path: root/drivers/usb/host/ehci-pci.c
2012-01-24usb: add support for STA2X11 host driverAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18EHCI: workaround for MosChip controller bugAlan Stern
This patch (as1489) works around a hardware bug in MosChip EHCI controllers. Evidently when one of these controllers increments the frame-index register, it changes the three low-order bits (the microframe counter) before changing the higher order bits (the frame counter). If the register is read at just the wrong time, the value obtained is too low by 8. When the appropriate quirk flag is set, we work around this problem by reading the frame-index register a second time if the first value's three low-order bits are all 0. This gives the hardware a chance to finish updating the register, yielding the correct value. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Jason N Pitt <jpitt@fhcrc.org> CC: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22USB: EHCI: remove usages of hcd->stateAlan Stern
This patch (as1483) improves the ehci-hcd driver family by getting rid of the reliance on the hcd->state variable. It has no clear owner and it isn't protected by the usual HCD locks. In its place, the patch adds a new, private ehci->rh_state field to record the state of the root hub. Along the way, the patch removes a couple of lines containing redundant assignments to the state variable. Also, the QUIESCING state simply gets changed to the RUNNING state, because the driver doesn't make any distinction between them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-27Intel xhci: Support EHCI/xHCI port switching.Sarah Sharp
The Intel Panther Point chipsets contain an EHCI and xHCI host controller that shares some number of skew-dependent ports. These ports can be switched from the EHCI to the xHCI host (and vice versa) by a hardware MUX that is controlled by registers in the xHCI PCI configuration space. The USB 3.0 SuperSpeed terminations on the xHCI ports can be controlled separately from the USB 2.0 data wires. This switchover mechanism is there to support users who do a custom install of certain non-Linux operating systems that don't have official USB 3.0 support. By default, the ports are under EHCI, SuperSpeed terminations are off, and USB 3.0 devices will show up under the EHCI controller at reduced speeds. (This was more palatable for the marketing folks than having completely dead USB 3.0 ports if no xHCI drivers are available.) Users should be able to turn on xHCI by default through a BIOS option, but users are happiest when they don't have to change random BIOS settings. This patch introduces a driver method to switchover the ports from EHCI to xHCI before the EHCI driver finishes PCI enumeration. We want to switch the ports over before the USB core has the chance to enumerate devices under EHCI, or boot from USB mass storage will fail if the boot device connects under EHCI first, and then gets disconnected when the port switches over to xHCI. Add code to the xHCI PCI quirk to switch the ports from EHCI to xHCI. The PCI quirks code will run before any other PCI probe function is called, so this avoids the issue with boot devices. Another issue is with BIOS behavior during system resume from hibernate. If the BIOS doesn't support xHCI, it may switch the devices under EHCI to allow use of the USB keyboard, mice, and mass storage devices. It's supposed to remember the value of the port routing registers and switch them back when the OS attempts to take control of the xHCI host controller, but we all know not to trust BIOS writers. Make both the xHCI driver and the EHCI driver attempt to switchover the ports in their PCI resume functions. We can't guarantee which PCI device will be resumed first, so this avoids any race conditions. Writing a '1' to an already set port switchover bit or a '0' to a cleared port switchover bit should have no effect. The xHCI PCI configuration registers will be documented in the EDS-level chipset spec, which is not public yet. I have permission from legal and the Intel chipset group to release this patch early to allow good Linux support at product launch. I've tried to document the registers as much as possible, so please let me know if anything is unclear. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-05-03USB: EHCI: Support controllers with big endian capability regsJan Andersson
The two first HC capability registers (CAPLENGTH and HCIVERSION) are defined as one 8-bit and one 16-bit register. Most HC implementations have selected to treat these registers as part of a 32-bit register, giving the same layout for both big and small endian systems. This patch adds a new quirk, big_endian_capbase, to support controllers with big endian register interfaces that treat HCIVERSION and CAPLENGTH as individual registers. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-01USB host: Move AMD PLL quirk to pci-quirks.cAndiry Xu
