path: root/drivers/usb/host/fhci-tds.c
2012-06-26USB: FHCI: Reusing QUICC Engine USB Controller registers from immap_qe.hGuilherme Maciel Ferreira
The struct fhci_regs (in drivers/usb/host/fhci.h) is basically a redefinition of the struct qe_usb_ctlr (in arch/powerpc/include/asm/immap_qe.h). The qe_usb_ctlr struct is preferrable once it uses accurately the registers' names found in the Freescale's QUICC Engine Block Reference Manuals (QEIWRM.pdf Rev.4.4 Chapter 19 for MPC836xE series and MPC8323ERM.pdf Rev.2 Chapter 36 for MPC832xE series), making easier to map the FHCI device driver to the hardware manual. Also, as the FHCI driver uses the USB Controller registers, the name qe_usb_ctlr is a more precise representation of the hardware than fhci_regs. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18usb: Fix various typo within usbMasanari Iida
Correct spelling typo within usb Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-01-03drivers: fix comment typo diable -> disable.Justin P. Mattock
The below patch fixes a typo "diable" to "disable" and also fixes another typo in a comment. Please let me know if this is correct or not. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20USB: make hcd.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hcd.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16USB: FHCI: Fix build after kfifo reworkAnton Vorontsov
After kfifo rework FHCI fails to build: CC drivers/usb/host/fhci-tds.o drivers/usb/host/fhci-tds.c: In function 'fhci_ep0_free': drivers/usb/host/fhci-tds.c:108: error: used struct type value where scalar is required drivers/usb/host/fhci-tds.c:118: error: used struct type value where scalar is required drivers/usb/host/fhci-tds.c:128: error: used struct type value where scalar is required This is because kfifos are no longer pointers in the ep struct. So, instead of checking the pointers, we should now check if kfifo is initialized. Reported-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-22kfifo: move struct kfifo in placeStefani Seibold
This is a new generic kernel FIFO implementation. The current kernel fifo API is not very widely used, because it has to many constrains. Only 17 files in the current 2.6.31-rc5 used it. FIFO's are like list's a very basic thing and a kfifo API which handles the most use case would save a lot of development time and memory resources. I think this are the reasons why kfifo is not in use: - The API is to simple, important functions are missing - A fifo can be only allocated dynamically - There is a requirement of a spinlock whether you need it or not - There is no support for data records inside a fifo So I decided to extend the kfifo in a more generic way without blowing up the API to much. The new API has the following benefits: - Generic usage: For kernel internal use and/or device driver. - Provide an API for the most use case. - Slim API: The whole API provides 25 functions. - Linux style habit. - DECLARE_KFIFO, DEFINE_KFIFO and INIT_KFIFO Macros - Direct copy_to_user from the fifo and copy_from_user into the fifo. - The kfifo itself is an in place member of the using data structure, this save an indirection access and does not waste the kernel allocator. - Lockless access: if only one reader and one writer is active on the fifo, which is the common use case, no additional locking is necessary. - Remove spinlock - give the user the freedom of choice what kind of locking to use if one is required. - Ability to handle records. Three type of records are supported: - Variable length records between 0-255 bytes, with a record size field of 1 bytes. - Variable length records between 0-65535 bytes, with a record size field of 2 bytes. - Fixed size records, which no record size field. - Preserve memory resource. - Performance! - Easy to use! This patch: Since most users want to have the kfifo as part of another object, reorganize the code to allow including struct kfifo in another data structure. This requires changing the kfifo_alloc and kfifo_init prototypes so that we pass an existing kfifo pointer into them. This patch changes the implementation and all existing users. [akpm@linux-foundation.org: fix warning] Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27USB: Driver for Freescale QUICC Engine USB Host ControllerAnton Vorontsov
This patch adds support for the FHCI USB controller, as found in the Freescale MPC836x and MPC832x processors. It can support Full or Low speed modes. Quite a lot the hardware is doing by itself (SOF generation, CRC generation and checking), though scheduling and retransmission is on software's shoulders. This controller does not integrate the root hub, so this driver also fakes one-port hub. External hub is required to support more than one device. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
