commit 17d3e145a4ad680b3d1b1c30d0696a5bbb2b65c4 upstream.
Signed-off-by: Arvid Brodin <arvid.brodin@enea.com>
Both control and bulk transfers use isp1760 slots of type ATL, but the
driver unlink code for ATL slots only acts on urbs describing a bulk
transfer, letting the code for INT slots take care of the unlink instead,
which often ended up removing the interrupt transfer for root hub events
instead. That's not good, and gets fixed by this patch.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Use skip map to avoid spurious interrupts from unlinked transfers.
Also changes to urb_dequeue() and endpoint_disable() to avoid
release of spinlock in uncertain state.
Preparation for patch #2. The function isp1760_endpoint_disable() does almost
the same thing as urb_dequeue(). In patch #2 I change these to use a common
helper function instead of calling each other - for clarity but also to
avoid releasing the spinlock while in a "questionable" state. It seemed
proper to have these functions close to each other in the code.
This patch replaces the code that handles qtds. Intead of directly allocating
chip mem and chip slot, enqueue the transfer in a list of queue heads. Use
a centralized function enqueue_qtds() to prioritize and enqueue transfers.
This removes all of the interrupt context BUG() calls when out of chip
mem or transfer slots. It also makes it possible to efficiently use the
dual-port mem on the chip for double-buffered transfers, which improve
transfer times to/from/between usb sticks by about 40 % on my HW.
With this patch it should also be possible to handle qtd scheduling outside
of the interrupt handler, for significantly improved kernel latency. I have
not implemented this since there are some locking issues which I haven't
had time to look at.
This fixes a bug in my previous (2.6.38) patch series which caused
urb->status value to be wrong after unlink (broke usbtest 11, 12).
Since we always set the OR flag for each transfer, we can just as well set all
these bits to 1 at init and be done with it. Also, HcBufferStatus can be set
at init as per the ISP1761 datasheet page 47 with no loss of performance.
This collects urb enqueue code that was spread out all over the place
into a couple of more readable functions.
This removes the "qh is 0" printout. qh == NULL if the urb has
been unlinked, so this condition is normal.
This reverts commit 5808544690300071f09eef9ab83a0fb1f60cf1cd.
To quote Richard:
I don't think this should be mainlined. It was a
misunderstanding on my part. If you see all the other hdc
drivers in the same location, they all do the same thing (i.e.
clear the interrupt status first, then do the work) that
"glitch" I think I saw was actually two back-to-back
interrupts.
Sebastian (the original author of isp1760) explained it to me a
few days after my submission.
sorry for the confusion
Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
This patch moves the HcInterrupt register write to clear the
pending interrupt to after the isr work is done, doing this removes
glitches in the irq line.
Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
Fix printk format build warning and grammar typo on same line.
drivers/usb/host/isp1760-hcd.c:300: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'size_t'
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly
different hub descriptor than USB 2.0 hubs, with a fixed (rather than
variable length) size. Change the USB core's hub descriptor to have a
union for the last fields that differ. Change the host controller drivers
that access those last fields (DeviceRemovable and PortPowerCtrlMask) to
use the union.
Translate the new version of the hub port status field into the old
version that khubd understands. (Note: we need to fix it to translate the
roothub's port status once we stop converting it to USB 2.0 hub status
internally.)
Add new code to handle link state change status. Send out new control
messages that are needed for USB 3.0 hubs, like Set Hub Depth.
This patch is a modified version of the original patch submitted by John
Youn. It's updated to reflect the removal of the "bitmap" #define, and
change the hub descriptor accesses of a couple new host controller
drivers.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: "Robert P. J. Day" <rpjday@crashcourse.ca>
Cc: Max Vozeler <mvz@vozeler.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Lothar Wassmann <LW@KARO-electronics.de>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Martin Fuzzey <mfuzzey@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Using a #define to redefine a common variable name is a bad thing,
especially when the #define is in a header. include/linux/usb/hcd.h
redefined bitmap to DeviceRemovable to avoid typing a long field in the
hub descriptor. This has unintended side effects for files like
drivers/usb/core/devio.c that include that file, since another header
included after hcd.h has different variables named bitmap.
Remove the bitmap #define and replace instances of it in the host
controller code. Cleanup the spaces around function calls and square
brackets while we're at it.
This fixes a problem with my previous patch series where there's a great
risk that the kernel will crash when unplugging interrupt devices from
the USB port. These lines must have got missing when I rebased the
patches from the older kernel I was working with to 2.6.37 and 2.6-next:
This fixes a bug where the kernel may crash if you unplug a USB device
that has active interrupt transfers.
Remove redundant "toggle" member from struct isp1760_qtd, and store toggle
status in struct isp1760_qh only.
Replace the period calculation for INT packets with something readable. Seems
to fix a rare bug with quickly repeated insertion/removal of several USB
devices simultaneously (hub control INT packets).