This patch moves the AMD PLL quirk code in OHCI/EHCI driver to pci-quirks.c, and exports the functions to be used by xHCI driver later. AMD PLL quirk disable the optional PM feature inside specific SB700/SB800/Hudson-2/3 platforms under the following conditions: 1. If an isochronous device is connected to OHCI/EHCI/xHCI port and is active; 2. Optional PM feature that powers down the internal Bus PLL when the link is in low power state is enabled. Without AMD PLL quirk, USB isochronous stream may stutter or have breaks occasionally, which greatly impair the performance of audio/video streams. Currently AMD PLL quirk is implemented in OHCI and EHCI driver, and will be added to xHCI driver too. They are doing similar things actually, so move the quirk code to pci-quirks.c, which has several advantages: 1. Remove duplicate defines and functions in OHCI/EHCI (and xHCI) driver and make them cleaner; 2. AMD chipset information will be probed only once and then stored. Currently they're probed during every OHCI/EHCI initialization, move the detect code to pci-quirks.c saves the repeat detect cost; 3. Build up synchronization among OHCI/EHCI/xHCI driver. In current code, every host controller enable/disable PLL only according to its own status, and may enable PLL while there is still isoc transfer on other HCs. Move the quirk to pci-quirks.c prevents this issue. Signed-off-by: Andiry Xu <andiry.xu@amd.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Alex He <alex.he@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03USB: EHCI: fix scheduling while atomic during suspendYin Kangkai
There is a msleep with spin lock held during ehci pci suspend, which will cause kernel BUG: scheduling while atomic. Fix that. [ 184.139620] BUG: scheduling while atomic: kworker/u:11/416/0x00000002 [ 184.139632] 4 locks held by kworker/u:11/416: [ 184.139640] #0: (events_unbound){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb [ 184.139669] #1: ((&entry->work)){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb [ 184.139686] #2: (&__lockdep_no_validate__){+.+.+.}, at: [<c127cde3>] __device_suspend+0x2c/0x154 [ 184.139706] #3: (&(&ehci->lock)->rlock){-.-...}, at: [<c132f3d8>] ehci_pci_suspend+0x35/0x7b [ 184.139725] Modules linked in: serio_raw pegasus joydev mrst_gfx(C) battery [ 184.139748] irq event stamp: 52 [ 184.139753] hardirqs last enabled at (51): [<c14fdaac>] mutex_lock_nested+0x258/0x293 [ 184.139766] hardirqs last disabled at (52): [<c14fe7b4>] _raw_spin_lock_irqsave+0xf/0x3e [ 184.139777] softirqs last enabled at (0): [<c10371c1>] copy_process+0x3d2/0x109d [ 184.139789] softirqs last disabled at (0): [< (null)>] (null) [ 184.139802] Pid: 416, comm: kworker/u:11 Tainted: G C 2.6.37-6.3-adaptation-oaktrail #37 [ 184.139809] Call Trace: [ 184.139820] [<c102eeff>] __schedule_bug+0x5e/0x65 [ 184.139829] [<c14fbca5>] schedule+0xac/0xc4c [ 184.139840] [<c11d4845>] ? string+0x37/0x8b [ 184.139853] [<c1044f21>] ? lock_timer_base+0x1f/0x3e [ 184.139863] [<c14fe7da>] ? _raw_spin_lock_irqsave+0x35/0x3e [ 184.139876] [<c1061590>] ? trace_hardirqs_off+0xb/0xd [ 184.139885] [<c14fccdc>] schedule_timeout+0x283/0x2d9 [ 184.139896] [<c104516f>] ? process_timeout+0x0/0xa [ 184.139906] [<c14fcd47>] schedule_timeout_uninterruptible+0x15/0x17 [ 184.139916] [<c104566a>] msleep+0x10/0x16 [ 184.139926] [<c132f316>] ehci_adjust_port_wakeup_flags+0x69/0xf6 [ 184.139937] [<c132f3eb>] ehci_pci_suspend+0x48/0x7b [ 184.139946] [<c1326587>] suspend_common+0x52/0xbb [ 184.139956] [<c1326625>] hcd_pci_suspend+0x26/0x28 [ 184.139967] [<c11e7182>] pci_pm_suspend+0x5f/0xd0 [ 184.139976] [<c127ca3a>] pm_op+0x5d/0xf0 [ 184.139986] [<c127ceac>] __device_suspend+0xf5/0x154 [ 184.139996] [<c127d2c8>] async_suspend+0x16/0x3a [ 184.140006] [<c1058f54>] async_run_entry_fn+0x89/0x111 [ 184.140016] [<c104deb6>] process_one_work+0x295/0x4cb [ 184.140026] [<c1058ecb>] ? async_run_entry_fn+0x0/0x111 [ 184.140036] [<c104e3d0>] worker_thread+0x17f/0x298 [ 184.140045] [<c104e251>] ? worker_thread+0x0/0x298 [ 184.140055] [<c105277f>] kthread+0x64/0x69 [ 184.140064] [<c105271b>] ? kthread+0x0/0x69 [ 184.140075] [<c1002efa>] kernel_thread_helper+0x6/0x1a Signed-off-by: Yin Kangkai <kangkai.yin@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <dbrownell@users.sourceforge.net> CC: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-22USB: EHCI: ASPM quirk of ISOC on AMD HudsonAlex He
AMD Hudson also needs the same ASPM quirk as SB800 Signed-off-by: Alex He <alex.he@amd.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16Merge branch 'usb-next' into musb-mergeGreg Kroah-Hartman
* usb-next: (132 commits) USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added usb: gadget: f_ncm.c added usb: gadget: u_ether: prepare for NCM usb: pch_udc: Fix setup transfers with data out usb: pch_udc: Fix compile error, warnings and checkpatch warnings usb: add ab8500 usb transceiver driver USB: gadget: Implement runtime PM for MSM bus glue driver USB: gadget: Implement runtime PM for ci13xxx gadget USB: gadget: Add USB controller driver for MSM SoC USB: gadget: Introduce ci13xxx_udc_driver struct USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc USB: gadget: Separate out PCI bus code from ci13xxx_udc ...
