path: root/drivers/usb/host/ehci-mv.c
2014-11-07host: ehci-mv: remove duplicate check on resourceVarka Bhadram
Sanity check on resource happening with devm_ioremap_resource(). Signed-off-by: Varka Bhadram <varkab@cdac.in> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-03usb: host: ehci-mv: delete unnecessary 'out of memory' messagesPeter Chen
The memory subsystem has already had similar message for it. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27usb: host: ehci-mv: Use devm_ioremap_resource instead of devm_ioremapVivek Gautam
Using devm_ioremap_resource() API should actually be preferred over devm_ioremap(), since the former request the mem region first and then gives back the ioremap'ed memory pointer. devm_ioremap_resource() calls request_mem_region(), therby preventing other drivers to make any overlapping call to the same region. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08usb: hcd: move controller wakeup setting initialization to individual driverPeter Chen
Individual controller driver has different requirement for wakeup setting, so move it from core to itself. In order to align with current etting the default wakeup setting is enabled (except for chipidea host). Pass compile test with below commands: make O=outout/all allmodconfig make -j$CPU_NUM O=outout/all drivers/usb Signed-off-by: Peter Chen <peter.chen@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04USB: fix coccinelle warningsFengguang Wu
drivers/usb/host/ehci-mv.c:181:26-27: WARNING comparing pointer to 0, suggest !E /c/kernel-tests/src/cocci/drivers/usb/host/ehci-mv.c:181:26-27: WARNING comparing pointer to 0 Compare pointer-typed values to NULL rather than 0 Semantic patch information: This makes an effort to choose between !x and x == NULL. !x is used if it has previously been used with the function used to initialize x. This relies on type information. More type information can be obtained using the option -all_includes and the option -I to specify an include path. Generated by: coccinelle/null/badzero.cocci CC: Jingoo Han <jg1.han@samsung.com> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2013-09-23Revert "Revert "USB: EHCI: support running URB giveback in tasklet context""Greg Kroah-Hartman
This reverts commit 3b8d7321ed4b8511e17048303b806ffcc2806077, which brings back commit 428aac8a81058e2303677a8fbf26670229e51d3a as it should be working for the 3.13-rc1 merge window now that Alan's other fixes are here in the tree already. Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17Revert "USB: EHCI: support running URB giveback in tasklet context"Greg Kroah-Hartman
This reverts commit 428aac8a81058e2303677a8fbf26670229e51d3a. This isn't quite ready for 3.12, we need some more EHCI driver changes that are just now showing up. So revert this for now, and queue it up later for 3.13. Reported-by: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12USB: EHCI: support running URB giveback in tasklet contextMing Lei
All 4 transfer types can work well on EHCI HCD after switching to run URB giveback in tasklet context, so mark all HCD drivers to support it. Also we don't need to release ehci->lock during URB giveback any more. >From below test results on 3 machines(2 ARM and one x86), time consumed by EHCI interrupt handler droped much without performance loss. 1 test description 1.1 mass storage performance test: - run below command 10 times and compute the average performance dd if=/dev/sdN iflag=direct of=/dev/null bs=200M count=1 - two usb mass storage device: A: sandisk extreme USB 3.0 16G(used in test case 1 & case 2) B: kingston DataTraveler G2 4GB(only used in test case 2) 1.2 uvc function test: - run one simple capture program in the below link http://kernel.ubuntu.com/~ming/up/capture.c - capture format 640*480 and results in High Bandwidth mode on the uvc device: Z-Star 0x0ac8/0x3450 - on T410(x86) laptop, also use guvcview to watch video capture/playback 1.3 about test2 and test4 - both two devices involved are tested concurrently by above test items 1.4 how to compute irq time(the time consumed by ehci_irq) - use trace points of irq:irq_handler_entry and irq:irq_handler_exit 1.5 kernel 3.10.0-rc3-next-20130528 1.6 test machines Pandaboard A1: ARM CortexA9 dural core Arndale board: ARM CortexA15 dural core T410: i5 CPU 2.67GHz quad core 2 test result 2.1 test case1: single mass storage device performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 25.280(avg:145,max:772) | 25.540(avg:14, max:75) Arndale board: 29.700(avg:33, max:129) | 29.700(avg:10, max:50) T410: 34.430(avg:17, max:154*)| 34.660(avg:12, max:155) --------------------------------------------------------------------- 2.2 test case2: two mass storage devices' performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 15.840/15.580(avg:158,max:1216) | 16.500/16.160(avg:15,max:139) Arndale board: 17.370/16.220(avg:33 max:234) | 