path: root/drivers/usb/host/ehci-w90x900.c
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-24host: ehci-w90x900: fix error return codeJulia Lawall
Return a negative error code on failure. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier ret; expression e1,e2; @@ ( if (\(ret < 0\|ret != 0\)) { ... return ret; } | ret = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-07host: ehci-w90x900: remove duplicate check on resourceVarka Bhadram
Sanity check on resource happening with devm_ioremap_resource(). Signed-off-by: Varka Bhadram <varkab@cdac.in> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20usb: host: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-12-18USB: ehci-w90x900: Use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08usb: hcd: move controller wakeup setting initialization to individual driverPeter Chen
Individual controller driver has different requirement for wakeup setting, so move it from core to itself. In order to align with current etting the default wakeup setting is enabled (except for chipidea host). Pass compile test with below commands: make O=outout/all allmodconfig make -j$CPU_NUM O=outout/all drivers/usb Signed-off-by: Peter Chen <peter.chen@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26USB: EHCI: make ehci-w90X900 a separate driverManjunath Goudar
Separate the W90X900(W90P910) on-chip host controller driver from ehci-hcd host code so that it can be built as a separate driver module. This work is part of enabling multi-platform kernels on ARM; however, note that other changes are still needed before W90X900(W90P910) can be booted with a multi-platform kernel and an ehci driver that only works on one of them. With the infrastructure added by Alan Stern in patch 3e0232039 "USB: EHCI: prepare to make ehci-hcd a library module", we can avoid this problem by turning a bus glue into a separate module, as we do here for the w90X900 bus glue. This patch is rebased on greghk/usb-next 3.12 rc1. Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org> Signed-off-by: Deepak Saxena <dsaxena@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-23Revert "Revert "USB: EHCI: support running URB giveback in tasklet context""Greg Kroah-Hartman
This reverts commit 3b8d7321ed4b8511e17048303b806ffcc2806077, which brings back commit 428aac8a81058e2303677a8fbf26670229e51d3a as it should be working for the 3.13-rc1 merge window now that Alan's other fixes are here in the tree already. Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-17Revert "USB: EHCI: support running URB giveback in tasklet context"Greg Kroah-Hartman
This reverts commit 428aac8a81058e2303677a8fbf26670229e51d3a. This isn't quite ready for 3.12, we need some more EHCI driver changes that are just now showing up. So revert this for now, and queue it up later for 3.13. Reported-by: Alan Stern <stern@rowland.harvard.edu> Cc: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12USB: EHCI: support running URB giveback in tasklet contextMing Lei
All 4 transfer types can work well on EHCI HCD after switching to run URB giveback in tasklet context, so mark all HCD drivers to support it. Also we don't need to release ehci->lock during URB giveback any more. >From below test results on 3 machines(2 ARM and one x86), time consumed by EHCI interrupt handler droped much without performance loss. 1 test description 1.1 mass storage performance test: - run below command 10 times and compute the average performance dd if=/dev/sdN iflag=direct of=/dev/null bs=200M count=1 - two usb mass storage device: A: sandisk extreme USB 3.0 16G(used in test case 1 & case 2) B: kingston DataTraveler G2 4GB(only used in test case 2) 1.2 uvc function test: - run one simple capture program in the below link http://kernel.ubuntu.com/~ming/up/capture.c - capture format 640*480 and results in High Bandwidth mode on the uvc device: Z-Star 0x0ac8/0x3450 - on T410(x86) laptop, also use guvcview to watch video capture/playback 1.3 about test2 and test4 - both two devices involved are tested concurrently by above test items 1.4 how to compute irq time(the time consumed by ehci_irq) - use trace points of irq:irq_handler_entry and irq:irq_handler_exit 1.5 kernel 3.10.0-rc3-next-20130528 1.6 test machines Pandaboard A1: ARM CortexA9 dural core Arndale board: ARM CortexA15 dural core T410: i5 CPU 2.67GHz quad core 2 test result 2.1 test case1: single mass storage device performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 25.280(avg:145,max:772) | 25.540(avg:14, max:75) Arndale board: 29.700(avg:33, max:129) | 29.700(avg:10, max:50) T410: 