG variables.
Bug 887361
Change-Id: Ibafa37a048df4377b73029039b04d04a53020bd4
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103599
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
GVS: Gerrit_Virtual_Submit
This reverts commit 83722bc9430424de1614ff31696f73a40b3d81a9.
Our OTG support doesn't play nice with the upstreamed OTG support, so
for now, revert the upstream commit.
drivers/usb/gadget/fsl_udc_core.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R5a4b466ee983307ee277a591e664c854b0ddd970
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R6b5fc7c5110e02d29a98043492416569cc959969
When host_pc is enabled ehci_bus_suspend is disabling the
usb phy by setting the PHCD bit in the HOST_PC register.
Due to this system is hanging during the bus_suspend procedure.
This PHCD bit should be set after completing the USB suspend
procedure. This PHCD bit is set as part of the phy suspend.
Fixing this by removing the code for disabling PHCD bit in
the suspend path.
Bug 793834
Original-Change-Id: I02df4cb9f8ec32c253709ea921f4da5041461f4d
Reviewed-on: http://git-master/r/21492
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Original-Change-Id: Ied6b9e26faf063c956b406ea1d9e1ac50b4727dc
Rebase-Id: Rd49c371c8e2b75e437c69abecaac61d2033ff39f
ehci_bus_resume().
From EHCI Spec p.28 HC should clear PORT_SUSPEND when SW clears
PORT_RESUME. In Intel Oaktrail platform, MPH (Multi-Port Host
Controller) core clears PORT_SUSPEND directly when SW sets PORT_RESUME
bit. If we rely on PORT_SUSPEND bit to stop USB resume, we will miss
the action of clearing PORT_RESUME. This will cause unexpected long
resume signal on USB bus.
Signed-off-by: Wang Zhi <zhi.wang@windriver.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@kernel.org>
The sequence to put port in test mode is not complete.
According EHCI specification all enabled ports must be
put in suspend.
Signed-off-by: Boris Todorov <boris.st.todorov@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
MAX4967 USB power supply chip we use on our boards signals over-current when
power is not enabled; once it's enabled, over-current signal returns to normal.
That unfortunately caused the endless stream of "over-current change on port"
messages. The EHCI root hub code reacts on every over-current signal change
with powering off the port -- such change event is generated the moment the
port power is enabled, so once enabled the power is immediately cut off.
I think we should only cut off power when we're seeing the active over-current
signal, so I'm adding such check to that code. I also think that the fact that
we've cut off the port power should be reflected in the result of GetPortStatus
request immediately, hence I'm adding a PORTSCn register readback after write...
Cc: stable@kernel.org
The only sysfs attr implemented so far is "companion" from ehci-hub.c,
but in the next patch we are going to add another sysfs file, so prior
to that let's structure things and move already-in-there sysfs code to
separate file.
NOTE: All the code I'm moving into this new file was written by Alan
Stern (in 57e06c11 "EHCI: force high-speed devices to run at full
speed"; Jan 16 2007), that's why I'm putting
Copyright (C) 2007 by Alan Stern
there after explicit request from the author.
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
Cc: Li Yang <leoli@freescale.com>
Mark ehci_adjust_port_wakeup_flags as __maybe_unused to avoid the following
warning when building the ehci-mxc driver:
CC drivers/usb/host/ehci-hcd.o
drivers/usb/host/ehci-hub.c:130: warning: 'ehci_adjust_port_wakeup_flags' defined but not used
Current ehci-mxc driver implementation does not support suspend/resume.
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly
different hub descriptor than USB 2.0 hubs, with a fixed (rather than
variable length) size. Change the USB core's hub descriptor to have a
union for the last fields that differ. Change the host controller drivers
that access those last fields (DeviceRemovable and PortPowerCtrlMask) to
use the union.
Translate the new version of the hub port status field into the old
version that khubd understands. (Note: we need to fix it to translate the
roothub's port status once we stop converting it to USB 2.0 hub status
internally.)
Add new code to handle link state change status. Send out new control
messages that are needed for USB 3.0 hubs, like Set Hub Depth.