17.480/16.200(avg:11, max:91) T410: 21.180/19.820(avg:18 max:160) | 21.220/19.880(avg:11, max:149) --------------------------------------------------------------------- 2.3 test case3: one uvc streaming test - uvc device works well(on x86, luvcview can be used too and has same result with uvc capture) -------------------------------------------------------------------- upstream | patched irq time(us) | irq time(us) -------------------------------------------------------------------- Pandaboard A1: (avg:445, max:873) | (avg:33, max:44) Arndale board: (avg:316, max:630) | (avg:20, max:27) T410: (avg:39, max:107) | (avg:10, max:65) --------------------------------------------------------------------- 2.4 test case4: one uvc streaming plus one mass storage device test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 20.340(avg:259,max:1704)| 20.390(avg:24, max:101) Arndale board: 23.460(avg:124,max:726) | 23.370(avg:15, max:52) T410: 28.520(avg:27, max:169) | 28.630(avg:13, max:160) --------------------------------------------------------------------- 2.5 test case5: read single mass storage device with small transfer - run below command 10 times and compute the average speed dd if=/dev/sdN iflag=direct of=/dev/null bs=4K count=4000 1), test device A: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 6.5(avg:21, max:64) | 6.5(avg:10, max:24) Arndale board: 8.13(avg:12, max:23) | 8.06(avg:7, max:17) T410: 6.66(avg:13, max:131) | 6.84(avg:11, max:149) --------------------------------------------------------------------- 2), test device B: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 5.5(avg:21,max:43) | 5.49(avg:10, max:24) Arndale board: 5.9(avg:12, max:22) | 5.9(avg:7, max:17) T410: 5.48(avg:13, max:155) | 5.48(avg:7, max:140) --------------------------------------------------------------------- * On T410, sometimes read ehci status register in ehci_irq takes more than 100us, and the problem has been reported on the link: http://marc.info/?t=137065867300001&r=1&w=2 Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-31USB: host: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-16USB: ehci-mv: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05Merge tag 'usb-for-v3.10' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v3.10 merge window Here is the big Gadget & PHY pull request. Many of us have been really busy lately getting multiple drivers to a better position. Since this pull request is so large, I will divide it in sections so it's easier to grasp what's included. - cleanups: . UDC drivers no longer touch gadget->dev, that's now udc-core responsibility . Many more UDC drivers converted to usb_gadget_map/unmap_request() . UDC drivers no longer initialize DMA-related fields from gadget's device structure . UDC drivers don't touch gadget.dev.driver directly . UDC drivers don't assign gadget.dev.release directly . Removal of some unused DMA_ADDR_INVALID . Introduction of CONFIG_USB_PHY . All phy drivers have been moved to drivers/usb/phy and renamed to a common naming scheme . Fix PHY layer so it never returns a NULL pointer, also fix all callers to avoid using IS_ERR_OR_NULL() . Sparse fixes all over the place . drivers/usb/otg/ has been deleted . Marvel drivers (mv_udc, ehci-mv, mv_otg and mv_u3d) improved clock usage - new features: . UDC core now provides a generic way for tracking and reporting UDC's state (not attached, resuming, suspended, addressed, default, etc) . twl4030-usb learned that it shouldn't be enabled during init . Full DT support for DWC3 has been implemented . ab8500-usb learned about pinctrl framework . nop PHY learned about DeviceTree and regulators . DWC3 learned about suspend/resume . DWC3 can now be compiled in host-only and gadget-only (as well as DRD) configurations . UVC now enables streaming endpoint based on negotiated speed . isp1301 now implements the PHY API properly . configfs-based interface for gadget drivers which will lead to the removal of all code which just combines functions together to build functional gadget drivers. . f_serial and f_obex were converted to new configfs interface while maintaining old interface around. - non-critical fixes: . UVC gadget driver got fixes for Endpoint usage and stream calculation . ab8500-usb fixed unbalanced clock and regulator API usage . twl4030-usb got a fix for when OMAP3 is booted with cable connected . fusb300_udc got a fix for DMA usage . UVC got fixes for two assertions of the USB Video Class Compliance specification revision 1.1 . build warning issues caused by recent addition of __must_check to regulator API These are all changes which deserve a mention, all other changes are related to these one or minor spelling fixes and other similar tasks. Signed-of-by: Felipe Balbi <balbi@ti.com>
2013-04-02usb: ehci: mv_ehci: remove unused clockChao Xie