34.430(avg:17, max:154*)| 34.660(avg:12, max:155) --------------------------------------------------------------------- 2.2 test case2: two mass storage devices' performance test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 15.840/15.580(avg:158,max:1216) | 16.500/16.160(avg:15,max:139) Arndale board: 17.370/16.220(avg:33 max:234) | 17.480/16.200(avg:11, max:91) T410: 21.180/19.820(avg:18 max:160) | 21.220/19.880(avg:11, max:149) --------------------------------------------------------------------- 2.3 test case3: one uvc streaming test - uvc device works well(on x86, luvcview can be used too and has same result with uvc capture) -------------------------------------------------------------------- upstream | patched irq time(us) | irq time(us) -------------------------------------------------------------------- Pandaboard A1: (avg:445, max:873) | (avg:33, max:44) Arndale board: (avg:316, max:630) | (avg:20, max:27) T410: (avg:39, max:107) | (avg:10, max:65) --------------------------------------------------------------------- 2.4 test case4: one uvc streaming plus one mass storage device test -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 20.340(avg:259,max:1704)| 20.390(avg:24, max:101) Arndale board: 23.460(avg:124,max:726) | 23.370(avg:15, max:52) T410: 28.520(avg:27, max:169) | 28.630(avg:13, max:160) --------------------------------------------------------------------- 2.5 test case5: read single mass storage device with small transfer - run below command 10 times and compute the average speed dd if=/dev/sdN iflag=direct of=/dev/null bs=4K count=4000 1), test device A: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 6.5(avg:21, max:64) | 6.5(avg:10, max:24) Arndale board: 8.13(avg:12, max:23) | 8.06(avg:7, max:17) T410: 6.66(avg:13, max:131) | 6.84(avg:11, max:149) --------------------------------------------------------------------- 2), test device B: -------------------------------------------------------------------- upstream | patched perf(MB/s)+irq time(us) | perf(MB/s)+irq time(us) -------------------------------------------------------------------- Pandaboard A1: 5.5(avg:21,max:43) | 5.49(avg:10, max:24) Arndale board: 5.9(avg:12, max:22) | 5.9(avg:7, max:17) T410: 5.48(avg:13, max:155) | 5.48(avg:7, max:140) --------------------------------------------------------------------- * On T410, sometimes read ehci status register in ehci_irq takes more than 100us, and the problem has been reported on the link: http://marc.info/?t=137065867300001&r=1&w=2 Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Geoff Levand <geoff@infradead.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Li Yang <leoli@freescale.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-24usb: "ehci-w90x900" Fix a typo and add some whitespace.Justin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-12-08usb: Remove ehci_reset call from ehci_runGeoff Levand
Remove the ehci_reset() call done in the ehci_run() routine of the USB EHCI host controller driver and add an ehci_reset() call to the probe processing of all EHCI platform drivers that do not already call ehci_reset(). The call to ehci_reset() from ehci_run() was problematic for several platform drivers, and unnecessary for others. This change moves the decision to call ehci_reset() at driver startup to the platform driver code. Signed-off-by: Geoff Levand <geoff@infradead.org> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-03USB: EHCI: Support controllers with big endian capability regsJan Andersson
The two first HC capability registers (CAPLENGTH and HCIVERSION) are defined as one 8-bit and one 16-bit register. Most HC implementations have selected to treat these registers as part of a 32-bit register, giving the same layout for both big and small endian systems. This patch adds a new quirk, big_endian_capbase, to support controllers with big endian register interfaces that treat HCIVERSION and CAPLENGTH as individual registers. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-30usb: Add in missing EHCI helpers.Paul Mundt
Several of the EHCI glue drivers either predate or were merged in the same timeframe as API changes at the USB core level, resulting in some missing endpoint_reset and clear_tt_buffer_complete callbacks. This fixes up all of ehci-atmel, mxc, w90x900, and xilinx-of to tie in the new helpers, which brings them in line with everyone else. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: Add nuvoton Ehci driver for w90p910 platformWan ZongShun
Add ehci support for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