This patch is a modified version of the original patch submitted by John
Youn. It's updated to reflect the removal of the "bitmap" #define, and
change the hub descriptor accesses of a couple new host controller
drivers.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: "Robert P. J. Day" <rpjday@crashcourse.ca>
Cc: Max Vozeler <mvz@vozeler.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Lothar Wassmann <LW@KARO-electronics.de>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Martin Fuzzey <mfuzzey@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Using a #define to redefine a common variable name is a bad thing,
especially when the #define is in a header. include/linux/usb/hcd.h
redefined bitmap to DeviceRemovable to avoid typing a long field in the
hub descriptor. This has unintended side effects for files like
drivers/usb/core/devio.c that include that file, since another header
included after hcd.h has different variables named bitmap.
Remove the bitmap #define and replace instances of it in the host
controller code. Cleanup the spaces around function calls and square
brackets while we're at it.
If a device plug/unplug is detected on an ATI SB700 USB controller in D3,
it appears to set the port status register but not the controller status
register. As a result we'll fail to detect the plug event. Check the port
status register on resume as well in order to catch this case.
Cc: stable <stable@kernel.org> [after .39-rc1 is out]
This is needed to resolve some merge conflicts that were found
in the USB host controller patches, and reported by Stephen Rothwell.
In create_companion_file() there is a bogus assignemt to i created for
the express purpose of avoiding an ignored return value warning.
With pre-release GCC-4.6, this causes a 'set but not used' warning.
Kick the problem further down the road by just returning i. All the
callers of create_companion_file() ignore its return value, so all is
good:
o No warnings are issued.
o We still subvert the desires of the authors of device_create_file()
by ignorning error conditions.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
There is a msleep with spin lock held during ehci pci suspend, which will
cause kernel BUG: scheduling while atomic. Fix that.
[ 184.139620] BUG: scheduling while atomic: kworker/u:11/416/0x00000002
[ 184.139632] 4 locks held by kworker/u:11/416:
[ 184.139640] #0: (events_unbound){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139669] #1: ((&entry->work)){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139686] #2: (&__lockdep_no_validate__){+.+.+.}, at: [<c127cde3>] __device_suspend+0x2c/0x154
[ 184.139706] #3: (&(&ehci->lock)->rlock){-.-...}, at: [<c132f3d8>] ehci_pci_suspend+0x35/0x7b
[ 184.139725] Modules linked in: serio_raw pegasus joydev mrst_gfx(C) battery
[ 184.139748] irq event stamp: 52
[ 184.139753] hardirqs last enabled at (51): [<c14fdaac>] mutex_lock_nested+0x258/0x293
[ 184.139766] hardirqs last disabled at (52): [<c14fe7b4>] _raw_spin_lock_irqsave+0xf/0x3e
[ 184.139777] softirqs last enabled at (0): [<c10371c1>] copy_process+0x3d2/0x109d
[ 184.139789] softirqs last disabled at (0): [< (null)>] (null)
[ 184.139802] Pid: 416, comm: kworker/u:11 Tainted: G C 2.6.37-6.3-adaptation-oaktrail #37
[ 184.139809] Call Trace:
[ 184.139820] [<c102eeff>] __schedule_bug+0x5e/0x65
[ 184.139829] [<c14fbca5>] schedule+0xac/0xc4c
[ 184.139840] [<c11d4845>] ? string+0x37/0x8b
[ 184.139853] [<c1044f21>] ? lock_timer_base+0x1f/0x3e
[ 184.139863] [<c14fe7da>] ? _raw_spin_lock_irqsave+0x35/0x3e
[ 184.139876] [<c1061590>] ? trace_hardirqs_off+0xb/0xd
[ 184.139885] [<c14fccdc>] schedule_timeout+0x283/0x2d9
[ 184.139896] [<c104516f>] ? process_timeout+0x0/0xa
[ 184.139906] [<c14fcd47>] schedule_timeout_uninterruptible+0x15/0x17
[ 184.139916] [<c104566a>] msleep+0x10/0x16
[ 184.139926] [<c132f316>] ehci_adjust_port_wakeup_flags+0x69/0xf6
[ 184.139937] [<c132f3eb>] ehci_pci_suspend+0x48/0x7b
[ 184.139946] [<c1326587>] suspend_common+0x52/0xbb
[ 184.139956] [<c1326625>] hcd_pci_suspend+0x26/0x28
[ 184.139967] [<c11e7182>] pci_pm_suspend+0x5f/0xd0
[ 184.139976] [<c127ca3a>] pm_op+0x5d/0xf0
[ 184.139986] [<c127ceac>] __device_suspend+0xf5/0x154
[ 184.139996] [<c127d2c8>] async_suspend+0x16/0x3a
[ 184.140006] [<c1058f54>] async_run_entry_fn+0x89/0x111
[ 184.140016] [<c104deb6>] process_one_work+0x295/0x4cb
[ 184.140026] [<c1058ecb>] ? async_run_entry_fn+0x0/0x111
[ 184.140036] [<c104e3d0>] worker_thread+0x17f/0x298
[ 184.140045] [<c104e251>] ? worker_thread+0x0/0x298
[ 184.140055] [<c105277f>] kthread+0x64/0x69
[ 184.140064] [<c105271b>] ? kthread+0x0/0x69
[ 184.140075] [<c1002efa>] kernel_thread_helper+0x6/0x1a
Signed-off-by: Yin Kangkai <kangkai.yin@intel.com>
CC: David Brownell <dbrownell@users.sourceforge.net>
CC: stable@kernel.org
This patch (as1394) adds code to ehci-hcd, ohci-hcd, and uhci-hcd for
automatically resuming the root hub when the controller is resumed, if
the root hub has a wakeup request pending on some port.