The origianl understanding of clock is wrong. The EHCI controller only have one clock input. Passing clock name by pdata is wrong. The clock is defined by device iteself. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-18usb: host: ehci-mv: fix PHY error handlingFelipe Balbi
PHY layer no longer returns NULL. We must switch from IS_ERR_OR_NULL() to IS_ERR(). Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-18usb: ehci: marvel: check against CONFIG_USB_PHYFelipe Balbi
CONFIG_USB_OTG_UTILS will be removed very soon, so we should check CONFIG_USB_PHY instead. Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-15usb: Use resource_size functionPaul Vlase
Signed-off-by: Paul Vlase <vlase.paul@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-25Merge tag 'gadget-for-v3.9' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: gadget: patches for v3.9 merge window finally getting rid of the old ->start()/->stop() methods in favor of the better and improved ->udc_start()/->udc_stop(). There were surprisingly quite a few users left, but all of them have been converted. f_mass_storage removed some dead code, which is always great ;-) There's also a big cleanup to the gadget framework from Sebastian which gets us a lot closer to having only function drivers in kernel and move over to configfs-based binding. Other than these, there's the usual set of cleanups: s3c UDCs are moving over to devm_regulator_bulk_get() API, at91_udc removed an unnecessary check for work_pending() before scheduling and there's the removal of an unused variable from uac2_pcm_trigger().
2013-01-24usb: host: ehci-mv: remove unused variableChao Xie
Signed-off-by: Chao Xie <chao.xie@marvell.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-12-13usb: host: ehci-mv: fix clk APIsChao Xie
the clock common driver changes, and arch-mmp will make use of the common clock driver instead of its own. So for enable clock. first prepare the clock then enable the clock. for disable clock first disable the clock then unprepare the clock Signed-off-by: Chao Xie <chao.xie@marvell.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-08-10drivers/usb/host/ehci-mv.c: use devm_ functionsJulia Lawall
The various devm_ functions allocate memory that is released when a driver detaches. This patch uses these functions for data that is allocated in the probe function of a platform device and is only freed in the remove function. A new label name is created in one case to better reflect the contents of the error-handling code. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-02usb: phy: fix return value check of usb_get_phyKishon Vijay Abraham I
usb_get_phy will return -ENODEV if it's not able to find the phy. Hence fixed all the callers of usb_get_phy to check for this error condition instead of relying on a non-zero value as success condition. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-06-25usb: otg: support for multiple transceivers by a single controllerKishon Vijay Abraham I
Add a linked list for keeping multiple PHY instances with different types so that we can have separate USB2 and USB3 PHYs on one single board. _get_phy_ has been changed so that the controller gets the transceiver by type. _remove_phy_ has been added to let the phy be removed from the phy list. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-06-25usb: otg: utils: rename function name in OTG utilsKishon Vijay Abraham I
_transceiver() in otg.c is replaced with _phy. usb_set_transceiver is replaced with usb_add_phy to make it similar to other usb standard function names like usb_add_hcd. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-27usb: otg: Convert all users to pass struct usb_otg for OTG functionsHeikki Krogerus
This changes the otg functions so that they receive struct otg instead of struct usb_phy as parameter and converts all users of these functions to pass the otg member of their usb_phy. Includes fixes to IMX code from Sascha Hauer. [ balbi@ti.com : fixed a compile warning on ehci-mv.c ] Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-27usb: Convert all users to new usb_phyHeikki Krogerus
Use the new usb_phy_* functions with transceiver operations instead of the old otg functions. Includes fixes from Sascha Hauer. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-02-13usb: otg: Rename otg_transceiver to usb_phyHeikki Krogerus
This is the first step in separating USB transceivers from USB OTG utilities. Includes fixes to IMX code from Sascha Hauer. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Acked-by: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-12-20USB: EHCI: Add Marvell Host Controller driverNeil Zhang
This patch adds support for EHCI compliant HSUSB Host controller found on Marvell Socs. It fits both OTG and SPH controller on marvell Socs, including PXA9xx/MMP2/MMP3/MGx. Signed-off-by: Neil Zhang <zhangwm@marvell.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
