path: root/drivers/usb/host/r8a66597.h
2008-04-24USB: r8a66597-hcd: Add support for SH7366 USB hostYoshihiro Shimoda
R8A66597 is similar to SH7366 USB 2.0 Host/Function module. It can support SH7366 USB host by changing several R8A66597 code. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: r8a66597-hcd: fix usb device connection timingYoshihiro Shimoda
Fix the problem that enumeration of a USB device was slow. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: r8a66597-hcd: fix interrupt transfer intervalYoshihiro Shimoda
This driver ignored the value of bInterval and revised the problem that performed interrupt transfer. ASIX USB Ethernet adapter comes to work with this host controller by applying this patch. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: r8a66597-hcd: fixes some problemYoshihiro Shimoda
This patch incorporates some updates. Updates include: - Fix the problem that control transfer might fail - Change from GFP_KERNEL to GFP_ATOMIC - Clean up some coding style issue Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: r8a66597-hcd: host controller driver for R8A66597Yoshihiro Shimoda
I would like to submit Renesas R8A66597 USB HCD driver. R8A66597 is Renesas USB 2.0 host and peripheral combined controller device originally designed for embedded products. As a limitation of this device, it does not support externel hub more than 2 tier, and cannot communicate with a USB device more than 10. Then this device is not compatible with EHCI and/or OHCI, I wrote driver support patch based on sl811 code. This driver has the following unique specifications: - Implement transfer timeout to share one pipe with plural endpoint. - Detach detection of a USB device connected to externel hub. The driver has been tested external hub, usb-hdd, usb-cdrom, usb-speaker, mice, keyboard, and usbtest driver. Signed-off-by : Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
