path: root/drivers/usb/host/ohci-dbg.c
2010-08-10USB: convert usb_hcd bitfields into atomic flagsAlan Stern
This patch (as1393) converts several of the single-bit fields in struct usb_hcd to atomic flags. This is for safety's sake; not all CPUs can update bitfield values atomically, and these flags are used in multiple contexts. The flag fields that are set only during registration or removal can remain as they are, since non-atomic accesses at those times will not cause any problems. (Strictly speaking, the authorized_default flag should become atomic as well. I didn't bother with it because it gets changed only via sysfs. It can be done later, if anyone wants.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: Convert concatenated __FILE__ to %s, __FILE__Joe Perches
Reduces string space a bit Neaten a macro redefine of dbg Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: OHCI: use the ohci structure directly in debugfs files.Greg Kroah-Hartman
Right now we jump through some hoops to get to the struct ohci_hcd struct in the ohci debugfs files. Remove all of the fun casting around and just use the pointer directly. This is needed as the dev pointer in the hcd structure is going away, and it makes the code simpler and smaller Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: EHCI, OHCI, UHCI: remove version numbersAlan Stern
This patch (as1145) removes the essentially useless driver-version strings from ehci-hcd, ohci-hcd, and uhci-hcd. It also unifies the form of the banner lines they display upon loading and adds a missing test for usb_disabled() to ehci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: usb dev_name() instead of dev->bus_idKay Sievers
The bus_id field is going away, use the dev_name() function instead. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove dev->power.power_stateAlan Stern
power.power_state is scheduled for removal. This patch (as1053) removes all uses of that field from drivers/usb. Almost all of them were write-only, the most significant exceptions being sl811-hcd.c and u132-hcd.c. Part of this patch was written by Pavel Machek. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: convert ohci debug files to use debugfs instead of sysfsTony Jones
We should not have multiple line files in sysfs, this moves the data to debugfs instead, like the UHCI driver. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Convert from class_device to device for USB coreTony Jones
Convert from class_device to device for drivers/usb/core. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: reorganize urb->status use in ohci-hcdAlan Stern
This patch (as975) reorganizes the way ohci-hcd sets urb->status. It now keeps the information in a local variable until the last moment. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: ohci, fix oddball gcc warningDavid Brownell
Some versions of GCC recently grew annoying warnings about constants. This gets rid of that warning from the OHCI driver. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: use function attribute __maybe_unusedDavid Rientjes
Substitute USB instances of __attribute__ ((unused)) functions with the newly introduced __maybe_unused. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: ohci whitespace/comment fixupsDavid Brownell
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace (space before tab, at end of line) as well as the obsolete inline changelog. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27USB: fix __must_check warnings in drivers/usb/host/Greg Kroah-Hartman
2006-09-27usbcore: trim down usb_bus structureAlan Stern
As part of the ongoing program to flatten out the HCD bus-glue layer, this patch (as771b) eliminates the hcpriv, release, and kref fields from struct usb_bus. hcpriv and release were not being used for anything worthwhile, and kref has been moved into the enclosing usb_hcd structure. Along with those changes, the patch gets rid of usb_bus_get and usb_bus_put, replacing them with usb_get_hcd and usb_put_hcd. The one interesting aspect is that the dev_set_drvdata call was removed from usb_put_hcd, where it clearly doesn't belong. This means the driver private data won't get reset to NULL. It shouldn't cause any problems, since the private data is undefined when no driver is bound. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: OHCI avoids root hub timer pollingDavid Brownell
This teaches OHCI to use the root hub status change (RHSC) IRQ, bypassing root hub timers most of the time and switching over to the "new" root hub polling scheme. It's complicated by the fact that implementations of OHCI trigger and ack that IRQ differently (the spec is vague there). Avoiding root hub timers helps mechanisms like "dynamic tick" leave the CPU in lowpower modes for longer intervals. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] OHCI PM updatesDavid Brownell
This simplifies the OHCI root hub suspend logic: - Uses new usbcore root hub calls to make autosuspend work again: * Uses a newish usbcore root hub wakeup mechanism, making requests to khubd not keventd. * Uses an even newer sibling suspend hook. - Expect someone always made usbcore call ohci_hub_suspend() before bus glue fires; and that ohci_hub_resume() is only called after that bus glue ran. Previously, only CONFIG_USB_SUSPEND promised those things. (Includes updates to PCI and OMAP bus glue.) - Handle a not-noticed-before special case during resume from one of the swsusp snapshots when using "usb-handoff": the controller isn't left in RESET state. (A bug to fix in the usb-handoff code...) Also cleans up a minor debug printk glitch, and switches an mdelay over to an msleep (how did that stick around for so long?). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/ohci-dbg.c | 4 ---- drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/ohci-hub.c | 42 ++++++++++++------------------------------ drivers/usb/host/ohci-mem.c | 1 - drivers/usb/host/ohci-omap.c | 36 ++++++++++++------------------------ drivers/usb/host/ohci-pci.c | 40 ++++++++-------------------------------- drivers/usb/host/ohci.h | 1 - 7 files changed, 33 insertions(+), 93 deletions(-)
2005-09-12[PATCH] USB: OHCI relies less on NDP registerDavid Brownell
Some OHCI implementations have differences in the way the NDP register (in roothub_a) reports the number of ports present. This patch allows the platform specific code to optionally supply the number of ports. The driver just reads the value at init (if not supplied) instead of reading it every time its needed (except for an AMD756 bug workaround). It also sets the value correctly for the ARM pxa27x architecture. Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] USB: move the usb hcd code to use the new class code.gregkh@suse.de
This moves a kref into the main hcd structure, which detaches it from the class device structure. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