2010-12-10USB: EHCI: ASPM quirk of ISOC on AMD SB800Alex He
When ASPM PM Feature is enabled on UMI link, devices that use ISOC stream of data transfer may be exposed to longer latency causing less than optimal per- formance of the device. The longer latencies are normal and are due to link wake time coming out of low power state which happens frequently to save power when the link is not active. The following code will make exception for certain features of ASPM to be by passed and keep the logic normal state only when the ISOC device is connected and active. This change will allow the device to run at optimal performance yet minimize the impact on overall power savings. Signed-off-by: Alex He <alex.he@amd.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-30USB: ehci: disable LPM and PPCD for nVidia MCP89 chipsBrian J. Tarricone
Tested on MacBookAir3,1. Without this, we get EPROTO errors when fetching device config descriptors. Signed-off-by: Brian Tarricone <brian@tarricone.org> Reported-by: Benoit Gschwind <gschwind@gnu-log.net> Tested-by: Edgar Hucek <gimli@dark-green.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-17USB: ce4100: Add support for CE4100 EHCI IP block to EHCI driverDirk Brandewie
This patch adds support for the EHCI IP block present on the Intel CE4100. Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16USB: EHCI: AMD periodic frame list table quirkAndiry Xu
On AMD SB700/SB800/Hudson-2/3 platforms, USB EHCI controller may read/write to memory space not allocated to USB controller if there is longer than normal latency on DMA read encountered. In this condition the exposure will be encountered only if the driver has following format of Periodic Frame List link pointer structure: For any idle periodic schedule, the Frame List link pointers that have the T-bit set to 1 intending to terminate the use of frame list link pointer as a physical memory pointer. Idle periodic schedule Frame List Link pointer shoule be in the following format to avoid the issue: Frame list link pointer should be always contains a valid pointer to a inactive QHead with T-bit set to 0. Signed-off-by: Andiry Xu <andiry.xu@amd.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20USB: EHCI: Disable langwell/penwell LPM capabilityAlek Du
We have to do so due to HW limitation. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: EHCI: remove PCI assumptionAlan Stern
This patch (as1405) fixes a small bug in ehci-hcd's isochronous scheduler. Not all EHCI controllers are PCI, and the code shouldn't assume that they are. Instead, introduce a special flag for controllers which need to delay iso scheduling for full-speed devices beyond the scheduling threshold. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> CC: David Brownell <david-b@pacbell.net> CC: stable <stable@kernel.org> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2010-08-10USB: add do_wakeup parameter for PCI HCD suspendAlan Stern
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend method used by PCI-based host controller drivers. ehci-hcd in particular needs to know whether or not to enable wakeup when suspending a controller. Although that information is currently available through device_may_wakeup(), when support is added for runtime suspend this will no longer be true. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: EHCI: EHCI 1.1 addendum: Basic LPM feature supportAlek Du
With this patch, the LPM capable EHCI host controller can put device into L1 sleep state which is a mode that can enter/exit quickly, and reduce power consumption. Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com> Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: EHCI: fix controller wakeup flag settings during suspendAlan Stern
This patch (as1380) fixes a bug in the wakeup settings for EHCI host controllers. When the controller is suspended, if it isn't enabled for remote wakeup then we have to turn off all the port wakeup flags. Disabling PCI PME# isn't good enough, because some systems (Intel) evidently use alternate wakeup signalling paths. In addition, the patch improves the handling of the Intel Moorestown hardware by performing various power-up and power-down delays just once instead of once for each port (i.e., the delays are moved outside of the port loops). This requires extra code, but the total delay time is reduced. There are also a few additional minor cleanups. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Ondrej Zary <linux@rainbow-software.org> CC: Alek Du <alek.du@intel.com> CC: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: ehci: Elide I/O watchdog on NEC partsDavid Miller
I've been running with this patch on my Niagara2 boxes for some time and have not seen any ill effects yet. Maybe we can stash this into the USB tree to get exposure for some time in -next and if anything crops up we can simply revert? Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-30USB: work around for EHCI with quirky periodic schedulesOliver Neukum