During resume from system sleep this doesn't matter, because the root
hubs will naturally be resumed along with every other device in the
system. However it _will_ matter for runtime PM: If the controller is
suspended and a remote wakeup request is received then the controller
will autoresume, but we need to ensure that the root hub also
autoresumes. Otherwise the wakeup request would be ignored, the
controller would go back to sleep, and the cycle would repeat a large
number of times (I saw this happen before the patch was written).
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend
method used by PCI-based host controller drivers. ehci-hcd in
particular needs to know whether or not to enable wakeup when
suspending a controller. Although that information is currently
available through device_may_wakeup(), when support is added for
runtime suspend this will no longer be true.
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
This patch will enable Per-port event feature defined in EHCI 1.1
addendum. This feature addresses an issue where HCD is currently
required to read and parse PORTSC for all enabled root hub ports. With
this patch, the overhead will be reduced.
Signed-off-by: Alek Du <alek.du@intel.com>
With this patch, the LPM capable EHCI host controller can put device
into L1 sleep state which is a mode that can enter/exit quickly, and
reduce power consumption.
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
This patch (as1380) fixes a bug in the wakeup settings for EHCI host
controllers. When the controller is suspended, if it isn't enabled
for remote wakeup then we have to turn off all the port wakeup flags.
Disabling PCI PME# isn't good enough, because some systems (Intel)
evidently use alternate wakeup signalling paths.
In addition, the patch improves the handling of the Intel Moorestown
hardware by performing various power-up and power-down delays just
once instead of once for each port (i.e., the delays are moved outside
of the port loops). This requires extra code, but the total delay
time is reduced.
There are also a few additional minor cleanups.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
CC: Alek Du <alek.du@intel.com>
CC: stable <stable@kernel.org>
This is a bug fix for PHCD (phy clock disable) low power feature:
After PHCD is set, any write to PORTSC register is illegal, so when
resume ports, clear PHCD bit first.
This patch (as1349b) clears up the confusion in many USB host
controller drivers between port features and port statuses. In mosty
cases it's true that the status bit is in the position given by the
corresponding feature value, but that's not always true and it's not
guaranteed in the USB spec.
There's no functional change, just replacing expressions of the form
(1 << USB_PORT_FEAT_x) with USB_PORT_STAT_x, which has the same value.
It seems that for USB IP on Freescale MX5x processors, it needs >750
usec for the reset to complete. This change should not hurt any other
EHCI hardware.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
1. There are two msleep calls inside two spin lock sections, need to unlock
and lock again after msleep.
2. Save a extra status reg setting.
This patch (as1321) fixes a problem with EHCI and UHCI root-hub
suspends: If the suspend occurs while a port is trying to resume, the
resume doesn't finish and simply gets lost. When remote wakeup is
enabled, this is undesirable behavior.
The patch checks first to see if any port resumes are in progress, and
if they are then it fails the root-hub suspend with -EBUSY.
No need to check ehci->debug twice.
Found-by: Sergei Shtylyov sshtylyov@ru.mvista.com
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
In order for the dbgp driver to survive suspend/resume, on every ehci
resume operation the debug controller must get re-initialized.
