We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Reviewed-by: Felipe Balbi <balbi@ti.com>
The debug routine fill_async_buffer() in ohci-hcd is buggy: It never
produces any output because it forgets to initialize the output buffer
size. Also, the debug routine ohci_dump() has an unused argument.
This patch adds the correct initialization and removes the unused
argument.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
Conditional compilation for debugging is removed in favor of
dynamic debugging. To do so
1. the support for debugfs is always compiled
2. the support for the ancient print_urb debugging aid is removed
Signed-off-by: Oliver Neukum <oneukum@suse.de>
These aren't necessary after switch and if blocks.
dbg() was a very old USB-specific macro that should no longer
be used. This patch removes it from being used in the driver
and uses dev_dbg() instead.
CC: Alan Stern <stern@rowland.harvard.edu>
This patch (as1515) fixes some unavoidably dumb compiler warnings:
CC [M] drivers/usb/renesas_usbhs/mod.o
In file included from drivers/usb/host/ohci-hcd.c:101:0:
drivers/usb/host/ohci-dbg.c: In function ‘fill_registers_buffer’:
drivers/usb/host/ohci-dbg.c:656:2: warning: the comparison will always evaluate as ‘true’ for the address of ‘next’ will never be NULL [-Waddress]
drivers/usb/host/ohci-dbg.c:675:3: warning: the comparison will always evaluate as ‘true’ for the address of ‘next’ will never be NULL [-Waddress]
Instead of trying to fix the macro to work under all cirumstances,
just add a second macro for use in cases where the "next" argument is
the address of a local variable.
Unfortunately the macro cannot be replaced by a real subroutine,
because there's no va_list version of ohci_dbg() or dev_dbg().
This patch (as1500) removes all uses of the objectionable hcd->state
variable from the ohci-hcd family of drivers. It is replaced by a
private ohci->rh_state field, just as in uhci-hcd and ehci-hcd.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
This patch (as1393) converts several of the single-bit fields in
struct usb_hcd to atomic flags. This is for safety's sake; not all
CPUs can update bitfield values atomically, and these flags are used
in multiple contexts.
The flag fields that are set only during registration or removal can
remain as they are, since non-atomic accesses at those times will not
cause any problems.
(Strictly speaking, the authorized_default flag should become atomic
as well. I didn't bother with it because it gets changed only via
sysfs. It can be done later, if anyone wants.)
Reduces string space a bit
Neaten a macro redefine of dbg
Right now we jump through some hoops to get to the struct ohci_hcd
struct in the ohci debugfs files. Remove all of the fun casting around
and just use the pointer directly.
This is needed as the dev pointer in the hcd structure is going away,
and it makes the code simpler and smaller
Cc: David Brownell <dbrownell@users.sourceforge.net>
This patch (as1145) removes the essentially useless driver-version
strings from ehci-hcd, ohci-hcd, and uhci-hcd. It also unifies the
form of the banner lines they display upon loading and adds a missing
test for usb_disabled() to ehci-hcd.
The bus_id field is going away, use the dev_name() function instead.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
power.power_state is scheduled for removal. This patch (as1053)
removes all uses of that field from drivers/usb. Almost all of them
were write-only, the most significant exceptions being sl811-hcd.c and
u132-hcd.c.
Part of this patch was written by Pavel Machek.
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Pavel Machek <pavel@ucw.cz>
We should not have multiple line files in sysfs, this moves the data to
debugfs instead, like the UHCI driver.
Signed-off-by: Tony Jones <tonyj@suse.de>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Convert from class_device to device for drivers/usb/core.
This patch (as975) reorganizes the way ohci-hcd sets urb->status. It
now keeps the information in a local variable until the last moment.
CC: David Brownell <david-b@pacbell.net>
Some versions of GCC recently grew annoying warnings about constants.
This gets rid of that warning from the OHCI driver.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Substitute USB instances of __attribute__ ((unused)) functions with the
newly introduced __maybe_unused.
Signed-off-by: David Rientjes <rientjes@google.com>
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace
(space before tab, at end of line) as well as the obsolete inline changelog.
SLAB_ATOMIC is an alias of GFP_ATOMIC
Signed-off-by: Christoph Lameter <clameter@sgi.com>
As part of the ongoing program to flatten out the HCD bus-glue layer,
this patch (as771b) eliminates the hcpriv, release, and kref fields
from struct usb_bus. hcpriv and release were not being used for
anything worthwhile, and kref has been moved into the enclosing
usb_hcd structure.
Along with those changes, the patch gets rid of usb_bus_get and
usb_bus_put, replacing them with usb_get_hcd and usb_put_hcd.
The one interesting aspect is that the dev_set_drvdata call was
removed from usb_put_hcd, where it clearly doesn't belong. This means
the driver private data won't get reset to NULL. It shouldn't cause
any problems, since the private data is undefined when no driver is
bound.
This teaches OHCI to use the root hub status change (RHSC) IRQ, bypassing
root hub timers most of the time and switching over to the "new" root hub
polling scheme. It's complicated by the fact that implementations of OHCI
trigger and ack that IRQ differently (the spec is vague there).
Avoiding root hub timers helps mechanisms like "dynamic tick" leave the
CPU in lowpower modes for longer intervals.
This simplifies the OHCI root hub suspend logic:
- Uses new usbcore root hub calls to make autosuspend work again:
* Uses a newish usbcore root hub wakeup mechanism,
making requests to khubd not keventd.
* Uses an even newer sibling suspend hook.
- Expect someone always made usbcore call ohci_hub_suspend() before bus
glue fires; and that ohci_hub_resume() is only called after that bus
glue ran. Previously, only CONFIG_USB_SUSPEND promised those things.
(Includes updates to PCI and OMAP bus glue.)
- Handle a not-noticed-before special case during resume from one of
the swsusp snapshots when using "usb-handoff": the controller isn't
left in RESET state. (A bug to fix in the usb-handoff code...)
Also cleans up a minor debug printk glitch, and switches an mdelay over
to an msleep (how did that stick around for so long?).
drivers/usb/host/ohci-dbg.c | 4 ----
drivers/usb/host/ohci-hcd.c | 2 +-
drivers/usb/host/ohci-hub.c | 42 ++++++++++++------------------------------
drivers/usb/host/ohci-mem.c | 1 -
drivers/usb/host/ohci-omap.c | 36 ++++++++++++------------------------
drivers/usb/host/ohci-pci.c | 40 ++++++++--------------------------------
drivers/usb/host/ohci.h | 1 -
7 files changed, 33 insertions(+), 93 deletions(-)
Some OHCI implementations have differences in the way the NDP register
(in roothub_a) reports the number of ports present. This patch allows the
platform specific code to optionally supply the number of ports. The
driver just reads the value at init (if not supplied) instead of reading
it every time its needed (except for an AMD756 bug workaround).
It also sets the value correctly for the ARM pxa27x architecture.
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
This adds type-checking to pm_message_t, so that people can't confuse it
with int or u32. It also allows us to fix "disk yoyo" during suspend (disk
spinning down/up/down).
[We've tried that before; since that cpufreq problems were fixed and I've
tried make allyes config and fixed resulting damage.]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Alexander Nyberg <alexn@telia.com>
This moves a kref into the main hcd structure, which detaches it from
the class device structure.
infrastructure for it.
Let it rip!