a quirky chipset needs periodic schedules to run for a minimum time before they can be disabled again. This enforces the requirement with a time stamp and a calculated delay Signed-off-by: Oliver Neukum <oliver@neukum.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: ehci-dbgp,ehci: Allow early or late use of the dbgp deviceJason Wessel
If the EHCI debug port is initialized and in use, the EHCI host controller driver must follow two rules. 1) If the EHCI host driver issues a controller reset, the debug controller driver re-initialization must get called after the reset is completed. 2) The EHCI host driver should ignore any requests to the physical EHCI debug port when the EHCI debug port is in use. The code to check for the debug port was moved from ehci_pci_reinit() to ehci_pci_setup because it must get called prior to ehci_reset() which will clear the debug port registers. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: dbrownell@users.sourceforge.net Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: EHCI: add need_io_watchdog flag to ehci_hcdAlek Du
Basically the io watchdog is only useful for those quirk HCDs. For most good ones, it only brings unnecessary wakeups. At least, I know the Intel EHCI HCDs should turn off the flag. Signed-off-by: Alek Du <alek.du@intel.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-21trivial: fix typo "for for" in multiple filesAnand Gadiyar
trivial: fix typo "for for" in multiple files Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-12USB: EHCI: use the new clear_tt_buffer interfaceAlan Stern
This patch (as1256) changes ehci-hcd and all the other drivers in the EHCI family to make use of the new clear_tt_buffer callbacks. When a Clear-TT-Buffer request is in progress for a QH, the QH is not allowed to be linked into the async schedule until the request is finished. At that time, if there are any URBs queued for the QH, it is linked into the async schedule. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: EHCI: update toggle state for linked QHsAlan Stern
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued for an endpoint whose QH is already in the LINKED state, the QH doesn't get refreshed. As a result, if usb_clear_halt() was called during the time that the QH was linked but idle, the data toggle value in the QH doesn't get reset. The symptom is that after a clear_halt, data gets lost and transfers time out. This problem is starting to show up now because the "ehci-hcd unlink speedups" patch causes QHs with no queued URBs to remain linked for a suitable time. The patch utilizes the new endpoint_reset mechanism to fix the problem. When an endpoint is reset, the new method forcibly unlinks the QH (if necessary) and safely updates the toggle value. This allows qh_update() to be simplified and avoids using usb_device's toggle bits in a rather unintuitive way. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Tested-by: David <david@unsolicited.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: new flag for resume-from-hibernationAlan Stern
This patch (as1237) changes the way the PCI host controller drivers avoid retaining bogus hardware states during resume-from-hibernation. Previously we had reset the hardware as part of preparing to reinstate the memory image. But we can do better now with the new PM framework, since we know exactly which resume operations are from hibernation. The pci_resume method is changed to accept a flag indicating whether the system is resuming from hibernation. When this flag is set, the drivers will reset the hardware to get rid of any existing state. Similarly, the pci_suspend method is changed to remove the pm_message_t argument. It's no longer needed, since no special action has to be taken when preparing to reinstate the memory image. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: move PCI host controllers to new PM frameworkAlan Stern
This patch (as1236) converts the USB PCI power management routines over to the new PM framework. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-07dma-mapping: replace all DMA_31BIT_MASK macro with DMA_BIT_MASK(31)Yang Hongyang
Replace all DMA_31BIT_MASK macro with DMA_BIT_MASK(31) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17USB/PCI: Fix resume breakage of controllers behind cardbus bridgesRafael J. Wysocki
If a USB PCI controller is behind a cardbus bridge, we are trying to restore its configuration registers too early, before the cardbus bridge is operational. To fix this, call pci_restore_state() from usb_hcd_pci_resume() and remove usb_hcd_pci_resume_early() which is no longer necessary (the configuration spaces of USB controllers that are not behind cardbus bridges will be restored by the PCI PM core with interrupts disabled anyway). This patch fixes the regression from 2.6.28 tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12659 [ Side note: the proper long-term fix is probably to just force the unplug event at suspend time instead of doing a plug/unplug at resume time, but this patch is fine regardless - Linus ] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27USB: Fix suspend-resume of PCI USB controllersRafael J. Wysocki