Cc: dbrownell@users.sourceforge.net
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
If the EHCI debug port is initialized and in use, the EHCI host
controller driver must follow two rules.
1) If the EHCI host driver issues a controller reset, the debug
controller driver re-initialization must get called after the reset
is completed.
2) The EHCI host driver should ignore any requests to the physical
EHCI debug port when the EHCI debug port is in use.
The code to check for the debug port was moved from ehci_pci_reinit()
to ehci_pci_setup because it must get called prior to ehci_reset()
which will clear the debug port registers.
This patch was previously discussed in the following thread:
http://thread.gmane.org/gmane.linux.usb.general/19472/focus=19484
On the OMAP3 device the usbhost controller is in a separate internal
power-domain. So when the usbhost is inactive or suspend is called,
we can disable clocks and power-down the usbhost to save power.
Recently we found that after calling ehci_bus_suspend() and disabling
the usbhost clocks we would see the ehci watchdog timer event fire. This
was causing a kernel panic because the usbhost controllers clocks were
disabled and inside the watchdog timer function the clocks were not
being re-enabled, so when the ehci registers were accessed this resulted
in a CPU data-abort.
To avoid this panic, per recommendation from Alan Stern (see above thread), we
make sure any pending timer events (that may have been scheduled by calling
ehci_work within the ehci_bus_suspend() function) are deleted before returning.
Signed-off-by: Fei Yang <fei.yang@motorola.com>
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
support phy low power mode
The Intel Moorestown EHCI controller supports non-standard HOSTPCx register
extension. This register controls the LPM behaviour and controls the behaviour
of each USB port.
The controller device is where we want this sysfs file, especially as
the dev pointer is about to go away...
A published errata for ppc440epx states, that when running Linux with
both EHCI and OHCI modules loaded, the EHCI module experiences a fatal
error when a high-speed device is connected to the USB2.0, and
functions normally if OHCI module is not loaded.
There used to be recommendation to use only hi-speed or full-speed
devices with specific conditions, when respective module was unloaded.
Later, it was observed that ohci suspend is enough to keep things
going, and it was turned into workaround, as explained below.
Quote from original descriprion:
The 440EPx USB 2.0 Host controller is an EHCI compliant controller. In
USB 2.0 Host controllers, each EHCI controller has one or more companion
controllers, which may be OHCI or UHCI. An USB 2.0 Host controller will
contain one or more ports. For each port, only one of the controllers
is connected at any one time. In the 440EPx, there is only one OHCI
companion controller, and only one USB 2.0 Host port.
All ports on an USB 2.0 controller default to the companion
controller. If you load only an ohci driver, it will have control of
the ports and any deviceplugged in will operate, although high speed
devices will be forced to operate at full speed. When an ehci driver
is loaded, it explicitly takes control of the ports. If there is a
device connected, and / or every time there is a new device connected,
the ehci driver determines if the device is high speed or not. If it
is high speed, the driver retains control of the port. If it is not,
the driver explicitly gives the companion controller control of the
port.
The is a software workaround that uses
Initial version of the software workaround was posted to
linux-usb-devel:
http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg54019.html
and later available from amcc.com:
http://www.amcc.com/Embedded/Downloads/download.html?cat=1&family=15&ins=2
The patch below is generally based on the latter, but reworked to
powerpc/of_device USB drivers, and uses a few devicetree inquiries to
get rid of (some) hardcoded defines.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
For function ehci_bus_resume()
- Added flag resume_needed
No need to wait for 20ms if no port was suspended
- Change mdelay to msleep
- release and reacquire the spinlock around mdelay
Signed-off-by: vikram pandita <vikram.pandita@ti.com>
This patch (as1147) fixes the remote-wakeup support for EHCI
controllers using the ARC/TDI "embedded-TT" core. These controllers
turn off the RESUME bit by themselves when a port resume is complete;
hence we need to keep separate track of which ports are suspended or
in the process of resuming.
The patch also makes a couple of small improvements in ehci_irq(),
replacing reads of the command register with the value already stored
in a local variable.
Tested-by: Thomas Reitmayr <treitmayr@devbase.at>
CC: David Brownell <david-b@pacbell.net>
This patch (as1097) fixes a bug in the remote-wakeup handling in
ehci-hcd. The driver currently does not keep track of whether the
change-suspend feature is enabled for each port; the feature is
automatically reset the first time it is read. But recent changes to
the hub driver require that the feature be read at least twice in
order to work properly.