Consolidate printouts to use dev_XXX functions instead of an assortment of
printks and driver specific macros. Remove some unused code snippets and struct
members. Remove some unused function parameters and #defines. Change the
"queue_entry" variable name which has different but related meanings in
different places and use "slot" only.
Encapsulate payload addresses within qtds.
Removes the redundant hw_next list pointer from struct isp1760_qtd, removes some
unused #defines, removes redundant "urb" member from struct inter_packet_info.
This helps users with platform-bus-connected isp176xs, big-endian cpu,
and missing byteswapping on the data bus. It does so by collecting all
SW byteswaps in one place and also fixes a bug with non-32-bit io
transfers on this hardware, where payload has to be byteswapped
instead of ptds.
The document says:
|2.1 Problem description
| When at least two USB devices are simultaneously running, it is observed that
| sometimes the INT corresponding to one of the USB devices stops occurring. This may
| be observed sometimes with USB-to-serial or USB-to-network devices.
| The problem is not noticed when only USB mass storage devices are running.
|2.2 Implication
| This issue is because of the clearing of the respective Done Map bit on reading the ATL
| PTD Done Map register when an INT is generated by another PTD completion, but is not
| found set on that read access. In this situation, the respective Done Map bit will remain
| reset and no further INT will be asserted so the data transfer corresponding to that USB
| device will stop.
|2.3 Workaround
| An SOF INT can be used instead of an ATL INT with polling on Done bits. A time-out can
| be implemented and if a certain Done bit is never set, verification of the PTD completion
| can be done by reading PTD contents (valid bit).
| This is a proven workaround implemented in software.
Russell King run into this with an USB-to-serial converter. This patch
implements his suggestion to enable the high frequent SOF interrupt only
at the time we have ATL packages queued. It goes even one step further
and enables the SOF interrupt only if we have more than one ATL packet
queued at the same time.
Cc: <stable@kernel.org> # [2.6.35.x, 2.6.36.x, 2.6.37.x]
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The ISP1760 has some timing requirements where it has to delay a short
period after a write to a register has started. However, this delay is
from the time the write hits the USB chip (the ISP1760), not from the
time where the processor started processing the write. So on a quick
enough processor, it is sometimes possible for the write to not hit the
device before we start delaying, and we then violate the part's timing
requirements, so things stop working.
To avoid all this, insert a write barrier after the register write and
before the timing delay/register read so we can guarantee we only start
counting time after the write has hit the device.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
There were some reports[1] of isp1760 USB driver malfunctioning
with high speed devices, noticed on Blackfin and PowerPC targets.
These reports indicated that the original Philips 'pehcd'[2]
driver worked fine.
We've noticed the same issue with an ARM RealView platform. This
happens under load (with only some mass storage devices, not all,
just as in another report[3]):
error bit is set in DW3
usb 1-1.2: device descriptor read/64, error -32
It appears that the 'pehcd' driver checks the X bit only if the
transaction is halted (H bit), otherwise the error is so far
insignificant.
The ISP176x chips were modeled after EHCI, and EHCI spec says
(thanks to Alan Stern for pointing out):
"Transaction errors cause the status field to be updated to reflect
the type of error, but the transaction continues to be retried until
the Active bit is set to 0. When the error counter reaches 0, the
Halt bit is set and the Active bit is cleared."
So, just as the original Philips driver, isp1760 must report the
error only if the transaction error and the halt bits are set.
[1] http://markmail.org/message/lx4qrlbrs2uhcnly
[2] svn co svn://sources.blackfin.uclinux.org/linux-kernel/trunk/drivers/usb/host -r 5494
See pehci.c:pehci_hcd_update_error_status().
[3] http://blackfin.uclinux.org/gf/tracker/5148
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This patch (as1349b) clears up the confusion in many USB host
controller drivers between port features and port statuses. In mosty
cases it's true that the status bit is in the position given by the
corresponding feature value, but that's not always true and it's not
guaranteed in the USB spec.
There's no functional change, just replacing expressions of the form
(1 << USB_PORT_FEAT_x) with USB_PORT_STAT_x, which has the same value.
This patch (as1348) removes the bogus
USB_PORT_FEAT_{HIGHSPEED,SUPERSPEED} symbols from ch11.h. No such
features are defined by the USB spec. (There is a PORT_LOWSPEED
feature, but the spec doesn't mention it except to say that host
software should never use it.) The speed indicators are port
statuses, not port features.
As a temporary workaround for the xhci-hcd driver, a fictional
USB_PORT_STAT_SUPER_SPEED symbol is added.
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
When the HDC driver writes the data to the transfer buffers it pollutes
the D-cache (unlike DMA drivers where the device writes the data). If
the corresponding pages get mapped into user space, there are no
additional cache flushing operations performed and this causes random
user space faults on architectures with separate I and D caches
(Harvard) or those with aliasing D-cache.