Commit a0d4922da2e4ccb0973095d8d29f36f6b1b5f703 (USB: fix up suspend and resume for PCI host controllers) attempted to fix the suspend-resume of PCI USB controllers, but unfortunately it did that incorrectly and interrupts are left enabled by the USB controllers' ->suspend_late() callback as a result. This leads to serious problems during suspend which are very difficult to debug. Fix the issue by removing the ->suspend_late() callback of PCI USB controllers and moving the code from there to the ->suspend() callback executed with interrupts enabled. Additionally, make the ->resume() callback of PCI USB controllers execute pci_enable_wake(dev, PCI_D0, false) to disable wake-up from the full power state (PCI_D0). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Tested-by: "Jeff Chua" <jeff.chua.linux@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: "Zdenek Kabelac" <zdenek.kabelac@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: don't enable wakeup by default for PCI host controllersAlan Stern
This patch (as1199) changes the initial wakeup settings for PCI USB host controllers. The controllers are marked as capable of waking the system, but wakeup is not enabled by default. It turns out that enabling wakeup for USB host controllers has a lot of bad consequences. As the simplest example, if a USB mouse or keyboard is unplugged immediately after the computer is put to sleep, the unplug will cause the system to wake back up again! We are better off marking them as wakeup-capable and leaving wakeup disabled. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Rafael J. Wysocki <rjw@sisk.pl> CC: David Brownell <david-b@pacbell.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: automatically enable wakeup for PCI host controllersAlan Stern
This patch (as1193b) enables wakeup during initialization for all PCI host controllers, and it removes some code (and comments!) that are no longer needed now that the PCI core automatically initializes wakeup settings for all new devices. The idea is that the bus should initialize wakeup, and the bus glue or controller driver should enable it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: fix up suspend and resume for PCI host controllersAlan Stern
This patch (as1192) rearranges the USB PCI host controller suspend and resume and resume routines: Use pci_wake_from_d3() for enabling and disabling wakeup, instead of pci_enable_wake(). Carry out the actual state change while interrupts are disabled. Change the order of the preparations to agree with the general recommendation for PCI devices, instead of messing around with the wakeup settings while the device is in D3. In .suspend: Call the underlying driver to disable IRQ generation; pci_wake_from_d3(device_may_wakeup()); pci_disable_device(); In .suspend_late: pci_save_state(); pci_set_power_state(D3hot); (for PPC_PMAC) Disable ASIC clocks In .resume_early: (for PPC_PMAC) Enable ASIC clocks pci_set_power_state(D0); pci_restore_state(); In .resume: pci_enable_device(); pci_set_master(); pci_wake_from_d3(0); Call the underlying driver to reenable IRQ generation Add the necessary .suspend_late and .resume_early method pointers to the PCI host controller drivers. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-30USB: fix SB600 USB subsystem hang bugShane Huang
This patch is required for all AMD SB600 revisions to avoid USB subsystem hang symptom. The USB subsystem hang symptom is observed when the system has multiple USB devices connected to it. In some cases a USB hub may be required to observe this symptom. Reported in bugzilla as #11599, the similar patch for SB700 old revision is: commit b09bc6cbae4dd3a2d35722668ef2c502a7b8b093 Reported-by: raffaele <ralfconn@tele2.it> Tested-by: Roman Mamedov <roman@rm.pp.ru> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-19USB: fix SB700 usb subsystem hang bugAndiry Xu
This patch is required for AMD SB700 south bridge revision A12 and A13 to avoid USB subsystem hang symptom. The USB subsystem hang symptom is observed when the system has multiple USB devices connected to it. In some cases a USB hub may be required to observe this symptom. This patch works around the problem by correcting the internal register setting that will help by changing the behavior of the internal logic to avoid the USB subsystem hang issue. The change in the behavior of the logic does not impact the normal operation of the USB subsystem. Reported-by: Volker Armin Hemmann <volker.armin.hemmann@tu-clausthal.de> Tested-by: Volker Armin Hemmann <volker.armin.hemmann@tu-clausthal.de> Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Libin Yang <libin.yang@amd.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: suppress unwanted error messagesAlan Stern