A bit-vector is added for storing the change-suspend feature values.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This patch (as1096) fixes an annoying problem: When a full-speed or
low-speed device is plugged into an EHCI controller, it fails to
enumerate at high speed and then is handed over to the companion
controller. But usbcore logs a misleading and unwanted error message
when the high-speed enumeration fails.
The patch adds a new HCD method, port_handed_over, which asks whether
a port has been handed over to a companion controller. If it has, the
error message is suppressed.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
* endianness annotations
* endianness fixes
* missing get_unaligned/put_unaligned
It's pretty much all over the place, changes to different files are independent.
Serial-parts-Acked-by: Alan Cox <alan@redhat.com>
This patch (as1072) fixes some recently-introduced compile problems
that show up in ehci-hcd when CONFIG_PM is turned off.
PORT_WAKE_BITS needs to be defined always.
ehci_port_power() is called during initialization by all the
EHCI variants other than the PCI version, in which it is
"defined but not used". So add a call to it.
When a USB device is suspended, whether or not it is enabled for
remote wakeup depends on the device_may_wakeup() setting. The setting
is then saved in the do_remote_wakeup flag.
Later on, however, the device_may_wakeup() value can change because of
user activity. So when testing whether a suspended device is or
should be enabled for remote wakeup, we should always test
do_remote_wakeup instead of device_may_wakeup(). This patch (as1076)
makes that change for root hubs in several places.
The patch also adjusts uhci-hcd so that when an autostopped controller
is suspended, the remote wakeup setting agrees with the value recorded
in the root hub's do_remote_wakeup flag.
And the patch adjusts ehci-hcd so that wakeup events on selectively
suspended ports (i.e., the bus itself isn't suspended) don't turn on
the PME# wakeup signal.
Minor cleanups to the EHCI code: revision history is what source
code repositories should have. Switch to a more standard way to
kick in verbose debugging -- don't be EHCI-specific.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling
it permanently. It also prevents the power/persist attribute from
being created for hub devices; there's no point in having it since
USB-PERSIST is always turned on for hubs.
This patch (as1044) causes EHCI port handover for non-high-speed
devices to occur during every root-hub resume, not just in cases where
the controller lost power or was reset. This is necessary because:
When some machines go into suspend, they remove power from
on-board USB devices while retaining suspend current for USB
controllers.
The user might well unplug a USB device while the system is
suspended and then plug it back in before resuming.
A corresponding change is made to the core resume routine; now
high-speed root hubs will always be resumed when the system wakes up,
even if they were suspended before the system went to sleep. If this
weren't done then EHCI port handover wouldn't work, since it is called
when the EHCI root hub is resumed.
Finally, a comment is added to the hub driver explaining the khubd has
to be freezable; if it weren't frozen then it could interfere with
port handover.
This patch, suggested by Alan Stern, fixes the hung USB issues
on my notebook from suspend/resume cycles.
It does so by eliminating some confusion about the internal state
machine associated with unlinking from the EHCI async schedule ring,
which caused a recent regression:
http://bugzilla.kernel.org/show_bug.cgi?id=10345
Signed-off-by: Mark Lord <mlord@pobox.com>
Some of the "EHCI ports reset forever" problems may be explained by
code paths which wrongly flagged resets as complete. This removes
two such paths; the ehci_hub_status_data() path should be the only one
to have an effect, since it was already properly flagged on the other
path. (Issue noted by Minhyoung Kim <a9a9@lge.com>.)
This patch (as1031) adds a short delay to the bus-suspend routine in
ehci-hcd. Without it some devices disconnect when they should
suspend.
Acked-by: David Brownell <david-b@pacbell.net>
This patch (as1030b) moves a del_timer_sync() call outside the scope of a
spinlock, where it could cause a deadlock, and adds a new
del_timer_sync() call for the new IAA watchdog timer (it was omitted
by mistake).
This patch (as1028) was mostly written by David Brownell; I made only
a few changes (extra log info and a small bug fix -- which might
account for why David's version had to be reverted). It adds a new
watchdog timer to the ehci-hcd driver to be used exclusively for
detecting lost or missing IAA notifications.
Previously a shared timer had been used, which may have led to some
problems as reported by Christian Hoffmann.
Cc: David Brownell <david-b@pacbell.net>