Cc: Matthew Dharm <mdharm-kernel@one-eyed-alien.net>
Cc: Greg KH <greg@kroah.com>
Cc: Oliver Neukum <oliver@neukum.org>
This error message is not actually an error, it's an information
message. It is triggered when a transfer which ended in a NAQ is
retried successfully by the hardware.
Signed-off-by: Colin Tuckley <colin.tuckley@arm.com>
Platform device support was merged earlier, but support for boards to
customize the devflags aspect of the controller was not. We want this on
Blackfin systems to control the bus width, but might as well expose all of
the fields while we're at it.
Signed-off-by: Bryan Wu <cooloney@kernel.org>
The option driver (and presumably others) allocates several URBs when it
opens and tries to free them when it closes. The isp1760_urb_dequeue
function gets called, but the packet being dequeued is not necessarily at
the
front of one of the 32 queues. If not, the isp1760_urb_done function doesn't
get called for the URB and the process trying to free it hangs forever on a
wait_queue. This patch does two things. If the URB being dequeued has others
queued behind it, it re-queues them. And it searches the queues looking for
the URB being dequeued rather than just looking at the one at the front of
the queue.
[bigeasy@linutronix] whitespace fixes, reformating
Cc: stable <stable@kernel.org>
Signed-off-by: Warren Free <wfree@ipmn.com>
The data read from the SKIPMAP registers is not immediately available
after writing and the driver panics when a packet is enqueued from the
interrupt handler. This patch adds an ndelay(195) before these registers
are read (delay value mentioned in section 15.1.1.3 of the ISP1760 data
sheet).
The base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
The patch changes the prototype of the isp1760_register() function to use
predefined types like phys_addr_t and resource_size_t rather than u64
There is no need to disable port 1 on ISP1761. That port could
be used as an OTG port which would require a different init
sequence. However we don't have OTG support (yet) so we can use
it as a normal USB port.
This patch allows port 1 to be used a normal Port on the ISP1761.
Signed-off-by: Thomas Hommel <Thomas.Hommel@gefanuc.com>
Signed-off-by: Enrico Scholz <enrico.scholz@sigma-chemnitz.de>
Acked-by: Sebastian Siewior <sebastian@breakpoint.cc>
According to Alan Stern, short packets are quite normal under
certain circumstances. This printk was triggered by usb to
serial converters on every packet and some usb sticks triggered
a few of those while plugging the stick.
This printks are now hidden unless USB debug mode is activated.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
ISP1760 requires a delay of 90ns between programming the address and
reading the data. Current driver solves this by a mdelay(1) which is
very heavy weighted and slow. This patch applies the workaround from
the ISP1760 FAQ by using two different banks for PTD and payload data
and using a common wait for them. This wait is done by an additional
ISP1760 access (whose timing constraints guarantee the 90ns delay).
This improves speed when reading from an USB stick from:
$ time dd if=/dev/sda of=/dev/zero bs=65536 count=1638
real 1m 15.43s
user 0m 0.44s
sys 0m 39.46s
to
real 0m 18.53s
user 0m 0.16s
sys 0m 12.97s
[bigeasy@linutronix.de: fixed comment formating, moved define into
header file, obey 80 char rule]
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
if the enqueue function returns -ESHUTDOWN or -ENOMEM then
we return 0 instead of an error. This leads to a timeout and
then to a dequeue request of an not enqueued urb.
This adds support for hardware configurations that don't match the
chip default register settings (e.g., 16-bit data bus, DACK and
DREQ pulled up instead of down, analog overcurrent mode).
These settings are passed in via the OF device tree. The PCI
interface still assumes the same default values.
Signed-off-by: Nate Case <ncase@xes-inc.com>
Acked-by: Olof Johansson <olof@lixom.net>
This patch makes the following needlessly global functions static:
- enqueue_an_ATL_packet()
- enqueue_an_INT_packet()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Sebastian Siewior <bigeasy@linutronix.de>
The bus_id field is going away, use the dev_set_name() function
to set it properly.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This fixes the bogus "io mem 0x00000000" message printed
during driver init due to hcd->rsrc_start being assigned after
the call to usb_add_hcd().
Fix printk format warnings in isp1760 (in linux-next):
next-20080430/drivers/usb/host/isp1760-hcd.c:994: warning: format '%d' expects type 'int', but argument 6 has type 'size_t'
next-20080430/drivers/usb/host/isp1760-hcd.c:1092: warning: format '%d' expects type 'int', but argument 3 has type 'size_t'
This driver has been written from scratch and supports the ISP1760. ISP1761
might (should) work as well but the OTG isn't supported. Also ISO packets are
not. However, it works on my little PowerPC board.