This patch (as1096) fixes an annoying problem: When a full-speed or low-speed device is plugged into an EHCI controller, it fails to enumerate at high speed and then is handed over to the companion controller. But usbcore logs a misleading and unwanted error message when the high-speed enumeration fails. The patch adds a new HCD method, port_handed_over, which asks whether a port has been handed over to a companion controller. If it has, the error message is suppressed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix up root-hub TT messAlan Stern
This patch (as1095) cleans up the HCD glue and several of the EHCI bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it means the same thing as the hcd->has_tt flag, so it is removed and the other flag used in its place. Some of the bus-glue files didn't get the relinquish_port method added to their hc_driver structures. Although that routine currently doesn't do anything for controllers with an integrated TT, in the future it might. So the patch adds it where it is missing. Lastly, some of the bus-glue files have erroneous entries for their hc_driver's suspend and resume methods. These method pointers are specific to PCI and shouldn't be used otherwise. (The patch also includes an invisible whitespace fix.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-04-24USB: fix compile problems in ehci-hcdAlan Stern
This patch (as1072) fixes some recently-introduced compile problems that show up in ehci-hcd when CONFIG_PM is turned off. PORT_WAKE_BITS needs to be defined always. ehci_port_power() is called during initialization by all the EHCI variants other than the PCI version, in which it is "defined but not used". So add a call to it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: HCDs use the do_remote_wakeup flagAlan Stern
When a USB device is suspended, whether or not it is enabled for remote wakeup depends on the device_may_wakeup() setting. The setting is then saved in the do_remote_wakeup flag. Later on, however, the device_may_wakeup() value can change because of user activity. So when testing whether a suspended device is or should be enabled for remote wakeup, we should always test do_remote_wakeup instead of device_may_wakeup(). This patch (as1076) makes that change for root hubs in several places. The patch also adjusts uhci-hcd so that when an autostopped controller is suspended, the remote wakeup setting agrees with the value recorded in the root hub's do_remote_wakeup flag. And the patch adjusts ehci-hcd so that wakeup events on selectively suspended ports (i.e., the bus itself isn't suspended) don't turn on the PME# wakeup signal. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: clarify usage of hcd->suspend/resume methodsAlan Stern
The .suspend and .resume method pointers in struct usb_hcd have not been fully understood by host-controller driver writers. They are meant for use with PCI controllers; other platform-specific drivers generally should not refer to them. To try and clarify matters, this patch (as1065) renames those methods to .pci_suspend and .pci_resume. It eliminates corresponding dead code and bogus references in the ohci-ssb and u132-hcd drivers. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: root hubs don't lie about their number of TTsAlan Stern
Currently EHCI root hubs enumerate with a bDeviceProtocol code indicating that they possess a Transaction Translator. However the vast majority of controllers do not; they rely on a companion controller to handle full- and low-speed communications. This patch (as1064) changes the root-hub device descriptor to match the actual situation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: EHCI: carry out port handover during each root-hub resumeAlan Stern
This patch (as1044) causes EHCI port handover for non-high-speed devices to occur during every root-hub resume, not just in cases where the controller lost power or was reset. This is necessary because: When some machines go into suspend, they remove power from on-board USB devices while retaining suspend current for USB controllers. The user might well unplug a USB device while the system is suspended and then plug it back in before resuming. A corresponding change is made to the core resume routine; now high-speed root hubs will always be resumed when the system wakes up, even if they were suspended before the system went to sleep. If this weren't done then EHCI port handover wouldn't work, since it is called when the EHCI root hub is resumed. Finally, a comment is added to the hub driver explaining the khubd has to be freezable; if it weren't frozen then it could interfere with port handover. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: ehci: stop vt6212 bus hoggingRene Herman
The VIA VT6212 defaults to only waiting 1us between passes over EHCI's async ring, which hammers PCI badly ... and by preventing other devices from accessing the bus, causes problems like drops in IDE throughput, a problem that's been bugging users of those chips for several years. A (partial) datasheet for this chip eventually turned up, letting us see how to make it use a VIA-specific register to switch over to the the normal 10us value instead, as suggested by the EHCI specification Solution noted by Lev A. Melnikovsky. It's not clear whether this register exists on other VIA chips; we know that it's ineffective on the vt8235. So this patch only applies to chips that seem to be incarnations of the (discrete) vt6212. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Lev A. Melnikovsky <melnikovsky@mail.ru> Tested-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: EHCI: add separate IAA watchdog timerAlan Stern
This patch (as1028) was mostly written by David Brownell; I made only a few changes (extra log info and a small bug fix -- which might account for why David's version had to be reverted). It adds a new watchdog timer to the ehci-hcd driver to be used exclusively for detecting lost or missing IAA notifications. Previously a shared timer had been used, which may have led to some problems as reported by Christian Hoffmann. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: force handover port to companion when hub_port_connect_change failsBalaji Rao
This patch hands over the port to the companion when the hub_port_connect_change fails. Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: EHCI restart speedupMarcelo Tosatti
It is not necessary to powerdown the ports on ehci_pci_reinit() when the chip reset already did that. Removing this saves 20ms during restart after poweroff paths (which OLPC uses a lot). To ensure driver startup then behaves consistently, force a reset during driver startup. (Not doing this was an accident of some previous changes to the init sequence.) Make the corresponding change in the PS3 support. It's not clear what ehci-fsl should do here; it has similar code to the PS3. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <rvinson@mvista.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: EHCI, OHCI: handover changesAlan Stern
This patch (as887) changes the way ehci-hcd and ohci-hcd handle a loss of VBUS power during suspend. In order for the USB-persist facility to work correctly, it is necessary for low- and full-speed devices attached to a high-speed port to be handed back to the companion controller during resume processing. This entails three changes: adding code to ehci-hcd to perform the handover, removing code from ohci-hcd to turn off ports during root-hub reinit, and adding code to ohci-hcd to turn on ports during PCI controller resume. (Other bus glue resume methods for platforms supporting high-speed controllers would need a similar change, if any existed.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: Implement support for EHCI with big endian MMIOBenjamin Herrenschmidt
This patch implements supports for EHCI controllers whose MMIO registers are big endian and enables that functionality for the Toshiba SCC chip. It does _not_ add support for big endian in-memory data structures as this is not needed for that chip and I hope it will never be. The guts of the patch are to convert readl(...) to ehci_readl(ehci, ...) and similarly for register writes. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01EHCI: Fix root-hub and port suspend/resume problemsAlan Stern
This patch (as738b) fixes numerous problems in the controller/root-hub suspend/resume/remote-wakeup support in ehci-hcd: The bus_resume() routine should wake up only the ports that were suspended by bus_suspend(). Ports that were already suspended should remain that way. The interrupt mask is used to detect loss of power in the bus_resume() routine (if the mask is 0 then power was lost). However bus_suspend() always sets the mask to 0. Instead the mask should retain its normal value, with port-change-detect interrupts disabled if remote wakeup is turned off. The interrupt mask should be reset to its correct value at the end of bus_resume() regardless of whether power was lost. bus_resume() reinitializes the operational registers if power was lost. However those registers are not in the aux power well, hence they can lose their values whenever the controller is put into D3. They should always be reinitialized. When a port-change interrupt occurs and the root hub is suspended, the interrupt handler should request a root-hub resume instead of starting up the controller all by itself. There's no need for the interrupt handler to request a root-hub resume every time a suspended port sends a remote-wakeup request. The pci_resume() method doesn't need to check for connected ports when deciding whether or not to reset the controller. It can make that decision based on whether Vaux power was maintained. Even when the controller does not need to be reset, pci_resume() must undo the effect of pci_suspend() by re-enabling the interrupt mask. If power was lost, pci_resume() must not call ehci_run(). At this point the root hub is still supposed to be suspended, not running. It's enough to rewrite the command register and set the configured_flag. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
